2012 seat Ibiza 1.6TDI fuel rail pressure to low. 0087.
sainzy70
Peebles, Scotland
C?ID=362860
2012 seat Ibiza 1.6TDI fuel rail pressure to low. 0087 ?
sainzy70
Peebles, Scotland
C?ID=362860
Tuesday,30,July,2019,08:16:28:26536
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
VIN: VSSZZZ6JZCR122168   License Plate:
Chassis Type: 6J-SE25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 44 4B 56 77
VIN: VSSZZZ6JZCR122168   Mileage: 90830km-56439miles
   Part No SW: 03L 906 023 LE    HW: 03L 906 023 Q
   Component: R4 1.6l TDI   H33 9978
   Revision: --H33---    Serial number:
   Coding: 00114016002500080000
   ASAM Dataset: EV_ECM16TDI02103L906023LE 003011
   ROD: EV_ECM16TDI02103L906023LL.rod
   VCID: 74B1DDCFEE3D5527DE9-8020
10116 - Fuel Rail/System Pressure
          P0087 00 [096] - Too Low
                    Mileage: 90827 km
                    Date: 2019.07.29
                    Time: 22:23:14
                    Engine speed: 2748.25 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 75 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 14.118 V
                    Fuel high pressure: actual value-FUP_FIL: 109.546 MPa
                    Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000000
                    Fuel level-FTL_CAN: 39 l
                    Fuel temperature-TFU: 27 °C
                    Fuel Metering Valve-VCV: 32.184 %
                    Fuel Pressure Regulator Valve-PCV: 41.743 %
                    Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 145922.852 kPa
7476 - Fuel Pressure Regulation Valve 2 Control Difference
          P229A 00 [096] - Pressure too Low
                    Mileage: 90827 km
                    Date: 2019.07.29
                    Time: 22:23:14
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
   Part No SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Coding: 100200DB006F00B4082600E800D900000000
   Shop #: WSC 04941 000 00000
   VCID: 0059811FAA457987CA1-8054
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6J0 820 043 C    HW: 6J0 820 043 C
   Component: Climatronic   H07 0606
   Revision: S0000000
   VCID: 2411ED8F1EDD85A78E9-8070
   Part No SW: 7H0 937 089 F    HW: 7H0 937 089
   Component: BCM T5GP Li4  H50 0254
   Revision: BS050001    Serial number: 0465 016120173
   Coding: 24880BE88861250093300EF06ECB8EC80F80602F608C2009200000000000
   Shop #: WSC 64564 324 38760
   VCID: 392F2CFB895FE84FCDF-806C
   Component: RLS 010212 05  54  0403
   Coding: 02242D
   Subsystem 2 - Part No SW: 6R0 959 802 N    HW: 6R0 959 802 N  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 3110
   Coding: 030000
   Subsystem 3 - Part No SW: 6R0 959 801 Q    HW: 6R0 959 801 Q  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 3110
   Coding: 020000
   Subsystem 4 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K8 951 605 B
   Subsystem 6 - Part No: 1K8 951 171 A
   Subsystem 7 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3121
   Subsystem 8 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3121
Address 10: Park/Steer Assist (J446)       Labels:| 6J0-919-475.clb
   Part No SW: 6J0 919 475 B    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H08 0008
   Revision: --------    Serial number: 36861132200647
   Coding: 000007
   Shop #: WSC 06402 785 00200
   ASAM Dataset: EV_SE250ParkiAssis2 S01006
   ROD: EV_SE250ParkiAssis2.rod
   VCID: 353720CBA5C70C2F297-8060
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagA0D H09 0020
   Revision: --------    Serial number: 003GX012VZ7%
   Coding: 003044
   Shop #: WSC 06401 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD6337DC3973D7545-801E
   Serial number: 3495RRB404R126SEC20E
   Serial number: 3505RRB404P126SEH0T-
   Part No SW: 6J0 920 903 H    HW: 6J0 920 903 H
   Component: KOMBI         H02 0504
   Coding: 410A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 2F3B12A3479B36FF63B-807A
   Part No SW: 6N0 909 901     HW: 7H0 937 089
   Component: GW-K-CAN TP20 H50 0254
   Revision: BS050001
   Coding: 322300
   VCID: 70B9D1DF9AA569073A1-8024
   Component: IMMO          H02 0504
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC3B7BCF993D7745-803E
   Part No SW: 6J0 035 342 E    HW: 6J0 035 342 E
   Revision: A1001003    Serial number: 7661738846
   Coding: 020000
   VCID: 2615F78768E177B790D-8072
   Part No: 6R0 423 156 B
   Coding: 10121
   Shop #: WSC 06402
   VCID: 2F3B12A34E5B36FF63B-807A
Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
   Part No: 6J0 959 441 A
   Component: MF-Modul       0007 0001
   Coding: 0000002
   Shop #: WSC 77005 000 00000
   VCID: 313F14DB5D2F200F75F-8064
Address 56: Radio (J503)       Labels:. 6J0-035-153.clb
   Part No SW: 6J2 035 153 G    HW: 6J2 035 153 G
   Component: Radio         H15 0204
   Revision: R0000000    Serial number: SEZAZ2L1961825
   Coding: 0005020002
   VCID: 2A0D03B77CF953D7B45-807E
   Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
   Component: TELEFON       H13 2730
   Revision: 1B001001    Serial number: 00007661841208
   Coding: 0200000001010110
   ASAM Dataset: EV_UHVNA A01015
   ROD: UHVNA.rod
13635840 - Supply voltage
          U1011 00 [000] - Voltage too Low
          [Klemme 30: unterer Grenzwert unterschritten]
          U1400 00 [000] - -
End----------(Elapsed Time: 01:58, VBatt start/end: 12.4V/12.4V)-----------
Tuesday,30,July,2019,08:12:40:26536
VCDS Version: Release 19.6.0 (x64) Running on Windows 10 x64
                Address 01: Engine       Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 LE    HW: 03L 906 023 Q
  Component and/or Version: R4 1.6l TDI   H33 9978
           Software Coding: 00114016002500080000
            Work Shop Code: WSC 131071 1023 2097151
              ASAM Dataset: EV_ECM16TDI02103L906023LE 003011 (SE25)
                    Mileage: 90827 km
                    Date: 2081.14.23
                    Time: 22:23:14
                    Mileage: 90827 km
                    Date: 2081.14.23
                    Time: 22:23:14
sainzy70
Peebles, Scotland
C?ID=362860
Sorry but I'm a novice when it comes to mechanics. Looking to see if there are any common failures a diyer can do?
sainzy70
Peebles, Scotland
C?ID=362860
VCDS Version: Release 19.6.1
Mileage: 92973 km
Date: 2083.14.11
Time: 08:19:06
Engine speed: 1418.75 /min
Vehicle speed: 39 km/h
Coolant temperature: 95 °C
Intake air temperature: 17 °C
Voltage terminal 30: 14.231 V
Fuel high pressure: actual value-FUP_FIL: 112.439 MPa
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
Fuel level-FTL_CAN: 28 l
Fuel temperature-TFU: 30 °C
Fuel Metering Valve-VCV: 21.228 %
Fuel Pressure Regulator Valve-PCV: 50.626 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 129931.641 kPa
sainzy70
Peebles, Scotland
C?ID=362860
please see auto scan in previous posts I've made
sainzy70
Peebles, Scotland
C?ID=362860
Not sure how to test high pressure fuel pump?
Threads merged. Please refrain from opening multiple threads about the same problem in the same car.
dieseldub
Bay Area, CA
C?ID=28764
I would start by consulting the manual on what the fuel pressure should be on the feed side to the HPFP. Though I thought I read somewhere that many 1.6s come with their own low stage pump built into the HPFP like an older injection pump and thus don't even use an in tank or intermediate pump, but I don't know for certain, we never got them here in the U.S.. We only got 2.0L TDIs, some of which have both in tank and intermediate pump, the others have only the in tank pump but one that operates at a much higher pressure than the older two stage setup.
Verify you're getting correct fuel TO the HPFP first, and if you are, then I would remove the fuel metering valve that bolts to the top of the HPFP and check for metal particles on the screen of the valve. If metal is present, you're going to need to replace the entire fuel system most likely. HPFP, rail, lines, injectors at a minimum.
If no metal is present and, once again having already verified there's no loss of pressure or no restriction on the feed side to the HPFP, there's still the possibility that it once had water contaminated fuel and is causing either or both the metering valve and the pressure regulator valve (on one end of the fuel rail) to stick and cause intermittent fuel pressure issues. I've had a few that actually caused fuel rail pressure TOO HIGH codes as well, and subsequent limp mode. If this is the case, as you remove and open up more of the high pressure fuel system, you might notice a rust discoloration in some of the parts.
