Audi A3 DSG7 OAM DQ200 Harsh down Shift to 3rd
DCTLeigh
Australia
C?ID=350356
Hi, Audi A3 DSG 7 dry clutch.
Vehicle arrived with codes - 05981 = clutch 1 opens unintentionally & 05982 = clutch 1 closes unintentionally.
Shifts from cold start were very poor, slipping clunking. Was 80% better at running temp but not perfect.
Remove trans & replaced clutches, No sign of oil leaks. Order series 1 clutch via vin & installed with Luk special tools , Refit to vehicle warm, preform basic settings & Defined test drive.
when slowing for a corner and the trans shifts down 5-4 And I accelerate out of the corner at normal throttle it thumps harshly back to 3rd. Ive done about 50km driving and redone basic settings 3 x with no improvement.
The upshift in to 5th & 7th are firm, not harsh, nothing the customer would complain about.
And some times the 3 to 4 up shift has a very minor flare like the clutch for 3rd let go before 4th clutch applied - that's being fussy though.
Running temp makes these issues less, They are more obvious from cold start.
There are no codes logging.
Might I have a faulty Mechatronic unit?
Chassis Type: 8P-AU35 (8P0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 47 52 56 61 62 72
          77
VIN: WAUZZZ8P3BA010700   Mileage: 119910km-74508miles
Golftwincharged
Guyana
C?ID=320847
in the mean time you find your auto scan, sounds like you may have faulty solenoid valves in the mech unit, common problems with the DSG7 05981 /082 , im assuming Basic settings were successful? was it??, however did you changed or renewed mech unit fluid?? , also the Gearbox fluid? are the levels correct?
NostraJackAss
DCTLeigh
Australia
C?ID=350356
My apologies guys, Autoscan below
Basic settings were successful and I have done this 3x
Mech oil level not checked but I will be doing so now.
Thursday,05,September,2019,15:53:46:25814
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
Dealer/Shop Name:
VIN: WAUZZZ8P3BA010700   License Plate:
Mileage: 119930km-74521mi   Repair Order: Nick B
          77
VIN: WAUZZZ8P3BA010700   Mileage: 119930km-74521miles
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 8P7 907 115 K    HW: 8P0 907 115 Q
   Component: 1.8l R4/4V TFSI     0020
   Revision: AAH17---    Serial number: AUX7Z0J5FNA0MK
   Coding: 0143000C24070160
   Shop #: WSC 06314 000 00000
   VCID: 41CAB9CF18ED1C47D6-8014
   Part No SW: 0AM 300 050 E    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 2673
   Revision: 00043014    Serial number: CU501307307157
   Shop #: WSC 41308 000 1048576
   VCID: 2B16FB678A61E6171C-807E
   Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 13424012092300FAC81202E490190081390800
   VCID: 044470DB877FC96FBD-8050
   Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
   Component: KlimavollautomatH09 0150
   Revision: 000158      Serial number: 8P0820043BM
   VCID: 78BC142B0BB79D8FA1-802C
   Part No SW: 8P0 907 063 G    HW: 8P0 907 063 G
   Component: BCM PQ35  M   107 0615
   Revision: 00107 AF
   Coding: 4E000A2FA0051AC0207040E00100015C407A29AA106DC928E4000E800041
   VCID: 383CD42B8B375D8F61-806C
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 024C2D
                    Fault Status: 00101110
                    Fault Frequency: 27
                    Reset counter: 197
                    Mileage: 119473 km
                    Date: 2019.08.12
                    Time: 12:04:19
                    Voltage: 14.45 V
                        Term 50 Off
                    Fault Status: 00101010
                    Reset counter: 191
                    Mileage: 119475 km
                    Date: 2019.08.12
                    Time: 13:25:12
                    Voltage: 12.20 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 G    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0120
   Revision: 11001001    Serial number: 93641016100879
   Coding: 000103
   VCID: 42C8B6C3DDEB075FCF-8016
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
   Component: Airbag AU1042 H07 0200
   Revision: --------    Serial number: 003FB007HXZZ
   Coding: 30314238303830303037554A305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4FEE8FF716B9FA3750-801A
   Serial number: 3572DRB40000B79C7A10
   Serial number: 3582DRB40000B7C4CB34
   Serial number: 35128RB40000594C27FT
   Serial number: 35228RB4000058DCD7A1
   Serial number: 35547RB400005A3F050I
   Serial number: 35647RB400005A3F4D4Z
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0014142
   VCID: 46C0AAD331C33B7FE3-8012
   Component: E0221           H02 0100
   Part No SW: 8P0 920 932 K    HW: 8P0 920 932 K
   Component: KOMBIINSTR. VDO H01 0080
   Revision: D0H01002    Serial number: 2245J002003900
   Coding: 0256728
   Shop #: WSC 27509 003 1048576
   VCID: 3C34C83B7F0F71AF85-8068
   Part No SW: 8P0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H33 0302
   Revision:   H33       Serial number: 260510F1000947
   Coding: EDA07F0610060204002103
   VCID: 312AE90FA84D8CC726-8064
   Revision: D0H01002    Serial number: AUX7Z0J5FNA0MK
   Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
   Component: Tuer-SG         H04 0101
   Coding: 0000660
   VCID: 49DAA1EF20DDD4070E-801C
00912 - Window Regulator Switch; Front Left (E40)
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 232    3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P4 035 382 E    HW: 8P4 035 382 E
   Component: AB2 SUBWOOFERBOXH07 0180
   Revision: 00006       Serial number: 92158068209130
   VCID: 3620DA134123ABFF73-8062
   Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
   Coding: 0000660
   VCID: 4AD89EE325DBDF1F07-801E
   Part No SW: 8P0 035 186 S    HW: 8P0 035 186 S
   Component: R Concert2+     H03 0280
   Revision: 00H03000    Serial number: AUZ1Z3K6052098
   Coding: 0710111
   VCID: 42C8B6C31DEB075FCF-8016
   Part No SW: 8P0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H33 0302
   Coding: 0302085A
   VCID: 74A4201BD7DFF9EF8D-8020
   Subsystem 1 - Part No SW: 1K0 915 181 E    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650222329
02256 - Quiescent Current
                    Fault Status: 00100001
                    Reset counter: 207
                    Mileage: 119929 km
                    Date: 2019.08.28
                    Time: 11:25:27
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0000144
   Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0000144
   VCID: 43C6B3C702F10E57C4-8016
   Part No SW: 8P1 862 335     HW: 8P1 862 335
   Component: FSE_256x BT     H41 0650
   Revision: 00000000    Serial number: 00000005208646
   Coding: 0001222
   Shop #: WSC 21200 822 59815
   VCID: 74A4201B17DFF9EF8D-8020
End----------(Elapsed Time: 01:37, VBatt start/end: 12.2V/12.2V)-----------
NostraJackAss
You mean you didn't check vital signs of this patient yet? :rolleyes:
DCTLeigh
Australia
C?ID=350356
.[/COLOR]
Recovered 800ml of clean green oil from mech, Specification says dry fill is 1 litre but to measure correctly mech should be removed and turned around to empty.
Gearbox oil was replaced at the time of clutch swap.
DCTLeigh
Australia
C?ID=350356
That's my thoughts as well, A second opinion is appreciated these Mechtronic units cost us $2100 AUD I will replace it & report back.
Thanks.
