2002 Passat abs code challenge!
Schoonerzero
C?ID=79822
Hello guys,
So, having a little trouble with a Passat abs controller, it won’t keep the codes!
To ad to it the production label in the boot has been eaten by mould and there’s no book with a duplicate either!
Have tried some logins and codes,
With 09555 and 04255 it appears until the ignition is cycled.
Can anyone confirm from the scan if I’m in the right ballpark???
Kind regards...
Tuesday,03,September,2019,16:46:59:57278
VCDS Version: 18.2.1.5 (x64)
VIN: WVWZZZ3BZ3E077477   License Plate:
Mileage: 253250km-157362mi   Repair Order:
VIN: WVWZZZ3BZ3E077477   Mileage: 253250km-157362miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 GQ
   Component: 1,9l R4 EDC G000SG  1524
   Coding: 00002
   Shop #: WSC 05314
   VCID: 6CD3948A1C544924E8-4B00
   WVWZZZ3BZ3E077477     VWZ7Z0B5561862
Readiness: 0 0 X X X
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       1728
   Coding: 00000
   VCID: 2545A1AEBF3EB86C77-513C
            66-10 - Not Matched - Intermittent
            35-00 -  -
   Part No: 3B1 907 044 J
   Component: CLIMATRONIC B5GP    0005
   Coding: 17000
   Shop #: WSC 05311
   VCID: 285BA89AC82CA5044C-5196
   Part No: 1C0 909 605 C
   Component: 08 AIRBAG VW61 04   0001
   Coding: 12344
   Shop #: WSC 00028
   VCID: 2443BCAAB404416460-513C
   Part No: 3B0 920 927 A
   Component: KOMBI+WEGFAHRSP VDO V08
   Coding: 05415
   VCID: 2341BFB6B10A465C19-513C
01316 - ABS Control Module
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 05314
   VCID: 70EB80FA307CADC4D4-513C
00463 - Control Module for Digital Sound Package (J525)
            49-00 - No Communications
   Part No: 1C0 959 799 B
   Component: 6T Komfortgerát HLO 0003
   Coding: 00258
   Shop #: WSC 05311
   VCID: 366776E21298C3F4CE-4B18
   Subsystem 1 - Part No: 1C2959802
   Component: 8Q Tõrsteuer.FS KLO 0004
   Subsystem 2 - Part No: 1C2959801
   Component: 8Q Tõrsteuer.BF KLO 0004
   Subsystem 3 - Part No: 1C0959811
   Component: 8Q Tõrsteuer.HL KLO 0004
   Subsystem 4 - Part No: 1C0959812
   Component: 8Q Tõrsteuer.HR KLO 0004
01141 - Luggage Compartment Unlocking Switch (E165)
            27-00 - Implausible Signal
End-------------------------(Elapsed Time: 04:49)--------------------------
I would suggest you install the latest version of VCDS (currently 19.6.1) and re-scan.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
We can recover that for you based on the VIN, but...
+1. Please rescan and post with a current version of VCDS.
Schoonerzero
C?ID=79822
Ok will update tomorrow and post it, thanks
Schoonerzero
C?ID=79822
Here is the updated scan....
Thursday,05,September,2019,09:33:26:57278
VCDS Version: 19.6.1.0 (x64)
   Coding: 00002
   Shop #: WSC 05314
   VCID: 6CD3948A1C54492F55-4B00
   Coding: 00000
   VCID: 2545A1AEBF3EB867CA-5120
            35-00 - -
   Coding: 17000
   Shop #: WSC 05311
   VCID: 285BA89AC82CA50FF1-5178
   Coding: 12344
   Shop #: WSC 00028
   VCID: 2443BCAAB404416FDD-5120
   Coding: 05415
   VCID: 2341BFB6B10A4657A4-5120
   Coding: 00006
   Shop #: WSC 05314
   VCID: 70EB80FA307CADCF69-5120
   Coding: 00258
   Shop #: WSC 05311
   VCID: 366776E21298C3FF73-4B18
Ps Uwe...I’m filling out the form from part 2, it’s a Hex-can+usb
Schoonerzero
C?ID=79822
But my stickers no longer in the interface... will it be inside if I was to open the interface?
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Pulling up your build data from PL24 by VIN, you have:
  • Front brakes PR-1ZC disc brakes in front (Geomet D)
  • Base engine PR-T9J 4-cylinder diesel engine 1.9 l unit 038.K
If you'd like a complete PR code list for your car, as a replacement for your production label, PM me an email address and I'd be happy to send it to you.
That does indeed seem legitimate to me...
Login:
0 : 0
9 : VW Passat
5 : PR-1ZC disc brakes in front (Geomet D)
5 : Base engine PR-T9J 4-cylinder diesel engine 1.9 l unit 038.K with PR-1ZC disc brakes in front (Geomet D)
5 : Manual
Coding:
0 : 0
4 : VW Passat
2 : PR-1ZC disc brakes in front (Geomet D)
5 : Manual
You appear to have the correct ABS/ESP module for your car. That's been a problem for other people in the past, replacing with salvage or rebuilt modules.
I think you may need to complete the steering angle sensor basic setting procedure, in the same diagnostic session, in order for the new coding to be stored permanently. That's how Ross-Tech does it in their Bosch 5.3 and 5.7 training video. They don't mention it as a procedural requirement on the Bosch 5.7 Wiki page, but they do mention it on the Bosch 5.3 Wiki page, and it would be consistent with what you're seeing.
Schoonerzero
C?ID=79822
Dude, you are indeed a star!
No worries on the full pr label, I just needed to confirm my assumptions on the login/coding to vehicle build, but thanks anyway!
Diamond!!
Ps I’m an avid vcds user love it over my other tools and been using it for over ten years, bought from a reseller in the uk called hickleys, I think back then they were called Hinckley valtone, if anyone knows if the dongle serial in side the dongle without opening it is duplicated, then give me a pm, as I’ve tried filling the form out, but I have to have this number or cert which I don’t have, bummer... feel bad not doing as Uwe has asked! ....sorry, am trying!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I thought Uwe could get what he needed from just the license serial number in the About menu, but I see the registration form does ask for a second bit of verification. Not exactly sure what that's about; you could try submitting with "missing" or something in that field and let him contact you back if there's a problem. Ultimately he just wants to get you registered for proper full support access if you're entitled to it, so you're no worse off than you are now if you can't find it or get it figured out.
You have a PM.
