5Q0 614 517 CF 46 BYTES PLA 3.0 CODING
m.duran
Istanbul, Turkey
C?ID=352356
Trying to upgrade to the 2017 audi A3 pla 3.0. but 03 abs longcoding consists of 46 bytes, I couldn't find which bytes to change. Could you help. sorry for google translation
Thursday,05,September,2019,10:29:51:18632
VIN: WAUZZZ8V8HA090521   License Plate: 34XXXX
Mileage: 26291km-16336mi   Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 5F BB BC
VIN: WAUZZZ8V8HA090521   Mileage: 26291km-16336miles
Address 01: Engine (J623-CHZD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 AB    HW: 04C 907 309 AE
   Component: R3 1.0l TFS   H25 3494
   Revision: W1H25---
   Coding: 02250032230401083000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM10TFS01104C906026AB 002006
   ROD: EV_ECM10TFS_VW37.rod
   VCID: 619E50A631CD268FA57-8034
   CAN Converter 01:
Readiness: 0110 0001
   Part No SW: 0CW 300 040 S    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1004
   Revision: 00005026    Serial number: CU501612067177
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 44D0B9328E1F53A7AE1-8010
   Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
   Component: ESC           H62 0643
   Revision: 00000000    Serial number: 63426000005699
   Coding: 12F16AA22429126C8B7C0E0240C42448562448D1700224730021F0748208420000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_AU37.rod
   VCID: 78A81DC28257C747F29-802C
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0425282748
   Coding: 030C0C
   VCID: 3B22C2CEF3E12C5FDFB-806E
   Part No SW: 8V0 820 043 M    HW: 8V0 820 043 M
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001112247
   Coding: 03000003000000001000000000001000
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 3C20C1D2F6EF2B67D61-8068
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: CC18C16800PAG0MUFU03
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001634301663
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F5AF6DEA779F07FB33-802A
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 160829  043 0580
   Serial number:         160905181913
   Coding: 0A47F7
   Serial number: 62499567
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 28 09 2016  00000685
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417618240
   Coding: 0271061011
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FE8066416DB60F157-8004
13697025 - Control Module
          U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_01.EPS_PLA_Status - PLA-Codierung in Lenkhilfe prüfen]
                    Reset counter: 170
                    Mileage: 26291 km
                    Date: 2019.09.05
                    Time: 10:25:24
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0317
   Serial number: 003TDR2EKAF4
   Coding: 98CCC000000000005C5400CA004800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 107845628AE7FF075A9-8044
   Subsystem 1 - Part No SW: -----------    HW: 480 000 712 16
   Serial number: 35700000000B487D5F1-
   Subsystem 2 - Part No SW: -----------    HW: 480 000 712 16
   Serial number: 358000000000587D5F1R
   Subsystem 3 - Part No SW: -----------    HW: 480 401 012 16
   Serial number: 3510001C922CA562D2CB
   Subsystem 4 - Part No SW: -----------    HW: 480 401 012 16
   Serial number: 3520001C122CA561D582
   Subsystem 5 - Part No SW: -----------    HW: 480 401 211 16
   Serial number: 3550002A922C8EB53207
   Part No SW: 8V0 953 521 JP    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 05121604400904
   Coding: 8418
   VCID: 117E406681EDF60F557-8044
   Part No SW: 8V0 920 872 N    HW: 8V0 920 872 N
   Component: KOMBI         H04 8316
   Coding: 0B8D0A182B8000081601BA001001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009054
   VCID: 48C8AD02B23777C7429-801C
   Part No SW: 3Q0 907 530 B    HW: 3Q0 907 530 B
   Component: GW MQB Mid    417 4286
   Revision: --------    Serial number: 0005634520
   Coding: 030100043F0857005B000248100B00000001010000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 2E04FB9A3093C9F7685-807A
   Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
   Component: J453 MFL  H04 0003
   Serial number: 20161125025749 20416
   Serial number: 75410803001612075678
   Revision: 00000000    Serial number: 16000212777006
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3430E9F2DEBFE3271E1-8060
   Serial number: 251116EKO07236
   Coding: 001C9B204000040000001002
   VCID: 43D2BA2E8B11549F97B-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 0107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 45D6A43685256AAFB9F-8010
   Serial number: 271116EKR01536
   Coding: 001C93204C00040000001002
   VCID: 42DCBF2A940B5D979CD-8016
   Part No SW: 81A 035 824 A    HW: 81A 035 824 A
   Component: MU-S--ER      710 0771
   Coding: 01730300FF00000011110001000A00002F0024940170010002
   ASAM Dataset: EV_MUStd6C3DELP 001013
   ROD: EV_MUStd6C3DELP_AU37.rod
   VCID: 211E10A6714D668FE57-8074
   Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
   Component: DU High  H49 0014
   Serial number: AUZ8Z9GY2094WU
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 8V0 919 614 BB    HW: 8V0 919 614 BB
   Component: ControlUnit_B  H50 0103
   Serial number: ALJAL117101600020120
   Serial number: 211116EKL11476
   Coding: 000C93204000040000001002
   Serial number: 211116EKL11336
End----------(Elapsed Time: 01:09, VBatt start/end: 12.4V/12.4V)-----------
kreativ
Hidden
C?ID=108852
Try this coding in 03 - ABS
12F16AA22429126C8B7C0E0240C42448562448D1700224732021F0748208420000000012121212B835351919323200
PLA 3 is byte 24, bit 5
also remember to code adress 44
new long code
0307
m.duran
Istanbul, Turkey
C?ID=352356
360 degree optical parking works but automatic parking is not active
Thursday,05,September,2019,20:22:49:18632
Mileage: 26296km-16339mi   Repair Order:
VIN: WAUZZZ8V8HA090521   Mileage: 26296km-16339miles
   Revision: W1H25---
   CAN Converter 01:
Readiness: 1110 0001
   Coding: 12F16AA22429126C8B7C0E0240C42448562448D1700224732021F0748208420000000012121212B835351919323200
   Coding: 030C0C
   Coding: 0A47F7
   Coding: 00006C
   Coding: 0270061051
   Coding: 8418
   ROD: EV_GatewNF.rod
   Coding: 0307
End----------(Elapsed Time: 01:09, VBatt start/end: 12.6V/12.6V)-----------
darkchina811
ITALY
C?ID=333184
what do you mean by automatic parking? you have to press the PARK ASSIST button when close to a parking space, to tell the system you want to park (also turn signal needs to be flashing). then follow the instructions on the cluster.
PLA 3.0 is sometimes weird, read the manual and try all the different features with no traffic.
m.duran
Istanbul, Turkey
C?ID=352356
I have experience in using pla 2.0 before. I wonder if something is incompatible
m.duran
Istanbul, Turkey
C?ID=352356
There is no error. The codings are okay, just to select the parking position does not come to the media screen. it must have an encoding
This may not be the answer but post #2 is from a S3 and the #10 coding in significantly different in Byte 3.
m.duran
Istanbul, Turkey
C?ID=352356
No, I tried. I wonder if the pla3.0 unit in this upgrade. canH canL cables should carry another network.
darkchina811
ITALY
C?ID=333184
my Golf was born with PARK PILOT, then I retrofitted PLA 2.0, then I upgraded to PLA 3.0. besides adding the extra sensors, replacing the rear ABS sensors, and adding the PLA activation button, it's all coding. the module pinout is the same, the CAN-BUS is indeed the same.
I am perplexed as how you don't get the feature on the cluster with the autoscan showing no errors at all.
if you want to take a look at my conding, it's here:
https://forums.ross-tech.com/showthread.php?19690-MY2017-Golf-1-4-TSI-92kW-BMT-Sport-quot-R-Line-quot-Hatchback-3-doors
Golf7 and Audi A3 8V are both MQB so you might find some inspiration.
Spacewalker
Poland
C?ID=159607
Enable PLA in Cluster
if PLA is not able to display "space" detection on the cluster - it will not show any message
it stay silent , no error , nothing , it will just like you not touch button
OPS is OPS ....
m.duran
Istanbul, Turkey
C?ID=352356
I am grateful to everyone for their ideas. however, VWgolf te pla works on different MFA screens. The AUDI A3 has to come to the media screen. I couldn't find the code for it
m.duran
Istanbul, Turkey
C?ID=352356
It was until 2017 mode. https://youtu.be/enTLlsxQM3o
m.duran
Istanbul, Turkey
C?ID=352356
I solved the problem. 5QA 919 298 D Unit Imp WSC Geraet I have written the numbers as 12345 123 12345 and it works. endless thanks to the love of helping everyone
Spacewalker
Poland
C?ID=159607
Based on that autoscan with PLA 3.0 and Virtual cluster - when you can see PLA is also code in a cluster
Address 01: Engine (J623-DJHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 J    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 0A2500322466010B3004
   ASAM Dataset: EV_ECM20TFS0208V0906259J 001005
   ROD: EV_ECM20TFS0208V0906259J_AU37.rod
   VCID: 479D9026FECC1D7E0B-8012
   Part No SW: 8V0 614 517 C    HW: 8V0 614 517 C
   Component: ESC           H25 0621
   Revision: 00000000    Serial number: 61627000000111
   Coding: 329C938D549A13AA8B930B6D4198694CC92AC8D1D0829677184150B482A812
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   ROD: EV_Brake1UDSContiMK100IPB_035_AU37.rod
   VCID: 3979E6DEB8387B8E8D-806C
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417617145
   Coding: 0370167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   VCID: 50AFBB7A0B82DAC65A-8004
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 8V0 920 790 A    HW: 8V0 920 790 A
   Component: FBenRDW       H16 0066
   Coding: 248D08527F9800080181E8001000000000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001027
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3A7BF9D2BD3E709684-806E
   Part No SW: 8V1 035 041 B    HW: 8V1 035 041
   Component: MU-P-LND-RW   054 1106
   Serial number: A838D0HB004494
   Coding: 017353080000000011511102000A00312F0027E6017001045E
   VCID: 2E53C5827176AC3628-807A
Your car with B/W cluster use this same label file for coding
and you can see - you not enable it
NEtech
Denmark
C?ID=56995
There seems to be some differences between
and
The FPK seems to have Byte 5 Bit 4 Active and Byte 13 Bit 0 NOT Active (maybe PLA2.0)
The VDD seems to have Byte 5 Bit 4 NOT Active and Byte 13 Bit 0 Active
From m.duran
From Spacewalker:
Most Audi A3 (8V) use FPK, I have 2 with VDD (and PLA3.0)
Audi A3 (8V) and with [10] PLA 3.0, 2 first codings is VDD and 2 next are FPK:
m.duran
Istanbul, Turkey
C?ID=352356
I had the chance to test pla 3.0 yesterday. i used pla 2.0 on my vw golf 7 vehicle before. There are a few differences between the audi park area itself chooses (vertical horizontal cross) vw leaves you with the choice. sometimes it is interesting to see horizontally when the distance between the two vehicles in the vertical parking area is wide. and most importantly, the maneuver does not brake. I realized you didn't brake in danger. whereas VW Golf was braking right away. I wonder if there is a lack of coding.
I made a short video of how it works. I think it is very successful to be over mmi in 2017 and beyond.
https://youtu.be/JnEzwuy8d0M
Doing it the right way:
:cool:
