HEX-V2 USB interface "No Response From Controller".
Yashar
Plano, Texas, USA
C?ID=361434
Hello Im having a problem with my Vagcom when ever i try to go to specific modules (Although some work others do not). Some background info. I have not used my VCDS for a couple months because i had my car rear ended and it was in the body shop for that time period. Though when i got my car back and tried to code something on a specific module it would not load saying "No Response From Controller". At first i thought maybe I did not plug it in all the way in or the USB port was bad so I tried to search up the problem on YouTube and other forums. Which led me doing variety of things that do not seem to work as they did for others. So now I am stuck on what to do next. if any of y'all have had the same issue or know the fix please enlighten me. Ill give you explanations on what I did so far that did not work. First i tried going to my power options and went to the USB settings and disabled both On battery and Plugged in. That didn't work so I next tried uninstalling VCDS software and reinstalling to the latest version. That did not work either. So I tried on a different computer with windows 10 no result kept saying "No Response From Controller". Next I tried going under Device management to see whether it was under Universal Serial Bus controllers and under Generic USB Hub properties was my VCDS named "HD complaint vendor defined device". So i did find it under my USB but i guess that wasn't the problem but I heard I have to set the device to COM1 but frankly i cant figure how to do it so i just left it to USB. Also when Im first on VCDS and i test it out on USB (not COM1) it says-
port status:ok
interface: Found!
Type: HEX-V2
Status: ready
CAN: OK K1: OK K2: OK
But when i try to open a control module right after I get the text saying can not find controller and then when I test it again it changes from CAN: OK to CAN: TESTING. What to do?
Is it safe to assume that you have car's the ignition turned on?
It might be good if we knew what kind of car this was. Please try to run an Auto-Scan on it and post the result.
For use with a HEX-V2, VCDS should always be set to USB.
Yashar
Plano, Texas, USA
C?ID=361434
Yes the ignition was always turned on. Also heres my auto scan. The car is a Audi A4 2015 b8.5
Thursday,05,September,2019,20:04:28:44748
VIN: WAUBFAFL6FN027582   License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
VIN: WAUBFAFL6FN027582   Mileage: 98700km-61329miles
Address 01: Engine (DET-CPMB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 N    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---
   Coding: 4A2A0013242600062000
   Shop #: WSC 23920 002 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115N 001006
   ROD: EV_ECM20TFS0118K5907115N.rod
   VCID: 3D273B12BDFB422FE1F-8068
   Part No SW: 8K0 927 158 AD    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H19 1004
   Revision: --H19---
   VCID: 78A9EA06D259A707F29-802C
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 2D1D1801
   Shop #: WSC 02391 785 00200
   VCID: 094F9FC2B933AE8F9D7-805C
   Part No SW: 8K0 907 064 KL    HW: 8K0 907 064 KL
   Component: BCM2 2.0      H15 0711
   Coding: 09814040000000000000
   VCID: 04518EF69E11F3E7EE1-8050
   Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
   Serial number: 0817000036231011
   Serial number: 3214000173942005
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01081220140172
   Coding: 6480208000
   VCID: 77ABE93ADFC7A87FFB3-8022
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000960231202
   Coding: 26008091863CAFC00000480300003D0D0F1C5308A2090221000008004000030100000000000000
   VCID: 76B5E43ED8CDD177E05-8022
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA121114  H18 0461
   Serial number: 1411100601201
   Coding: 004577
   Serial number: 20005802
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002211140832
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01D3F2D9
   Serial number: 1F684F57000000000001
   Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NDD12TTB
   Coding: 303844354730383131304A55304C384B3053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4BC365CAF34FFC9F6FB-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R140000LB3Q
   Serial number: 6334MSME4B3C7A6A-
   Serial number: 6344MSME4B3C543CS
   Serial number: 6352QSME06494774I
   Serial number: 6362QSME0E4B1664O
   Serial number: 63732SME054D007C/
   Serial number: 63832SME7A4C2D48H
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NL7001NJ
   Coding: 000016
   VCID: 48C95AC6E2B91787429-801C
   Part No SW: 8K0 920 983 F    HW: 8K0 920 983 F
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 61U54TWCF
   Coding: 8BBF09000301D705020000
   VCID: 38292A0692596707329-806C
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y14C050462
   Coding: 80C303FF00
   VCID: 4ACD60CEFCB5E59754D-801E
   Serial number: 0855995103
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H10 0305
   Coding: 011C03204000410001
   VCID: 56F584BE380DB177C05-8002
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0022240662
   Coding: 100000000001
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 38292A0692D96707329-806C
   Revision: 00002001    Serial number: 0354897478
   Coding: 0106063A00FA400408B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000922852
   Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J245 PS051  H08 0043
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H10 0305
   Coding: 011C03205400410001
   VCID: 55F783B2250BBA6FC9F-8000
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000555716
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D300EACD57517C4D-806E
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156L10E8125284
   Coding: 020007020100000001
   VCID: 2411EE763ED113E78E1-8070
   Part No SW: 8R1 035 746 G    HW: 8R1 035 746 G
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 523LZ0E7510721
   Coding: 0F0200000006A1EC01028B5C00000403140000000000000000
   VCID: 3B23350AA36F4C1FDFB-806E
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Component: DU7 High  H42 0104
   Serial number: A130KN0E3206106
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000002077378
   Component: CD-Database  5950
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H08 0305
   Coding: 010C03204000210001
   VCID: 59EF8F8249139E0FED7-800C
   Component: TSG HR        H08 0305
End----------(Elapsed Time: 01:44, VBatt start/end: 12.3V/12.3V)-----------
Bruce
Near Philadelphia, PA, USA
Thank you for the Autoscan. Looks like the expected list of the modules for your car are responding. Which module are you trying to speak with that is not responding?
Yashar
Plano, Texas, USA
C?ID=361434
07-Head unit. Also some others don’t work either they pop up the same message “No response from controller”. But some work to like 01- Engine
This car has a 5F module. That means there is no module at 07 in this car.
What other modules were you experiencing this issue with? The list of modules actually installed in your car is at the top of your scan.
Yashar
Plano, Texas, USA
C?ID=361434
Hmmmm okay that’s my bad then since I saw all those control modules in VCDS I thought that meant they were compatible with my car. When I get a chance to pop up VCDS later today I’ll be sure to check the other modules with the ones that are listed on top of the scan. Thank you both.
Bruce
Only the installed modules can respond. If you want to verify the full list of the modules installed, contact your dealer. They should be able to pull it the list from their corporate records and tell you which modules are in the build of your car.
Keep in mind that just because a platform supports all these modules, the build of your specific car may not have them all based on the options installed.
Yashar
Plano, Texas, USA
C?ID=361434
Okay I figured it out thank you. I did some more research on the topic. I should have done from the beginning but oh well. It seems to me all the listed control modules for my car are working I’m not getting any controller problems. So I think it was just me being dumb and not researching enough. Thank you both again you both have been great help.
