Hi,
Got a Q7 with the suspension stuck up, and I cannot get any corner to move up or down.
Measured levels are : -
FL = 450
FR = 430
RL = 530
RR = 505.
Error code is 01400, which can be cleared, but returns when vehicle moves.
Also cannot get into adaption to reset the levels.
I am using security access code 31564, but it refuses to accept, giving Error code 22.
Last log attached.
I would appreciate some help.
Thanks,
Mike
FL = 450
FR = 430
RL = 530
RR = 505.
Last log attached.
Wednesday,31,December,2014,14:05:47:03847
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: License Plate: E4LCB
Mileage: 121300km-75372mi Repair Order:
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 42 46 47 4F 52 56
61 62 6F 72 76
Mileage: 121300km-75372miles
Address 01: Engine
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 FS HW: 09D 927 750 FS
Component: AL 750 6A 1000
Revision: 00H64000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 040C691F471418014B3-8051
Address 03: ABS Brakes Labels: 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 D
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0103569
VCID: 295218AB80F62569185-807C
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500811533
Coding: 0000147
VCID: 63CE4A83A25ABF39129-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: Redir Fail!
Part No SW: 4L0 910 730 J HW: 4L0 035 729
Component: MMI Cockpit H15 0410
Revision: C61150CE Serial number: AUZ6Z2G6UJ38P3
Coding: 0550522
VCID: 2E58EBB7B9184251CD7-807B
Subsystem 1 - Part No: 4L0 910 609
Component: E0380 BedienteilH02 0060
Subsystem 2 - Serial number: 00000000808987
Subsystem 3 - Serial number: 0111.07.070000000100010454ÿ
Subsystem 4 - Serial number: 010454ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000030052422
Coding: 0001046
VCID: 61C2408BB846AD29005-8034
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Coding: 0010101
VCID: 3162F0CBA8265DA9D05-8064
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H09 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150059
Shop #: WSC 31414
Address 0E: Media Player 1 Labels: None
Coding: 0550522
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH42 0230
Revision: 03H42000 Serial number: 00399D039CHW
Coding: 0014129
Subsystem 1 - Serial number: 6332QSME32711A234
Subsystem 2 - Serial number: 6342QSME320B4C51E
Subsystem 3 - Serial number: 6352QSME32733E63I
Subsystem 4 - Serial number: 6362QSME30472943A
Subsystem 5 - Serial number: 63734SME2D6C35155
Subsystem 6 - Serial number: 63834SME2E24767BC
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H02000 Serial number: 90026071870474
Coding: 0102042
VCID: 27561E9396E213190E1-8072
Component: E0221 H02 0030
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 900 C HW: 4L0 920 950 G
Component: KOMBIINSTR. M73 H16 0220
Revision: 00100000 Serial number: 65W74Y377
Coding: 3617458
Shop #: WSC 00613 210 51240
VCID: 2044058FF3CCE4214FB-8075
Coding: 3617458
Coding: 3617458
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 D
Component: Heizgeraet H08 0080
Revision: 0000000C Serial number: 00000009014264
Coding: 0000001
VCID: 60C4458FB34CA4210FB-8035
00664 - Fuel gauge
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B076258007
Coding: F55B9E5F30020200
VCID: 2D5AECBBB41E3949F4D-8078
Address 34: Level Control Labels: None
Part No SW: 4L0 910 553 C HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7660
Revision: --H03001 Serial number: 15.1528-0096.2
Coding: 0015510
VCID: 2A50E7A785F02E7111F-807F
01400 - Suspension Level Control
001 - Upper Limit Exceeded
Fault Status: 11100001
Reset counter: 178
Mileage: 121302 km
Date: 2014.12.31
Time: 15:07:21
Error Code: 66
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0150
Revision: 00000000 Serial number: “
Coding: 0002651
VCID: 2F66F6B3BE124B59C61-807A
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 F HW: 4L0 907 289 C
Component: Komfortgeraet H07 0040
Revision: 0040 --- Serial number: 01050692630000
Coding: 4202747
VCID: 336EFAC3523A6FB9A29-8066
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Fault Status: 01101100
Reset counter: 178
Mileage: 112346 km
Date: 2013.11.04
Time: 09:31:05
Address 47: Sound System Labels: 4F0-910-7xx-47.lbl
Coding: 0550522
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000025990
Coding: 0011101
VCID: 5EB87B77893892D13D7-800B
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0150
Revision: 00000000 Serial number: EC�
Coding: 0002651
Address 56: Radio Labels: None
Coding: 0550522
Part No SW: 4L0 910 181 A HW: 4L0 915 181
Component: J0644 BEM H12 0690
Revision: -------- Serial number: 00000000011944
Shop #: WSC 00045 210 90248
VCID: 254A149BECEE01093CD-8070
Subsystem 1 - Part No: 4F0 915 105 C
Component: von VA0 2706150196
Coding: 344630393135313035432056413032373036313530313936
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0150
Coding: 0002058
Address 6F: Centr. Conv. II Labels: 4L0-910-290.lbl
Part No SW: 4L0 910 290 HW: 4L0 907 290
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002897759-----
Coding: 0000001
VCID: 65CA549BAC6EC109FCD-8030
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0150
Coding: 0002058
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Component: Parkhilfe 4-Kan H09 0060
Revision: 00H09000 Serial number: 06220718303711
Coding: 0001046
End-------------------------(Elapsed Time: 02:32)--------------------------
Thanks,
Mike
