2016 GOLF R DQ500 BASIC SETTING ABORT ISSUE
JRMS
NJ, USA
C?ID=362617
Good Afternoon all.
I have a 2016 Golf R that I have swapped a DQ500 into. I have been fighting with issues for a long time on this car. finally was able to install a new mechtronics unit which leads me to my new issue.
When I try to perform basic setting for the transmission I get abort code 10. Anyone know what that is?
ign on
engine at idle
dsg fluid 65 deg c
parking brake on
vehicle level
start the adaptation and i get aborted safety reasons.
no fault codes.
attached is the auto scan and controller map. let me know if anyone could shed some light on this for me.
Wednesday,28,August,2019,00:02:49:11506
VCDS Version: 19.6.1.0 (x64)
Dealer/Shop Name: 3
VIN: WVWVF7AU0HW142856   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
          55 5F 75 A5 A9
VIN: WVWVF7AU0HW142856   Mileage: 25462km-15821miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 I718
   Revision: --H13---
   Coding: 091D00122466000E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
   ROD: EV_ECM20TFS0208V0906259H.rod
   VCID: 45818740C48D1467EA-8010
Readiness: 1010 0101
   Part No SW: 0DL 300 043 T    HW: 0DE 927 711
   Component: TVS DQ500     H12 9999
   Revision: 00H12V32
   VCID: 3E73E8ACA15B47BFAB-806A
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 63206000000865
   Coding: 01FA6BA15424096E457F030540C96980D62A90A2C0029637184050D8C2A8430000000012121212B835351919323200
   VCID: 79F93BB0F8F5A087DE-802C
0128 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2018.12.12
                    Time: 00:40:27
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 222
                    Mileage: 25462 km
                    Date: 2018.12.12
                    Time: 01:02:23
4202 - Rear Right ABS Wheel Speed Sensor
          C101D F1 [008] - Magnetic Field too Low
                    Reset counter: 182
                    Mileage: 25462 km
                    Date: 2018.12.12
                    Time: 01:16:47
32928 - Function Restricted due to Insufficient Voltage
          U1400 00 [009] - -
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2019.01.17
                    Time: 01:45:40
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0423411988
   Coding: 032C0C
   VCID: 3B75E1B8B24952978C-806E
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010000010500001251140A
   Shop #: WSC 12345 123 61029
   VCID: 6DD11FE0BCBD0C2742-8038
   Air quality sensor:
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 181
                    Mileage: 25462 km
                    Date: 2018.12.12
                    Time: 01:02:27
                    Outside air temperature: 28.5 °C
                    Engine speed: 0 /min
                    Temperature after evaporator: 32.7 °C
                    System run time-Terminal 15 on: 5 s
          B10CD 00 [008] - -
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2018.12.14
                    Time: 18:06:58
                    Voltage terminal 30: 7.9 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 3
                    CAN input signal(s) status-Back-up light: OFF
   Part No SW: 5Q0 937 085 BL    HW: 5Q0 937 085 AF
   Component: BCM MQBAB HNA H24 0175
   Serial number: 01061631400540
   Coding: 00011B46C041A2E169E44000091407201800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 04075A448F37ED6FBD-8050
   Component: WWS    161024  043 0551
   Serial number:         161107073447
   Component: RLHS  042 0105
   Serial number: S3Y16M11D21H10M36S25
   Coding: 00A8DD
131330 - Supply voltage
                    Reset counter: 223
          U1400 00 [008] - -
                    Reset counter: 223
136458 - Terminal 15
          B1148 15 [008] - Open or Short to Plus
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2019.01.17
                    Time: 01:45:35
   Revision: --------    Serial number: 39331631710835
   Coding: 0071155011
   VCID: 43859958CAB92A57C4-8016
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [008] - Open Circuit
                    Reset counter: 180
                    Mileage: 25462 km
                    Date: 2018.11.27
                    Time: 05:19:05
          U1400 00 [008] - -
                    Reset counter: 223
13637120 - Databus
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2018.12.15
                    Time: 01:36:06
13637426 - Databus
                    Reset counter: 222
                    Mileage: 25462 km
                    Date: 2018.12.12
                    Time: 01:02:23
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Coding: 350000C151FFC428949C810530301600000000000000000000
   VCID: 3C77E2A4B74755AF85-8068
7 Faults Found:
2055 - Databus
                    Reset counter: 222
                    Mileage: 25462 km
                    Date: 2018.12.12
                    Time: 01:02:25
                    Voltage terminal 15: 13.0 V
0803 - Databus
                    Reset counter: 222
                    Mileage: 25462 km
                    Date: 2018.12.12
                    Time: 01:02:24
                    Voltage terminal 15: 13.3 V
2086 - Databus
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2018.12.15
                    Time: 01:36:06
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 12.2 V
2101 - Databus
                    Reset counter: 222
                    Mileage: 25462 km
                    Date: 2018.12.12
                    Time: 01:02:23
                    Voltage terminal 15: 12.9 V
2067 - Databus
                    Fault Frequency: 26
                    Reset counter: 222
                    Mileage: 25462 km
                    Date: 2018.11.27
                    Time: 05:45:55
                    Control Module temperature: 44 °C
                    Voltage terminal 15: 14.4 V
2068 - Databus
                    Reset counter: 222
                    Mileage: 25462 km
                    Date: 2018.11.26
                    Time: 06:16:00
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 14.6 V
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2018.12.15
                    Time: 01:28:27
                    Control Module temperature: 31 °C
                    Voltage terminal 15: 7.0 V
                    Status_ACC_System: ACC_Init
   Serial number: 09101641350795
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 387FFEB4837F798F61-806C
   Serial number: 003GCR06HVJ2
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 479D8D48FE81067718-8012
   Occupant Detection:
   Serial number: IBH00000000000602TKH
   Coding: 30324E
   Subsystem 2 - Part No SW: -----------    HW: 480 001 711 16
   Serial number: 35700000000060414F13
   Subsystem 3 - Part No SW: -----------    HW: 480 001 211 16
   Serial number: 358000000006E1819F1S
   Subsystem 4 - Part No SW: -----------    HW: 480 400 911 16
   Serial number: 3510001A72303C8133CV
   Subsystem 5 - Part No SW: -----------    HW: 480 401 211 16
   Serial number: 3520001C123B3B51653V
   Subsystem 6 - Part No SW: -----------    HW: 480 401 411 16
   Serial number: 3550001B52303C82058U
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 411 16
   Component: FrontSensor_P  000 6149
   Serial number: 3560001B52303C83C35$
          B10B4 00 [008] - Function Restriction due to Undervoltage
                    Reset counter: 222
                    Mileage: 25462 km
                    Date: 2018.12.15
                    Time: 01:28:34
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 16111604220439
   Coding: 0C10
   VCID: 09194B70A815B007CE-805C
   Part No SW: 5G1 920 858 B    HW: 5G1 920 858 B
   Component: KOMBI         304 8311
   Coding: 0BAD081A7F88CF0502886B0B5400000000000000
   VCID: 2F6DC5E87631BE3730-807A
13635840 - Supply voltage
                    Reset counter: 223
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005593897
   Coding: 0101000838085900FB00023A9C0F00000001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CF722A4F7C795AFC5-8028
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Serial number: 29160002086150076425
   Coding: 35FFFF
1282 - Supply voltage
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2019.01.17
                    Time: 02:04:13
                    Supply voltage: Terminal 30: 8.4 V
                    Terminal 15: On
   Serial number: HA1-00018.10.16
   Coding: 0001
   VCID: 4A9BB47CED93FB1F07-801E
   Revision: 00000000    Serial number: 16000194265006
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3467CA849F179DEF4D-8060
          U1400 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 223
                    ELV State: 04
                    Information Clamps: 00 00
                    CoCo State: E0 00
                    WFS State: 00 06
                    Vehicle speed: 655.33 km/h
                    Voltage: 35
                    AD-Value H-bridge: 18
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 05
   Serial number: 0421291709
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Serial number: 0421356520
   Coding: 020111
   Serial number: 011116EK100027
   Coding: 003E13208000040000000000
   Serial number: 00000000000012353969
   Coding: 111000
65548 - Supply voltage
                    Reset counter: 223
65799 - Door Warning / Entry Lighting
          B1775 01 [008] - Electrical Failure
                    Reset counter: 222
                    Mileage: 25462 km
                    Date: 2018.12.15
                    Time: 01:36:04
65649 - Lamp for Ambient Illumination
          B1325 13 [008] - Open Circuit
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2018.12.15
                    Time: 01:36:04
589829 - Window Regulator; Rear Driver side
          B131F F5 [008] - Supply Voltage too Low
                    Fault Frequency: 13
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2018.12.12
                    Time: 00:00:19
   Coding: 9102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A7BE4BCBD736B9F97-806E
16272 - Steering Angle Sensor
                    Reset counter: 187
                    Motor status: 00
                    System status: Reset
                    Supply voltage: 10.25 V
                    Temperature: 32.0 °C
                    KFC: 3F
                    KFA: 00 90
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 10.13 V
                    uAdSensI_SwitchedKl30_xdu16: 10.10 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 00 C0
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: activated
                    RP_CNTERR: activated
12289 - Supply voltage
                    Reset counter: 222
                    Motor status: 00
                    Supply voltage: 6.75 V
                    Temperature: 27.0 °C
                    KFC: 30
                    KFA: 00 01
                    uioUdNotFilt_xdu16: 5.08 V
                    uAdSensI_SwitchedKl30_xdu16: 5.09 V
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
11776 - Supply voltage
                    Reset counter: 222
                    Mileage: 25462 km
                    Date: 2018.12.15
                    Time: 01:29:46
                    Motor status: 00
                    Supply voltage: 8.50 V
                    Temperature: 34.0 °C
                    KFC: 2E
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 8.81 V
                    uAdSensI_SwitchedKl30_xdu16: 8.82 V
   Revision: 00000001    Serial number: VWZ8Z1GBA02SJAN
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
          U1400 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2018.12.12
                    Time: 01:02:24
                    Voltage terminal 30: 7.6 V
   Serial number: 251016EJP23167
   Coding: 003E13208600040000800000
   VCID: 428B9C5CD5A3235FCF-8016
   Serial number: 00000000000012039118
   Coding: 091000
                    Reset counter: 223
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2018.12.15
                    Time: 01:31:34
589845 - Window Regulator; Front Passenger side
          B1320 F5 [008] - Supply Voltage too Low
                    Fault Frequency: 13
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2018.12.12
                    Time: 00:00:29
   Coding: 022202010B000400
   VCID: 408F9654DBAF314FD9-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0751
   Coding: 027300020000000051220002001808009F0207F401200105C6
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 326BCC9C650393DF5F-8066
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H50 4065
   Serial number: VWZ6Z9S2501003
   Subsystem 2 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
          U1400 00 [008] - -
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2018.12.14
                    Time: 01:13:22
                    Voltage terminal 30: 7.5 V
          B11CF 53 [009] - Deactivated
                    Reset counter: 180
                    Mileage: 25462 km
                    Date: 2018.11.26
                    Time: 06:14:57
                    Voltage terminal 30: 14.6 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 132 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 07
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 07
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2019.01.17
                    Time: 02:02:12
          U1400 00 [008] - -
                    Fault Frequency: 11
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2018.12.12
   Serial number: 16111612P21265
   Coding: 0003070000000201002213548050490084000E100020
1123173 - Databus
                    Reset counter: 222
                    Mileage: 25462 km
                    Date: 2018.11.26
                    Time: 06:14:51
                    Control Module temperature: 17 °C
                    Outside air temperature: 5.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 605.0 s
                    mid: 02 E0
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
262144 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 223
                    Mileage: 25462 km
                    Date: 2018.12.15
                    Time: 01:28:36
                    Outside air temperature: 25.5 °C
                    System run time: 5.8 s
                    Voltage terminal 15: 6.9 V
                    mid: 00 05
                    Engine_Running_Info: 0
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 160930200242
End---------------------(Elapsed Time: 05:41, udsna)-----------------------
Wednesday,28,August,2019,00:06:42:11506
Dealer/Shop Name: 3
Mileage: 25462km-15821mi   Repair Order:
Gateway Installation List:  5Q0 907 530 AM
47-Sound System -- Status: Cannot be reached 0100
Address 02: DTCs cleared
Address 02,0DL 300 043 T,channel IDE00001-Production mode,adapted from,not activated ,to,activated ,
Address 02,0DL 300 043 T,channel IDE02332-Deactivate production mode,adapted from,00 00 00 ,to,00 00 00 ,
Address 02,0DL 300 043 T,channel IDE06425-Roller test bench mode: functional,adapted from,not activated ,to,activated ,
Address 02,0DL 300 043 T,channel IDE06425-Roller test bench mode: functional,adapted from,activated ,to,not activated ,
darkchina811
ITALY
C?ID=333184
several modules are complaining about insufficient voltage. I would try to fix that first, then clear errors again and see what stays.
JRMS
NJ, USA
C?ID=362617
Yes that was because the battery was dead. installed a new battery. just didn't clear the faults on that Auto scan.
All faults are now cleared.
could the abort be due to the hood being opened?
kamold
Australia
C?ID=241363
...thread hijack alert...
I'm having trouble running basic settings on my DQ500 retrofit also...it aborts with main reason 0 and sub reason 91.
Is anyone able to decode these status codes at all? For both OP and myself?
Mine happens at the point of clutch 1 closure so it looks like a problem with K1 clutch somewhere.
JRMS
NJ, USA
C?ID=362617
haha its all good.
I made sure all codes are clear and have a clean auto scan now.
closed the hood.
still have the same issue with aborting
main abort 0
sub 10
NEtech
Denmark
C?ID=56995
You are looking at these Measurement values, while trying to do Basic Settings ?
IDE02775
IDE02824
IDE02825
JRMS
NJ, USA
C?ID=362617
IDE02775
IDE02824
IDE02825
Sorry for my ignorance but how do you watch the MVB While doing the Basic settings?
NEtech
Denmark
C?ID=56995
While in Basic Settings, press the button [Show Measuring Data], enter the numbers, one at a time, 2775 2824 2825, in search box and select them.
JRMS
NJ, USA
C?ID=362617
I tried that and nothing shows up in the box after selecting any Chanel’s
NEtech
Denmark
C?ID=56995
Start Basic Settings
JRMS
NJ, USA
C?ID=362617
I will do that this evening. what am I looking for exactly?
here is what i found before and after the basic setting
IDE02825 Substatus of abort code basic setting-Basic Settings Sub Status: 10
IDE02824 Main status of abort code basic setting-Basic Settings Main Status: 0
IDE02775 Status of basic setting data-State Of Basic Adjustmentdata: Invalid
also my fluid pressure is 1.2 bar is that normal
JRMS
NJ, USA
C?ID=362617
IDE02775
IDE02824
IDE02825
ok i just performed this and watched the channels
IDE02775 invalid
IDE02824 0 then goes to 2
IDE02825 0 then goes to 10 and aborts
NEtech
Denmark
C?ID=56995
I guess you have looked at this ?
IDE02775 Is "invalid", so BS will not work, either procedure or some fault.
If you use the original tester, we maybe (or maybe not) get to know what "main reason 0" and "sub reason 10" means.
kamold
Australia
C?ID=241363
When I tried with that other tester it only gave me the same information - main reason and sub reason. I will try and run it again and then run GFF and see if it gives any more info
JRMS
NJ, USA
C?ID=362617
Yes I did see that post.
I assume the Invalid is my issue. I am trying to find someone with ODIS that can help me..
JRMS
NJ, USA
C?ID=362617
Ok I have an update. Seems that there is something incorrect with the TCU that I have. I have a Brand new RS3 mechatronics that I plugged in and when I check the data state of basic setting it reads Valid where the TCU from the swap Dq500 reads invalid.
So my question for the pros is can I install and adapt the Immobilizer from a Brand new Mechatronic unit from audi that is off of a VIN of an RS3 on this DQ500 in my GOLF R?
I know I would need a pass-thru device or ODIS.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
I don't think the TCU is an Immobilizer participant. You could certainly have Component Protection, but many people report success removing CP with ODIS even in weird retrofit situations, provided you don't try to set/restore things like coding and parameterization at the same time.
kamold
Australia
C?ID=241363
In MQB the transmission needs to be unlocked with ODIS online if swapped.
You can flash it to appropriate software version or use custom which I guess you already had in mind.
JRMS
NJ, USA
C?ID=362617
ok great, yes Using custom software. Thank you.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Correcting myself here, having recently re-read SSP 517, page 42 regarding Immobilizer V shows the DSG mechatronic is now a participant in the Immobilizer scheme.
