MK7.5 Golf R ABS Fault & Frt Assist Fault - New Rack
PaulieJ
Australia
C?ID=288598
Hi, Just after some assistance with a U1122 code on a 2018 Golf R.
I have fitted a brand new genuine steering rack due to accident damage.
The rack has been initialized, steering angle sensor and rack end stops calibrated - no codes remaining in the steer assist system.
I cannot clear fault code U1122 from the ABS system - EPS invalid status signal and Frt Sens Drv Assist fault 0659 - C10AC F2 (009) - Lane Hold Assist not calibrated. I have tried various coding options in Steering Assist but not had any luck improving things
Has anyone come across this before?
Auto Scan:
Address 01: Engine (J623-DJHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 J    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 092500122466050B3004
   ASAM Dataset: EV_ECM20TFS0208V0906259J 001005
   ROD: EV_ECM20TFS0208V0906259J.rod
   VCID: 47DE88A3FE36BF7718-8012
Readiness: 1010 0001
   Part No SW: 0GC 300 012 M    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2301
   Revision: 00H06V07
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 2D12DA0B7C8A752702-8078
   Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
   Component: ESC           H25 0524
   Revision: 00000000    Serial number: 62798000003524
   Coding: 01FA93A1542421704779070660C76980C92A84E2E0069677384250B8C2A8430B00000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 77BE3863CE560FF7A8-8022
8277 - Databus
          [FCAN: EPS_DSR_Status signal is invalid]
                    Reset counter: 74
                    Mileage: 3737 km
                    Date: 2019.09.03
                    Time: 16:17:16
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0495170004
   Coding: 132C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   VCID: 43C69CB3CA0E9357C4-8016
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0012001420010000110500001210142A
   VCID: 6D921A0BBC0AB52742-8038
   Air quality sensor:
   Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H38 0273
   Serial number: 00001828602572
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7CB4274FF7702CAFC5-8028
   Component: WWS    180910  042 0551
   Serial number:         180918151401
   Component: RLHS  052 0107
   Serial number: S6Y18M10D11H17M15S48
   Coding: 00A8DD
   Serial number: 000000000ZY18261059P
   Serial number: 00000000000045302721
   Sun Roof:
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST00268M6800000
   Coding: 181901
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000028091804400970
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418018281
   Coding: 0471155811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CD4B78FE7505C2F35-8018
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 330067C15DFFC728949C810580400600000000000000000004
   VCID: 44C49FAFCF00946FFD-8010
   Serial number: 18081841351467
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 383CFB5F83C8C08F61-806C
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4LXXY3
   Coding: 98CCC000000000005C000000008800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 095A4E9BA8A20907CE-805C
   Belt Pretensioner left:
   Serial number: 34169677E11101820341
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E16101841126
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 110 18
   Serial number: 3570000000037B4C843O
   Subsystem 4 - Part No SW: -----------    HW: 480 001 210 18
   Serial number: 35800000000E6518353I
   Subsystem 5 - Part No SW: -----------    HW: 480 401 010 18
   Component: SideSensor_Dr  004 6149
   Serial number: 3510001182B72261458O
   Subsystem 6 - Part No SW: -----------    HW: 480 401 110 18
   Component: SideSensor_Pr  004 6149
   Serial number: 35200010C2B7DBA655AH
   Subsystem 7 - Part No SW: -----------    HW: 480 401 010 18
   Serial number: 3550001182B72262B5E%
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         403 4191
   Coding: 27AD301E7F88000801886B0B5401000080000000
   VCID: 2B16D413429E7B171C-807E
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 05101810801664
   Coding: 030100047F085900FB00827E9C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 3D32EA4BACEAE5A7B2-8068
   Component: 1-01-13-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180002289120098395
   Coding: 2DFFFF
   Serial number: 0757319204
   Serial number: HA1-00013.08.18
   Coding: 0001
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H07 0021
   Serial number: 18000321447004
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 312AC67B60B211C726-8064
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RJ128462
   Coding: 0014000000000500018280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 0495094175
   Coding: 02011203
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0494917131
   Coding: 020112
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007RJ32216D
   Coding: 003F1220D201048000001000
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000024095698
   Coding: 0D0000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 00020000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C34E74FB7F0ECAF85-8068
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1JMD03AKDR
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 2E10DD07718C0E3F3B-807A
   Component: FCM MQB Low   002 0345
   Serial number: 07101810521043
   Coding: 00000005090016D606204F01020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 3522F26B94DA3DE77A-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RJ526064
   Coding: 003F1020DE01048000001000
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000024213388
   Coding: 150000
   Part No SW: 5NA 035 045 C    HW: 5NA 035 045
   Component: MU-H-N-RW     H55 1161
   Serial number: A849J0JS035042
   Coding: 027310080000000051510002000808001F0107F601200402DF
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJV2820770
   Subsystem 2 - Part No SW: V03 959 801 EE    HW: -----------
   Component: ROW 2018  --- 0068
   Compact Disc Database:
   Component: Gracenote2  --- 4013
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 30071815P20441
   Coding: 0003070000000101000223548150A90088000E300040
0659 - Steering
          C10AC F2 [009] - Lane-Holding Assistance Not Coded
          [HC_interface_at_the_steering_not_activated]
                    Reset counter: 74
                    Mileage: 3737 km
                    Date: 2019.09.03
                    Time: 16:14:53
                    Control Module temperature: 43 °C
                    Outside air temperature: 19.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 247.2 s
                    Voltage terminal 15: 13.3 V
                    mid: 02 A6
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 180612200198
   VCID: 2F2EC0037686073730-807A
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 393AFE5BB8C2D9879E-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxRKEBODVW481.rod
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
You need to set the coding checkboxes in your new 44-Steering Assist for DSR (Driver Steering Recommendation) which is for automatic countersteer against ABS/ESP operation, and HCA (Heading Control Assist) which is for lane-keeping assist steering from the front camera. The steering rack is not configured to support those things, and 03/A5 check for that, and are telling you about it.
In fact, I think you are probably missing a large number of things. No promises since this is from NAR and not Row/AUS, but here's my own 2018 Golf R coding:
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
[B]   [COLOR="#008000"]Coding: 911F0000[/COLOR]
[/B]   Shop #: WSC 08607 444 00005
   VCID: BB3676843237A2970C-80EE
vs yours:
[B]   [COLOR="#FF0000"]Coding: 00020000[/COLOR]
[/B]   Shop #: WSC 00000 000 00000
I'd start with copying mine and seeing what happens.
PaulieJ
Australia
C?ID=288598
vs yours:
Thanks!!
I had tried different coding, I have ended up with 91C70000 and all faults have cleared, the error I had made was activating pull compensation as well as counter steer, once I de-activated that everything was happy :)
Thanks again
United States
Thanks, Don has 28183 listed here MQB platform - Security Codes - work in progress
... so I added it to the 5Q0-909-144 file.
On a side note, 20103 might also be Coding Enabling but that isn't in the file or in Don's thread. If you happen to test that SA code please bump this back up with the results. If not, I can test it on my 2018 Golf wagon at some point - so don't feel obligated.
