2012 Q5 With hard codes all over.
Pater
C?ID=57506
Hi there everybody,
So I have been working on a 2012 Q5 2.0 quattro. The complaint was that the warning lights for the CEL, TCS, TPMS all came on. the car started to sputter, lacked power, and stalled. Test driving it seemed to have normal power, a little rough at idle (sometimes), and I could not get it to stall. There are 2 codes for limited function in the ECM due to other modules, mass air flow, Pressure Drop between Turbo and Throttle Valve, and 2 other modules with codes 01314 - Engine Control Module.
I replaced the original battery, which had failed the test, and inspected / cleaned all grounds I could find. I knew the motor mounts were leaking, and have heard those could cause some odd issues. I tried to un-plug the mounts to see if codes would change. Yet same codes returned, along with codes for the mounts. Does this seem like the ECM is toast, or should I be looking at something else? The first test drive after the battery replacement with mounts hooked up the warning did not come back on till about 8 miles into the test drive. With the mounts un-plugged the codes came back with in half a mile.
Also side note, but the drivers window will not re-initiate after battery replacement. All other windows did, and the auto up, and down work when commanded threw VCDS. Anything helps, I am at a loss now, thanks.
Friday,30,August,2019,16:34:12:49215
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WA1LFAFP7CA125009   License Plate:
Mileage: 129610km-80535mi   Repair Order:
Chassis Type: FP-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
          62 69 6C 6D 72
VIN: WA1LFAFP7CA125009   Mileage: 129610km-80535miles
Address 01: Engine (0-----CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8R0 907 115 P    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H20 0002
   Revision: E1H20---
   Coding: 0121010A290F0960
   Shop #: WSC 22803 444 183826
   ASAM Dataset: EV_ECM20TFS0118R0907115P 001002
   ROD: EV_ECM20TFS0118K2907115AG.rod
   VCID: C1CA0EDF5049754756-8094
          U1113 00 [039] - -
                    Mileage: 129610 km
                    Date: 2019.08.30
                    Time: 16:27:06
                    Engine speed: 1689.50 /min
                    Normed load value: 5.9 %
                    Vehicle speed: 91 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 50 °C
                    Ambient air pressure: 820 mbar
                    Voltage terminal 30: 14.088 V
5658 - Fuel Pressure Sensor (G247)
          P119A 00 [039] - Malfunction
                    Mileage: 129615 km
                    Date: 2019.08.30
                    Time: 16:32:50
                    Engine speed: 748.50 /min
                    Normed load value: 12.2 %
                    Intake air temperature: 54 °C
                    Ambient air pressure: 830 mbar
                    Voltage terminal 30: 13.711 V
5667 - Mass Air Flow Sensor (G70)
          P0101 00 [039] - Implausible Signal
                    Mileage: 129612 km
                    Date: 2019.08.30
                    Time: 16:28:15
                    Engine speed: 1115.00 /min
                    Normed load value: 6.7 %
                    Vehicle speed: 48 km/h
                    Coolant temperature: 89 °C
                    Voltage terminal 30: 14.112 V
2999 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
          P1297 00 [039] - -
                    Mileage: 129610 km
                    Date: 2019.08.30
                    Time: 16:27:05
                    Engine speed: 1697.50 /min
                    Normed load value: 7.5 %
                    Voltage terminal 30: 14.135 V
Readiness: 0000 0101
   Part No SW: 8R0 927 158 T    HW: 0BK 927 156 AJ
   Component: 0BK 20TFSIUSA H16 1006
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: CED025E391179A3FDB-809A
2505 - Torque Management Feedback Signal A
          P2637 00 [039] - -
                    Mileage: 129610 km
                    Date: 2019.08.30
                    Time: 16:27:08
                    Voltage terminal 30: 14.007 V
                    Transmission output speed: 2470.00 /min
                    Driving position: d
                    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: regulated
                    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Coasting
                    Transfer speed from ESP: valid
                    Transfer speed from ESP: 88.87 km/h
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 H    HW: 8R0 907 379 H
   Component: ESP8 quattro  H06 0110
   Coding: 129D18
   VCID: C5C21ACF4C6159676A-8090
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 235
                    Mileage: 129610 km
                    Date: 2019.08.30
                    Time: 16:27:06
                    Hex Value: 0x5B00
                    Hex Value: 0x4006
                    Hex Value: 0x120A
                    Hex Value: 0x46B1
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 FP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H10 0602
   Coding: 0D854000000000000000
   Shop #: WSC 06335 000 00000
   VCID: 8346C4D702D5A75704-80D6
   Serial number: 2312000105499015
   Revision: C1000000    Serial number: 01290520120978
   Coding: 64112000
   VCID: 804CCBDB13C3BC4F19-80D4
                    Fault Status: 01101000
                    Reset counter: 234
                    Mileage: 129602 km
                    Date: 2019.08.30
                    Time: 16:11:46
   Part No SW: 8K0 907 063 CE    HW: 8K0 907 063 P
   Component: BCM1 1.0      H30 0410
   Revision: 10030001    Serial number: 00000001511159
   Coding: 26001091063CAF010000080300001D0D0F1C660802010161000000
   VCID: F4A4970B577B90EF0D-80A0
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 120522  H11 0050
   Serial number: 90243014120508203214
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 12028108
   Coding: 024D25
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001705121054
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0081
   Revision: 11001001    Serial number: 12561214900515
   Coding: 310105
   VCID: F8BCA33B4B13F48F21-80AC
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Serial number: 003GPD90FU1Q
   Coding: 303633313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: C7DE10C77E6D4B7798-8092
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R12000095VK
   Serial number: 6334MSME6D146F03L
   Serial number: 6344MSME4F503A44J
   Serial number: 6352QSME10140454$
   Serial number: 6362QSME0D140848G
   Serial number: 63732SME1B18016C$
   Serial number: 63832SME1A18016E+
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372LEV001GO
   Coding: 000017
   VCID: BD32722F24B111A732-80E8
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 981 G    HW: 8R0 920 981 G
   Component: KOMBIINSTR.   H44 0640
   Revision: 00000000    Serial number: P9X20706D
   Coding: 8B1622000300D705020000
   VCID: BE30752329B70ABF2B-80EA
   Part No SW: 8T0 907 468 AH    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0120
   Revision: EC101057    Serial number: 5700E125068009
   Coding: 00C303
   VCID: 875ED0C736ED8B7758-80D2
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790434627
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0076
   Revision: AA000000    Serial number: 00000029483711
   Coding: 00581B00000000000000
   VCID: C2C801D35D4F6E5F4F-8096
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000030964516
   Coding: 011D13205E00440004
   VCID: CFEE38E79E1D9337D0-809A
   Revision: 00002001    Serial number: 0177190400
   Coding: 0126023A20FA749584B0053200000000
   Shop #: WSC 06334 000 00000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000526810
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H03 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H03 0220
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34804015600604
   VCID: FAB8B933751FE69F57-80AE
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000031142868
   VCID: CED025E399179A3FDB-809A
   Revision: 00000003    Serial number: 20000000220020
   VCID: B424570B17FBD0EFCD-80E0
                    Fault Status: 11101101
                    Reset counter: 235
                    Mileage: 129602 km
                    Date: 2019.08.30
                    Time: 16:11:46
                    Voltage: 12.00 V
                    Count: 58
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 120516-0002-033
   Coding: 1197A61010020400
   ROD: EV_HeadlRegulBasic.rod
   VCID: AD12426FFCD1812782-80F8
   Part No SW: 4G0 035 082 C    HW: 4G0 035 082
   Component: Radio U SIRIU H53 0101
   Revision: AB001007    Serial number: 236F.0C7542077
   Coding: 020007010000000001
   VCID: A00CAB5BB3035C4F39-80F4
   Part No SW: 8T1 035 664 D    HW: 8T1 035 664 B
   Component: H-BN-NA       H52 0165
   Revision: --------    Serial number: 490FZ0C7680260
   Coding: 010200060005A1EF41002B0E000000030000
   VCID: B93A663F30992D871E-80EC
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130E90CS178371
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000001167441
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000031077321
   Coding: 010C13204000240004
   VCID: C6C01DC37167527F63-8092
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
   Revision: 1A001001    Serial number: 00000164857529
   Coding: 0200000000000000
   VCID: B6206D030187C2FFF3-80E2
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H07---    Serial number: 525PA8-J23A318
   Coding: 1030010
   VCID: B424570BD7FBD0EFCD-80E0
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8R0827851B
   VCID: BB367C373AA51F970C-80EE
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H52 0330
   Serial number: 8R0827852B
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000031077412
End----------(Elapsed Time: 01:57, VBatt start/end: 14.1V/14.1V)-----------
NostraJackAss
Hi there everybody,
Vehicle Identification No.WA1LFAFP7CA125009
ModelAudi Q5 qu. 2.0
AQ5
Date of production12.06.2012
Model year2012
Sales type8RB56A
Engine CodeCAEB
Transmission CodeNXX
Emission standard7GBEmission standard ULEV 2
ECM8R0 907 115 P 000235256D79CADXJ02.03UB
ECM8R0 907 115 P 000388B40E11CADXJ02.03UB
ECM8R09071115P Q000487393D3BCADXJ02.03UB
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=27353&flag=1
Application for Emissions Certification Part 12012 Model YearDurability Group: CADXGPGNN3UBEvap. Families: CADXR0140B8QCADXR0140C7ATest Group: CADXJ02.03UBCertificate Number: CADXJ02.03UB-xxx / CADXJ02.03UB-xxxDurability Group Description: Four Stroke, Otto Cycle, Gasoline Fueled, Direct FuelInjection, Catalyst Code: REX 1662, TEX 0442Test group Description: 2.0 Liter Turbocharged I-4 longitude - LDVApplicable Standards: 50-State: Federal:CA:Tier 2 BIN 5LEV-II ULEVCarlines Covered: Audi Q5, Audi A4, A4 quattro, A4 Avant quattro,Audi A5 quattro, A5 Cabriolet, A5 Cabriolet quattro,Audi A6
Are not these faults related to useful life warranty for a free diagnosis and repair, including equipment to diagnosis or all costs endured by the consumer to correct, reimbursable?
Did you JPPSG yet?
Were there not firmware updates required as per TSB & that would imply certification failing compliance & as a vicarious cause of possible faults you are experiencing?
Did you check HPP and lift pump volume or PSI + regulation and MAF function?
Did you verify turbo charger, pipes and WG function and if faulty did you know is under useful life warranty?
[COLOR=#333333]-------------------------------------------------------------------------------
   Component: 2.0l R4/4V TF H20 [/COLOR][B]0002   <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< [/B][COLOR=#333333][B]Doesn't[/B][/COLOR][B] this [/B][COLOR=#ff0000][B]require[/B][/COLOR][COLOR=#ff0000][COLOR=#333333][B] a firmware update?[/B][/COLOR][/COLOR][COLOR=#333333]
   Revision: E1H20---
   Shop #: [/COLOR][COLOR=#045504][B]WSC[/B][/COLOR][COLOR=#333333] 22803 444 183826
   [/COLOR][COLOR=#045504][B]ASAM[/B][/COLOR][COLOR=#333333] Dataset: EV_ECM20TFS0118R0907115P 001002
          U1113 00 [039] - -
                    Mileage: 129610 km
                    Date: 2019.08.30
                    Time: 16:27:06
                    Mileage: 129615 km
                    Date: 2019.08.30
                    Time: 16:32:50
                    Mileage: 129612 km
                    Date: 2019.08.30
                    Time: 16:28:15
          P1297 00 [039] - -
                    Mileage: 129610 km
                    Date: 2019.08.30
                    Time: 16:27:05
   Component: 0BK 20TFSIUSA H16 [/COLOR][COLOR=#ff0000][I][B]1006 <<<<<<<<<<<<<<<<[/B][/I][/COLOR][B] <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< [COLOR=#333333][B]Doesn't[/B][/COLOR][B] this [COLOR=#ff0000][B]require[/B][/COLOR][B] a firmware update?[/B][/B][/B][COLOR=#333333]
   Revision: --H16---
   Coding: 000002
   Shop #: [/COLOR][COLOR=#045504][B]WSC[/B][/COLOR][COLOR=#333333] 00000 000 00000
   [/COLOR][COLOR=#045504][B]ASAM[/B][/COLOR][COLOR=#333333] Dataset: EV_TCMAL551211 002018
          P2637 00 [039] - -
                    Mileage: 129610 km
                    Date: 2019.08.30
                    Time: 16:27:08
                    Driving position: d
[/COLOR]
Pater
C?ID=57506
Hmm very interesting. I did not find anything about a lifetime warranty on alldata or identifix. I just expected it to have the 7 year 70000 mile California warranty, and the car has 80523 miles.
Car is stock
Replaced battery, and cleaned grounds, replaced spark plugs (due by mileage), replaced dirty cabin and air filters, replaced oil, and filter.
All barts that I have looked at so far are OEM. well the battery we installed is a AGM H8 interstate battery.
Warning light comes on for parking break, TCS, TPMS last time when coming to a stop. Car will run rough, slight miss at idle once warning lights come on.
Battery replaced, cleaned terminals during replacement service, All fuses tested good.
I have searched for TSB's related to these codes and did not see a firmware update. I must of missed it. I did preform the test for 'FUEL SYSTEM - MIL ON/DTC'S P0087/P0192/P119A' Fuel pressure was good, wires measured out to .4 ohms
I did not check volume but pressure was good for the high, and low/lift pump. Did not know there was a test plan for the MAF so I will look for that and run it. I did smoke the air intake after the filter box, but no leak was found.
It is boosting, and didn't find anything saying that it had a lifetime warranty. I will call the dealer and check into that. Thank you so much.
NostraJackAss
Not lifetime silly, didn't you read it's USEFUL LIFE, no?
Car is stock
Excellent that means the warranty for useful life as defined by EPA & CARB is active, no?
You apparently need to sharpen your pencil, huh?
Oh pitter pater, as a professional & in the business Hans, you are supposed to know this and didn't you read the conformity certificate aforementioned & in links to know what is covered and what is not, doesn't everyone know that all specific AECD's such as fuel lift pumps, HPP & turbo charger assembly are covered under the FULL useful life warranty?
