2009 Vw Golf gti Mk5 ( no ignition lights, no start, no ecu comunication )
Alvaro
Ecuador
C?ID=125686
Hi, I have a 2009 Vw golf gti year 2009, the car dont start, I make a key in on but I dont have ignition lights in the cluster, the lights, radio, etc working, I dont have comunicacion with the ecm, this is the auto scan
Saturday,31,August,2019,15:53:40:14592
VCDS Version: 19.6.1.0 (x64)
VIN: WVWZZZ1KZ9W141278   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
VIN: WVWZZZ1KZ9W141278   Mileage: 62680km-38947miles
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6DD1F00D74A8FE2742-8038
7 Faults Found:
00538 - Reference Voltage
            002 - Lower Limit Exceeded
01273 - Fresh Air Blower (V2)
            007 - Short to Ground
            009 - Open or Short to Ground
   Revision: 00H54000    Serial number: 00000008950425
   Coding: E78F8F2700041500471400001400000000097F075C000100000000000000
   VCID: 33652675520C68D754-8066
   Component: Wischer 081008 021  0501
   Coding: 00038805
   Shop #: WSC 01357
   Component: RLS     131008 054  0402
   Coding: 00209069
   Shop #: WSC 01357
                    Fault Status: 00101001
                    Reset counter: 234
                    Mileage: 62683 km
                    Voltage: 12.80 V
00924 - Relay for Headlamp Cleaning System (J39)
                    Reset counter: 234
                    Mileage: 62683 km
                    Voltage: 12.80 V
02403 - Terminal 15 for Interior
                    Fault Status: 01101100
                    Reset counter: 194
                    Mileage: 62683 km
                    Voltage: 12.95 V
                    Reset counter: 194
                    Mileage: 62683 km
                    Voltage: 12.90 V
                    Reset counter: 194
                    Mileage: 62683 km
                    Voltage: 12.90 V
                    Reset counter: 194
                    Mileage: 62683 km
                    Voltage: 12.90 V
Address 15: Airbags
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           057 0101
   Coding: 0012102
   VCID: 78FFD1590BEA4B8FA1-802C
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00002 - Transmission Control Unit
01426 - Controls in Steering Wheel (E221)
   Part No SW: 1K6 920 874     HW: 1K6 920 874
   Component: KOMBIINSTRUMENT VDD 2416
   Revision: V0002000    Serial number: VWX7Z0H83NT8CD
   Coding: 0004103
   VCID: 70EFE979639A13CF69-8024
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 021008F2000160
   Coding: ED811F060002020000
   VCID: 3561186D5C7876E77A-8060
   Component: IMMO            VDD 2416
   Component: Tuer-SG         006 1207
   Coding: 0000052
   VCID: 387F11594B6A8B8F61-806C
Address 44: Steering Assist
   Coding: 819002085103087F2D04840570084A06F0BC00
   VCID: 0305B6B5422C185784-8056
   Component: LIN BACKUP HORN H08 9001
                    Reset counter: 194
00625 - Vehicle Speed Signal
                    Reset counter: 194
                    Mileage: 62683 km
                    Time: 22:27:24
   Coding: 0000052
   VCID: 3979145D706092879E-806C
Address 55: Headlight Range
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  040 0166
   Revision: 00000001    Serial number: VWZ1Z3K6401310
   Coding: 0100040004
   Shop #: WSC 00020 790 00000
   VCID: 65C1882D6C58C6670A-8030
                    Reset counter: 194
                    Mileage: 62543 km
                    Time: 07:40:58
End-------------------------(Elapsed Time: 01:50)--------------------------
Looks like the everything on the powertrain CAN is not talking, but strangely enough, there's no fault for that bus in the Gateway, so I'm not sure what to make of this.
Alvaro
Ecuador
C?ID=125686
Thanks Uwe, I have one question,it is possible that the problem may be a BCM? or ignition switch?
What do you think
thanks
Alvaro
Ecuador
C?ID=125686
Hi, I ahve news, I have ignition lights in the cluster, I found a problem in the BCM, , I start a engine, but the EPC light is on and the car dont work , I dont have Volt in electronic components, any idea abou that
thanks
Wednesday,04,September,2019,13:15:12:14592
09-Cent. Elect. -- Status: Malfunction 1010
15-Airbags -- Status: Malfunction 1010
   Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0H83NT8CD
   Coding: 040300101C070060
7 Faults Found:
008852 - Fuel Pressure Regulator Valve (N276)
               P2294 - 004 - Open Circuit - Intermittent
                    Mileage: 62683 km
                    Time: 22:05:09
                    RPM: 760 /min
                    Load: 20.0 %
                    Temperature: 53.0°C
                    Temperature: 34.0°C
                    Absolute Pres.: 730.0 mbar
                    Voltage: 13.716 V
012423 - Voltage Supply Relay for Engine Components
               P3087 - 004 - Electrical Malfunction
                    Mileage: 62683 km
                    Time: 22:05:09
                    RPM: 760 /min
                    Load: 20.0 %
                    Temperature: 53.0°C
                    Temperature: 34.0°C
                    Voltage: 13.716 V
001092 - EVAP Purge Control Valve (N80)
               P0444 - 004 - Circuit Open
                    Mileage: 62683 km
                    Time: 22:05:09
                    RPM: 737 /min
                    Load: 20.0 %
                    Temperature: 53.0°C
                    Temperature: 34.0°C
                    Voltage: 13.589 V
000051 - Turbocharger Bypass Valve Control Circuit
               P0033 - 004 - Malfunction / Open Circuit
                    Mileage: 62683 km
                    Time: 22:05:09
                    RPM: 737 /min
                    Load: 20.0 %
                    Temperature: 53.0°C
                    Temperature: 34.0°C
                    Voltage: 13.589 V
000579 - Solenoid Valve  for Boost Pressure Control (N75)
               P0243 - 004 - Malfunction
                    Mileage: 62683 km
                    Time: 22:05:09
                    RPM: 737 /min
                    Load: 20.0 %
                    Temperature: 53.0°C
                    Temperature: 34.0°C
                    Voltage: 13.589 V
009728 - Coolant Pump Control Circuit
               P2600 - 004 - Open
                    Mileage: 62683 km
                    Time: 22:05:09
                    RPM: 737 /min
                    Load: 20.0 %
                    Temperature: 53.0°C
                    Temperature: 34.0°C
                    Voltage: 13.589 V
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
               P0030 - 004 - Malfunction / Open Circuit
                    Mileage: 62683 km
                    Time: 22:05:19
                    RPM: 772 /min
                    Load: 20.0 %
                    Temperature: 53.0°C
                    Temperature: 34.0°C
                    Voltage: 13.843 V
Readiness: 0000 0101
   Part No SW: 02E 300 051 C    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1817
   Revision: 04843012    Serial number: 00000807111279
   VCID: 132586F5324C88D734-8046
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 143B600D092600FB280D06EB90210041B500
   Shop #: WSC 11149 003 1048576
   VCID: 000FB9B9933A034F99-8054
7 Faults Found:
            013 - Check DTC Memory
   Coding: 00038805
   Shop #: WSC 01357
   Coding: 00209069
   Shop #: WSC 01357
10 Faults Found:
00156 - Control Circuit for Windshield Washer Pump
                    Reset counter: 234
                    Voltage: 5.00 V
02398 - Control Circuit for Rear Windshield Washer Pump
                    Reset counter: 234
                    Voltage: 5.00 V
00906 - Horn (H1)
                    Reset counter: 234
                    Voltage: 5.00 V
                    Reset counter: 234
                    Voltage: 5.00 V
01800 - Light Switch (E1)
                    Fault Status: 01101000
                    Reset counter: 194
                    Mileage: 62683 km
                    Voltage: 12.20 V
01516 - Terminal 30; Left
                    Fault Status: 00101011
                    Reset counter: 234
                    Voltage: 5.00 V
                    Fault Status: 00101100
                    Reset counter: 234
                    Voltage: 5.00 V
02389 - Release Signal Transmission; Position P/N
                    Reset counter: 234
                    Mileage: 62683 km
                    Voltage: 12.25 V
00926 - Terminal 30
                    Reset counter: 234
                    Voltage: 5.00 V
00918 - Terminal 31
                    Reset counter: 234
                    Voltage: 5.00 V
   Component: 39 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD28A4XK
   Coding: 0013113
   VCID: 3D71004D6448AEA7B2-8068
   Subsystem 1 - Serial number: 6332MSME41134432-
   Subsystem 2 - Serial number: 6342MSME4020391B2
   Subsystem 3 - Serial number: 6352QSME680B0D18O
   Subsystem 4 - Serial number: 6362QSME6007312EB
   Coding: 0012102
   Coding: 0004103
                    Reset counter: 234
                    Mileage: 62683 km
                    Time: 21:27:01
                    Reset counter: 234
                    Mileage: 62683 km
                    Time: 21:49:08
                    Fault Status: 00110100
                    Reset counter: 234
                    Mileage: 62683 km
                    Time: 21:27:02
                    Reset counter: 234
                    Mileage: 62683 km
                    Time: 21:49:09
                    Reset counter: 234
                    Mileage: 62683 km
                    Time: 21:26:17
   Coding: 0000052
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
                    Fault Status: 01101101
                    Reset counter: 194
                    Reset counter: 234
                    Mileage: 62683 km
                    Time: 21:49:08
   Coding: 0000052
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74E7E56917822FEF8D-8020
   Coding: 0100040004
                    Reset counter: 234
                    Mileage: 62683 km
                    Time: 21:49:12
End-------------------------(Elapsed Time: 01:45)--------------------------
