UK spec. I have set up my A6 with DRL (activated on MMI) but I want to change the lights used. I just want parking nothing more.
Currently it's using parking (side) lights and dipped headlights. I tried changing the country but only US config was different and used parking and fog lights.
Same for the coming and leaving home lights. I want to swap from fogs to parking lights.
I tried adjusting section 09 byte 02 (I tried byte 03 also) but it did nothing and though no errors were shown it didn't take the change.
Latest scan (before changing coding in 09 to 0010121):
Sunday,27,October,2013,22:17:17:42852
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ4F06N117103 License Plate: FV55 RAU
Mileage: 318600km-197968mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 0F 15 16 17 19 37 42 46 47 4F 52 53 56
61 62 72 76
VIN: WAUZZZ4F06N117103 Mileage: 318600km/197968miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F2 910 402 C HW: 4F0 907 401 B
Component: 2.7L V6TDI G000SG 0010
Revision: --H01--- Serial number:
Coding: 0011322
Shop #: WSC 02334 785 00200
VCID: 1F47A16BCE1AB8E68D9-804A
004120 - Intake Manifold Runner (Bank 2)
P1018 - 001 - Lower limit not reached
Fault Status: 01100001
Mileage: 318579 km
Date: 2013.10.27
Time: 15:09:53
Torque: 0.0 Nm
Voltage: 11.63 V
Duty Cycle: 20.5 %
Duty Cycle: 88.8 %
Duty Cycle: 20.5 %
005445 - Throttle Valve Controller
P1545 - 002 - Malfunction
Fault Status: 01100010
Mileage: 318579 km
Date: 2013.10.27
Time: 15:09:54
Torque: 0.0 Nm
Voltage: 11.63 V
Duty Cycle: 92.7 %
Bin. Bits: 010
Mass Air / Rev.: 0.0 mg/str
005662 - Glowplug for Cylinder 5 (Q15)
P161E - 001 - Open Circuit
Fault Status: 01110001
Mileage: 318579 km
Date: 2013.10.27
Time: 15:14:46
RPM: 966 /min
Torque: 74.1 Nm
Duty Cycle: 1.0 %
Voltage: 11.48 V
Duty Cycle: 23.3 %
Temperature: 11.7°C
004195 - Fuel Pressure Regulation
P1063 - 001 - Control Range Not Reached - MIL ON
Fault Status: 11110001
Mileage: 318582 km
Date: 2013.10.27
Time: 15:04:58
RPM: 1827 /min
Torque: 444.6 Nm
Speed: 85.1 km/h
Duty Cycle: 71.7 %
Voltage: 13.68 V
Pressure: 859.1 bar
Duty Cycle: 39.8 %
Readiness: 1 2 0 0 0
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
Component: ESP 8.0 front H04 0090
Coding: 0020871
Shop #: WSC 02325 785 00200
VCID: 2C5D46A78FAC537E18B-8079
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10604000302669
Coding: 0000017
Shop #: WSC 00590 210 61861
VCID: E3CF6D9B22F25C06691-80B6
Subsystem 1 - Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H45 0070
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350KT057622196
Coding: 0000002
Shop #: WSC 02335 785 00200
VCID: 254BB383EC466236C75-8070
Component: Bedienteil MMIC6H03 0050
Subsystem 2 - Serial number: 00000000277123
Subsystem 3 - Serial number: 0114.11.050000000100010160ÿ
Subsystem 4 - Serial number: 010160ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043 J
Component: KLIMABETAETIGUNGH12 0160
Revision: 00000027 Serial number: 00000000207203
Coding: 0001046
VCID: DBBF557B1A8264C6211-808E
Part No SW: 4F0 910 279 E HW: 4F0 907 279 B
Component: ILM Fahrer H15 0190
Coding: 0010101
VCID: 2B5F45BB8AA25446111-807E
Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0150
Coding: 00062736
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE8020478
VCID: 1C3D9667DF0CA3FE68B-8049
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1229T8000349
Coding: 0000001
Shop #: WSC 02323 785 00200
VCID: 244DAE87E77C9B3ED0B-8071
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4E AIRBAG AUDI8RH29 0260
Revision: 07H29000 Serial number: 0037LD0B6UV-
Coding: 0013381
VCID: 2953BFB3805E4656E3D-807C
Subsystem 1 - Serial number: 6332CSME0C58045E9
Subsystem 2 - Serial number: 6342CSME0C583C48E
Subsystem 3 - Serial number: 6352QSME074E1605E
Subsystem 4 - Serial number: 6362QSME052C4567J
Subsystem 5 - Serial number: 63734SME02527A4B%
Subsystem 6 - Serial number: 63834SME063C322F2
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90055053240161
Coding: 0102041
VCID: E6C9748FD1C0292E8EF-80B3
Component: Lenkradmodul H07 0090
Part No SW: 4F0 910 930 A HW: 4F0 920 980 M
Component: KOMBIINSTR. M73 H16 0630
Revision: 00200000 Serial number: 4PX31MJC5
Coding: 2308443
Shop #: WSC 06795 116 50998
VCID: 2143A793F86E8E16BBD-8074
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 1300805B210123
Coding: ECEE53C41B2904
VCID: 2757B98B964A7026F59-8072
Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
Component: MNS ECE H47 1060
Revision: 00000000 Serial number: 364K-057509824
VCID: 3B7F75FB7AC2C4C6811-806E
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0080
Revision: 00-00000
Coding: 0002682
Shop #: WSC 02327 785 00200
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H22 0170
Revision: 01700022 Serial number: 01008809340000
Coding: 0008443
VCID: 2E594CAFB9B0216E36F-807B
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H10 0350
Revision: 32S00001 Serial number: 02711050183176
Coding: 0000003
VCID: 2241A89FFD68950EA27-8077
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000161557
Coding: 0001103
VCID: DEB95C6F099071EE46F-808B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0080
Revision: 00-00000
Coding: 0002682
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000511
VCID: DDBB5B6304966AF65F5-8088
Part No SW: 4E0 910 541 T HW: 4F0 035 541 E
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 352KL057601243
Coding: 0000001
VCID: 316357D3A88E3E962BD-8064
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000164007
Shop #: WSC 00000 384 00290
VCID: 234FAD9BE2729C06A91-8076
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 1511210356
Coding: 344630393135313035442056413031353131323130333536
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0050
Coding: 0002090
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0050
Coding: 0002090
Part No SW: 4F0 910 283 B HW: 4F0 919 283 B
Component: Parkhilfe 4-Kan H09 0030
Revision: 00H09000 Serial number: 11720531212268
Coding: 0200006
End ---------------------------------------------------------------------
