Hi, Just after some assistance with a U1122 code on a 2018 Golf R.
I have fitted a brand new genuine steering rack due to accident damage.
The rack has been initialized, steering angle sensor and rack end stops calibrated - no codes remaining in the steer assist system.
I cannot clear fault code U1122 from the ABS system - EPS invalid status signal and Frt Sens Drv Assist fault 0659 - C10AC F2 (009) - Lane Hold Assist not calibrated. I have tried various coding options in Steering Assist but not had any luck improving things
Has anyone come across this before?
Auto Scan:
Auto Scan:
Address 01: Engine (J623-DJHB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 J HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0003
Revision: --H13---
Coding: 092500122466050B3004
ASAM Dataset: EV_ECM20TFS0208V0906259J 001005
ROD: EV_ECM20TFS0208V0906259J.rod
VCID: 47DE88A3FE36BF7718-8012
Readiness: 1010 0001
Part No SW: 0GC 300 012 M HW: 0GC 927 711 H
Component: GSG DQ381 H06 2301
Revision: 00H06V07
ROD: EV_TCMDQ381061_VW37.rod
VCID: 2D12DA0B7C8A752702-8078
Part No SW: 5Q0 614 517 DE HW: 5Q0 614 517 AD
Component: ESC H25 0524
Revision: 00000000 Serial number: 62798000003524
Coding: 01FA93A1542421704779070660C76980C92A84E2E0069677384250B8C2A8430B00000012121212B835351919323200
VCID: 77BE3863CE560FF7A8-8022
8277 - Databus
[FCAN: EPS_DSR_Status signal is invalid]
Reset counter: 74
Mileage: 3737 km
Date: 2019.09.03
Time: 16:17:16
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0495170004
Coding: 132C0C0723
VCID: 43C69CB3CA0E9357C4-8016
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0012001420010000110500001210142A
VCID: 6D921A0BBC0AB52742-8038
Air quality sensor:
Part No SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H38 0273
Serial number: 00001828602572
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7CB4274FF7702CAFC5-8028
Component: WWS 180910 042 0551
Serial number: 180918151401
Component: RLHS 052 0107
Serial number: S6Y18M10D11H17M15S48
Coding: 00A8DD
Serial number: 000000000ZY18261059P
Serial number: 00000000000045302721
Sun Roof:
Component: J245 PS73.404 H04 0005
Serial number: 0000FST00268M6800000
Coding: 181901
Steering Column Switch:
Subsystem 6 - Part No SW: 5Q1 953 507 M HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000028091804400970
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Component: PDC 8 KanalH07 0050
Serial number: 000308418018281
Coding: 0471155811
ASAM Dataset: EV_EPHVA18AU3700000 009039
VCID: 4CD4B78FE7505C2F35-8018
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Coding: 330067C15DFFC728949C810580400600000000000000000004
VCID: 44C49FAFCF00946FFD-8010
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 18081841351467
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 383CFB5F83C8C08F61-806C
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR4LXXY3
Coding: 98CCC000000000005C000000008800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 095A4E9BA8A20907CE-805C
Belt Pretensioner left:
Serial number: 34169677E11101820341
Coding: 333135
Belt Pretensioner right:
Serial number: 34169676E16101841126
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 110 18
Serial number: 3570000000037B4C843O
Subsystem 4 - Part No SW: ----------- HW: 480 001 210 18
Serial number: 35800000000E6518353I
Subsystem 5 - Part No SW: ----------- HW: 480 401 010 18
Component: SideSensor_Dr 004 6149
Serial number: 3510001182B72261458O
Subsystem 6 - Part No SW: ----------- HW: 480 401 110 18
Component: SideSensor_Pr 004 6149
Serial number: 35200010C2B7DBA655AH
Subsystem 7 - Part No SW: ----------- HW: 480 401 010 18
Component: FrontSensor_D 004 6149
Serial number: 3550001182B72262B5E%
Part No SW: 5G1 920 791 B HW: 5G1 920 791 B
Component: KOMBI 403 4191
Coding: 27AD301E7F88000801886B0B5401000080000000
VCID: 2B16D413429E7B171C-807E
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 518 5344
Serial number: 05101810801664
Coding: 030100047F085900FB00827E9C0F00010001070000000000000000000000
ROD: EV_GatewNF.rod
VCID: 3D32EA4BACEAE5A7B2-8068
Component: 1-01-13-01-04
Subsystem 2 - Part No SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0052
Serial number: 29180002289120098395
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 0757319204
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7084
Serial number: HA1-00013.08.18
Coding: 0001
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H07 0021
Serial number: 18000321447004
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 312AC67B60B211C726-8064
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0024
Serial number: Y0006RJ128462
Coding: 0014000000000500018280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0495094175
Coding: 02011203
ROD: EV_HREntryHella_VW37.rod
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0494917131
Coding: 020112
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007RJ32216D
Coding: 003F1220D201048000001000
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000024095698
Coding: 0D0000
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 00020000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C34E74FB7F0ECAF85-8068
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1JMD03AKDR
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI.rod
VCID: 2E10DD07718C0E3F3B-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 07101810521043
Coding: 00000005090016D606204F01020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 3522F26B94DA3DE77A-8060
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007RJ526064
Coding: 003F1020DE01048000001000
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000024213388
Coding: 150000
Part No SW: 5NA 035 045 C HW: 5NA 035 045
Component: MU-H-N-RW H55 1161
Serial number: A849J0JS035042
Coding: 027310080000000051510002000808001F0107F601200402DF
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H52 9130
Serial number: VWZ6ZJV2820770
Subsystem 2 - Part No SW: V03 959 801 EE HW: -----------
Component: ROW 2018 --- 0068
Component: Gracenote2 --- 4013
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0272
Serial number: 30071815P20441
Coding: 0003070000000101000223548150A90088000E300040
0659 - Steering
C10AC F2 [009] - Lane-Holding Assistance Not Coded
[HC_interface_at_the_steering_not_activated]
Reset counter: 74
Mileage: 3737 km
Date: 2019.09.03
Time: 16:14:53
Control Module temperature: 43 °C
Outside air temperature: 19.5 °C
Vehicle speed: 0.00 km/h
System run time: 247.2 s
Voltage terminal 15: 13.3 V
mid: 02 A6
Status of camera: operational
Engine_Running_Info: 1
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 180612200198
VCID: 2F2EC0037686073730-807A
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 393AFE5BB8C2D9879E-806C
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxRKEBODVW481.rod
