2013 Touareg Brake Replacement Challenges
LWitty
US
C?ID=331034
Replaced my brake pads and rotors on my 2013 Touareg recently. Good news is they work and I can stop my car, bad news is I am dealing with 2 indicator lights. The "Brake Pad Ware" light is on as well as the "Brake" indicator light. Was hoping a scan would shed some light on why the "Brake" light is on, but I am not seeing anything helpful (visually check fluid level and seems to be in range, but VW makes it very difficult to tell on this model).
Second issue is I know I damaged one of the wires when installing the pad ware sensors, so I would like to turn off that light if possible. Not seeing anything in 17 Instruments that point to that feature, any help on how to turn that off?
Monday,26,August,2019,15:11:23:50497
VIN: WVGEP9BP6DD003589   License Plate: A
Mileage: 182866km-113627mi   Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
          69 6C 6D 72
VIN: WVGEP9BP6DD003589   Mileage: 182866km-113627miles
Address 01: Engine (J623-CNRB)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 K    HW: 7P0 907 401 K
   Component: 3.0TDI FSA    H17 0011
   Revision: 56H17---
   Coding: 292A4012233600050000
   Shop #: WSC 23342 444 00000
   ASAM Dataset: EV_ECM30TDI0117P0907401K 001012
   ROD: EV_ECM30TDI0117P0907401K.rod
   VCID: 372BD6085FC1D0AF3B3-8062
8863 - Diesel Particulate Filter
          P2459 00 [096] - Regeneration Frequency
17277 - SCR NOx Catalyst Bank 1
          P20EE 00 [096] - Efficiency too Low
   Part No SW: 0C8 927 750 AK    HW: 0C8 927 750 AK
   Component: AL1000 AISIN  001 3398
   Coding: 001368
   Shop #: WSC 41331 001 1048576
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002.rod
   VCID: 75B71C00054D62BFE9F-8020
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 M    HW: 7P0 907 379 A
   Component: MK25A         H36 0436
   Revision: --------    Serial number: 418920010EC815
   Coding: 5B7613C349242556DAF9C89B92DBA4407300
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 47CBA6C82F21A02F4B3-8012
   Part No SW: 4H0 907 064 CK    HW: 4H0 907 064 CK
   Component: BCM2 2.0      H32 0421
   Coding: 09860010000000000000
   VCID: 74B121040EB77BB7DE1-8020
   Subsystem 1 - Part No SW: 7P6 959 754 AD    HW: 7P6 959 754 AD
   Component: FBSTOUAREGIDG  H04 0051
   Serial number: 0512000041786012
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 2312000147086002
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
   Component: Klima 2 Zonen H20 1305
   Coding: B686200A80
   VCID: 7EA5032C307B21E7B85-802A
          U1101 00 [008] - Active
                    Reset counter: 28
                    Mileage: 182117 km
                    Date: 2019.08.10
                    Time: 22:11:17
0243 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 252
                    Mileage: 180832 km
                    Date: 2019.07.24
                    Time: 06:21:09
   Part No SW: 4H0 907 063 BL    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0111
   Revision: 15012002    Serial number: 00000001554352
   Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
   VCID: 73B322180BB97C8FC7B-8026
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    120626  31  0020
   Serial number: 90243400120706154751
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10413081
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000001207120610
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R15DG07
01856 - Temperature Sensor for Heated Seat; Front Right (G345)
                    Fault Status: 00101100
                    Reset counter: 252
                    Mileage: 180832 km
                    Date: 2019.07.24
                    Time: 06:21:00
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
   Component: VW10Airbag025 H05 0025
   Revision: --------    Serial number: 003L00042U1I
   Coding: 000000000000000000000000000000003235
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 41DFB8D001059E1F857-8014
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R1243008U3U
   Serial number: 3575LRB405V1F0BA8O6M
   Serial number: 3585LRB405T1F0BA5H8D
   Serial number: 3515RRB404P1ADPC4GBW
   Serial number: 3525RRB40651ADPCHG8P
   Serial number: 3555NRB400M4UIV8R0S-
   Serial number: 3565NRB400K4UIV8713Y
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Component: Lenks.Modul   H05 0005
   Revision: --------    Serial number: 90372QGQ0001A
   Coding: 000415
   VCID: 3829D534525FDFD7329-806C
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0197198
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 981 F    HW: 7P6 920 981 F
   Component: Kombi         H13 0318
   Revision: 13240077    Serial number: 658260612592029
   Coding: 8B7733022B00CF05020004
   ASAM Dataset: EV_KombiUDSRBVW526 001017
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 40D9BDD40A0F97178A9-8014
   Part No SW: 7P6 907 530 F    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H11 6028
   Revision: --------    Serial number: 00000000602288
   Coding: 0001037500
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3B23CA3863E9F4CFDFB-806E
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650778968
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000034314519
   Coding: 0058130000004001000001010101202020202121202020
   VCID: 3431E1044E373BB71E1-8060
   Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
   Component: TSG FA        H07 0166
   Revision: --------    Serial number: 0000129061681
   Coding: 011D07205E00453005080000
   VCID: 44D1B1C41E978B37AE1-8010
   Revision: 00002001    Serial number: 0180018216
   Coding: 0186123A28B9509480A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 194124326
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO17385727
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO1741322.
   Coding: 191100
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0166
   Revision: --------    Serial number: 0000128888513
   VCID: 3B23CA386369F4CFDFB-806E
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1270201062
   Coding: 01040200
   ROD: EV_ParkbA7.rod
   VCID: 3635DB0C58CB29A7205-8062
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 010A00010F000400
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   VCID: 7CA10924266733F7961-8028
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Coding: 130000
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156F$0C7608462
   Coding: 020007020100000001
   VCID: 211F1850E1C5BE1FE57-8074
   Part No SW: 7P6 035 664 C    HW: 7P6 035 664
   Component: H-BN-NA       H45 0544
   Revision: --------    Serial number: 445G10C7537861
   Coding: 010200050040E1EE41022B0C00000003F0000100
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H26 0045
   Serial number: VWZ8Z9M7900CMT
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0167
   Revision: --------    Serial number: 0000129107491
   Coding: 011C07200000253005080000
   VCID: 3A2DCF3C6C53CDC7C4D-806E
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000086386
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 3FDBBE2877F1E8EFF33-806A
8397058 - Front Left TPMS Sensor
          C1050 31 [009] - No Signal
                    Reset counter: 244
                    Mileage: 182585 km
                    Date: 2019.08.22
                    Time: 17:48:43
                    Vehicle speed: 134 km/h
                    Outside air temperature: 22 °C
                    Reception level antenna 1: 670 mV
                    Offset level antenna 1: 630 mV
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H09 0110
   Revision: 5A001001    Serial number: 00000179754306
   Coding: 020D000000000000
   Part No SW: 7P6 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0020
   Revision: 00H06000    Serial number: 525 PA8J261227
   Coding: 0110001
   VCID: 372BD6085341D0AF3B3-8062
   Part No SW: 7P6 959 107 A    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0620
   Revision: 22010001    Serial number: 170200965
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202137
   ROD: EV_HeckkTouar.rod
   VCID: 3D27C4207DFDFAFFE1F-8068
   Component: TSG HR        H09 0167
   Revision: --------    Serial number: 0000129107393
End----------(Elapsed Time: 02:02, VBatt start/end: 14.4V/14.5V)-----------
Did you do front and rear or just front?
Your brake wear warning light is probably on due to the damaged wire. That's generally a dumb circuit straight to the instrument cluster; continuity in the circuit turns the light off. Where's the damage? On car's wiring or the pad's wiring?
Jef
HQ
So it is a simple circuit that goes from the J519 to ground. J519 to left front to right front to right rear to left rear to ground. Make sure the pigtail connectors of the sensors are secured. /1 of each sensor goes back towards the J519 and /2 of each sensor goes towards ground.
You can unplug a sensor and short /1 to ground and see if that tricks the system. If so, then the point of failure is past that point, plug back up and go down stream towards ground. I guess you should also be able to ohm test /2 to ground and get 0 ohms, if not, go down stream towards ground.
LWitty
US
C?ID=331034
I did front and back rotors and pads.
As for the damaged wire, it was the left front. When trying to remove the clip which is held in the metal bracket, I accidentally pulled the car side wires out of the plug. Thought I hard wired it together correctly, but may not have made a good enough connection. Will take the tire off later in the day and see if I can do a better job connecting to get the light to go off. Will be a few hours before I can do this but will report back later in the day.
LWitty
US
C?ID=331034
Just a quick update. Took off the right front tire and removed the damaged pad sensor connectors to just wires then used a couple of butt connectors and heat shrink to connect the wires directly from the car to the pad sensors, not ideal but not many options given the damage to the connectors. This worked and both the "BRAKE" and "Pad Ware" indicator lights are off so all is now good. Hopefully I do not need to worry about this for another 100k miles (what I got out of the original pads). Thanks for the help.
Jef
HQ
Lulz, you are a VERY optimistic Touareg owner.:D
