2012 Audi A6 3.0T Canadian Car
AJCO
CANADA
C?ID=378519
Windshield Washer Issue - 2012 Audi A6 3.0T Canadian Car
This may be a dumb question... Just purchased the HEX-V2 and was using it to reset the engine service indicator and confirmed rear E Brake could be electronically disengaged and reengaged before starting the rotor and pad change this coming weekend. Have just noticed tonight the windshield washer sprayer is now not working - although the headlight sprayer is... Could I have disengaged this function in error? Can I check what is going wrong using the HEX-V2?
A.J.
AJCO
CANADA
C?ID=378519
Windshield Washer Issue - 2012 Audi A6 3.0T Canadian Car with Auto Scan Included
ednesday,04,September,2019,20:55:53:25141
Dealer/Shop Name: 00000
VIN: WAUFGCFC2CN063372   License Plate: AUDI
Mileage: 136212km-84638mi   Repair Order: 2
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 15 16 17 19 36 3B 42 44 46 52 53 55
          56 5F 62 72
VIN: WAUFGCFC2CN063372   Mileage: 136212km-84638miles
Address 01: Engine (J623-CGXB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 A    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0010
   Revision: --H07---
   Coding: 0A2A0032052600060000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
   ROD: EV_ECM30TFS0214G0907551A_003.rod
   VCID: 270BFB354F6B376FAB3-8072
6143 - Fan 2 Control Circuit
          P0693 00 [047] - Short to GND
                    Fault Frequency: 79
                    Mileage: 123572 km
                    Date: 2018.07.14
                    Time: 11:32:11
                    Engine speed: 835.00 /min
                    Normed load value: 6.7 %
                    Coolant temperature: 90 °C
                    Intake air temperature: 52 °C
                    Voltage terminal 30: 11.984 V
                    Engine speed: actual: 0 /min
                    MAF_ENVD: 0.00000 mg/stroke
                    Coolant temperature (unfiltered): 53.25 °C
                    Engine: operating status: ES
                    Engine load: 0.000000 %
                    Vehicle speed: actual: 0 km/h
   Part No SW: 4G0 927 158 P    HW: 0BK 927 156 R
   Component: 0BK 30TFSIUSA H17 1006
   Revision: --H17---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 3B233745A3E3838FDFB-806E
   Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
   Component: ESP PREMIUM   H09 0250
   Coding: 44A70F0122E5F0805B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004017
   VCID: 34311C798EBD4CF71E1-8060
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Ldm_ApbFailureState]
                    Reset counter: 84
                    Mileage: 136170 km
                    Date: 2019.09.02
                    Time: 16:18:49
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 22
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 01
                    Uz: 99
   Part No SW: 4H0 907 064 BC    HW: 4H0 907 064 BC
   Component: BCM2 2.0      H31 0330
   Coding: 09883006000000000000
   VCID: 6B83C7059383D30F0FB-803E
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000216881011
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
   Component: KLIMA 2 ZONEN H10 0062
   Serial number: 22091100040184
   Coding: 6681201808
   ASAM Dataset: EV_AirCondiBasisUDS 002037
   ROD: EV_AirCondiBasisUDS_002.rod
   VCID: 2411EC393E5DDC778E1-8070
   Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0100
   Revision: 11012002    Serial number: 00000001073569
   Coding: 06002096063C9FE00100088780003908CF9CD308A2090121800004402000
   VCID: 6E85CE11A0912627285-803A
   Component: WWS57X 110804  H35 0051
   Serial number:         110810001153
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11704205
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 26 09 2011  00000799
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R0P3T02
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA102281000000491275
   Coding: 020300
   Subsystem 6 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H02 0002
   Serial number: B4284BC5000000000001
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 B    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0480
   Revision: 00000007
   VCID: 2C010419560D1437461-8078
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0043
   Revision: 11001001    Serial number: 55901126900414
   Coding: 080105
   ASAM Dataset: EV_EPHVA18AU57X0000 002005
   ROD: EV_EPHVA18AU57X0000_002_AU57.rod
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H31 0032
   Revision: --------    Serial number: 003D8001D87A
   Coding: 30323437313130303035554A304C34473053
   VCID: 33331F658BB34BCF07B-8066
   Serial number: 3575HRB405R0Q3SKCOGP
   Serial number: 3585HRB405D0OPMGFPBL
   Serial number: 3515JRB40630P7AOEHU$
   Serial number: 3525JRB405J0PMKOK0KG
   Serial number: 3554VRB40610M5SODOSQ
   Serial number: 3564VRB40610M5SOJ9PF
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372KIM001ES
   Coding: 000434
   VCID: 382928499255A897329-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Component: E221 - MFL  H08 0009
   Serial number: 06 09 2011  11165458
   Part No SW: 4G8 920 931 C    HW: 4G8 920 931 C
   Component: TBenRdw       H79 0375
   Revision: 26181120    Serial number: 658300911591003
   Coding: 0BA609040B010008020000
   ASAM Dataset: EV_RBD4K 004040
   ROD: EV_RBD4K_AU57.rod
   VCID: 2E050E1160916627685-807A
   Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0213
   Revision: --------    Serial number: 00000000262636
   Coding: 00C1033000
   ROD: EV_GatewUDS_AU57.rod
   VCID: 323D1A6174A942C70CD-8066
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650643993
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000014866967
   Coding: 0058130000002001000001010101102030303232203232
   VCID: 77ABEB75DFCB67EFFB3-8022
   Part No SW: 4G0 907 637     HW: 4G0 907 637
   Component: SARA 3D       H02 0004
   Revision: --------    Serial number: EJ1BPA3200M3BZ0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6B83C7059303D30F0FB-803E
   Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
   Component: TSG FA        H05 0212
   Coding: 011F17204E00620002000002
   Shop #: WSC 02312 785 00200
   VCID: 42DD4AA1C489F2479CD-8016
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0017170328
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0159694388
   Coding: 0106023A00FA440480B00800000500000000000000000000000000000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000050623
   Subsystem 3 - Part No SW: 7P5 959 591     HW: 4H0 959 591
   Component: J245 PS40.033  H07 0006
   Serial number:     WOO13579559
   Coding: 101E00
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   VCID: 41DF45ADC18FE95F857-8014
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000147118
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0D02015C790A07B4D-807E
721152 - Brake Pad Replacement Mode Active
          C1011 00 [000] - -
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 111005-0002-021
   Coding: 1221A6101002A200
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C010419568D1437461-8078
   Part No SW: 4G0 035 082 B    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0076
   Revision: AB001007    Serial number: 156J+0B7557251
   Coding: 020007020100000001
   VCID: 1F1BE3D517BBFFAFD33-804A
   Part No SW: 4G0 035 664 C    HW: 4G0 035 664
   Component: H-BN-NA       H48 0423
   Revision: --------    Serial number: 434J 0B7506292
   Coding: 050200000003E0ED45028B0E00000003F00001020000000000
   VCID: 2615F63148E12E67905-8072
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1301Q5SY
   Subsystem 3 - Part No SW: 4G1 919 610 A    HW: 4G1 919 610 A
   Component: E380 BDT C7  H08 0203
   Serial number: 90349KIN000N8
   Component: CD-Database  3371
02244 - Button in Control Head is Stuck
                    Reset counter: 84
                    Mileage: 136170 km
                    Date: 2019.09.02
                    Time: 14:28:24
                    Voltage: 12.10 V
                    Hex Value: 0x0001
                        not available
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F17204000620002000002
   VCID: 44D14CB9DE9DFC77AE1-8010
   Component: TSG HR        H04 0212
End----------(Elapsed Time: 02:06, VBatt start/end: 13.7V/14.1V)-----------
AJCO
CANADA
C?ID=378519
Thanks - added auto scan
NostraJackAss
Not likely but do you have a scan before you started doing anything with VCDS?
Did you fiddle with any coding configurations?
Did you check the washer pump for the wipers stage with test light during operation or if something is plugged in sprayers?
AJCO
CANADA
C?ID=378519
Unfortunately I didn't before trying the "SRI Reset" to clear the engine reset, which didn't work as I had to clear through a manual function in Select Control Module. After that I performed a scan but the output showed "not able to communicate" in all areas but the radio I believe. The one I provided last night was much clearer. I believe the first one was because the "ignition" has time out.
AJCO
CANADA
C?ID=378519
Jack, appreciate all your help - thank you.
I looked at the fuse outlay and didn't see a separate fuse for the wiper sprayer pump and assumed it was part of the wiper motor assembly fuse, which is functioning?? I did see a fuse for the headlight washer pump and they are functioning. I am not sure what you mean about checking the actual outputs of the washer pump yet using VCDS, is there a process to do that?
Next,I was going visually try and locate the actual pump and see if there is a wire lose or no power when engaged.
Thanks again
A.J.
NostraJackAss
Thanks again
A.J.
Looks like you answered your own question no?
Did you check VCDS outputs 03 for washer pump function in BCM?
