2013 golf 2.5 P0491 code
Doginu
So Cal
C?ID=43307
Recent purchase runs fine 300k miles secondary air blows great, replaced cracked PCV diaphragm. Line to Combi Valve looks good installed new sensor for that line...? ideas
Thx, Rich
Saturday,31,August,2019,12:16:25:13139
VCDS Version: Release 19.6.1 Running on Windows 7 x86
Address 01: Engine Labels: 07K-906-055-CBT.clb
Control Module Part Number: 07K 906 055 DA HW: 07K 907 309 B
Component and/or Version: 2,5l R5/4V G01 3850
Software Coding: 0000075
Work Shop Code: WSC 49139 001 1048576
VCID: 70E4440A639040CF69-8024
001169 - Secondary Air Injection System: Bank 1
P0491 - 000 - Insufficient Flow
Mileage: 500958 km
Date: 2010.14.19
Time: 21:18:56
RPM: 1379 /min
Load: 40.8 %
Temperature: 28.0°C
Temperature: 26.0°C
Absolute Pres.: 960.0 mbar
Voltage: 14.224 V
Readiness: 0000 1100
Doginu
So Cal
C?ID=43307
Tuesday,03,September,2019,17:10:56:13139
VCDS Version: 19.6.1.0
VIN: WVWBB7AJ9DW125679   License Plate:
Mileage: 501270km-311474mi   Repair Order: 007
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56
VIN: WVWBB7AJ9DW125679   Mileage: 501270km-311474miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 DA    HW: 07K 907 309 B
   Component: 2,5l R5/4V      G01 3850
   Revision: T4H06---    Serial number:
   Coding: 0000075
   Shop #: WSC 49139 001 1048576
               P0491 - 000 - Insufficient Flow - MIL ON
                    Fault Status: 11100000
                    Mileage: 501101 km
                    Date: 2014.01.22
                    Time: 21:40:20
                    RPM: 1359 /min
                    Load: 46.3 %
                    Temperature: 32.0°C
                    Temperature: 32.0°C
                    Voltage: 13.589 V
   Part No SW: 09G 927 750 LM    HW: 09G 927 750 LM
   Component: AQ 250 6F           2252
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 07160FD6761E6777D8-8052
   Revision: 00H31001
   Coding: 114B400C492400FF881102EB92220041B70000
   VCID: 7DFA6D3EE4C23DA7F2-8028
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 58
                    Mileage: 500897 km
                    Date: 2014.01.18
                    Time: 01:50:14
                    Count: 3
                    Count: 14
                    Count: 12288
                    Count: 16401
                    Count: 44032
                    Count: 255
Address 08: Auto HVAC
   Part No SW: 1K0 937 084 J    HW: 1K0 937 084 J
   Component: BCM PQ35  B   111 0709
   Revision: AC111709
   Coding: 6F180A1A90272A04008800C11000044448010386424D8960648020200040
   VCID: 356AB51E9C7225E77A-8060
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 16011  26  0512
   Coding: 009795
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R019ZJX
   Coding: 00004737
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C7CA03AB758F4AF85-8068
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00005VK000
   Serial number: 3572MSME07472277ZZZT
   Serial number: 3582MSME63611276ZZZQ
   Serial number: 3512QSME76302365ZZZN
   Serial number: 3522QSME54492564ZZZV
   Serial number: 35527SME0F09122FZZZK
   Serial number: 35627SME0F1E102FZZZP
   Part No SW: 5K0 953 507 AE    HW: 5K0 953 549
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90422MAQ000B3
   Coding: 5880140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 73EE4B06DA867BD794-8026
   Part No SW: 5K0 920 973 B    HW: 5K0 920 973 B
   Component: KOMBI         H05 0705
   Coding: 270F01
   VCID: 3064840A6B1000CF29-8064
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 260113F2000380
   Coding: 350000
   VCID: 74EC481AD7887CEF8D-8020
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         002 0002
   Revision: 00002000    Serial number: 1225223RMDJM07
   Coding: 0000002
   VCID: 7EF86A3229C426BFEB-802A
   Component: IMMO          H05 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD056628D4CBA1F27-803E
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2117
   Coding: 0001076
   VCID: 3162810EA81A09C726-8064
01706 - Switch for Mirror-Adjust (E43)
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   VCID: 3776BF16467ED7F768-8062
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001076
   VCID: 32608E02AD1C32DF5F-8066
   Part No SW: 1K0 035 164 D    HW: 1K0 035 164 D
   Component: LOW NAR       H02 0004
   Revision: -----03S    Serial number: VWZ4Z6L3216070
   Coding: 05000400040005
   VCID: 234E7B4622E6AB57A4-8076
End-------------------------(Elapsed Time: 11:44)--------------------------
Doginu
So Cal
C?ID=43307
No, I didn't. How would I go about this?
Doginu
So Cal
C?ID=43307
Is this covered by the Dealer or any idea of the cost involved?
Doginu
So Cal
C?ID=43307
After codes cleared
Scanned with car running..
Tuesday,03,September,2019,17:43:15:13139
Mileage: 501270km-311474mi   Repair Order: 008
   Coding: 0000075
Readiness: 1110 1101
   Coding: 0000840
   Revision: 00H31001
                    Reset counter: 74
                    Mileage: 501270 km
                    Date: 2014.01.24
                    Time: 05:14:15
                    Count: 12
                    Count: 12288
                    Count: 16401
                    Count: 43264
                    Count: 254
   Part No SW: 7N0 907 426 BG    HW: 7N0 907 426 BG
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010002002
   VCID: 7AF06622FDEC0A9FD7-802E
   Revision: AC111709
   Coding: 009795
   Coding: 00004737
   Coding: 5880140000
   Coding: 270F01
   Coding: 350000
   Coding: 0000002
   Coding: 0001076
   Revision: 00H22000
   Coding: 0001076
End-------------------------(Elapsed Time: 10:39)--------------------------
Doginu
So Cal
C?ID=43307
i have no idea what that means
Doginu
So Cal
C?ID=43307
He is saying you are two times the useful life warranty, huh OP?
Cross to carry...
I'm trying to get this car registered, I have no transportation since my truck was stolen. I've never posted on this forum and all I get is sarcasm. I'm not looking for a hand out. Just point me in the right direction. If it's my ECU can you do this? price and turnaround time...
Gone But Not Forgotten
Cross to carry...
You asked if this was under some type of warranty coverage and I believe Uwe answered you, no?
Did you ask the local VW dealer to do it for a reasonable fee & close to you and so you can get this done to your timeline expectations, I believe I already asked this, no?
https://forums.ross-tech.com/showth...2-5-P0491-code&p=175447&viewfull=1#post175447
Could it be covered as a post useful life modification that would be still the dealers responsibility, I wonder?
Doginu
So Cal
C?ID=43307
ECU
Thank You, I will look into that.
Doginu
So Cal
C?ID=43307
Went to the Dealer, there was no update that applied to my car. Pulled the plugs, they looked great. Gap was opened from all the miles on them.
I was concerned that I had carbon build up in the head, I powered the Secondary air pump and ran the output tests. It's not blocked, the air blew the latex gloves off I had on the exhaust tips. Any other areas to check?
