A4 B9 Avant MY16 OEM alarm retrofit faults
Ciamardo
Italy
C?ID=105004
Hi guys, I retrofitted the complete alarm system on my A4 B9 which consists on a front alarm horn + the interior monitoring system. After doing that, I coded what was necessary on module 46 and I got the horn working (also beep on closing/opening works) but the interior monitoring system doesn't. I did an autoscan ad this is the fault it gives me (I post only the involved unit, the others are ok and have no faults):
   Part No SW: 8W0 907 064 BC    HW: 8W0 907 064 C
   Component: BCM2 MLBevo   018 0327
   Coding: 013400004F0000E0E38980006E00080031004000104702502F0400000504803F001F0000000000
   Shop #: WSC 06335 790 00001
   ASAM Dataset: EV_BCM2HellaAU736 011012
   ROD: EV_BCM2HellaAU736_011_AU49.rod
   VCID: 7EB0337EE13986BFEB-802A
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY161022GHN
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000099623377
   Subsystem 3 - Part No SW: 3AA 962 243 G    HW: 3AA 962 243 G
   Component: GEB.F.Heckoef  H16 0903
   Serial number: 84390097
65598 - Sensor 2 for interior monitoring
          B1332 29 [008] - Signal Implausible
                    Fault Frequency: 70
                    Reset counter: 39
                    Mileage: 130471 km
                    Date: 2019.08.11
                    Time: 20:06:21
                    Supply voltages-Supply voltage: Terminal 30: 12.392 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.419 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.419 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 12 04 38
I checked the button for activation/deactivation of the interior monitoring system and it is correctly wired, as all the other connections. Plus, if I try to disconnect the interior sensors VCDS gives me a different error, like "no communication" or something similar, so I think the fault I have means that the sensors don't work and need to be changed.
Thank you for your help in advance!
Thomas
siLc
Tallinn, Estonia
C?ID=330192
The alarm sensor module 5Q0 951 172 has three sensors. If one is implausible, perhaps check its installation - is it secured in it's proper place?
Ciamardo
Italy
C?ID=105004
Thanks for your reply siLc, yes in fact it has three sensors and the fault is on sensor 2, but the part has only one connection for all the three sensors, so I don't know what to check....it seems one of the sensors is faulty right?
siLc
Tallinn, Estonia
C?ID=330192
I meant the sensors see through a plastic trim piece (usually a grille) to monitor the car interior. Perhaps sensor 2 is out of place and is monitoring a plastic piece inside the headliner, instead of the car interior. Did you buy the sensor module new or used?
Ciamardo
Italy
C?ID=105004
Oh ok, I will check them! I bought it used so maybe during the transport or removing someone moved the sensor...but is it possible that the whole system don't work just for a fault like this?!
Ciamardo
Italy
C?ID=105004
Is it the wrong area for this thread? If yes, sorry it is the first time for me....
Gone But Not Forgotten
https://forums.ross-tech.com/forumdisplay.php?10-Retrofits
Yes please see the door to Boggy land
Ciamardo
Italy
C?ID=105004
Solved! I replaced the interior monitoring sensors and now it works! So maybe sensor 2 was faulty like I thought since the beginning...thanks anyway for your help!
berto
Spain
C?ID=48936
Hi, anyone did B9 alarm retrofit? I tried contact to Ciamardo but seems didn't connect time ago..
Would be helpful if you can share your experience. I noticed the main differences are the sensor module in the roof, the horn, and a switch in the door.
They will be connected by a single wire LIN bus to confort module in the trunk, and will get power from a fuse.
And I think I also have the diagrams to wire the switch in the door module.
any suggestion for wiring the external horn? I suppose here will not be so complex, just find the better way to pass the firewall.
And the most important:
At least for my door modules there is no long coding help, is needed to modify anything to enable alarm switch?
in confort module I saw lots of documented bits, so I suppose will be some related to alarm activation
Thanks in advance!
