Atlas Exterior Light Tweaks - Help Needed
TWs/VW
NW Florida
C?ID=369048
Not sure this is the best thread for this…I’m just a novices here, but with help from this forum I’ve may some successful tweaks to the exterior lights on my 2019 Atlas SEL - that I'm very happy with. (1) Added inner Brake lights and (2) rear Daytime Running lights for better visibility from ‘rear-enders’. Also, as a matter of preference, (3) changed to Fogs only in the front and (4) Reverse lights only in the back during Coming Home/Leaving Home activation. I’d be happy to share some photos and the coding with anyone here who’s interested.
Now, I’m trying to learn how the Atlas headlights might be re-coded, specifically, the Daytime Running lights that go out completely when the turn signal is activated. I know all about the Federal regulations on DRLs – please, no lectures. Is it even possible with the Atlas’ light configuration? Can the DRLs be re-coded to stay on during signal activation; or what I would really like to see is, dimmed DRLs during the turn signal cycle?
I believe Leuchte8FL LB39 (left) and Leuchte9FL RB2 (right) function as High Beam, DRL, Parking light, Turn Signal and Side Marker all in one – this might be a unique configuration for the Atlas. The Dipped beam (or Low beam) function appears to be singularly assigned to Leuchte6ABL LC5 (Left) and Leuchte7ABL RB1 (Right) – please let me know if otherwise.
Shown below is the Factory coding for Leuchte8FL LB39 (left) and Leuchte9FL RB2 (right). Interestingly, these are the only lights on the Atlas coded with a Light function (Lichtfunktion) of “Versorgungsbedarf der LCM Module”. I’m sure this complicates things but I’m not sure how, or for that matter, what coding options to try regarding the LCM.
TW
Autoscan
;SW:5Q0-937-085-BT   HW:5Q0-937-085-BG ---  Cent. Elect.
;Component:BCM MQBAB HNA H38 0273	 Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB	19001
;Sunday	25
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: 0C41A58456CD9757A61-8058
IDE00001-ENG99061-Production mode-Access control	not active
IDE00001-ENG115730-Production mode-Exterior lighting	not active
IDE00001-ENG112304-Production mode-Heckwischer	not active
IDE00001-ENG98647-Production mode-Interior lighting	not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active
IDE00002-Transport mode	active
IDE00820-Activating and deactivating all development messages	not active
IDE02152-Characteristics in production mode	2000 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	short
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	active
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit	200 ms
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit	200 ms
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit	200 ms
IDE02332-Deactivate production mode	0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	8 s
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	16 s
IDE02711-ENG112304-Rear Window Wiper-Heckwischer	logikgesteuert
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer	Keine_Spannungsanforderung
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck	0 ms
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	0.3 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	80 °
IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h
IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht	15 min
IDE03787-Activate left/right hand drive switch-over	not active
IDE04927-IDE01446-Window heater-Running time of heated front window	240 s
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.0 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.0 °C
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer	0 s
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt	not installed
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus	not installed
IDE04927-ENG126845-Window heater-FSH Automatik	active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	320 s
IDE04927-ENG141955-Window heater-heizbare Heckscheibe	installed
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe	not installed
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage	not installed
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv	-2.0 °C
IDE04927-ENG141962-Window heater-Waschduesenheizung	installed
IDE04927-ENG154810-Window heater-window heating front activation time pause	240 s
IDE04928-MAS01577-Anti-theft device-Parking heater	not installed
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system	active
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick	activ
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI	not_active
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder	Horn_verbaut
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor	not installed
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet	No
IDE04928-ENG142249-Anti-theft device-OBD Alarm	not_active
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm	activ
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)	No
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung	No
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme
IDE04928-ENG142008-Anti-theft device-tilt_sensor	No
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung
IDE05143-MAS02985-Writing parameter-Value	130
IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00
IDE05144-Read parameter address	FE 00 00
IDE05145-Light configuration	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 05 44 00 4A 46 00 7F 08 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 1E 00 64 00 00 00 0A 42 00 23 13 17 64 00 00 00 1E 00 64 00 00 00
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler	0
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN	Heizmatten am BCM
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	18.50 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	18.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	18.50 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	18.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	26.00 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	25.50 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	26.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	25.50 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	43.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	42.50 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	43.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	42.50 °C
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI	Keine_Spannungsanforderung
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO	Keine_Spannungsanforderung
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe	not installed
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75	15.7 V
IDE06425-Roller test bench mode: functional	not active
IDE06507-MAS13125-Button in center console-Function of button 1	Start-stop
IDE06507-MAS13129-Button in center console-Function of button 2	not coded/not installed
IDE06507-MAS13132-Button in center console-Function of button 3	not coded/not installed
IDE06507-MAS13135-Button in center console-Function of button 4	Steering wheel heater
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED	LED installed
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich	active
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt	not active
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige	active
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik	active
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active
IDE07007-ENG115720-A/C heater function via remote control-Remote Start	installed
IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut	not installed
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung	active
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein	active
IDE08577-Garage door opener: use of GPS data	not active
IDE08578-Garage door opener: bi-directional communic.	active
IDE08580-Garage door opener: increasing transm. power	not active
IDE08583-Garage door opener: no. of channels	3 channels
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A	not active
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B	not active
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C	not active
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D	not active
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E	not active
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F	not active
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G	not active
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H	not active
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I	not active
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J	not active
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K	not active
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I	not active
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II	not active
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III	not active
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV	not active
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB	not active
IDE08585-Garage door opener: activation via remote key	not active
IDE08778-Garage door opener: surround. target area	30 m
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active
IDE08786-ENG141956-Assistance light functions-Humidity sensor	installed
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion	not active
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor	LIN_REGEN_LICHT_SENSOR
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor	installed
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual	7
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation	not active
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung	not active
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default	not active
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	50%
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	2
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum	50%
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	50%
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer	50%
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn	50%
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen	active
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten	active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active
IDE09731-ENG98648-Int. light: 2nd generation-Interior light	Keine_Spannungsanforderung
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM	not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht	not installed
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel	not installed
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel	not installed
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G	installed
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default	1
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	not installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	30%
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	30%
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	50%
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	50%
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	50%
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	50%
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	75%
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	75%
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	80%
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung	not installed
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar	installed
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik	not installed
IDE10308-Garage door opener: support door name	not active
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode	not active
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1	not active
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2	not active
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3	not active
IDE10350-Garage door opener: programming antenna	External antenna
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	1
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	0.4
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	0
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	1
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	0
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	70%
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	0%
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	0%
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	70%
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	0%
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	0%
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	70%
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	0%
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	0%
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	70%
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	0%
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	0%
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	70%
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	0%
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	0%
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	0%
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	0%
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0%
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	70%
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	0%
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	0%
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	127%
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	0%
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	0%
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	0%
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	0%
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	127%
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	0%
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	0%
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	126%
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	0%
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	0%
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	70%
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	0%
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	0%
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	70%
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	0%
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	0%
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	70%
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	0%
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	0%
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	70%
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	0%
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	0%
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	200 ms
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	2.0 s
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.0 s
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1	0
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	0
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2	0
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3	0
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	0
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	0
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	0
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	0
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	0
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	0
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1	0
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	0
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2	0
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3	0
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	0
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	0
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	0
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	0
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	0
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	0
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1	0
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	0
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2	0
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3	0
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	0
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	0
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	0
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	0
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	0
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	0
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung	installed
IDE11944-ENG141948-Keyless access and start authorization-Kessy	installed
IDE11944-ENG246971-Keyless access and start authorization-Kessy BewegungsüberwachungIDGeber	not active
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen	not active
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen	active
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung	active
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit	not active
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit	not active
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung	not active
IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor	Not available
IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor	Not available
IDE12302-SFT271875-Identification of sub-bus participant-Light switch	Not available
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module	Not available
IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit	Not available
IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System	Not available
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn	Not available
IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof	Not available
IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module	Not available
IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind	Not available
IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender	Not available
IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left	Not available
IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right	Not available
IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left	Not available
IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left	Not available
IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right	Not available
IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right	Not available
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control	Not available
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch	Not available
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin	0
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin	0
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin	0
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin	0
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin	0
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin	0
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin	0
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin	0
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin	0
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin	0
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin	0
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin	0
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin	0
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin	0
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin	0
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin	0
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin	0
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin	0
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin	0
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin	0
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin	0
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin	0
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin	0
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin	0
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin	0
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin	0
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin	0
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin	0
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin	0
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin	0
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung	active
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug	not installed
MAS01490-ENG141950-Energy management-Hybrid vehicle	No
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active
MAS01490-ENG141978-Energy management-Recuperation	active
MAS01490-ENG142037-Energy management-Zweitbatterie	not installed
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	1200 lx
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	2200 lx
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	0 lx
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	600 lx
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	1200 lx
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	2200 lx
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	00 00
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	2000 lx
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway	not active
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain	not active
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity	frueh
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF	not active
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe	not active
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	0 mV
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	0 lx
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	0 mV
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status	not active
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC	00 00 00
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC	First_dtc
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	active
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	active
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler	not installed
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11	0
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12	0
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13	0
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14	0
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15	0
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16	0
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17	0
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18	0
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19	0
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20	0
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21	0
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22	0
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23	0
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24	0
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25	0
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26	0
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27	0
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28	0
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29	0
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30	0
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11	0
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12	0
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13	0
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14	0
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15	0
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16	0
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17	0
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18	0
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19	0
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20	0
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21	0
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22	0
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23	0
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24	0
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25	0
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26	0
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27	0
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28	0
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29	0
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30	0
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11	0
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12	0
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13	0
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14	0
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15	0
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16	0
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17	0
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18	0
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19	0
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20	0
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21	0
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22	0
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23	0
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24	0
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25	0
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26	0
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27	0
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28	0
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29	0
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30	0
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin	0
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin	0
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin	0
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin	0
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin	0
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin	0
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin	0
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin	0
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin	0
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin	0
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin	0
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin	0
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin	0
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin	0
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin	0
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin	0
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin	0
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin	0
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin	0
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin	0
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin	0
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin	0
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin	0
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin	0
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin	0
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin	0
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin	0
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin	0
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin	0
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin	0
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin	0
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin	0
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin	0
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin	0
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin	0
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin	0
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin	0
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin	0
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin	0
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin	0
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin	0
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin	0
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin	0
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin	0
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin	0
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin	0
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin	0
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin	0
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin	0
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin	0
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin	0
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin	0
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin	0
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin	0
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin	0
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin	0
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin	0
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin	0
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin	0
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin	0
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente	Keine_Spannungsanforderung
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0	1
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1	1
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10	1
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11	1
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12	1
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13	1
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14	1
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15	1
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2	1
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3	1
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4	1
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5	1
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6	1
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7	1
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8	1
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9	1
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken	not active
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken	active
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger	separte
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing	not active
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken	not active
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung	not active
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10	not active
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay	50 ms
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken	not active
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen	Warnblinke_zulaessig
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken	active
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen	5
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken	not active
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2	not active
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing	not active
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS	PreCrash_passiv
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links	not active
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts	not active
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken	not active
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing	not active
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken	not active
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz	not active
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max	120 min
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS	not active
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN	not active
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf	not active
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu	not active
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp	H7
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren	not active
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze	350 km/h
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze	350 km/h
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag	Daytime running lights
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL	5 km/h
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich	not active
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument	not active
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut	not installed
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht	active
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	active
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	active
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO	not active
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte	not active
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit	not active
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren	limitieren
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht	No
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit	0 km/h
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA	not active
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion	not active
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe	not installed
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights	not installed
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung	begrenzen auf Mindestverfügbarkeit
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung	begrenzen auf Mindestverfügbarkeit
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht	Aktive Begrenzung
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf	0 ms
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten	Fog light
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus	automatic
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis	Driver door
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach	not active
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH	Sollspannungsanforderung 13.5
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light	Sollspannungsanforderung 13.5
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung	46400 lx
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung	12 lx
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige	No
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker	false
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL	Yes
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht	No
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht	Yes
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung	Yes
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus	Enabled
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)	discrete
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten	klemmenabhaengig
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module	installed
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam	Sollspannungsanforderung 13.5
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome	90 seconds
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP	90 seconds
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung	active
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP	active
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert	not active
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus	active
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht	not active
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit	6 s
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal	Sollspannungsanforderung 13.5
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte	not active
ENG126647-ENG98399-debug_light_function-Activation	0
ENG126647-ENG101417-debug_light_function-Adresse	0
ENG126647-ENG126820-debug_light_function-Bitmask	0
ENG126647-ENG126821-debug_light_function-Divisor	0
ENG126647-ENG98827-debug_light_function-Offset	0
ENG126647-ENG126822-debug_light_function-Polaritaet	0
ENG246955-ENG246967-digital_key-central_locking_digital_key_general	not installed
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle	not active
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion	not active
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer	not active
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle	not active
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion	not active
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer	not active
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0	0.00%
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1	50.00%
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2	100.00%
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0	0.00%
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1	50.00%
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2	100.00%
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP	present
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung	AFS: FLA: Fernlicht ueber AFS
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset	not active
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent	present
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung	present
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA	not active
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung	800 ms
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm	active
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf	active
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig	Sollspannungsanforderung 13.5
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition	not active
ENG141682-ENG141966-Front_wiper-Frontwischertyp	Direct
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer	not active
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer	0 ms
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren	Deactivating
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay	300 ms
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz	active
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status	not active
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung	not active
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant	not active
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube	not active
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus	not active
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube	active
ENG99457-ENG117394-Head area heater-blower_speed	1
ENG99457-ENG98971-Head area heater-Temperature	-2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid	installed
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid	installed
ENG141645-MAS00213-HW_Verbau-Insufficient coolant	installed
ENG141645-MAS00214-HW_Verbau-Brake pad wear	not installed
ENG141645-ENG142026-HW_Verbau-Druckklappe	not installed
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv	not active
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung	not installed
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor	installed
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube	installed
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung	not installed
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer	not installed
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15	active
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung	not active
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0	-100.00%
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1	-100.00%
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2	-100.00%
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3	-100.00%
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4	-100.00%
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5	-100.00%
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6	-100.00%
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7	-100
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8	-100.00%
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9	-100.00%
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0	100.00%
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1	90.00%
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2	80.00%
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3	70.00%
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4	60.00%
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5	50.00%
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6	40.00%
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7	30.00%
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8	15.00%
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9	0.00%
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	0
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	0
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	0
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	not active
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	not active
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15	maximize
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15	maximize
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15	maximize
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15	100
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15	0
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15	0
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15	0
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15	63
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15	0
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15	41 - LED Kleinleistung
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15	Always
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15	Warnblinktaster_Suchbeleuchtung
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15	not active
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15	not active
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15	not active
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15	not active
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15	not active
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15	not active
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15	not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	100
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	Abbiegelicht links
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	Coming Home oder Leaving Home aktiv
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	100
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	Abbiegelicht rechts
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	Coming Home oder Leaving Home aktiv
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	minimize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	minimize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	10
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	2A
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	1A
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	43 - allgemeine LED
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	Daytime running lights
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	Brake light
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	Coming Home oder Leaving Home aktiv
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	minimize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	minimize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	10
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	29
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0A
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	43 - allgemeine LED
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	Daytime running lights
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	Brake light
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	Coming Home oder Leaving Home aktiv
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	100
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	8
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	12 - Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	100
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	18
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	12 - Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	0
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	0
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	0
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	not active
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	not active
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	127
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	0
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	2B
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	9
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	43 - allgemeine LED
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	not active
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	not active
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	127
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	0
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	2D
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	19
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	43 - allgemeine LED
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	not active
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	not active
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	127
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	only_if_closed
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	Quittierungsfunktion 1
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	minimize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	10
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	127
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	35
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	43 - allgemeine LED
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	only_if_closed
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	Daytime running lights
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	Brake light
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	Coming Home oder Leaving Home aktiv
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	minimize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	10
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	127
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	36
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	43 - allgemeine LED
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	only_if_closed
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	Daytime running lights
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	Brake light
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	Coming Home oder Leaving Home aktiv
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	minimize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	75
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	only_if_closed
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	Coming Home oder Leaving Home aktiv
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	100
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	0
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	43 - allgemeine LED
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	minimize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	minimize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	10
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	127
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	37
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	9
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	41 - LED Kleinleistung
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	only_if_closed
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	Brake light
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	Coming Home oder Leaving Home aktiv
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	100
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	9 - allgemeine Glühlampe 27W: auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	only_if_closed
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	Coming Home oder Leaving Home aktiv
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	100
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	only_if_closed
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	Coming Home oder Leaving Home aktiv
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	0
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	0
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	0
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	0
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	0
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	not active
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	not active
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	not active
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	not active
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	100
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	0
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	0
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	0
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	0
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	0
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	not active
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	not active
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	not active
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	not active
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	maximize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	0
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	0
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	0
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	0
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	not active
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	not active
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	not active
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	not active
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	not active
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	maximize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	0
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	0
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	0
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	0
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	not active
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	not active
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	not active
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	not active
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	not active
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	5 - LED Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	5 - LED Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	127
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	127
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	49
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	3A
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	5 - LED Abblendlicht
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Versorgungsbedarf der LCM Module
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	not active
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	127
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	127
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	4A
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	44
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	5 - LED Abblendlicht
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Versorgungsbedarf der LCM Module
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	not active
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	Parking light right
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck	0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 2B 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 2B 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 FF 00 00 00 00 00 00 00 00 00 2B 0A 00 35 08 14 8A 18 00 7F 1E 00 80 00 00 00 2B 1A 00 36 08 14 8A 18 00 7F 1E 00 80 00 00 00 2B 28 00 30 08 00 CB 00 00 00 1E 00 80 00 00 00 2B 00 00 00 08 00 64 00 00 00 00 00 00 00 00 00 29 09 00 37 08 00 8A 18 00 FF 1E 00 80 00 00 00 09 0B 00 31 19 00 E4 00 00 00 1E 00 64 00 00 00 09 1B 00 32 19 00 E4 00 00 00 1E 00 64 00 00 00
ENG141662-Leuchtenkonfiguration_Sonstiges	2B 1A 00 2A 08 14 0A 18 00 80 1E 00 80 00 00 00 2B 0A 00 29 08 14 0A 18 00 80 1E 00 80 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR	1-Sensor_LWR
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges	0 mm
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe	not active
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze	90.00%
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze	10.00%
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung	-127.0 ms
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz	15%
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe	10.0 s
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1	-8.00 mm/%
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2	-8.00 mm/%
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3	-8.00 mm/%
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1	-8.00 mm/%
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2	-8.00 mm/%
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3	-8.00 mm/%
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante	Variante_1
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR	0.00%
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf	0.00 Hz
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung	normal
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal	Negative
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1	0 mm
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2	0 mm
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3	0 mm
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4	0 mm
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand	0 mm
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe	0 mm
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle	95.00%
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle	5.00%
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr	0 km/h
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr	100 Hz
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung	0.00 Hz
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte	BCM
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed	not installed
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht	active
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese	20.00%
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart	not active
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad	0.0 %/s
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht	-100.00%
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut	not installed
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR	0.00 s
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1	2.0 s
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang	10 s
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion	active
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik	active
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS	Nicht_verbaut
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark	not active
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze	100 m
ENG246957-ENG246981-Lichttaster-Lichttastermodul	lds
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config	1
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle	30 km/h
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig	not active
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter	active
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig	active
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig	not active
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter	active
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig	active
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig	not active
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	not active
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	not active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	not active
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen	40 ms
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen	40 ms
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit	100 ms
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt	10 ms
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen	40 ms
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen	40 ms
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v	1 km/h
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen	40 ms
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen	500 ms
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i	0.5
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset	5 °C
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p	13.00%
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh	110 W
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen	40 ms
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh	25 Hz
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg	0
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0	39 °C
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1	43 °C
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2	47 °C
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen	40 ms
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus	50 °C
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen	0 ms
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung	0 ms
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen	40 ms
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen	40 ms
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung	60 s
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh	30 s
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display	not installed
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation	Always
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper	installed
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock	not installed
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation	not installed
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button	not installed
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch	not installed
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch	not installed
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn	not active
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked	not active
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation	not active
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st	installed
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button	not installed
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0	-5.00%
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1	-5.00%
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2	-5.00%
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3	-5.00%
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4	-5.00%
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0	-5
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1	-5
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2	-5
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3	-5
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4	-5
ENG122979-ENG141954-Networking-A/C electronics	installed
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet	installed
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet	installed
ENG122979-ENG141953-Networking-Getriebesteuergeraet	installed
ENG122979-ENG99457-Networking-Head area heater	not installed
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG	not installed
ENG122979-ENG141969-Networking-UGDO	installed
ENG124714-ENG142044-OCU-DWA_push	active
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare	active
ENG124714-ENG246970-OCU-IAA -Nutzer_management	not installed
ENG124714-OCU-	installed
ENG124714-ENG142261-OCU-Remote HuF Abbruch	20 km/h
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz	3 Hz
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1	80 s
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3	2000 ms
ENG124714-ENG125657-OCU-Remote_Unlock_Lock	Via ZV-Absicherung Light
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	active
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	4
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	not active
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	active
ENG98831-ENG126848-Personalization-Personalisierung_aktiv	active
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion	profiles_active
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	active
ENG98831-ENG142030-Personalization-Profil_Variante	Konto (v. 1.x)
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	active
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	active
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	active
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	not active
ENG141646-MAS01065-Querschnitts_funktionen-Brand	VW
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll	active
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung	active
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung	not active
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21	active
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus	Pin A31
ENG141646-ENG154685-Querschnitts_funktionen-Hupe	Sollspannungsanforderung 13.5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben	active
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme	not_installed
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem	not active
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment	Left
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side	Right
ENG122927-RLS_close_glazing	2.0 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off	120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on	10 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off	65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on	140 km/h
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle	6000 lx
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high	12
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low	6
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht	30 s
ENG122929-RLS_LIN_Communication	4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn	200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day	500 lx
ENG122930-RLS_tunel_gateway_recognize	5 s
ENG122935-RLS_Washer_Front	15 s
ENG122926-RLS_wiper_position_parking	15 s
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system	not installed
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel	active
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit	2000 ms
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit	800 ms
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit	0 ms
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit	0 ms
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit	800 ms
ENG115729-ENG154424-Scheinwerferreinigung-Waschen	Keine_Spannungsanforderung
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss	200 ms
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung	1000 ms
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus	5000 ms
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein	300 s
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus	5000 ms
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein	300 s
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus	5000 ms
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein	300 s
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel	200 ms
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus	0 ms
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein	0 ms
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel	0 ms
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung	90000 ms
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung	90000 ms
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error	200 ms
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss	200 ms
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung	1000 ms
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus	5000 ms
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein	300 s
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel	200 ms
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis	2000 ms
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus	5000 ms
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein	60 s
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen	20 ms
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen	0 ms
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen	0 s
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt	0
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle	16.5 V
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr	15.5 V
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle	8.5 V
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr	8.5 V
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss	0 ms
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus	0 ms
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein	0 ms
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus	0 ms
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein	0 s
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss	200 ms
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung	1000 ms
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus	0.0 s
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein	0 s
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus	5000 ms
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein	300 s
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel	200 ms
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus	5000 ms
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein	300 s
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus	5000 ms
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein	300 s
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG	not installed
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker	MFG
ENG116588-Sonderfunktionen-	not enabled
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1	not installed
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen	not active
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus	by convenience operation via remote control key
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen	not active
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung	active
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung	not active
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel	active
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung	not active
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt	active
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung	not active
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron	not active
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt	250
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel	10 km/h
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter	LIN
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel	1000 ms
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen	40 ms
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0	0.0 lx
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1	8.0 lx
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2	50.0 lx
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3	80.0 lx
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4	100.0 lx
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0	6
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1	6
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2	20
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3	50
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4	100
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0	0.0 lx
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1	8.0 lx
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2	50.0 lx
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3	80.0 lx
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4	100.0 lx
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0	6
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1	6
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2	20
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3	50
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4	100
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0	0 ms
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1	200 ms
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10	2000 ms
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2	400 ms
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3	600 ms
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4	800 ms
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5	1000 ms
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6	1200 ms
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7	1400 ms
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8	1600 ms
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9	1800 ms
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0	100.00%
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1	100.00%
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10	0.00%
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2	95.00%
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3	80.00%
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4	40.00%
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5	20.00%
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6	10.00%
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7	5.00%
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8	3.00%
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9	1.00%
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM	0.00 s
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM	0.00 s
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM	0.00 s
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM	0.00 s
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM	0.00 s
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung	HMI
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen	20.0 s
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen	3.0 s
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe	not active
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten	not_active
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung	active
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS	2
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM	0.00 s
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert	50%
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl	Fotosensor_Kombi
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung	Always active
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor	0.1
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert	10.00%
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0	0
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1	50
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10	0
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2	100
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3	200
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4	253
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5	0
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6	0
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7	0
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8	0
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9	0
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0	0 lx
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1	50 lx
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10	0 lx
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2	100 lx
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3	200
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4	500
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5	0
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6	0 lx
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7	0 lx
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8	0 lx
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9	0 lx
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0	0 ms
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1	200 ms
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10	2000 ms
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2	400 ms
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3	600 ms
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4	800 ms
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5	1000 ms
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6	1200 ms
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7	1400 ms
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8	1600 ms
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9	1800 ms
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0	0.00%
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1	1.00%
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10	100.00%
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2	3.00%
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3	5.00%
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4	11.00%
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5	22.00%
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6	40.00%
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7	80.00%
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8	95.00%
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9	100.00%
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0	0 lx
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1	8 lx
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2	50 lx
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3	500 lx
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0	100
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1	100
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2	100
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3	100
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0	0 lx
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1	8 lx
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2	50 lx
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3	510 lx
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0	6
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1	6
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2	100
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3	100
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0	0.00%
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1	6.00%
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2	16.00%
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3	30.00%
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4	60.00%
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5	100.00%
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0	10
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1	10
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2	100
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3	150
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4	220
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5	253
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0	0 lx
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1	8 lx
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2	200 lx
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3	300 lx
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4	500 lx
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0	16
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1	16
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2	100
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3	100
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4	100
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0	0 lx
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1	50 lx
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2	220 lx
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3	300 lx
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4	500 lx
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0	6
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1	16
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2	25
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3	30
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4	50
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0	0
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1	10
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2	50
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3	100
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4	220
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5	253
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0	2.00%
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1	2.00%
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2	6.00%
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3	10.00%
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4	80.00%
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5	100.00%
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0	0 lx
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1	8 lx
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2	50 lx
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3	500 lx
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0	6
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1	6
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2	100
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3	100
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0	0 lx
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1	8 lx
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2	50 lx
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3	500 lx
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0	100
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1	100
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2	100
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3	100
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0	0.00%
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1	50.00%
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2	100.00%
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0	0.00%
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1	50.00%
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2	100.00%
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0	0 lx
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1	10 lx
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2	100 lx
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3	500 lx
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4	800 lx
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5	1020 lx
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0	0
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1	20
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2	80
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3	180
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4	300
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5	500
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0	0 ms
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1	2000 ms
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2	3000 ms
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3	4000 ms
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4	5100 ms
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0	1.00%
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1	5
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2	15
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3	40
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4	100
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen	not active
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen	active
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen	tilting
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1	installed
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3	not installed
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo	installed
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule	CAN
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck	not_installed
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck	active
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv	not active
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb	not active
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close	not installed
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global	active
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen	active
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen	active
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf	not active
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen	active
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung	nur wenn mind. 1 Raste zu
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden	Always
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit	installed
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach	not active
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung	active
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy	active
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder	active
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung	active
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy	active
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder	active
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal	active
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar	active
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau	installed
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version	Version_1_2
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB	not active
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern	not active
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein	active
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein	active
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt	not installed
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster	not installed
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion	not active
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung	active
ENG141651-ENG115755-ZV allgemein-Notschließfunktion	active
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung	not active
ENG141651-ENG141957-ZV allgemein-Radio freq.	315MHz
ENG141651-ENG141958-ZV allgemein-Tankschloss	Bidirectional
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum	ZV_Wiederveriegelung
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung	Einzeltuerentriegelung
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion	installed
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck	active
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln	active
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit	active
ENG141654-ENG116706-ZV Autolock-Autounlock NAR	active
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock	not active
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen	not active
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash	not active
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels	active
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster	via_CAN
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung	not active
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen	active
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste	Yes
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung	Kontaktsteuerung mit Mindestansteuerzeit
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster	0.0 s
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang	No
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel	active
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen	not active
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp	1 or 2 notch rear actuator
ENG141681-IDE02021-ZV Komfort-Comfort closing	active
ENG141681-IDE02022-ZV Komfort-Comfort opening	not active
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten	Yes
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen	active
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen	not active
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit	600 s
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus	active
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen	active
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen	active
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen	active
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global	active
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer	not active
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar	adjustable
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen	not active
ENG141681-ENG246991-ZV Komfort-pa_Two_Keys	not active
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art	once
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus	not active
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen	not active
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen	not active
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss	2-Motorenschloesser
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal	nicht invertiert
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite	not installed
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite	not installed
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links	No
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts	No
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter	not installed
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM	Driver side
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR	Yes
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer	Yes
Hi and welcome.
Can we get a complete Auto-Scan from your car for context please? I suspect much of the front lighting is going to be controlled by the 4B/D6/D7 type modules, which aren't understood all that well yet.
TWs/VW
NW Florida
C?ID=369048
Hi and welcome.
If more is needed, I'll be happy to provide...
TW
Autoscan 4B:
;SW:3Q0-907-338-C   HW:3Q0-907-338-C ---  Multifunc. Module
;Component:FCM MQB Low   002 0345	 Coding:000000070900134A00010000000000000000000000000000000000000000
;EV_MultiModulContiVW48X	2006	EV_MultiModulContiVW48X_002_VW41.rod
;Sunday	25	August	2019	16:06:25:27651
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: 3537206065C7B69F29F-8060
IDE00001-Production mode	not active 	3
IDE00820-Activating and deactivating all development messages	not active 	1
IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection	Yes 	1
IDE01996-SFT00041-Installation list: specified installations-Light Control Left	No 	1
IDE01996-SFT00057-Installation list: specified installations-Light Control Right	No 	1
IDE01996-SFT00075-Installation list: specified installations-Multifunction module	Yes 	1
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit	No 	1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2	Yes 	1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2	Yes 	1
IDE01996-SFT33031-Installation list: specified installations-Antenna Control Module	No 	1
IDE02332-Deactivate production mode	0	3
IDE03641-Presentation run dynamic AFS light	not active 	1
IDE03642-Presentation mode	not active 	1
IDE03679-Adaptive light functions	active 	1
IDE03787-Activate left/right hand drive switch-over	not active 	1
IDE08418-Matrix light: total dimming	0.00%	1
IDE09156-Matrix headlamp: function at standstill	not active 	1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1	OFF 	12
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2	OFF 	12
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3	OFF 	12
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4	OFF 	12
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5	OFF 	12
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6	OFF 	12
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7	OFF 	12
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8	OFF 	12
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9	OFF 	12
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10	OFF 	12
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11	OFF 	12
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12	OFF 	12
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13	OFF 	12
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14	OFF 	12
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15	OFF 	12
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16	OFF 	12
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17	OFF 	12
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18	OFF 	12
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19	OFF 	12
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20	OFF 	12
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21	OFF 	12
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22	OFF 	12
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23	OFF 	12
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24	OFF 	12
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25	OFF 	12
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26	OFF 	12
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27	OFF 	12
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28	OFF 	12
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29	OFF 	12
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30	OFF 	12
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31	OFF 	12
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32	OFF 	12
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33	OFF 	12
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34	OFF 	12
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35	OFF 	12
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36	OFF 	12
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37	OFF 	12
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38	OFF 	12
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39	OFF 	12
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40	OFF 	12
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41	OFF 	12
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42	OFF 	12
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43	OFF 	12
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44	OFF 	12
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45	OFF 	12
IDE09568-MAS11516-Bit pattern of individual segment activation: left headlight-LED 46	OFF 	12
IDE09568-MAS11517-Bit pattern of individual segment activation: left headlight-LED 47	OFF 	12
IDE09568-MAS11518-Bit pattern of individual segment activation: left headlight-LED 48	OFF 	12
IDE09568-MAS11519-Bit pattern of individual segment activation: left headlight-LED 49	OFF 	12
IDE09568-MAS11520-Bit pattern of individual segment activation: left headlight-LED 50	OFF 	12
IDE09568-MAS11521-Bit pattern of individual segment activation: left headlight-LED 51	OFF 	12
IDE09568-MAS11522-Bit pattern of individual segment activation: left headlight-LED 52	OFF 	12
IDE09568-MAS11523-Bit pattern of individual segment activation: left headlight-LED 53	OFF 	12
IDE09568-MAS11524-Bit pattern of individual segment activation: left headlight-LED 54	OFF 	12
IDE09568-MAS11525-Bit pattern of individual segment activation: left headlight-LED 55	OFF 	12
IDE09568-MAS11526-Bit pattern of individual segment activation: left headlight-LED 56	OFF 	12
IDE09568-MAS11527-Bit pattern of individual segment activation: left headlight-LED 57	OFF 	12
IDE09568-MAS11528-Bit pattern of individual segment activation: left headlight-LED 58	OFF 	12
IDE09568-MAS11529-Bit pattern of individual segment activation: left headlight-LED 59	OFF 	12
IDE09568-MAS11530-Bit pattern of individual segment activation: left headlight-LED 60	OFF 	12
IDE09568-MAS11531-Bit pattern of individual segment activation: left headlight-LED 61	OFF 	12
IDE09568-MAS11532-Bit pattern of individual segment activation: left headlight-LED 62	OFF 	12
IDE09568-MAS11533-Bit pattern of individual segment activation: left headlight-LED 63	OFF 	12
IDE09568-MAS11534-Bit pattern of individual segment activation: left headlight-LED 64	OFF 	12
IDE09568-MAS11535-Bit pattern of individual segment activation: left headlight-LED 65	OFF 	12
IDE09568-MAS11536-Bit pattern of individual segment activation: left headlight-LED 66	OFF 	12
IDE09568-MAS11537-Bit pattern of individual segment activation: left headlight-LED 67	OFF 	12
IDE09568-MAS11538-Bit pattern of individual segment activation: left headlight-LED 68	OFF 	12
IDE09568-MAS11539-Bit pattern of individual segment activation: left headlight-LED 69	OFF 	12
IDE09568-MAS11540-Bit pattern of individual segment activation: left headlight-LED 70	OFF 	12
IDE09568-MAS11541-Bit pattern of individual segment activation: left headlight-LED 71	OFF 	12
IDE09568-MAS11542-Bit pattern of individual segment activation: left headlight-LED 72	OFF 	12
IDE09568-MAS11543-Bit pattern of individual segment activation: left headlight-LED 73	OFF 	12
IDE09568-MAS11544-Bit pattern of individual segment activation: left headlight-LED 74	OFF 	12
IDE09568-MAS11545-Bit pattern of individual segment activation: left headlight-LED 75	OFF 	12
IDE09568-MAS11546-Bit pattern of individual segment activation: left headlight-LED 76	OFF 	12
IDE09568-MAS11547-Bit pattern of individual segment activation: left headlight-LED 77	OFF 	12
IDE09568-MAS11548-Bit pattern of individual segment activation: left headlight-LED 78	OFF 	12
IDE09568-MAS11549-Bit pattern of individual segment activation: left headlight-LED 79	OFF 	12
IDE09568-MAS11550-Bit pattern of individual segment activation: left headlight-LED 80	OFF 	12
IDE09568-MAS11551-Bit pattern of individual segment activation: left headlight-LED 81	OFF 	12
IDE09568-MAS11552-Bit pattern of individual segment activation: left headlight-LED 82	OFF 	12
IDE09568-MAS11553-Bit pattern of individual segment activation: left headlight-LED 83	OFF 	12
IDE09568-MAS11554-Bit pattern of individual segment activation: left headlight-LED 84	OFF 	12
IDE09568-MAS11555-Bit pattern of individual segment activation: left headlight-LED 85	OFF 	12
IDE09568-MAS11556-Bit pattern of individual segment activation: left headlight-LED 86	OFF 	12
IDE09568-MAS11557-Bit pattern of individual segment activation: left headlight-LED 87	OFF 	12
IDE09568-MAS11558-Bit pattern of individual segment activation: left headlight-LED 88	OFF 	12
IDE09568-MAS11559-Bit pattern of individual segment activation: left headlight-LED 89	OFF 	12
IDE09568-MAS11560-Bit pattern of individual segment activation: left headlight-LED 90	OFF 	12
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1	OFF 	12
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2	OFF 	12
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3	OFF 	12
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4	OFF 	12
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5	OFF 	12
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6	OFF 	12
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7	OFF 	12
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8	OFF 	12
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9	OFF 	12
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10	OFF 	12
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11	OFF 	12
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12	OFF 	12
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13	OFF 	12
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14	OFF 	12
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15	OFF 	12
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16	OFF 	12
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17	OFF 	12
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18	OFF 	12
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19	OFF 	12
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20	OFF 	12
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21	OFF 	12
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22	OFF 	12
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23	OFF 	12
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24	OFF 	12
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25	OFF 	12
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26	OFF 	12
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27	OFF 	12
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28	OFF 	12
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29	OFF 	12
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30	OFF 	12
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31	OFF 	12
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32	OFF 	12
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33	OFF 	12
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34	OFF 	12
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35	OFF 	12
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36	OFF 	12
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37	OFF 	12
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38	OFF 	12
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39	OFF 	12
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40	OFF 	12
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41	OFF 	12
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42	OFF 	12
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43	OFF 	12
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44	OFF 	12
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45	OFF 	12
IDE09569-MAS11516-Bit pattern of individual segment activation: right headlight-LED 46	OFF 	12
IDE09569-MAS11517-Bit pattern of individual segment activation: right headlight-LED 47	OFF 	12
IDE09569-MAS11518-Bit pattern of individual segment activation: right headlight-LED 48	OFF 	12
IDE09569-MAS11519-Bit pattern of individual segment activation: right headlight-LED 49	OFF 	12
IDE09569-MAS11520-Bit pattern of individual segment activation: right headlight-LED 50	OFF 	12
IDE09569-MAS11521-Bit pattern of individual segment activation: right headlight-LED 51	OFF 	12
IDE09569-MAS11522-Bit pattern of individual segment activation: right headlight-LED 52	OFF 	12
IDE09569-MAS11523-Bit pattern of individual segment activation: right headlight-LED 53	OFF 	12
IDE09569-MAS11524-Bit pattern of individual segment activation: right headlight-LED 54	OFF 	12
IDE09569-MAS11525-Bit pattern of individual segment activation: right headlight-LED 55	OFF 	12
IDE09569-MAS11526-Bit pattern of individual segment activation: right headlight-LED 56	OFF 	12
IDE09569-MAS11527-Bit pattern of individual segment activation: right headlight-LED 57	OFF 	12
IDE09569-MAS11528-Bit pattern of individual segment activation: right headlight-LED 58	OFF 	12
IDE09569-MAS11529-Bit pattern of individual segment activation: right headlight-LED 59	OFF 	12
IDE09569-MAS11530-Bit pattern of individual segment activation: right headlight-LED 60	OFF 	12
IDE09569-MAS11531-Bit pattern of individual segment activation: right headlight-LED 61	OFF 	12
IDE09569-MAS11532-Bit pattern of individual segment activation: right headlight-LED 62	OFF 	12
IDE09569-MAS11533-Bit pattern of individual segment activation: right headlight-LED 63	OFF 	12
IDE09569-MAS11534-Bit pattern of individual segment activation: right headlight-LED 64	OFF 	12
IDE09569-MAS11535-Bit pattern of individual segment activation: right headlight-LED 65	OFF 	12
IDE09569-MAS11536-Bit pattern of individual segment activation: right headlight-LED 66	OFF 	12
IDE09569-MAS11537-Bit pattern of individual segment activation: right headlight-LED 67	OFF 	12
IDE09569-MAS11538-Bit pattern of individual segment activation: right headlight-LED 68	OFF 	12
IDE09569-MAS11539-Bit pattern of individual segment activation: right headlight-LED 69	OFF 	12
IDE09569-MAS11540-Bit pattern of individual segment activation: right headlight-LED 70	OFF 	12
IDE09569-MAS11541-Bit pattern of individual segment activation: right headlight-LED 71	OFF 	12
IDE09569-MAS11542-Bit pattern of individual segment activation: right headlight-LED 72	OFF 	12
IDE09569-MAS11543-Bit pattern of individual segment activation: right headlight-LED 73	OFF 	12
IDE09569-MAS11544-Bit pattern of individual segment activation: right headlight-LED 74	OFF 	12
IDE09569-MAS11545-Bit pattern of individual segment activation: right headlight-LED 75	OFF 	12
IDE09569-MAS11546-Bit pattern of individual segment activation: right headlight-LED 76	OFF 	12
IDE09569-MAS11547-Bit pattern of individual segment activation: right headlight-LED 77	OFF 	12
IDE09569-MAS11548-Bit pattern of individual segment activation: right headlight-LED 78	OFF 	12
IDE09569-MAS11549-Bit pattern of individual segment activation: right headlight-LED 79	OFF 	12
IDE09569-MAS11550-Bit pattern of individual segment activation: right headlight-LED 80	OFF 	12
IDE09569-MAS11551-Bit pattern of individual segment activation: right headlight-LED 81	OFF 	12
IDE09569-MAS11552-Bit pattern of individual segment activation: right headlight-LED 82	OFF 	12
IDE09569-MAS11553-Bit pattern of individual segment activation: right headlight-LED 83	OFF 	12
IDE09569-MAS11554-Bit pattern of individual segment activation: right headlight-LED 84	OFF 	12
IDE09569-MAS11555-Bit pattern of individual segment activation: right headlight-LED 85	OFF 	12
IDE09569-MAS11556-Bit pattern of individual segment activation: right headlight-LED 86	OFF 	12
IDE09569-MAS11557-Bit pattern of individual segment activation: right headlight-LED 87	OFF 	12
IDE09569-MAS11558-Bit pattern of individual segment activation: right headlight-LED 88	OFF 	12
IDE09569-MAS11559-Bit pattern of individual segment activation: right headlight-LED 89	OFF 	12
IDE09569-MAS11560-Bit pattern of individual segment activation: right headlight-LED 90	OFF 	12
IDE12648-MAS09833-Headlights left: low beam segment actuation-LED 1	OFF 	3
IDE12648-MAS09834-Headlights left: low beam segment actuation-LED 2	OFF 	3
IDE12648-MAS09835-Headlights left: low beam segment actuation-LED 3	OFF 	3
IDE12648-MAS09836-Headlights left: low beam segment actuation-LED 4	OFF 	3
IDE12648-MAS09837-Headlights left: low beam segment actuation-LED 5	OFF 	3
IDE12648-MAS09838-Headlights left: low beam segment actuation-LED 6	OFF 	3
IDE12648-MAS09839-Headlights left: low beam segment actuation-LED 7	OFF 	3
IDE12648-MAS09840-Headlights left: low beam segment actuation-LED 8	OFF 	3
IDE12648-MAS09841-Headlights left: low beam segment actuation-LED 9	OFF 	3
IDE12648-MAS09842-Headlights left: low beam segment actuation-LED 10	OFF 	3
IDE12648-MAS09843-Headlights left: low beam segment actuation-LED 11	OFF 	3
IDE12648-MAS09844-Headlights left: low beam segment actuation-LED 12	OFF 	3
IDE12648-MAS09845-Headlights left: low beam segment actuation-LED 13	OFF 	3
IDE12648-MAS09846-Headlights left: low beam segment actuation-LED 14	OFF 	3
IDE12648-MAS09847-Headlights left: low beam segment actuation-LED 15	OFF 	3
IDE12648-MAS09848-Headlights left: low beam segment actuation-LED 16	OFF 	3
IDE12648-MAS09849-Headlights left: low beam segment actuation-LED 17	OFF 	3
IDE12648-MAS09850-Headlights left: low beam segment actuation-LED 18	OFF 	3
IDE12648-MAS09851-Headlights left: low beam segment actuation-LED 19	OFF 	3
IDE12648-MAS09852-Headlights left: low beam segment actuation-LED 20	OFF 	3
IDE12649-MAS09833-Headlights right: low beam segment actuation-LED 1	OFF 	3
IDE12649-MAS09834-Headlights right: low beam segment actuation-LED 2	OFF 	3
IDE12649-MAS09835-Headlights right: low beam segment actuation-LED 3	OFF 	3
IDE12649-MAS09836-Headlights right: low beam segment actuation-LED 4	OFF 	3
IDE12649-MAS09837-Headlights right: low beam segment actuation-LED 5	OFF 	3
IDE12649-MAS09838-Headlights right: low beam segment actuation-LED 6	OFF 	3
IDE12649-MAS09839-Headlights right: low beam segment actuation-LED 7	OFF 	3
IDE12649-MAS09840-Headlights right: low beam segment actuation-LED 8	OFF 	3
IDE12649-MAS09841-Headlights right: low beam segment actuation-LED 9	OFF 	3
IDE12649-MAS09842-Headlights right: low beam segment actuation-LED 10	OFF 	3
IDE12649-MAS09843-Headlights right: low beam segment actuation-LED 11	OFF 	3
IDE12649-MAS09844-Headlights right: low beam segment actuation-LED 12	OFF 	3
IDE12649-MAS09845-Headlights right: low beam segment actuation-LED 13	OFF 	3
IDE12649-MAS09846-Headlights right: low beam segment actuation-LED 14	OFF 	3
IDE12649-MAS09847-Headlights right: low beam segment actuation-LED 15	OFF 	3
IDE12649-MAS09848-Headlights right: low beam segment actuation-LED 16	OFF 	3
IDE12649-MAS09849-Headlights right: low beam segment actuation-LED 17	OFF 	3
IDE12649-MAS09850-Headlights right: low beam segment actuation-LED 18	OFF 	3
IDE12649-MAS09851-Headlights right: low beam segment actuation-LED 19	OFF 	3
IDE12649-MAS09852-Headlights right: low beam segment actuation-LED 20	OFF 	3
IDE13611-Cornering lamp in operation	not active 	1
IDE13612-Matrix head lamps: steering angle	9600.00 °	2
ENG124608-Order_Reference_Run_Activation_Effect	No dependency 	1
ENG124607-Reference_Run_Activation_Effect	Activation effect disabled 	1
ENG103979-Reference_Run_Start_Condition	Engine start 	1
Autoscan D6:
;SW:7P5-941-591-AA   HW:7P5-941-591-A ---  Light Ctrl Left 2
;Component:LED1L         H06 0003	 Coding:
;EV_LED_PLUS_L_KEBODAVW416	1003	EV_LED_PLUS_L_KEBODAVW416_VW37.rod
;Sunday	25	August	2019	16:09:55:27651
;VCID: 7BA3F6580363A0EF9FB-802E
IDE00036-Vehicle equipment code	00 00 00 00 00 00 00 00 00 00 00 00 	12
IDE00047-Parameter set version	---- 	4
IDE00048-Parameter set part number	----------- 	11
Autoscan D7:
;SW:7P5-941-591-AA   HW:7P5-941-591-A ---  Light Ctrl Right 2
;Component:LED1R         H06 0003	 Coding:
;EV_LED_PLUS_R_KEBODAVW416	1003	EV_LED_PLUS_R_KEBODAVW416_VW41.rod
;Sunday	25	August	2019	16:10:02:27651
South Molton, UK
A VCDS Auto-Scan would be even better, not adaptation channel maps of modules... they are quite different things :thumbs:
TWs/VW
NW Florida
C?ID=369048
Autoscan - 2019 Atlas SEL
Scan
Sunday,25,August,2019,15:46:55:27651
VIN:                                    License Plate:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 36 3C 42 44 4B 52 5F 69
          6C 6D 75 A5 CA D6 D7
VIN:                                   Mileage: 6388km-3969miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (0-32-CDVC)       Labels: None
   Part No SW: 03H 906 026 AA    HW: 03H 907 309 K
   Component: VR6 3.6l FSI  H21 6694
   Revision: 52H21000
   Coding: 012A003244740108B0000000000000000000000000000000
   Shop #: WSC 06050 062 00200
   ASAM Dataset: EV_ECM36FSI01103H906026AA 001005
   ROD: EV_ECM36FSI01103H906026AA.rod
   VCID: 6491AD249EDD7F174E1-8030
   CAN Converter 01:
Readiness: 1010 0101
   Part No SW: 09G 927 158 DR    HW: 09G 927 158
   Component: AISIN AQ8     206 3536
   Coding: 0000000100000000000000000000000000000000
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 065597AC48A1ED07F05-8052
   Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
   Component: ESC           H25 0524
   Revision: 00000000    Serial number: 53468000000124
   Coding: 44FC6B8D84231A6DC57F0203A2C66922D62158A34045967038415058C2A2420B0023641C12141A1D8DDB45506CC8CF
   ROD: EV_Brake1UDSContiMK100IPB_037_VW41.rod
   VCID: 77ABEA683F4B848FFB3-8022
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0497749765
   Coding: 1F30000723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   VCID: 43D34EB83B13182F97B-8016
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11358006
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 3CN 907 044 L    HW: 3CN 907 044 L
   Component: Climatronic   H04 2009
   Revision: 00001K03
   Coding: 1602002620001C001104210C5210142C
   ASAM Dataset: EV_ACClimaBHBVW416 002012
   ROD: EV_ACClimaBHBVW416.rod
   VCID: 48C9599402353B77429-801C
   Fresh Air Blower Back:
   Part No SW: 5Q0 937 085 BT    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H38 0273
   Serial number: 8335010201ÿÿÿÿ
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 0C41A58456CD9757A61-8058
   Subsystem 1 - Part No SW: 5Q0 955 555     HW: 5Q0 955 555
   Component: RLHSS  052 0122
   Serial number: S7Y18M10D30H02M31S58
   Coding: 00382D
   Subsystem 2 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H08 0050
   Serial number: 0000009600363Z01QP02
   Coding: 150000
   Garage Door Opener Operating Unit:
   Subsystem 3 - Part No SW: 3CN 959 719     HW: 3CN 959 719
   Component: GTO BF  H06 0007
   Serial number: 8MW00130091800010032
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 R    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23 0170
   Serial number: 0300091220180C205828
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000137088R18341
   Coding: 0471155111
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CC16584164DD757661-8018
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 3200074959FFC728949C810530401600000000000000000004
   VCID: 44D14DA43E1D1F17AE1-8010
   Part No SW: 3Q0 959 655 BN    HW: 3Q0 959 655 BN
   Component: Airbag VW21   006 0713
   Revision: --------    Serial number: 003SUMKVWKQe
   Coding: 8CCCDC00000000005000001A420800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0B43A69853C3906FAFB-805E
   Occupant Detection:
   Component: Occ.Detection  H13 0022
   Serial number: IBH0000J18000ARK0B0D
   Coding: 303030
   Subsystem 2 - Part No SW: -----------    HW: 454 002 910 18
   Serial number: 35700000000424496236
   Subsystem 3 - Part No SW: -----------    HW: 454 001 110 18
   Serial number: 35800000000D0A78623M
   Subsystem 4 - Part No SW: -----------    HW: 454 801 212 18
   Serial number: 3510097AC3F17000000U
   Subsystem 5 - Part No SW: -----------    HW: 454 802 711 18
   Serial number: 35200E3FA1F17000000X
   Subsystem 6 - Part No SW: -----------    HW: 454 802 111 18
   Serial number: 35500096FEC16000000X
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 454 802 111 18
   Component: FrontSensor_P  304 0149
   Serial number: 356009120BA16000000B
   Part No SW: 3CN 920 891 B    HW: 3CN 920 891 B
   Component: KOMBI         403 4191
   Coding: 0BA40F1D6F88CF0502887B0B50010000A0000000
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 26111800842619
   Coding: 0B0100347F087300FA0002581C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 3D2738405DF76EDFE1F-8068
   Component: 1-01-0e-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 33180001692630031439
   Coding: 2EFFFF
   Serial number: 1795406200
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 3CN 907 155     HW: 3CN 907 155
   Component: U13DCAC  H23 0890
   Serial number: B007541
   Serial number: 18000331561015
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 33331E786BB3A8AF07B-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RJG33148
   Coding: 0010000200000500018280808080000000008100000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   Serial number: 0500310573
   Coding: 02012103
   ROD: EV_HREntryHella_VW27.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0501777184
   Coding: 020121
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YA008RKM004U2
   Coding: 00341B200200020000000000
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000001319046
   Coding: 011000
   Part No SW: 3QF 909 144 B    HW: 3QF 909 144 A
   Component: EPS_MQB_ZFLS  570 1582
   Coding: 191F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 47CB5AA80F2B340F4B3-8012
   Component: FCM MQB Low   002 0345
   Serial number: 03121800841225
   Coding: 000000070900134A00010000000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YA008RK500QUA
   Coding: 003413200E00020000000000
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000001321896
   Coding: 091000
   Part No SW: 3QF 035 876 A    HW: 3QF 035 876 A
   Component: MU-S-NS-US    853 0890
   Coding: 02140602FF00000051220001001808001F0506E401200405CE
   ROD: EV_MUStd4CDELP_VW37.rod
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZJV2910251
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0497745983
   Coding: 0200000200000000
   VCID: 40D941B42A0503378A9-8014
   Component: RVC Compact   H15 0231
   Coding: 01140602A3002017300040
   VCID: 392F2C5049DF52FFCD7-806C
   Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0266
   Revision: --------    Serial number: A2-C758-8680-2
   Coding: 0988
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   VCID: 45D750A03527261FB9F-8010
   Component: OCULowMQBUS   009 0570
   Coding: 02140602C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 1272
   Serial number: 21011941K22283
   Coding: 0004010600010201002213558150A90084000E200120
   Shop #: WSC 56641 001 104857
   ROD: EV_MFKBoschMQBB_001_VW27.rod
   VCID: 0849999442B5FB77829-805C
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 00804074160C
   ROD: EV_SunRoofCONTIAU736_006.rod
   Part No SW: 7P5 941 591 AA    HW: 7P5 941 591 A
   Component: LED1L         H06 0003
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   Component: LED1R         H06 0003
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 01:53, VBatt start/end: 14.2V/14.3V)-----------
adpmap-D7
Elapsed Time: 00:01
blockmap-D7
;Sunday	25	August	2019	16:09:58:27651
Group	Description	Actual
IDE00030-FSS01408	Status of actuator test-Status	not active
IDE00325	Diagnostic mode	Extended Session
IDE00767-ENG14124	No. of unscheduled ECU resets-Test_Program_Watchdog_reset	0
IDE03680-MAS01468	Supply voltages-Terminal 15	12.8	 V
IDE03680-MAS09374	Supply voltages-Terminal 56b	0.1	 V
IDE03680-MAS09375	Supply voltages-Terminal 56a	0	 V
IDE03680-MAS09376	Supply voltages-Supply via vehicle elec. sys. ctrl. unit	0	 V
IDE03680-MAS10129	Supply voltages-Daytime driving light supply	0	 V
IDE03680-MAS12194	Supply voltages-Supply for logic	12.8	 V
IDE03680-ENG35043	Supply voltages-Terminal_30g	13	 V
IDE06926-ENG28625	History memory: reset counter-reset_reason	Watchdog Reset
IDE06926-ENG08623	History memory: reset counter-Timestamp	13 08 19 10 0A
IDE08742-IDE09773	Operating time-Side-marker light	42.42	 H
IDE08742-MAS02923	Operating time-Highway light	0	 H
IDE08742-MAS09325	Operating time-Daytime running lights	68.67	 H
IDE08742-MAS13654	Operating time-Auxiliary high beam	0	 H
IDE08742-ENG28624	Operating time-all_weather_light	0	 H
IDE08742-ENG36151	Operating time-City_light 4	0	 H
IDE08742-ENG28616	Operating time-Control_module	218.5	 H
IDE08742-ENG120597	Operating time-High_beam	1.33	 H
IDE08742-ENG120596	Operating time-Low_beam	40.42	 H
IDE08742-ENG35039	Operating time-Position_light	42.25	 H
IDE08742-ENG120595	Operating time-Static_Cornering_Light	0	 H
IDE08742-ENG28679	Operating time-Tourist_light	0	 H
IDE08742-ENG35044	Operating time-Turn_indicator	0	 H
IDE09770-IDE10205	High side channel 1-Control module version	Min LIN
IDE09770-MAS09022	High side channel 1-PWM value	0	 %
IDE09771-MAS02526	High side channel 2-Activation	Turn_indicator
IDE09771-MAS04136	High side channel 2-Current	outside permissible range
IDE09771-MAS09022	High side channel 2-PWM value	0	 %
IDE09772-MAS02526	High side channel 3-Activation	Channel not used
IDE09772-MAS04136	High side channel 3-Current	Channel not used
IDE09772-MAS09022	High side channel 3-PWM value	0	 %
IDE09774-IDE09773	Number of activations-Side-marker light	486
IDE09774-MAS02923	Number of activations-Highway light	0
IDE09774-MAS09325	Number of activations-Daytime running lights	442
IDE09774-MAS13654	Number of activations-Auxiliary high beam	0
IDE09774-ENG28624	Number of activations-all_weather_light	0
IDE09774-ENG36136	Number of activations-city_light	0
IDE09774-ENG120597	Number of activations-High_beam	354
IDE09774-ENG28914	Number of activations-High_beam_excess_temperature	0
IDE09774-ENG28912	Number of activations-High_beam_excess_temperature_protection	0
IDE09774-ENG120596	Number of activations-Low_beam	572
IDE09774-ENG28913	Number of activations-Low_beam_excess_temperature	0
IDE09774-ENG28911	Number of activations-Low_beam_excess_temperature_protection	0
IDE09774-ENG35039	Number of activations-Position_light	527
IDE09774-ENG120595	Number of activations-Static_Cornering_Light	0
IDE09774-ENG28679	Number of activations-Tourist_light	0
IDE09774-ENG35044	Number of activations-Turn_indicator	14063
IDE09795-MAS09342	Operating times for motor of headlight range adjustment-between 0% and 30%	0	 H
IDE09795-MAS09343	Operating times for motor of headlight range adjustment-between 30% and 60%	0	 H
IDE09795-MAS09344	Operating times for motor of headlight range adjustment-over 60%	217	 H
IDE09828-MAS00890	Head lamp variant-via CAN	E0 41
IDE09828-ENG28616	Head lamp variant-Control_module	E0 41
IDE10048-IDE09768	Supply information-LED channel 1	Not Used
IDE10048-IDE09769	Supply information-LED channel 2	Terminal_30g
IDE10048-IDE11123	Supply information-High side channel 4	Terminal 15
IDE10048-MAS01968	Supply information-Fan	Not Used
IDE10048-MAS09754	Supply information-LED channel 3	Terminal_30g
IDE10048-MAS09755	Supply information-Matrixbeam channels	Not Used
IDE10048-MAS16122	Supply information-LED channel 4	Terminal_30g
IDE10048-ENG30205	Supply information-Highside_channel 1	Terminal_30g
IDE10048-ENG30206	Supply information-Highside_channel 2	Terminal_30g
IDE10048-ENG30207	Supply information-Highside_channel 3	Terminal 15
IDE10165-FSS01570	LED channel 1: Master 1-Temperature	42	 °C
IDE10165-MAS01340	LED channel 1: Master 1-Functions	Low_beam
IDE10165-MAS04136	LED channel 1: Master 1-Current	0	 mA
IDE10165-MAS09022	LED channel 1: Master 1-PWM value	100	 %
IDE10165-MAS09327	LED channel 1: Master 1-LED brightness class	1
IDE10167-FSS01570	LED channel 1: Slave-Temperature	42	 °C
IDE10167-MAS01340	LED channel 1: Slave-Functions	no function
IDE10167-MAS04136	LED channel 1: Slave-Current	0	 mA
IDE10167-MAS09022	LED channel 1: Slave-PWM value	100	 %
IDE10167-MAS09327	LED channel 1: Slave-LED brightness class	2
IDE10168-FSS01570	LED channel 2: Master-Temperature	38	 °C
IDE10168-MAS01340	LED channel 2: Master-Functions	High_beam
IDE10168-MAS04136	LED channel 2: Master-Current	0	 mA
IDE10168-MAS09022	LED channel 2: Master-PWM value	100	 %
IDE10168-MAS09327	LED channel 2: Master-LED brightness class	2
IDE10169-FSS01570	LED channel 2: Slave-Temperature	38	 °C
IDE10169-MAS01340	LED channel 2: Slave-Functions	no function
IDE10169-MAS04136	LED channel 2: Slave-Current	0	 mA
IDE10169-MAS09022	LED channel 2: Slave-PWM value	100	 %
IDE10169-MAS09327	LED channel 2: Slave-LED brightness class	2
IDE10170-FSS01570	LED channel 3: Master-Temperature	35	 °C
IDE10170-MAS01340	LED channel 3: Master-Functions	Position_light / Daytime_running_light
IDE10170-MAS04136	LED channel 3: Master-Current	0	 mA
IDE10170-MAS09022	LED channel 3: Master-PWM value	0	 %
IDE10170-MAS09327	LED channel 3: Master-LED brightness class	2
IDE10173-MAS09336	Operating times in temperature ranges-°C	0	 H
IDE10173-MAS09337	Operating times in temperature ranges-between 105°C and 115°C	0	 H
IDE10173-MAS09338	Operating times in temperature ranges-over 115°C	0	 H
IDE10173-MAS09378	Operating times in temperature ranges-between -40°C and 95°C	177.33	 H
IDE10205	Control module version	plus
IDE10206-MAS02526	Fan for headlight-Activation	Highbeam_shutter
IDE10206-MAS04136	Fan for headlight-Current	in permissible range
IDE10282-IDE10165	LED channels: voltages-LED channel 1: Master 1	0	 V
IDE10282-IDE10168	LED channels: voltages-LED channel 2: Master	0	 V
IDE10282-IDE10170	LED channels: voltages-LED channel 3: Master	0	 V
IDE10282-ENG36145	LED channels: voltages-Channel _1_Slave	0	 V
IDE10282-ENG36146	LED channels: voltages-Channel _2_Slave	0	 V
IDE10282-ENG36150	LED channels: voltages-Channel_4_Master	0	 V
IDE10864-MAS11561	Control mod. temperatures-Power output stage for LED	56	 °C
IDE10864-MAS11562	Control mod. temperatures-Matrix light power output stage	0	 °C
IDE11123-MAS02526	High side channel 4-Activation	Channel not used
IDE11123-MAS04136	High side channel 4-Current	Channel not used
IDE11123-MAS09022	High side channel 4-PWM value	0	 %
IDE11124-MAS12195	Headlight beam adjusting motor-Reference run status	not performed
IDE11124-MAS12196	Headlight beam adjusting motor-Fault position	not approached
IDE11124-MAS12199	Headlight beam adjusting motor-Adjustment speed	normal
IDE11124-ENG14129	Headlight beam adjusting motor-Test_Program_Inclination_of_low_beam	1024	 mm
IDE11124-ENG14128	Headlight beam adjusting motor-Test_Program_Motor_position_percentage_of_maximum_adjustment_travel	101.6	 %
IDE13678-FSS01570	LED channel 4: Master-Temperature	35	 °C
IDE13678-MAS01340	LED channel 4: Master-Functions	Position_light / Daytime_running_light
IDE13678-MAS04136	LED channel 4: Master-Current	0	 mA
IDE13678-MAS09022	LED channel 4: Master-PWM value	0	 %
IDE13678-MAS09327	LED channel 4: Master-LED brightness class	2
MAS00468	Unlearning counter	179
Elapsed Time: 00:04
adpmap-D6
Elapsed Time: 00:01
blockmap-D6
;Sunday	25	August	2019	16:09:51:27651
IDE03680-MAS01468	Supply voltages-Terminal 15	12.9	 V
IDE03680-MAS12194	Supply voltages-Supply for logic	12.9	 V
IDE03680-ENG35043	Supply voltages-Terminal_30g	13.1	 V
IDE06926-ENG08623	History memory: reset counter-Timestamp	13 08 19 10 09
IDE08742-IDE09773	Operating time-Side-marker light	38.67	 H
IDE08742-MAS09325	Operating time-Daytime running lights	62.5	 H
IDE08742-ENG28616	Operating time-Control_module	202.33	 H
IDE08742-ENG120597	Operating time-High_beam	0.92	 H
IDE08742-ENG120596	Operating time-Low_beam	36.75	 H
IDE08742-ENG35039	Operating time-Position_light	38.42	 H
IDE09770-MAS02526	High side channel 1-Activation	Sidemarker
IDE09770-MAS04136	High side channel 1-Current	outside permissible range
IDE09772-MAS01340	High side channel 3-Functions	no function
IDE09774-IDE09773	Number of activations-Side-marker light	460
IDE09774-MAS09325	Number of activations-Daytime running lights	377
IDE09774-ENG120597	Number of activations-High_beam	330
IDE09774-ENG120596	Number of activations-Low_beam	595
IDE09774-ENG35039	Number of activations-Position_light	491
IDE09774-ENG35044	Number of activations-Turn_indicator	27663
IDE09795-MAS09344	Operating times for motor of headlight range adjustment-over 60%	201.17	 H
IDE10048-IDE09771	Supply information-High side channel 2	Terminal_30g
IDE10048-IDE09772	Supply information-High side channel 3	Terminal 15
IDE10165-FSS01570	LED channel 1: Master 1-Temperature	44	 °C
IDE10167-FSS01570	LED channel 1: Slave-Temperature	44	 °C
IDE10170-FSS01570	LED channel 3: Master-Temperature	36	 °C
IDE10173-MAS09378	Operating times in temperature ranges-between -40°C and 95°C	165.5	 H
IDE10206-MAS09945	Fan for headlight-Fan 1: current	not installed
IDE10206-MAS09946	Fan for headlight-Fan 2: current	not installed
IDE10206-MAS11628	Fan for headlight-Fan 1: activation	not installed
IDE10206-MAS11629	Fan for headlight-Fan 2: activation	not installed
IDE10282-IDE13678	LED channels: voltages-LED channel 4: Master	0	 V
IDE10864-MAS11561	Control mod. temperatures-Power output stage for LED	52	 °C
IDE11124-IDE10205	Headlight beam adjusting motor-Control module version	not defined
IDE13678-FSS01570	LED channel 4: Master-Temperature	36	 °C
Elapsed Time: 00:04
adpmap-4B
Elapsed Time: 00:09
blockmap-4B
;Sunday	25	August	2019	16:06:16:27651
IDE00019	Voltage terminal 30	12.9	 V
IDE00030	Status of actuator test	not active
IDE00075	Vehicle speed	0	 km/h
IDE00322	Status of basic setting	not active
IDE00323	Security Access: Number of invalid keys	0
IDE00326	Steering wheel angle	12	 °
IDE00767-MAS03945	No. of unscheduled ECU resets-Watchdog Reset	0
IDE00773	Terminal 15 status via CAN	On
IDE01714	Status reverse gear	OFF
IDE01717-ENG30211	Processor load-Software_component_AFS_MXB	9	 %
IDE01717-ENG30223	Processor load-Total_system_FCM	22	 %
IDE01943	Turn signal	not activated
IDE01946	ESP intervention	not active
IDE02389	Ambient brightness	48	 lx
IDE02515	Low beam	OFF
IDE02743	High Beam	OFF
IDE03214	Engine stop using start-stop function	OFF
IDE03215	Engine start using start-stop function	OFF
IDE03602	Left front level control system sensor	-0.01	 %
IDE03604	Left rear level control system sensor	50	 %
IDE03616	Motor status	On
IDE03620	Front jounce travel	0	 mm
IDE03621	Rear jounce travel	0	 mm
IDE03622	Left headlight beam adjusting motor: status	no error
IDE03623	Right headlight beam adjusting motor: status	no error
IDE03624	Left dynamic AFS light motor: specified value	32	 °
IDE03625	Right dynamic AFS light motor: specified value	32	 °
IDE03626	Left dynamic AFS light motor: status	no error
IDE03627	Right dynamic AFS light motor: status	no error
IDE03628	Adjusting motor for variable left front lighting: status	no error
IDE03629	Adjusting motor for variable right front lighting: status	no error
IDE03630	Left headlight beam adjusting motor: specified value	1024	 mm
IDE03631	Right headlight beam adjusting motor: specified value	1024	 mm
IDE03632	Left-/right hand driving switch-over	OFF
IDE03638-IDE03717	static AFS light-Dim static left AFS light	102	 %
IDE03638-IDE03718	static AFS light-Dim static right AFS light	102	 %
IDE03640	Dynamic AFS light	On
IDE03669	Light distribution status	not activated
IDE03727	Variable left front lighting specified position	204.7	 %
IDE03728	Variable right front lighting specified position	204.7	 %
IDE03788	Status of basic headlamp setting	no request
IDE03850	Left front level ctrl sys sensor: adaptation value (zero pos)	-0.01	 %
IDE03866	Left rear level ctrl sys sensor: adaptation value (zero pos)	-0.01	 %
IDE04805-IDE02955	Driving profile selection-System status	Not available
IDE04805-IDE06419	Driving profile selection-Driving profile switchover	no request
IDE04805-MAS01447	Driving profile selection-Act.val.	0
IDE04805-MAS01448	Driving profile selection-Specified value	0
IDE04805-MAS05058	Driving profile selection-Compatibility	Yes
IDE08447	Driving axis angle	-120	 '
IDE08516-IDE02743	LED headlights: light distribution requirement-High Beam	not requested
IDE08516-IDE06864	LED headlights: light distribution requirement-Daytime running lights	not requested
IDE08516-MAS02922	LED headlights: light distribution requirement-City light	not requested
IDE08516-MAS02923	LED headlights: light distribution requirement-Highway light	not requested
IDE08516-MAS02931	LED headlights: light distribution requirement-Rural highway light	not requested
IDE08516-MAS02946	LED headlights: light distribution requirement-static AFS light	not requested
IDE08516-MAS07013	LED headlights: light distribution requirement-All-weather lights	not requested
IDE08516-MAS07014	LED headlights: light distribution requirement-Tourist light	not requested
IDE08516-MAS07015	LED headlights: light distribution requirement-Running light	not requested
IDE08516-MAS07234	LED headlights: light distribution requirement-Eco mode 1	both sides
IDE08516-MAS07235	LED headlights: light distribution requirement-Eco mode 2	not requested
IDE08706-MAS17323	Actual angle of ref. segments-Horizontal angle reference segment left: in angular minutes	-500	 '
IDE08706-MAS17324	Actual angle of ref. segments-Horizontal angle reference segment left: in degrees	-10	 °
IDE08706-MAS17325	Actual angle of ref. segments-Horizontal angle reference segment left: as a percentage	-15	 %
IDE08706-MAS17326	Actual angle of ref. segments-Horizontal angle reference segment right: in angular minutes	-500	 '
IDE08706-MAS17327	Actual angle of ref. segments-Horizontal angle reference segment right: in degrees	-10	 °
IDE08706-MAS17328	Actual angle of ref. segments-Horizontal angle reference segment right: as a percentage	-15	 %
IDE08706-MAS17329	Actual angle of ref. segments-Vertical angle reference segment left: in angular minutes	-120	 '
IDE08706-MAS17330	Actual angle of ref. segments-Vertical angle reference segment left: in degrees	-10	 °
IDE08706-MAS17331	Actual angle of ref. segments-Vertical angle reference segment left: as a percentage	-15	 %
IDE08706-MAS17332	Actual angle of ref. segments-Vertical angle reference segment right: in angular minutes	-120	 '
IDE08706-MAS17333	Actual angle of ref. segments-Vertical angle reference segment right: in degrees	-10	 °
IDE08706-MAS17334	Actual angle of ref. segments-Vertical angle reference segment right: as a percentage	-15	 %
IDE08713-MAS17335	Matrix light: calculated offset values-Horizontal offset: left headlight in angular minutes	-300	 '
IDE08713-MAS17336	Matrix light: calculated offset values-Horizontal offset: left headlight in degrees	-5	 °
IDE08713-MAS17337	Matrix light: calculated offset values-Horizontal: left headlight as a percentage	-9	 %
IDE08713-MAS17338	Matrix light: calculated offset values-Horizontal offset: right headlight in angular minutes	-300	 '
IDE08713-MAS17339	Matrix light: calculated offset values-Horizontal offset: right headlight in degrees	-5	 °
IDE08713-MAS17340	Matrix light: calculated offset values-Horizontal offset: right headlight as a percentage	-9	 %
IDE08713-MAS17341	Matrix light: calculated offset values-Vertical offset: left headlight in angular minutes	-300	 '
IDE08713-MAS17342	Matrix light: calculated offset values-Vertical offset: left headlight in degrees	-5	 °
IDE08713-MAS17343	Matrix light: calculated offset values-Vertical offset: left headlight as a percentage	-9	 %
IDE08713-MAS17344	Matrix light: calculated offset values-Vertical offset: right headlight in angular minutes	-300	 '
IDE08713-MAS17345	Matrix light: calculated offset values-Vertical offset: right headlight in degrees	-5	 °
IDE08713-MAS17346	Matrix light: calculated offset values-Vertical offset: right headlight as a percentage	-9	 %
IDE08714-MAS06929	Axle offsets-Axle offset front	-400	 mm
IDE08714-MAS06930	Axle offsets-Axle offset rear	-400	 mm
IDE08715	Func. status matrix high beam	not active
MAS16427-MAS17003	Online data acquisition configuration-Locking time for change of condition	1	 s
MAS16427-MAS19090	Online data acquisition configuration-Configuration version	FF FF FF FE
MAS16428-MAS00106	Online data acquisition and analysis-Year	2000
MAS16428-MAS00107	Online data acquisition and analysis-Month	0
MAS16428-MAS00108	Online data acquisition and analysis-Day	0
MAS16428-MAS00109	Online data acquisition and analysis-Hours	0
MAS16428-MAS00110	Online data acquisition and analysis-Minutes	0
MAS16428-MAS00111	Online data acquisition and analysis-Seconds	0
MAS16428-MAS16995	Online data acquisition and analysis-Downloads data set number	0
MAS16428-MAS19089	Online data acquisition and analysis-Emergency Call Module recognition and communication unit or navigation	Navigation
MAS16431-MAS16982	Online data acquisition warning overview-Type of first warning	24
MAS16431-MAS16983	Online data acquisition warning overview-Type of second warning	27
MAS16431-MAS16984	Online data acquisition warning overview-Type of third warning	31
MAS16431-MAS16985	Online data acquisition warning overview-Type of fourth WARNING	15
MAS16431-MAS16986	Online data acquisition warning overview-Type of fifth WARNING	0
MAS16431-MAS16987	Online data acquisition warning overview-Type of sixth WARNING	0
MAS16431-MAS16988	Online data acquisition warning overview-Type of seventh WARNING	0
MAS16432-MAS00106	Online data acquisition: warning 1-Year	2000
MAS16432-MAS00107	Online data acquisition: warning 1-Month	0
MAS16432-MAS00108	Online data acquisition: warning 1-Day	0
MAS16432-MAS00109	Online data acquisition: warning 1-Hours	0
MAS16432-MAS00110	Online data acquisition: warning 1-Minutes	0
MAS16432-MAS00111	Online data acquisition: warning 1-Seconds	0
MAS16432-MAS16989	Online data acquisition: warning 1-Index of the warning	2
MAS16432-MAS16990	Online data acquisition: warning 1-Number of warnings	185
MAS16433-MAS00106	Online data acquisition: warning 2-Year	2000
MAS16433-MAS00107	Online data acquisition: warning 2-Month	0
MAS16433-MAS00108	Online data acquisition: warning 2-Day	0
MAS16433-MAS00109	Online data acquisition: warning 2-Hours	0
MAS16433-MAS00110	Online data acquisition: warning 2-Minutes	0
MAS16433-MAS00111	Online data acquisition: warning 2-Seconds	0
MAS16433-MAS16989	Online data acquisition: warning 2-Index of the warning	2
MAS16433-MAS16990	Online data acquisition: warning 2-Number of warnings	185
MAS16434-MAS00106	Online data acquisition: warning 3-Year	2000
MAS16434-MAS00107	Online data acquisition: warning 3-Month	0
MAS16434-MAS00108	Online data acquisition: warning 3-Day	0
MAS16434-MAS00109	Online data acquisition: warning 3-Hours	0
MAS16434-MAS00110	Online data acquisition: warning 3-Minutes	0
MAS16434-MAS00111	Online data acquisition: warning 3-Seconds	0
MAS16434-MAS16989	Online data acquisition: warning 3-Index of the warning	2
MAS16434-MAS16990	Online data acquisition: warning 3-Number of warnings	185
MAS16435-MAS00106	Online data acquisition: warning 4-Year	2019
MAS16435-MAS00107	Online data acquisition: warning 4-Month	8
MAS16435-MAS00108	Online data acquisition: warning 4-Day	21
MAS16435-MAS00109	Online data acquisition: warning 4-Hours	5
MAS16435-MAS00110	Online data acquisition: warning 4-Minutes	37
MAS16435-MAS00111	Online data acquisition: warning 4-Seconds	53
MAS16435-MAS16989	Online data acquisition: warning 4-Index of the warning	3
MAS16435-MAS16990	Online data acquisition: warning 4-Number of warnings	8
MAS16436-MAS00106	Online data acquisition: warning 5-Year	2000
MAS16436-MAS00107	Online data acquisition: warning 5-Month	0
MAS16436-MAS00108	Online data acquisition: warning 5-Day	0
MAS16436-MAS00109	Online data acquisition: warning 5-Hours	0
MAS16436-MAS00110	Online data acquisition: warning 5-Minutes	0
MAS16436-MAS00111	Online data acquisition: warning 5-Seconds	0
MAS16436-MAS16989	Online data acquisition: warning 5-Index of the warning	0
MAS16436-MAS16990	Online data acquisition: warning 5-Number of warnings	0
MAS16437-MAS00106	Online data acquisition: warning 6-Year	2000
MAS16437-MAS00107	Online data acquisition: warning 6-Month	0
MAS16437-MAS00108	Online data acquisition: warning 6-Day	0
MAS16437-MAS00109	Online data acquisition: warning 6-Hours	0
MAS16437-MAS00110	Online data acquisition: warning 6-Minutes	0
MAS16437-MAS00111	Online data acquisition: warning 6-Seconds	0
MAS16437-MAS16989	Online data acquisition: warning 6-Index of the warning	0
MAS16437-MAS16990	Online data acquisition: warning 6-Number of warnings	0
MAS16438-MAS00106	Online data acquisition: warning 7-Year	2000
MAS16438-MAS00107	Online data acquisition: warning 7-Month	0
MAS16438-MAS00108	Online data acquisition: warning 7-Day	0
MAS16438-MAS00109	Online data acquisition: warning 7-Hours	0
MAS16438-MAS00110	Online data acquisition: warning 7-Minutes	0
MAS16438-MAS00111	Online data acquisition: warning 7-Seconds	0
MAS16438-MAS16989	Online data acquisition: warning 7-Index of the warning	0
MAS16438-MAS16990	Online data acquisition: warning 7-Number of warnings	0
ENG101323	Headlight leveling control state	static
ENG107365	Left dynamic cornering light value	9	 °
ENG26446-ENG30212	Multifunction_Module_Application_Software_Version-Software_Version_AFS/MXB	162
ENG26446-ENG30225	Multifunction_Module_Application_Software_Version-Version_Routing_FCM	7190
ENG124613	Predictive_Route_Data_Intown_Flag	Not available
ENG124610	Predictive_Route_Data_Number_Of_Lanes	Not available
ENG124612	Predictive_Route_Data_Placename_Sign	Not available
ENG124611	Predictive_Route_Data_Speed_Limit	Not available
ENG124609	Predictive_Route_Data_Street_Class	Not available
ENG108468	Right dynamic cornering light value	ERROR
Elapsed Time: 00:09
TWs/VW
NW Florida
C?ID=369048
Autoscan - 2019 Atlas SEL (continued)
adpmap-09
;SW:5Q0-937-085-BT   HW:5Q0-937-085-BG ---  Cent. Elect.
;Component:BCM MQBAB HNA H38 0273	 Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB	19001	EV_BCMBOSCH_019_VW37.rod
;Sunday	25	August	2019	16:01:12:27651
;VCID: 0C41A58456CD9757A61-8058
IDE00001-ENG99061-Production mode-Access control	not active 	3
IDE00001-ENG115730-Production mode-Exterior lighting	not active 	3
IDE00001-ENG112304-Production mode-Heckwischer	not active 	3
IDE00001-ENG98647-Production mode-Interior lighting	not active 	3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active 	3
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active 	3
IDE00002-Transport mode	active 	1
IDE02152-Characteristics in production mode	2000 ms	4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate 	10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active 	10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	active 	10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active 	10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active 	10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	short 	10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active 	10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	active 	10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active 	10
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl	not active 	10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl	active 	10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit	200 ms	10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit	200 ms	10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit	200 ms	10
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active 	8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen	not active 	8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1	8 s	8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2	16 s	8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer	logikgesteuert 	8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active 	8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active 	8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s	8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s	8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s	8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s	8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active 	8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer	Keine_Spannungsanforderung 	8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active 	8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck	0 ms	8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	0.3 °	16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s	16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides 	16
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h	16
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C	16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C	16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °	16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C	16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	80 °	16
IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h	16
IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119 	16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht	15 min	16
IDE04927-IDE01446-Window heater-Running time of heated front window	240 s	11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.0 °C	11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.0 °C	11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer	0 s	11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt	not installed 	11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus	not installed 	11
IDE04927-ENG126845-Window heater-FSH Automatik	active 	11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	320 s	11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe	installed 	11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe	not installed 	11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage	not installed 	11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active 	11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	active 	11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv	-2.0 °C	11
IDE04927-ENG141962-Window heater-Waschduesenheizung	installed 	11
IDE04927-ENG154810-Window heater-window heating front activation time pause	240 s	11
IDE04928-MAS01577-Anti-theft device-Parking heater	not installed 	8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active 	8
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated 	8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system	active 	8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick	activ 	8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI	not_active 	8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active 	8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active 	8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder	Horn_verbaut 	8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor	not installed 	8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet	No 	8
IDE04928-ENG142249-Anti-theft device-OBD Alarm	not_active 	8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm	activ 	8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)	No 	8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung	No 	8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme 	8
IDE04928-ENG142008-Anti-theft device-tilt_sensor	No 	8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active 	8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung 	8
IDE05143-MAS02985-Writing parameter-Value	130	5
IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00 	5
IDE05144-Read parameter address	FE 00 00 	3
IDE05145-Light configuration	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 05 44 00 4A 46 00 7F 08 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 1E 00 64 00 00 00 0A 42 00 23 13 17 64 00 00 00 1E 00 64 00 00 00 	224
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler	0	30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN	Heizmatten am BCM 	30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	18.50 °C	30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	18.00 °C	30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	18.50 °C	30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	18.00 °C	30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	26.00 °C	30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	25.50 °C	30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	26.00 °C	30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	25.50 °C	30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	43.00 °C	30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	42.50 °C	30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	43.00 °C	30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	42.50 °C	30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI	Keine_Spannungsanforderung 	30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO	Keine_Spannungsanforderung 	30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe	not installed 	30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75	15.7 V	30
IDE06425-Roller test bench mode: functional	not active 	1
IDE06507-MAS13125-Button in center console-Function of button 1	Start-stop 	8
IDE06507-MAS13129-Button in center console-Function of button 2	not coded/not installed 	8
IDE06507-MAS13132-Button in center console-Function of button 3	not coded/not installed 	8
IDE06507-MAS13135-Button in center console-Function of button 4	Steering wheel heater 	8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED	LED installed 	8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich	active 	8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt	not active 	8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige	active 	8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik	active 	8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active 	8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start	installed 	8
IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut	not installed 	8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung	active 	8
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit 	6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min	6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein	active 	6
IDE08577-Garage door opener: use of GPS data	not active 	1
IDE08578-Garage door opener: bi-directional communic.	active 	1
IDE08580-Garage door opener: increasing transm. power	not active 	1
IDE08583-Garage door opener: no. of channels	3 channels 	1
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A	not active 	2
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B	not active 	2
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C	not active 	2
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D	not active 	2
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E	not active 	2
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F	not active 	2
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G	not active 	2
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H	not active 	2
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I	not active 	2
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J	not active 	2
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K	not active 	2
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I	not active 	2
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II	not active 	2
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III	not active 	2
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV	not active 	2
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB	not active 	2
IDE08585-Garage door opener: activation via remote key	not active 	1
IDE08778-Garage door opener: surround. target area	30 m	1
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active 	9
IDE08786-ENG141956-Assistance light functions-Humidity sensor	installed 	9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal 	9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active 	9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion	not active 	9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor	LIN_REGEN_LICHT_SENSOR 	9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor	installed 	9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual	7	19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation	not active 	19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung	not active 	19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default	not active 	19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s	19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2	19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3	19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1	19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	50%	19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	2	19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum	50%	19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	50%	19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer	50%	19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn	50%	19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active 	19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active 	19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen	active 	19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten	active 	19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light	Keine_Spannungsanforderung 	19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM	not active 	19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht	not installed 	19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active 	19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel	not installed 	19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel	not installed 	19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active 	19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G	installed 	19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active 	19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default	1	5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI	not active 	5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed 	5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	not installed 	5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed 	5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active 	5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active 	5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed 	5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed 	5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed 	5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed 	5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed 	5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI	not active 	5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active 	5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed 	5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed 	5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%	17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	30%	17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%	17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	30%	17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	50%	17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	50%	17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	50%	17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	50%	17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	75%	17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	75%	17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	80%	17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%	17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung	not installed 	17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar	installed 	17
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik	not installed 	17
IDE10308-Garage door opener: support door name	not active 	1
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode	not active 	1
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1	not active 	1
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2	not active 	1
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3	not active 	1
IDE10350-Garage door opener: programming antenna	External antenna 	1
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1	256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	1	256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	0.4	256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	0	256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1	256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1	256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	1	256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	0	256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0	256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0	256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0	256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0	256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0	256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0	256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0	256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0	256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1	256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1	256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0	256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0	256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	70%	256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	0%	256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	0%	256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	70%	256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	0%	256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	0%	256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	70%	256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	0%	256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	0%	256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	70%	256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	0%	256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	0%	256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%	256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%	256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	70%	256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%	256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	0%	256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%	256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%	256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%	256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	0%	256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%	256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%	256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	0%	256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%	256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	0%	256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%	256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%	256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%	256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0%	256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%	256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%	256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	70%	256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%	256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	0%	256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%	256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%	256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%	256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	0%	256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%	256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%	256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	127%	256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	0%	256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%	256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%	256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	0%	256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%	256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%	256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%	256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%	256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	0%	256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%	256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%	256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%	256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	0%	256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	127%	256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	0%	256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	0%	256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%	256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%	256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	126%	256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%	256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	0%	256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%	256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%	256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%	256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	0%	256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%	256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%	256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	70%	256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%	256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	0%	256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%	256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%	256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%	256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	0%	256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%	256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%	256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	70%	256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	0%	256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%	256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%	256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	0%	256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%	256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%	256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	70%	256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%	256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	0%	256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%	256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%	256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%	256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	0%	256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%	256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%	256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	70%	256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%	256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	0%	256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%	256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%	256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%	256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	0%	256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte	200 ms	256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s	256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s	256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s	256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s	256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s	256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s	256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s	256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s	256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	2.0 s	256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s	256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s	256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.0 s	256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s	256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s	256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s	256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s	256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s	256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s	256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s	256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s	256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s	256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s	256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s	256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s	256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s	256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s	256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s	256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s	256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s	256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s	256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s	256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s	256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s	256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s	256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s	256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s	256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s	256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s	256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s	256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s	256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s	256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s	256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0	256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1	0	30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10	0	30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2	0	30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3	0	30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4	0	30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5	0	30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6	0	30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7	0	30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8	0	30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9	0	30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1	0	30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10	0	30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2	0	30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3	0	30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4	0	30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5	0	30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6	0	30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7	0	30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8	0	30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9	0	30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1	0	30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10	0	30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2	0	30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3	0	30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4	0	30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5	0	30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6	0	30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7	0	30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8	0	30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9	0	30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung	installed 	3
IDE11944-ENG141948-Keyless access and start authorization-Kessy	installed 	3
IDE11944-ENG246971-Keyless access and start authorization-Kessy BewegungsüberwachungIDGeber	not active 	3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen	not active 	3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen	active 	3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung	active 	3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit	not active 	3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit	not active 	3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung	not active 	3
IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor	Not available 	6
IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor	Not available 	6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch	Not available 	6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module	Not available 	6
IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit	Not available 	6
IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System	Not available 	6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn	Not available 	6
IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof	Not available 	6
IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module	Not available 	6
IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind	Not available 	6
IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender	Not available 	6
IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left	Not available 	6
IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right	Not available 	6
IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left	Not available 	6
IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left	Not available 	6
IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right	Not available 	6
IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right	Not available 	6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control	Not available 	6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch	Not available 	6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin	0	30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin	0	30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin	0	30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin	0	30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin	0	30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin	0	30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin	0	30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin	0	30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin	0	30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin	0	30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin	0	30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin	0	30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin	0	30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin	0	30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin	0	30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin	0	30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin	0	30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin	0	30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin	0	30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin	0	30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin	0	30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin	0	30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin	0	30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin	0	30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin	0	30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin	0	30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin	0	30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin	0	30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin	0	30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin	0	30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung	active 	5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation	Energy management active 	5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug	not installed 	5
MAS01490-ENG141950-Energy management-Hybrid vehicle	No 	5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement	not active 	5
MAS01490-ENG141978-Energy management-Recuperation	active 	5
MAS01490-ENG142037-Energy management-Zweitbatterie	not installed 	5
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze	1200 lx	24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze	2200 lx	24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle	0 lx	24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO	600 lx	24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten	1200 lx	24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten	2200 lx	24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red	00 00 	24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell	2000 lx	24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway	not active 	24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain	not active 	24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity	frueh 	24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF	not active 	24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe	not active 	24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung	0 mV	24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke	0 lx	24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung	0 mV	24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke	0 lx	24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung	2	24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status	not active 	9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC	00 00 00 	9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC	First_dtc 	9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	active 	4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	active 	4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler	not installed 	4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11	0	60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12	0	60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13	0	60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14	0	60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15	0	60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16	0	60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17	0	60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18	0	60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19	0	60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20	0	60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21	0	60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22	0	60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23	0	60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24	0	60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25	0	60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26	0	60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27	0	60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28	0	60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29	0	60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30	0	60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11	0	60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12	0	60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13	0	60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14	0	60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15	0	60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16	0	60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17	0	60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18	0	60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19	0	60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20	0	60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21	0	60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22	0	60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23	0	60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24	0	60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25	0	60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26	0	60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27	0	60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28	0	60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29	0	60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30	0	60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11	0	60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12	0	60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13	0	60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14	0	60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15	0	60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16	0	60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17	0	60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18	0	60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19	0	60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20	0	60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21	0	60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22	0	60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23	0	60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24	0	60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25	0	60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26	0	60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27	0	60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28	0	60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29	0	60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30	0	60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin	0	60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin	0	60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin	0	60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin	0	60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin	0	60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin	0	60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin	0	60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin	0	60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin	0	60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin	0	60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin	0	60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin	0	60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin	0	60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin	0	60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin	0	60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin	0	60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin	0	60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin	0	60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin	0	60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin	0	60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin	0	60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin	0	60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin	0	60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin	0	60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin	0	60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin	0	60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin	0	60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin	0	60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin	0	60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin	0	60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin	0	60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin	0	60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin	0	60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin	0	60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin	0	60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin	0	60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin	0	60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin	0	60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin	0	60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin	0	60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin	0	60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin	0	60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin	0	60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin	0	60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin	0	60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin	0	60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin	0	60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin	0	60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin	0	60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin	0	60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin	0	60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin	0	60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin	0	60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin	0	60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin	0	60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin	0	60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin	0	60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin	0	60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin	0	60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin	0	60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1	30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1	30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1	30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1	30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1	30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1	30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1	30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1	30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1	30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1	30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1	30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1	30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1	30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1	30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1	30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door 	30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door 	30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door 	30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door 	30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door 	30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door 	30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door 	30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door 	30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door 	30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door 	30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door 	30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door 	30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door 	30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door 	30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door 	30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed 	30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed 	30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed 	30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed 	30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed 	30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed 	30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed 	30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed 	30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed 	30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed 	30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed 	30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed 	30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed 	30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed 	30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed 	30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed 	60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed 	60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed 	60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed 	60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed 	60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed 	60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed 	60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed 	60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed 	60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed 	60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed 	60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed 	60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed 	60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed 	60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed 	60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed 	60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed 	60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed 	60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed 	60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed 	60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente	Keine_Spannungsanforderung 	23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0	1	23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1	1	23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10	1	23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11	1	23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12	1	23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13	1	23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14	1	23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15	1	23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2	1	23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3	1	23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4	1	23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5	1	23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6	1	23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7	1	23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8	1	23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9	1	23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken	not active 	10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken	active 	10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger	separte 	10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing	not active 	10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken	not active 	10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung	not active 	10
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10	not active 	10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay	50 ms	10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken	not active 	10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen	Warnblinke_zulaessig 	10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken	active 	10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen	5	10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken	not active 	10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2	not active 	10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing	not active 	10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS	PreCrash_passiv 	10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links	not active 	10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts	not active 	10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken	not active 	10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing	not active 	10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active 	10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken	not active 	10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz	not active 	10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max	120 min	10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS	not active 	10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN	not active 	10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf	not active 	10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu	not active 	10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp	H7 	9
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren	not active 	9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze	350 km/h	9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze	350 km/h	9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag	Daytime running lights 	9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL	5 km/h	9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich	not active 	9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active 	9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument	not active 	9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut	not installed 	9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht	active 	9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	active 	9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	active 	9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO	not active 	9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active 	9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte	not active 	9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit	not active 	9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active 	9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren	limitieren 	9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht	No 	5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit	0 km/h	5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA	not active 	5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion	not active 	5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe	not installed 	5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights	not installed 	18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung	begrenzen auf Mindestverfügbarkeit 	18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht	Aktive Begrenzung 	18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf	0 ms	18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten	Fog light 	18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus	automatic 	18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis	Driver door 	18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach	not active 	18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis 	18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten 	18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH	Sollspannungsanforderung 13.5 	18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light	Sollspannungsanforderung 13.5 	18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung	46400 lx	18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung	12 lx	18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige	No 	18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung 	18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker	false 	18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL	Yes 	18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht	No 	18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht	Yes 	18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung	Yes 	18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus	Enabled 	18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)	discrete 	18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten	klemmenabhaengig 	18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module	installed 	18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam	Sollspannungsanforderung 13.5 	18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren 	18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome	90 seconds 	18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP	90 seconds 	18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung	active 	18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP	active 	18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert	not active 	18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus	active 	18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht	not active 	18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit	6 s	18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal	Sollspannungsanforderung 13.5 	18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte	not active 	18
ENG126647-ENG98399-debug_light_function-Activation	0	11
ENG126647-ENG101417-debug_light_function-Adresse	0	11
ENG126647-ENG126820-debug_light_function-Bitmask	0	11
ENG126647-ENG126821-debug_light_function-Divisor	0	11
ENG126647-ENG98827-debug_light_function-Offset	0	11
ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
ENG246955-ENG246967-digital_key-central_locking_digital_key_general	not installed 	3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle	not active 	3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion	not active 	3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer	not active 	3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle	not active 	3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion	not active 	3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer	not active 	3
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0	0.00%	6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1	50.00%	6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2	100.00%	6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0	0.00%	6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1	50.00%	6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2	100.00%	6
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP	present 	6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung	AFS: FLA: Fernlicht ueber AFS 	6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset	not active 	6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent	present 	6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung	present 	6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA	not active 	6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung	800 ms	6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm	active 	6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf	active 	6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig	Sollspannungsanforderung 13.5 	6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition	not active 	6
ENG141682-ENG141966-Front_wiper-Frontwischertyp	Direct 	6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active 	6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer	not active 	6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer	0 ms	6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren	Deactivating 	6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay	300 ms	6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz	active 	6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status	not active 	6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung	not active 	6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant	not active 	6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube	not active 	6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus	not active 	6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube	active 	6
ENG99457-ENG117394-Head area heater-blower_speed	1	2
ENG99457-ENG98971-Head area heater-Temperature	-2	2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid	installed 	8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid	installed 	8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant	installed 	8
ENG141645-MAS00214-HW_Verbau-Brake pad wear	not installed 	8
ENG141645-ENG142026-HW_Verbau-Druckklappe	not installed 	8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv	not active 	8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung	not installed 	8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor	installed 	8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube	installed 	8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung	not installed 	8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer	not installed 	8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15	active 	8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung	not active 	8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0	-100.00%	30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1	-100.00%	30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2	-100.00%	30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3	-100.00%	30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4	-100.00%	30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5	-100.00%	30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6	-100.00%	30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7	-100	30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8	-100.00%	30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9	-100.00%	30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0	100.00%	30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1	90.00%	30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2	80.00%	30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3	70.00%	30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4	60.00%	30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5	50.00%	30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6	40.00%	30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7	30.00%	30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8	15.00%	30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9	0.00%	30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize 	16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize 	16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize 	16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	0	16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0	16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0	16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0	16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	0	16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	0	16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	not active 	16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always 	16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	not active 	16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active 	16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active 	16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active 	16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active 	16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active 	16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active 	16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active 	16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15	maximize 	16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15	maximize 	16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15	maximize 	16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15	100	16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15	0	16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15	0	16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15	0	16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15	63	16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15	0	16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15	41 - LED Kleinleistung 	16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15	Always 	16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15	Warnblinktaster_Suchbeleuchtung 	16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15	not active 	16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15	not active 	16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15	not active 	16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15	not active 	16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15	not active 	16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15	not active 	16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15	not active 	16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize 	16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize 	16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize 	16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	0	16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0	16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0	16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0	16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	0	16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	0	16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	not active 	16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always 	16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	not active 	16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	not active 	16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active 	16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active 	16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active 	16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active 	16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active 	16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active 	16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize 	16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize 	16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize 	16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0	16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0	16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0	16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0	16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	0	16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	0	16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	not active 	16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always 	16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	not active 	16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	not active 	16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active 	16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active 	16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active 	16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active 	16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active 	16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active 	16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize 	16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize 	16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize 	16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100	16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0	16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	100	16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0	16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22	16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38	16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer 	16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always 	16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links 	16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	Abbiegelicht links 	16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active 	16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active 	16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	Coming Home oder Leaving Home aktiv 	16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active 	16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active 	16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active 	16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize 	16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize 	16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize 	16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100	16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0	16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	100	16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0	16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23	16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42	16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer 	16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always 	16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts 	16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	Abbiegelicht rechts 	16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active 	16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active 	16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	Coming Home oder Leaving Home aktiv 	16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active 	16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active 	16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active 	16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	minimize 	16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	minimize 	16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize 	16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	10	16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0	16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0	16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0	16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	2A 	16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	1A 	16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	43 - allgemeine LED 	16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always 	16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	Daytime running lights 	16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	Brake light 	16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active 	16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	Coming Home oder Leaving Home aktiv 	16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active 	16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active 	16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active 	16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	minimize 	16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	minimize 	16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize 	16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	10	16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0	16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0	16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0	16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	29	16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0A 	16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	43 - allgemeine LED 	16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always 	16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	Daytime running lights 	16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	Brake light 	16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active 	16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	Coming Home oder Leaving Home aktiv 	16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active 	16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active 	16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active 	16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize 	16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize 	16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize 	16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	100	16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0	16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0	16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0	16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	16	16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	8	16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	12 - Blinkleuchten 	16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always 	16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	Blinken links Hellphase 	16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active 	16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active 	16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active 	16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active 	16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active 	16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active 	16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active 	16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize 	16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize 	16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize 	16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	100	16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0	16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0	16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0	16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	18	16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	18	16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	12 - Blinkleuchten 	16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always 	16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	Blinken rechts Hellphase 	16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active 	16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active 	16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active 	16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active 	16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active 	16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active 	16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active 	16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize 	16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize 	16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize 	16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	0	16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0	16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0	16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0	16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	0	16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	0	16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	not active 	16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always 	16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	not active 	16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active 	16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active 	16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active 	16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active 	16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active 	16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active 	16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active 	16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	maximize 	16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize 	16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize 	16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	127	16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	0	16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	0	16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0	16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	2B 	16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	9	16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	43 - allgemeine LED 	16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always 	16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light 	16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	not active 	16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	not active 	16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	not active 	16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	not active 	16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active 	16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active 	16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active 	16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	maximize 	16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize 	16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize 	16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	127	16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	0	16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	0	16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0	16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	2D 	16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	19	16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	43 - allgemeine LED 	16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always 	16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light 	16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	not active 	16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	not active 	16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	not active 	16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	not active 	16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active 	16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active 	16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active 	16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize 	16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize 	16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize 	16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	127	16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0	16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0	16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0	16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C 	16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29	16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte 	16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	only_if_closed 	16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light 	16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	Quittierungsfunktion 1 	16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active 	16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active 	16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active 	16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active 	16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active 	16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active 	16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize 	16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	minimize 	16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize 	16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	10	16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	127	16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0	16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0	16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	35	16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A 	16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	43 - allgemeine LED 	16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	only_if_closed 	16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	Daytime running lights 	16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	Brake light 	16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active 	16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	Coming Home oder Leaving Home aktiv 	16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active 	16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active 	16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active 	16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize 	16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	minimize 	16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize 	16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	10	16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	127	16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0	16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0	16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	36	16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A 	16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	43 - allgemeine LED 	16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	only_if_closed 	16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	Daytime running lights 	16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	Brake light 	16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active 	16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	Coming Home oder Leaving Home aktiv 	16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active 	16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active 	16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active 	16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize 	16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	minimize 	16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize 	16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	75	16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0	16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0	16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0	16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30	16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28	16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED 	16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	only_if_closed 	16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active 	16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active 	16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active 	16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	Coming Home oder Leaving Home aktiv 	16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active 	16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active 	16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active 	16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize 	16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize 	16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize 	16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	100	16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0	16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0	16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0	16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	0	16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	0	16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	43 - allgemeine LED 	16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	Always 	16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active 	16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active 	16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active 	16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active 	16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active 	16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active 	16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active 	16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	minimize 	16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	minimize 	16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize 	16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	10	16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	127	16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0	16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0	16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	37	16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	9	16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	41 - LED Kleinleistung 	16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	only_if_closed 	16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active 	16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	Brake light 	16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active 	16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	Coming Home oder Leaving Home aktiv 	16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active 	16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active 	16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active 	16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize 	16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize 	16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize 	16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	100	16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0	16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	100	16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0	16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31	16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B 	16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	9 - allgemeine Glühlampe 27W: auch H15 	16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	only_if_closed 	16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht 	16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active 	16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active 	16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active 	16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	Coming Home oder Leaving Home aktiv 	16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active 	16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active 	16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active 	16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize 	16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize 	16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize 	16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	100	16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0	16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	100	16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0	16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32	16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B 	16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	9 - allgemeine Glühlampe 27W: auch H15 	16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	only_if_closed 	16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht 	16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active 	16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active 	16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active 	16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	Coming Home oder Leaving Home aktiv 	16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active 	16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active 	16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active 	16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize 	16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize 	16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize 	16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	0	16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	0	16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	0	16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0	16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	0	16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	0	16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	not active 	16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always 	16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	not active 	16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active 	16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	not active 	16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	not active 	16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	not active 	16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	not active 	16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active 	16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active 	16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize 	16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize 	16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize 	16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	100	16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0	16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0	16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0	16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2	16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0	16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung 	16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always 	16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light 	16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active 	16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active 	16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active 	16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active 	16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active 	16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active 	16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active 	16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize 	16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize 	16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize 	16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0	16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0	16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0	16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0	16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0	16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0	16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active 	16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always 	16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active 	16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active 	16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active 	16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active 	16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active 	16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active 	16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active 	16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active 	16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize 	16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize 	16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize 	16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0	16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0	16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0	16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0	16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0	16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0	16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active 	16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always 	16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active 	16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active 	16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active 	16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active 	16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active 	16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active 	16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active 	16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active 	16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize 	16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize 	16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize 	16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0	16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0	16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0	16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0	16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0	16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0	16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active 	16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always 	16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active 	16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active 	16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active 	16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active 	16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active 	16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active 	16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active 	16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active 	16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize 	16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize 	16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize 	16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0	16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0	16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0	16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0	16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0	16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0	16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active 	16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always 	16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active 	16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active 	16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active 	16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active 	16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active 	16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active 	16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active 	16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active 	16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize 	16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize 	16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize 	16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	0	16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	0	16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	0	16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0	16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	0	16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	0	16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	not active 	16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always 	16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	not active 	16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active 	16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	not active 	16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	not active 	16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	not active 	16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	not active 	16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active 	16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active 	16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	maximize 	16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize 	16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize 	16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	0	16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	0	16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	0	16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0	16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	0	16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	0	16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	not active 	16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always 	16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	not active 	16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active 	16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	not active 	16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	not active 	16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	not active 	16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	not active 	16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active 	16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active 	16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	maximize 	16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize 	16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize 	16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	0	16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	0	16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	0	16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0	16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	0	16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	0	16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	not active 	16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always 	16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	not active 	16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active 	16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	not active 	16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	not active 	16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	not active 	16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	not active 	16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active 	16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active 	16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize 	16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize 	16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize 	16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	127	16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0	16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0	16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0	16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A 	16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36	16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	5 - LED Abblendlicht 	16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always 	16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links 	16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	Lichthupe generell 	16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active 	16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active 	16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active 	16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active 	16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active 	16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active 	16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize 	16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize 	16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize 	16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	127	16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0	16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0	16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0	16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B 	16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40	16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	5 - LED Abblendlicht 	16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always 	16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts 	16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	Lichthupe generell 	16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active 	16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active 	16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active 	16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active 	16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active 	16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active 	16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize 	16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize 	16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize 	16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	127	16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	127	16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0	16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0	16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	49	16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	3A 	16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	5 - LED Abblendlicht 	16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always 	16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Versorgungsbedarf der LCM Module 	16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	not active 	16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	Parklicht links (beidseitiges Parklicht aktiviert li & re) 	16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active 	16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active 	16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active 	16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active 	16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize 	16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize 	16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize 	16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	127	16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	127	16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0	16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0	16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	4A 	16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	44	16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	5 - LED Abblendlicht 	16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always 	16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Versorgungsbedarf der LCM Module 	16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	not active 	16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 	16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	Parking light right 	16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active 	16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active 	16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active 	16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active 	16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck	0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 2B 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 2B 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 FF 00 00 00 00 00 00 00 00 00 2B 0A 00 35 08 14 8A 18 00 7F 1E 00 80 00 00 00 2B 1A 00 36 08 14 8A 18 00 7F 1E 00 80 00 00 00 2B 28 00 30 08 00 CB 00 00 00 1E 00 80 00 00 00 2B 00 00 00 08 00 64 00 00 00 00 00 00 00 00 00 29 09 00 37 08 00 8A 18 00 FF 1E 00 80 00 00 00 09 0B 00 31 19 00 E4 00 00 00 1E 00 64 00 00 00 09 1B 00 32 19 00 E4 00 00 00 1E 00 64 00 00 00 	192
ENG141662-Leuchtenkonfiguration_Sonstiges	2B 1A 00 2A 08 14 0A 18 00 80 1E 00 80 00 00 00 2B 0A 00 29 08 14 0A 18 00 80 1E 00 80 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 	128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR	1-Sensor_LWR 	62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges	0 mm	62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe	not active 	62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze	90.00%	62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze	10.00%	62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung	-127.0 ms	62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz	15%	62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe	10.0 s	62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1	-8.00 mm/%	62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2	-8.00 mm/%	62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3	-8.00 mm/%	62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1	-8.00 mm/%	62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2	-8.00 mm/%	62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3	-8.00 mm/%	62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante	Variante_1 	62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR	0.00%	62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf	0.00 Hz	62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung	normal 	62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal	Negative 	62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1	0 mm	62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2	0 mm	62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3	0 mm	62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4	0 mm	62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand	0 mm	62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe	0 mm	62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle	95.00%	62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle	5.00%	62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr	0 km/h	62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr	100 Hz	62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung	0.00 Hz	62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte	BCM 	62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed	not installed 	62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht	active 	62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese	20.00%	62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart	not active 	62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad	0.0 %/s	62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht	-100.00%	62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut	not installed 	62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR	0.00 s	62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1	2.0 s	7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang	10 s	7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion	active 	7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik	active 	7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS	Nicht_verbaut 	7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark	not active 	7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze	100 m	7
ENG246957-ENG246981-Lichttaster-Lichttastermodul	lds 	7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config	1	7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle	30 km/h	7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig	not active 	7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter	active 	7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig	active 	7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig	not active 	7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter	active 	7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig	active 	7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig	not active 	7
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1	not active 	1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2	not active 	1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active 	1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active 	1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active 	1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6	not active 	1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ	not active 	1
ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen	40 ms	27
ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen	40 ms	27
ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit	100 ms	27
ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt	10 ms	27
ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen	40 ms	27
ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen	40 ms	27
ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v	1 km/h	27
ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen	40 ms	27
ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen	500 ms	27
ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i	0.5	27
ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset	5 °C	27
ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p	13.00%	27
ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh	110 W	27
ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen	40 ms	27
ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh	25 Hz	27
ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg	0	27
ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0	39 °C	27
ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1	43 °C	27
ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2	47 °C	27
ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen	40 ms	27
ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus	50 °C	27
ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen	0 ms	27
ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung	0 ms	27
ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen	40 ms	27
ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen	40 ms	27
ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung	60 s	27
ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh	30 s	27
ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display	not installed 	2
ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation	Always 	2
ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper	installed 	2
ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock	not installed 	2
ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation	not installed 	2
ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button	not installed 	2
ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch	not installed 	2
ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch	not installed 	2
ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn	not active 	2
ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked	not active 	2
ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation	not active 	2
ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st	installed 	2
ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button	not installed 	2
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%	12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%	12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%	12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%	12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110	12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5	12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%	12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%	12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%	12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%	12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%	12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%	12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0	-5.00%	20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1	-5.00%	20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2	-5.00%	20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3	-5.00%	20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4	-5.00%	20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0	-5	20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1	-5	20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2	-5	20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3	-5	20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4	-5	20
ENG122979-ENG141954-Networking-A/C electronics	installed 	8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet	installed 	8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet	installed 	8
ENG122979-ENG141953-Networking-Getriebesteuergeraet	installed 	8
ENG122979-ENG99457-Networking-Head area heater	not installed 	8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG	not installed 	8
ENG122979-ENG141969-Networking-UGDO	installed 	8
ENG124714-ENG142044-OCU-DWA_push	active 	8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare	active 	8
ENG124714-ENG246970-OCU-IAA -Nutzer_management	not installed 	8
ENG124714-OCU-	installed 	8
ENG124714-ENG142261-OCU-Remote HuF Abbruch	20 km/h	8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz	3 Hz	8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1	80 s	8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3	2000 ms	8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock	Via ZV-Absicherung Light 	8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar	active 	16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten	4	16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung	not active 	16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	active 	16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv	active 	16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion	profiles_active 	16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	active 	16
ENG98831-ENG142030-Personalization-Profil_Variante	Konto (v. 1.x) 	16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1	active 	16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2	active 	16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3	active 	16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4	not active 	16
ENG141646-MAS01065-Querschnitts_funktionen-Brand	VW 	5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll	active 	5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung	active 	5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung	not active 	5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21	active 	5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus	Pin A31 	5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe	Sollspannungsanforderung 13.5 	5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben	active 	5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme	not_installed 	5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem	not active 	5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment	Left 	5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side	Right 	5
ENG122927-RLS_close_glazing	2.0 s	1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off	120 s	3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on	10 s	3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off	65 km/h	3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on	140 km/h	3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle	6000 lx	2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high	12	2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low	6	2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht	30 s	2
ENG122929-RLS_LIN_Communication	4 s	1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn	200 lx	1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day	500 lx	1
ENG122930-RLS_tunel_gateway_recognize	5 s	1
ENG122935-RLS_Washer_Front	15 s	1
ENG122926-RLS_wiper_position_parking	15 s	1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	10	10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system	not installed 	10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel	active 	10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit	2000 ms	10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit	800 ms	10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit	0 ms	10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit	0 ms	10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit	800 ms	10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen	Keine_Spannungsanforderung 	10
ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss	200 ms	48
ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung	1000 ms	48
ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus	5000 ms	48
ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein	300 s	48
ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus	5000 ms	48
ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein	300 s	48
ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus	5000 ms	48
ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein	300 s	48
ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel	200 ms	48
ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus	0 ms	48
ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein	0 ms	48
ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel	0 ms	48
ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung	90000 ms	48
ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung	90000 ms	48
ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error	200 ms	48
ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss	200 ms	48
ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung	1000 ms	48
ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus	5000 ms	48
ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein	300 s	48
ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel	200 ms	48
ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis	2000 ms	48
ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus	5000 ms	48
ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein	60 s	48
ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen	20 ms	48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen	0 ms	48
ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen	0 s	48
ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt	0	48
ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle	16.5 V	48
ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr	15.5 V	48
ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle	8.5 V	48
ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr	8.5 V	48
ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss	0 ms	48
ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus	0 ms	48
ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein	0 ms	48
ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus	0 ms	48
ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein	0 s	48
ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss	200 ms	48
ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung	1000 ms	48
ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus	0.0 s	48
ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein	0 s	48
ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus	5000 ms	48
ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein	300 s	48
ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel	200 ms	48
ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus	5000 ms	48
ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein	300 s	48
ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus	5000 ms	48
ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein	300 s	48
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG	not installed 	4
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker	MFG 	4
ENG116588-Sonderfunktionen-	not enabled 	4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1	not installed 	4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen	not active 	5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus	by convenience operation via remote control key 	5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen	not active 	5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung	active 	5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung	not active 	5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel	active 	5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung	not active 	5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt	active 	5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung	not active 	5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron	not active 	5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt	250	10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel	10 km/h	10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter	LIN 	10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel	1000 ms	10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen	40 ms	10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0	0.0 lx	10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1	8.0 lx	10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2	50.0 lx	10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3	80.0 lx	10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4	100.0 lx	10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0	6	10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1	6	10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2	20	10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3	50	10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4	100	10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0	0.0 lx	10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1	8.0 lx	10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2	50.0 lx	10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3	80.0 lx	10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4	100.0 lx	10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0	6	10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1	6	10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2	20	10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3	50	10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4	100	10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0	0 ms	22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1	200 ms	22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10	2000 ms	22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2	400 ms	22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3	600 ms	22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4	800 ms	22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5	1000 ms	22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6	1200 ms	22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7	1400 ms	22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8	1600 ms	22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9	1800 ms	22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0	100.00%	22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1	100.00%	22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10	0.00%	22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2	95.00%	22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3	80.00%	22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4	40.00%	22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5	20.00%	22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6	10.00%	22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7	5.00%	22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8	3.00%	22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9	1.00%	22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM	0.00 s	21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM	0.00 s	21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM	0.00 s	21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM	0.00 s	21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM	0.00 s	21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung	HMI 	21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen	20.0 s	21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen	3.0 s	21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe	not active 	21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten	not_active 	21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung	active 	21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS	2	21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM	0.00 s	21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert	50%	21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl	Fotosensor_Kombi 	21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung	Always active 	21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor	0.1	21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert	10.00%	21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0	0	22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1	50	22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10	0	22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2	100	22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3	200	22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4	253	22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5	0	22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6	0	22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7	0	22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8	0	22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9	0	22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0	0 lx	22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1	50 lx	22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10	0 lx	22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2	100 lx	22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3	200	22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4	500	22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5	0	22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6	0 lx	22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7	0 lx	22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8	0 lx	22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9	0 lx	22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0	0 ms	22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1	200 ms	22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10	2000 ms	22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2	400 ms	22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3	600 ms	22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4	800 ms	22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5	1000 ms	22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6	1200 ms	22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7	1400 ms	22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8	1600 ms	22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9	1800 ms	22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0	0.00%	22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1	1.00%	22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10	100.00%	22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2	3.00%	22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3	5.00%	22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4	11.00%	22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5	22.00%	22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6	40.00%	22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7	80.00%	22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8	95.00%	22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9	100.00%	22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0	0 lx	8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1	8 lx	8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2	50 lx	8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3	500 lx	8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0	100	8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1	100	8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2	100	8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3	100	8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0	0 lx	8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1	8 lx	8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2	50 lx	8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3	510 lx	8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0	6	8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1	6	8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2	100	8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3	100	8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0	0.00%	12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1	6.00%	12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2	16.00%	12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3	30.00%	12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4	60.00%	12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5	100.00%	12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0	10	12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1	10	12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2	100	12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3	150	12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4	220	12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5	253	12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0	0 lx	10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1	8 lx	10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2	200 lx	10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3	300 lx	10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4	500 lx	10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0	16	10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1	16	10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2	100	10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3	100	10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4	100	10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0	0 lx	10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1	50 lx	10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2	220 lx	10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3	300 lx	10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4	500 lx	10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0	6	10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1	16	10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2	25	10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3	30	10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4	50	10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0	0	12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1	10	12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2	50	12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3	100	12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4	220	12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5	253	12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0	2.00%	12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1	2.00%	12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2	6.00%	12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3	10.00%	12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4	80.00%	12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5	100.00%	12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0	0 lx	8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1	8 lx	8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2	50 lx	8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3	500 lx	8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0	6	8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1	6	8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2	100	8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3	100	8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0	0 lx	8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1	8 lx	8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2	50 lx	8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3	500 lx	8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0	100	8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1	100	8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2	100	8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3	100	8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0	0.00%	6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1	50.00%	6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2	100.00%	6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0	0.00%	6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1	50.00%	6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2	100.00%	6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0	0 lx	12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1	10 lx	12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2	100 lx	12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3	500 lx	12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4	800 lx	12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5	1020 lx	12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0	0	12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1	20	12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2	80	12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3	180	12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4	300	12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5	500	12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0	0 ms	10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1	2000 ms	10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2	3000 ms	10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3	4000 ms	10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4	5100 ms	10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0	1.00%	10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1	5	10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2	15	10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3	40	10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4	100	10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen	not active 	4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen	active 	4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen	tilting 	4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1	installed 	4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3	not installed 	4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo	installed 	4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule	CAN 	4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck	not_installed 	9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck	active 	9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv	not active 	9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb	not active 	9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close	not installed 	9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global	active 	9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen	active 	9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen	active 	9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf	not active 	9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen	active 	9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung	nur wenn mind. 1 Raste zu 	9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden	Always 	9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit	installed 	9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach	not active 	9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung	active 	9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy	active 	9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder	active 	9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung	active 	9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy	active 	9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder	active 	9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal	active 	9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar	active 	9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau	installed 	9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version	Version_1_2 	9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00 	20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00 	20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00 	20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00 	20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00 	20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00 	20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00 	20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00 	20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00 	20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00 	20
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB	not active 	7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern	not active 	7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active 	7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein	active 	7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein	active 	7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt	not installed 	7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster	not installed 	7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion	not active 	7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung	active 	7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion	active 	7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung	not active 	7
ENG141651-ENG141957-ZV allgemein-Radio freq.	315MHz 	7
ENG141651-ENG141958-ZV allgemein-Tankschloss	Bidirectional 	7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum	ZV_Wiederveriegelung 	7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung	Einzeltuerentriegelung 	7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion	installed 	7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck	active 	3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln	active 	3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit	active 	3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR	active 	3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active 	3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock	not active 	3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active 	4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen	not active 	4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash	not active 	4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels	active 	7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active 	7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active 	7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster	via_CAN 	7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung	not active 	7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen	active 	7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste	Yes 	7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung	Kontaktsteuerung mit Mindestansteuerzeit 	7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster	0.0 s	7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active 	7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang	No 	7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel	active 	7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen	not active 	7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp	1 or 2 notch rear actuator 	7
ENG141681-IDE02021-ZV Komfort-Comfort closing	active 	8
ENG141681-IDE02022-ZV Komfort-Comfort opening	not active 	8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten	Yes 	8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen	active 	8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen	not active 	8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit	600 s	8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus	active 	8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen	active 	8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen	active 	8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen	active 	8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global	active 	8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer	not active 	8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar	adjustable 	8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen	not active 	8
ENG141681-ENG246991-ZV Komfort-pa_Two_Keys	not active 	8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art	once 	8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus	not active 	8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen	not active 	8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen	not active 	8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss	2-Motorenschloesser 	5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal	nicht invertiert 	5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite	not installed 	5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite	not installed 	5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links	No 	5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts	No 	5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter	not installed 	5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM	Driver side 	5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active 	5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR	Yes 	5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer	Yes 	5
Elapsed Time: 02:50
blockmap-09
;SW:5Q0-937-085-BT   HW:5Q0-937-085-BG ---  Cent. Elect.
;Component:BCM MQBAB HNA H38 0273	 Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB	19001	EV_BCMBOSCH_019_VW37.rod
;Sunday	25	August	2019	15:59:45:27651
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: 0C41A58456CD9757A61-8058
Group	Description	Actual
IDE00030	Status of actuator test	not active
IDE00075	Vehicle speed	0	 km/h
IDE00322	Status of basic setting	was not yet started
IDE00323	Security Access: Number of invalid keys	0
IDE00356-IDE00355	Cruise Control System (CCS): switch position-Cruise Control System (CCS): status	No communication
IDE00356-MAS00125	Cruise Control System (CCS): switch position-Cruise control system	No communication
IDE00356-MAS00128	Cruise Control System (CCS): switch position-Distance Regulation	No communication
IDE00356-MAS00320	Cruise Control System (CCS): switch position-Main switch	No communication
IDE00356-MAS00323	Cruise Control System (CCS): switch position-Decelerate tap	No communication
IDE00356-MAS00325	Cruise Control System (CCS): switch position-Setting	No communication
IDE00356-MAS00326	Cruise Control System (CCS): switch position-Activation	No communication
IDE00356-MAS02321	Cruise Control System (CCS): switch position-Cancel	NOT-DEFINED
IDE00356-MAS02343	Cruise Control System (CCS): switch position-Station coding	No communication
IDE00356-MAS03758	Cruise Control System (CCS): switch position-Not Used	No communication
IDE00356-MAS05138	Cruise Control System (CCS): switch position-Control unit	No communication
IDE00374-MAS05377	Electric auxiliary heater: relay activation-Low heat output relay	not coded/not installed
IDE00374-MAS05378	Electric auxiliary heater: relay activation-High heat output relay	not coded/not installed
IDE00844-MAS07314	Switch for engine hood-Status engine hood contact	closed
IDE00844-ENG122175	Switch for engine hood-Bonnet_Magnetic_Lock	Measured value not available
IDE00973	Outside air temperature	31.5	 °C
IDE01066-IDE02092	Convertible top status-Tailgate condition	not coded/not installed
IDE01066	Convertible top status	not coded/not installed
IDE01285	Counter of component protection malfunctions	0
IDE01464-IDE04741	Rear window defogger-Rear window defogger button	not activated
IDE01464-IDE04744	Rear window defogger-Rear window defogger indicator lamp	OFF
IDE01464-MAS01580	Rear window defogger-Activation	not active
IDE01537-IDE04742	Windshield defogger-Windshield defogger button	not coded/not installed
IDE01537-IDE04743	Windshield defogger-Windshield defogger indicator lamp	not coded/not installed
IDE01537-MAS01580	Windshield defogger-Activation	not coded/not installed
IDE01943-MAS01737	Turn signal-Diagnosis	normal
IDE01943-MAS02248	Turn signal-Signal state	not active
IDE01943-MAS03873	Turn signal-Duty cycle	0	 %
IDE01943-MAS04351	Turn signal-Connector terminal number	60
IDE01943-MAS04352	Turn signal-Connector number	Plug A
IDE02092-IDE02093	Tailgate condition-Status of rear lid lock	not coded/not installed
IDE02092-IDE02133	Tailgate condition-Activation using rear lid unlocking button	OFF
IDE02092-MAS01872	Tailgate condition-Rear lid remote release button	not activated
IDE02092-MAS02405	Tailgate condition-Pre-engagement contact for rotary latch	closed
IDE02092-MAS02447	Tailgate condition-Release	not enabled
IDE02092-MAS06265	Tailgate condition-Release button in rear lid handle	not activated
IDE02092-MAS06430	Tailgate condition-Main notch contact of rotary latch	closed
IDE02486	Data logger triggering	not active
IDE02488-MAS01632	DWA Interior monitoring-Status	not coded/not installed
IDE02488-MAS04508	DWA Interior monitoring-Alarm detected	not coded/not installed
IDE02515-MAS01737	Low beam-Diagnosis	normal
IDE02515-MAS02248	Low beam-Signal state	not active
IDE02515-MAS03873	Low beam-Duty cycle	0	 %
IDE02515-MAS04351	Low beam-Connector terminal number	5
IDE02515-MAS04352	Low beam-Connector number	Plug C
IDE02588-IDE00020	Terminal signals and start release-Terminal 15 status	active
IDE02588-IDE00773	Terminal signals and start release-Terminal 15 status via CAN	active
IDE02588-IDE01351	Terminal signals and start release-Terminal 75 status	On
IDE02588-IDE01715	Terminal signals and start release-Status terminal S	active
IDE02588-IDE01716	Terminal signals and start release-Terminal 50 status	OFF
IDE02588-IDE06027	Terminal signals and start release-Terminal S status via CAN	active
IDE02588-MAS12787	Terminal signals and start release-Terminal 15 ignition switch signal 1	active
IDE02588-MAS12788	Terminal signals and start release-Terminal 15 ignition switch signal 2	active
IDE02614-MAS02788	Reversing light switch-CAN	not active
IDE02614-MAS05360	Reversing light switch-Discreet wire	not coded/not installed
IDE02711	Rear Window Wiper	not active
IDE02743-MAS01737	High Beam-Diagnosis	not coded/not installed
IDE02743-MAS02248	High Beam-Signal state	not active
IDE02743-MAS03873	High Beam-Duty cycle	0	 %
IDE02743-MAS04351	High Beam-Connector terminal number	0
IDE02743-MAS04352	High Beam-Connector number	Plug A
IDE02744-MAS01632	Steering wheel heater-Status	switched off
IDE02744-MAS02311	Steering wheel heater-Steering wheel heating button	not activated
IDE02744-MAS09758	Steering wheel heater-Temperature sensor	79
IDE02857-IDE03111	Activation current-Interior light	2048	 mA
IDE02857-IDE05533	Activation current-Spray nozzle heater	0	 mA
IDE02857-IDE06012	Activation current-Search lights	0	 mA
IDE02857-MAS01554	Activation current-Left heated seat	0	 mA
IDE02857-MAS01556	Activation current-Right heated seat	0	 mA
IDE02857-MAS05942	Activation current-Windshield and rear window washer pump	0	 mA
IDE02857-ENG128454	Activation current-Cockpittaster_1	no error
IDE02857-ENG128455	Activation current-Cockpittaster_2	no error
IDE02857-ENG128456	Activation current-Cockpittaster_3	no error
IDE02857-ENG128457	Activation current-Cockpittaster_4	no error
IDE02857-ENG128458	Activation current-DWA_Einfachhorn	0	 mV
IDE02857-ENG126436	Activation current-signal_horn	65533	 mV
IDE02957-MAS01737	Ambient lighting-Diagnosis	not coded/not installed
IDE02957-MAS02248	Ambient lighting-Signal state	not active
IDE02957-MAS03873	Ambient lighting-Duty cycle	0	 %
IDE02957-MAS04351	Ambient lighting-Connector terminal number	0
IDE02957-MAS04352	Ambient lighting-Connector number	not coded/not installed
IDE02957-MAS06670	Ambient lighting-Channel	Chan. A
IDE03111-MAS01737	Interior light-Diagnosis	not coded/not installed
IDE03111-MAS02248	Interior light-Signal state	not active
IDE03111-MAS03873	Interior light-Duty cycle	0	 %
IDE03111-MAS04351	Interior light-Connector terminal number	0
IDE03111-MAS04352	Interior light-Connector number	Plug A
IDE03195-IDE03854	High values for automatic vertical headlight aim-Left front level control system sensor: height value current	0
IDE03195-IDE04144	High values for automatic vertical headlight aim-Left rear level control system sensor: height value current	0
IDE03195-IDE07143	High values for automatic vertical headlight aim-Vehicle level sensor: supply voltage	16.6	 V
IDE03195-MAS13964	High values for automatic vertical headlight aim-Spec. value: activation vehicle level sensor	127.5
IDE03195-MAS13965	High values for automatic vertical headlight aim-Vehicle level sensor: control voltage	13	 V
IDE03310-MAS01737	Brake light-Diagnosis	normal
IDE03310-MAS02248	Brake light-Signal state	not active
IDE03310-MAS03873	Brake light-Duty cycle	0	 %
IDE03310-MAS04351	Brake light-Connector terminal number	35
IDE03310-MAS04352	Brake light-Connector number	Plug B
IDE03388-IDE01217	Left front heated seat: status-Left heated seat stage	OFF
IDE03388-MAS02201	Left front heated seat: status-Temperature	39.5	 °C
IDE03389-IDE01218	Right front heated seat: status-Right heated seat stage	OFF
IDE03389-MAS02201	Right front heated seat: status-Temperature	39	 °C
IDE03504-IDE02022	Personalized settings-Comfort opening	NOT-DEFINED
IDE03504-IDE03679	Personalized settings-Adaptive light functions	active
IDE03504-IDE04036	Personalized settings-High beam assistant: status	active
IDE03504-MAS01597	Personalized settings-Sunroof	active
IDE03504-MAS04322	Personalized settings-Masked continuous high beam	active
IDE03504-MAS06456	Personalized settings-Autolock	active
IDE03504-MAS06457	Personalized settings-autounlock	active
IDE03504-MAS06911	Personalized settings-Status Coming Home	active
IDE03504-MAS06912	Personalized settings-Status Leaving Home	active
IDE03504-MAS07014	Personalized settings-Tourist light	not active
IDE03504-MAS07967	Personalized settings-profile	1
IDE03504-MAS07971	Personalized settings-Electrical rear lid	not active
IDE03504-MAS07972	Personalized settings-Manual door unlock	all
IDE03504-MAS07973	Personalized settings-Rain closure	not active
IDE03504-MAS07978	Personalized settings-Mirror adjustment	INDIVIDUAL
IDE03504-MAS07980	Personalized settings-Mirror lowering	active
IDE03504-MAS07981	Personalized settings-Automatic mirror fold-in	not active
IDE03504-MAS07982	Personalized settings-Activation sound: theft warning system	active
IDE03504-MAS07983	Personalized settings-Virtual pedal	active
IDE03504-MAS07984	Personalized settings-Automatic rear window wiper	not active
IDE03504-MAS07985	Personalized settings-Coming Home set point	10	 s
IDE03504-MAS07986	Personalized settings-Leaving Home set point	10	 s
IDE03504-MAS07987	Personalized settings-Light intensity	insensitive
IDE03504-MAS07990	Personalized settings-Comfort flasher	active
IDE03504-MAS07991	Personalized settings-Comfort flasher set point	5
IDE03504-MAS07992	Personalized settings-Sliding beam range	not active
IDE03504-MAS07993	Personalized settings-Rain light	active
IDE03504-ENG29901	Personalized settings-Touristenlicht Einstellwert	not active
IDE03638-MAS01737	static AFS light-Diagnosis	normal
IDE03638-MAS02248	static AFS light-Signal state	not active
IDE03638-MAS03873	static AFS light-Duty cycle	0	 %
IDE03638-MAS04351	static AFS light-Connector terminal number	45
IDE03638-MAS04352	static AFS light-Connector number	Plug B
IDE04213	Central locking button	not coded/not installed
IDE04213-IDE07357	Central locking button-Indicator light for central locking	not coded/not installed
IDE04254-MAS06517	Play protection for central locking-Rear spoiler counter	not active
IDE04347-IDE00104	Expanded environmental conditions-DTC	08 A7 16
IDE04347-IDE07836	Expanded environmental conditions-Log data	00 00 00 0A 0D 00 0D 00 63 00 00 03 61 FF 00 C0 00 00 00 00 00 00 00 00 00 02 00 02 00 05 A5 B0 00 00 07 15 00 00 07 15 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 01 02 00 00 00 02 00 20 00 00 0A 06 0B 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 1C 00 00 00 00 00 00 54 64 08 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 01 20 00 08 81 14 5B 00 00 10 00 04 4C 20 34 00 20 00 00 40 08 00 02 6B 1F 00 00 00 7B B6 96 00 3B 00 00 00 00 00 00 00 00 00 00 00 00 06 02 00 00 00 00 00 00 00 00 26 00 00 00 00 81 00 00 00 00 00 00
IDE04925-MAS01737	Daytime running lights-Diagnosis	not coded/not installed
IDE04925-MAS02248	Daytime running lights-Signal state	not active
IDE04925-MAS03873	Daytime running lights-Duty cycle	0	 %
IDE04925-MAS04351	Daytime running lights-Connector terminal number	0
IDE04925-MAS04352	Daytime running lights-Connector number	Plug A
IDE05042-IDE05043	Emergency flasher button-Emergency flasher indicator lamp	On
IDE05042-MAS02158	Emergency flasher button-Actuation condition	Not operated
IDE05042-MAS03873	Emergency flasher button-Duty cycle	20	 %
IDE05045-IDE05183	Front windshield wiper module-Malfunction left	not coded/not installed
IDE05045-IDE05184	Front windshield wiper module-Malfunction right	not coded/not installed
IDE05045-MAS01632	Front windshield wiper module-Status	not active
IDE05045-MAS02282	Front windshield wiper module-Position	park position
IDE05045-MAS03638	Front windshield wiper module-Wipe speed	0	 /min
IDE05045-MAS05057	Front windshield wiper module-Number of wiper cycles	3800
IDE05045-MAS05878	Front windshield wiper module-Stage	Stage 1
IDE05323-MAS01737	Fog light-Diagnosis	normal
IDE05323-MAS02248	Fog light-Signal state	not active
IDE05323-MAS03873	Fog light-Duty cycle	0	 %
IDE05323-MAS04351	Fog light-Connector terminal number	45
IDE05323-MAS04352	Fog light-Connector number	Plug B
IDE05434-MAS01737	Rear entry light-Diagnosis	not coded/not installed
IDE05434-MAS02248	Rear entry light-Signal state	not active
IDE05434-MAS03873	Rear entry light-Duty cycle	0	 %
IDE05434-MAS04150	Rear entry light-Side	NOT-DEFINED
IDE05434-MAS04351	Rear entry light-Connector terminal number	0
IDE05434-MAS04352	Rear entry light-Connector number	Plug A
IDE05533	Spray nozzle heater	not active
IDE05719-IDE05534	Window washer system-Headlamp washer system	not coded/not installed
IDE05719-MAS02339	Window washer system-Windshield washer system	not active
IDE05719-MAS02341	Window washer system-Rear window washer system	not active
IDE05720-IDE02589	Front driver side door status-Rotary latch status	Open
IDE05720-IDE04213	Front driver side door status-Central locking button	Not operated
IDE05720-IDE04214	Front driver side door status-Key switch in door lock	Not operated
IDE05720-MAS06256	Front driver side door status-Status door lock	Signal from door lock: released
IDE05722-IDE02589	Door status: driver side rear-Rotary latch status	closed
IDE05722-IDE04213	Door status: driver side rear-Central locking button	not coded/not installed
IDE05722-MAS06256	Door status: driver side rear-Status door lock	Signal from door lock: engaged
IDE05727-IDE02589	Front passenger side door status-Rotary latch status	closed
IDE05727-IDE04213	Front passenger side door status-Central locking button	Not operated
IDE05727-IDE04214	Front passenger side door status-Key switch in door lock	Not operated
IDE05727-MAS06256	Front passenger side door status-Status door lock	Signal from door lock: engaged
IDE05729-IDE02589	Door status: frt. pass. side rear-Rotary latch status	closed
IDE05729-IDE04213	Door status: frt. pass. side rear-Central locking button	not coded/not installed
IDE05729-MAS06256	Door status: frt. pass. side rear-Status door lock	Signal from door lock: engaged
IDE05730-MAS01737	Luggage compartment light-Diagnosis	not coded/not installed
IDE05730-MAS02248	Luggage compartment light-Signal state	not active
IDE05730-MAS03873	Luggage compartment light-Duty cycle	0	 %
IDE05730-MAS04351	Luggage compartment light-Connector terminal number	0
IDE05730-MAS04352	Luggage compartment light-Connector number	Plug A
IDE05739-MAS01737	Footwell light-Diagnosis	normal
IDE05739-MAS02248	Footwell light-Signal state	active
IDE05739-MAS03873	Footwell light-Duty cycle	70	 %
IDE05739-MAS04351	Footwell light-Connector terminal number	72
IDE05739-MAS04352	Footwell light-Connector number	Plug C
IDE05742-IDE02515	Light switch position-Low beam	not activated
IDE05742-IDE05323	Light switch position-Fog light	not activated
IDE05742-IDE07956	Light switch position-redundant signal line	OFF
IDE05742-MAS00063	Light switch position-OFF	operated
IDE05742-MAS02462	Light switch position-Automatic high beam assist	not activated
IDE05742-MAS03835	Light switch position-Parking light	not activated
IDE05742-MAS03836	Light switch position-Rear fog light	not coded/not installed
IDE05822-MAS01632	DWA Vehicle inclination sensor-Status	not coded/not installed
IDE05822-MAS04508	DWA Vehicle inclination sensor-Alarm detected	not coded/not installed
IDE05825-MAS02594	DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch	not coded/not installed
IDE05825-MAS04247	DWA Interior monitoring/vehicle inclination sensor button-Button	not coded/not installed
IDE05826-MAS01632	DWA Sirens / alarm horn for anti-theft warning system-Status	not coded/not installed
IDE05826-MAS04508	DWA Sirens / alarm horn for anti-theft warning system-Alarm detected	No
IDE05826-MAS04509	DWA Sirens / alarm horn for anti-theft warning system-Alarm activated	No
IDE05827	Alarm horn for anti-theft warning system	not activated
IDE05829-ENG28562	Rear spoiler history data-Spoiler_Activation_Trigger	NoEntry
IDE05829-ENG28563	Rear spoiler history data-Spoiler_Activation_Trigger_Date	335544320
IDE05829-ENG28565	Rear spoiler history data-Spoiler_Activation_Trigger_Milage	0	 km
IDE05829-ENG28564	Rear spoiler history data-Spoiler_Activation_Trigger_Time	0
IDE05830-MAS02282	Rear Spoiler-Position	not coded/not installed
IDE05830-ENG115793	Rear Spoiler-Spoiler_Button	not coded/not installed
IDE05830-ENG115792	Rear Spoiler-Spoiler_Cycle_Protection	not coded/not installed
IDE05830-ENG115794	Rear Spoiler-Spoiler_Indication_Light	not coded/not installed
IDE05830-ENG115791	Rear Spoiler-Spoiler_Position	not coded/not installed
IDE05833-MAS00106	Anti-theft warning system: history data-Year	2000
IDE05833-MAS00107	Anti-theft warning system: history data-Month	0
IDE05833-MAS00108	Anti-theft warning system: history data-Day	0
IDE05833-MAS00109	Anti-theft warning system: history data-Hours	0
IDE05833-MAS00110	Anti-theft warning system: history data-Minutes	0
IDE05833-MAS00111	Anti-theft warning system: history data-Seconds	0
IDE05833-MAS00711	Anti-theft warning system: history data-Odometer reading	0	 km
IDE05833-MAS04478	Anti-theft warning system: history data-Cause for alarm activation	No alarm
IDE05834-IDE01718	Driver info-Crash signal	not active
IDE05834-MAS00211	Driver info-Insufficient brake fluid	not active
IDE05834-MAS00212	Driver info-Insufficient washer fluid	not active
IDE05834-MAS00213	Driver info-Insufficient coolant	not active
IDE05834-MAS00214	Driver info-Brake pad wear	not coded/not installed
IDE05836-MAS03637	Rain recognition sensor-Rain quantity	0
IDE05836-MAS03638	Rain recognition sensor-Wipe speed	0
IDE05836-MAS04806	Rain recognition sensor-Splash	not active
IDE05836-MAS04807	Rain recognition sensor-park position	active
IDE05837	Activation for signal horn	not active
IDE05838-MAS01794	Light recognition sensor-Freeway	OFF
IDE05838-MAS02248	Light recognition sensor-Signal state	active
IDE05838-MAS02475	Light recognition sensor-Brightness infrared	0	 lx
IDE05838-MAS02851	Light recognition sensor-Brightness	48	 lx
IDE05838-MAS04808	Light recognition sensor-Rain	OFF
IDE05838-MAS04809	Light recognition sensor-Darkness	On
IDE05838-MAS04810	Light recognition sensor-Request for light activation	On
IDE05839-MAS01737	Parking light-Diagnosis	normal
IDE05839-MAS02248	Parking light-Signal state	active
IDE05839-MAS03873	Parking light-Duty cycle	100	 %
IDE05839-MAS04351	Parking light-Connector terminal number	39
IDE05839-MAS04352	Parking light-Connector number	Plug B
IDE05841-MAS06441	Central locking history data-Control-section / cause	Outside door handle sens.: frt. left
IDE05841-MAS07519	Central locking history data-Command	Unlock. indiv. doors
IDE05841-MAS07942	Central locking history data-Additional information	KESSY ID sensor 1
IDE05841-ENG29969	Central locking history data-command_direction_locking	No_locking
IDE05841-ENG29970	Central locking history data-command_direction_unlocking	Door unlock
IDE05842-MAS00218	Comfort function history data-Driver door	not active
IDE05842-MAS00219	Comfort function history data-Front Passenger Door	not active
IDE05842-MAS00220	Comfort function history data-Left rear door	not active
IDE05842-MAS00221	Comfort function history data-Right rear door	not active
IDE05842-MAS06441	Comfort function history data-Control-section / cause	radio remote control number_1
IDE05842-MAS07560	Comfort function history data-Top	not active
IDE05842-MAS07561	Comfort function history data-Sun roof/tilt roof	not active
IDE05842-MAS07941	Comfort function history data-Operating command	Open
IDE06012-MAS01737	Search lights-Diagnosis	not coded/not installed
IDE06012-MAS02248	Search lights-Signal state	not active
IDE06012-MAS03873	Search lights-Duty cycle	0	 %
IDE06012-MAS04351	Search lights-Connector terminal number	0
IDE06012-MAS04352	Search lights-Connector number	Plug A
IDE06012-MAS15156	Search lights-terminal	NOT-DEFINED
IDE06091-IDE01440	Humidity sensor: internal-Windshield temperature	-38.5	 °C
IDE06091-MAS04629	Humidity sensor: internal-Sensor temperature	33	 °C
IDE06091-MAS04630	Humidity sensor: internal-Relative humidity	32	 %
IDE06091-MAS04647	Humidity sensor: internal-Dew point	-38.8	 °C
IDE06096-IDE03111	Interior lighting-Interior light	100	 %
IDE06096-IDE05724	Interior lighting-Terminal 58xt dimmer	60	 %
IDE06096-IDE05725	Interior lighting-Terminal 58xs dimmer	0	 %
IDE06096-IDE05726	Interior lighting-Terminal 58xd dimmer	116	 %
IDE06096-MAS01634	Interior lighting-Supply voltage	100	 %
IDE06096-MAS04528	Interior lighting-Instrument panel and switch illumination dimmer switch	50	 %
IDE06324-IDE04217	Tank cap lock-Fuel filler door release button	not coded/not installed
IDE06324-MAS01580	Tank cap lock-Activation	not active
IDE06324-MAS06251	Tank cap lock-Contact switch	not coded/not installed
IDE06470-MAS01737	Ambience lighting-Diagnosis	not coded/not installed
IDE06470-MAS02248	Ambience lighting-Signal state	not active
IDE06470-MAS03873	Ambience lighting-Duty cycle	0	 %
IDE06470-MAS04351	Ambience lighting-Connector terminal number	0
IDE06470-MAS04352	Ambience lighting-Connector number	Plug A
IDE06507-MAS13127	Button in center console-Status of button 1	not activated
IDE06507-MAS13128	Button in center console-Indicator lamp button 1	On
IDE06507-MAS13130	Button in center console-Status of button 2	not coded/not installed
IDE06507-MAS13131	Button in center console-Indicator lamp button 2	not coded/not installed
IDE06507-MAS13133	Button in center console-Status of button 3	not coded/not installed
IDE06507-MAS13134	Button in center console-Indicator lamp button 3	not coded/not installed
IDE06507-MAS13136	Button in center console-Indicator lamp button 4	OFF
IDE06507-MAS13137	Button in center console-Status of button 4	not activated
IDE06592-MAS05002	Status: special functions-Showroom mode	OFF
IDE06592-MAS05003	Status: special functions-Debug functions	OFF
IDE06644-IDE06864	Vehicle positioning system-Daytime running lights	not coded/not installed
IDE06644-MAS01288	Vehicle positioning system-Signal horn	not coded/not installed
IDE06644-MAS03834	Vehicle positioning system-Emergency signal flashing	not coded/not installed
IDE06644-MAS03835	Vehicle positioning system-Parking light	not coded/not installed
IDE06649-MAS05016	Radio-frequency transmitter-Receiver status	not installed
IDE06649-MAS05048	Radio-frequency transmitter-Number of transmitters adapted	0
IDE06649-ENG116085	Radio-frequency transmitter-Kom.Schlüssel eFFB Handsender 1	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE06649-ENG116115	Radio-frequency transmitter-Kom.Schlüssel eFFB Handsender 2	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE06695-IDE01459	Energy management: last critical state-Energy management heat output control status	0
IDE06695-MAS00107	Energy management: last critical state-Month	0
IDE06695-MAS00108	Energy management: last critical state-Day	0
IDE06695-MAS06555	Energy management: last critical state-Maximum switch-off priority while driving	0
IDE06695-MAS06570	Energy management: last critical state-Number of critical operation cycles	0
IDE06695-ENG28924	Energy management: last critical state-Anz_erreichte_Max_Freigaben	0
IDE06695-ENG28921	Energy management: last critical state-Anz_krit_Betriebszyklen	0
IDE06695-ENG28922	Energy management: last critical state-Bedingung_Tab_NQ	0
IDE06695-ENG28920	Energy management: last critical state-min_prio_Tab_K	0
IDE06695-ENG28919	Energy management: last critical state-min_prio_Tab_M	0
IDE06695-ENG28923	Energy management: last critical state-min_prio_Tab_NQ	0
IDE06695-ENG99063	Energy management: last critical state-Year	2000
IDE06864-MAS01737	Daytime running lights-Diagnosis	normal
IDE06864-MAS02248	Daytime running lights-Signal state	not active
IDE06864-MAS03873	Daytime running lights-Duty cycle	0	 %
IDE06864-MAS04351	Daytime running lights-Connector terminal number	35
IDE06864-MAS04352	Daytime running lights-Connector number	Plug B
IDE07145-MAS06772	Component protection properties-Component protection generation	2
IDE07145-MAS06773	Component protection properties-KS Standard software main version nummer	2
IDE07145-MAS06774	Component protection properties-KS Standard software secondary version number	4
IDE07145-MAS06775	Component protection properties-KS Standard software correct number	0
IDE07145-MAS06776	Component protection properties-Komponent protection role	KS Slave
IDE07145-MAS06781	Component protection properties-Secure Hardware Extension	Not Used
IDE07145-MAS06782	Component protection properties-Master ECU Key	not administered by component protection
IDE07145-MAS06785	Component protection properties-GFA key	used
IDE07145-MAS06786	Component protection properties-SSW RND Generation	Not Used
IDE07145-MAS06787	Component protection properties-Indiv Key Generation	Not Used
IDE07145-MAS06788	Component protection properties-SHE Secure Boot	Not Used
IDE07145-MAS07187	Component protection properties-KS Data version	1
IDE07145-MAS09609	Component protection properties-Status IKA start key	not active
IDE07145-MAS09610	Component protection properties-Status GFA Key	valid
IDE07145-MAS09611	Component protection properties-Status Master ECU Key	stored
IDE07187-MAS06538	Level control system sensor-Left Front Level Control System Sensor: PWM signal	655.35	 %
IDE07187-MAS06539	Level control system sensor-Left Rear Level Control System Sensor: PWM signal	655.35	 %
IDE07187-MAS06540	Level control system sensor-Left front level control system sensor: frequency	6553.5	 Hz
IDE07187-MAS06541	Level control system sensor-Left Rear Left Control System Sensor: frequency	6553.5	 Hz
IDE07187-MAS06542	Level control system sensor-Vehicle level sensor: supply voltage	5	 V
IDE07344-IDE00542	Sunroof shade-Excessive temperature protection	not active
IDE07344-IDE03114	Sunroof shade-Comfort function	not active
IDE07344-MAS01979	Sunroof shade-Adapting	Not adapted
IDE07344-MAS02282	Sunroof shade-Position	126	 %
IDE07344-MAS02447	Sunroof shade-Release	not active
IDE07344-MAS03656	Sunroof shade-Reverse	not active
IDE07344-MAS05563	Sunroof shade-Norming	not normed
IDE07345-MAS07997	Sunroof front closed position switch-Rotary switch activation	not activated
IDE07345	Sunroof front closed position switch	not activated
IDE07345-ENG122183	Sunroof front closed position switch-rotary_switch_position	closed
IDE07346	Sunroof shade switches	not activated
IDE08125-MAS01458	Left cabin heater-Operating condition	not coded/not installed
IDE08125-MAS06651	Left cabin heater-PTC heater element: current consumption	not coded/not installed
IDE08125-MAS06652	Left cabin heater-Blower motor: speed	not coded/not installed
IDE08125-MAS06653	Left cabin heater-Indicator light for head area heater	not coded/not installed
IDE08126-MAS01458	Right cabin heater-Operating condition	not coded/not installed
IDE08126-MAS06651	Right cabin heater-PTC heater element: current consumption	not coded/not installed
IDE08126-MAS06652	Right cabin heater-Blower motor: speed	not coded/not installed
IDE08126-MAS06653	Right cabin heater-Indicator light for head area heater	not coded/not installed
IDE08177-MAS06456	Central locking-Autolock	not active
IDE08177-MAS06740	Central locking-Release button in rear lid handle locked	not active
IDE08177-MAS09894	Central locking-Status exterior skin	Open
IDE08177-MAS09896	Central locking-Act. condition: Status central locking internal locked	not active
IDE08177-MAS09897	Central locking-Act. condition: Status central locking external locked	not active
IDE08177-MAS09898	Central locking-Act. condition: Status central locking safe	not active
IDE08177-MAS09900	Central locking-Spec. condition: Status central lock	Vehicle unlocked at single door
IDE08177-ENG09185	Central locking-Load_compartment_closing	not coded/not installed
IDE08211-MAS00106	History data control module reset-Year	2019
IDE08211-MAS00107	History data control module reset-Month	5
IDE08211-MAS00108	History data control module reset-Day	19
IDE08211-MAS00109	History data control module reset-Hours	0
IDE08211-MAS00110	History data control module reset-Minutes	0
IDE08211-MAS03129	History data control module reset-Reset counter	23
IDE08211-MAS06734	History data control module reset-last cause of reset	MCU_RESET_UNDEFINED
IDE08343	Immobilizer Challenge	FC 74 68 EA
IDE08949-MAS07867	Operating current: light driver-Conn. pin 0	0	 mA
IDE08949-MAS07868	Operating current: light driver-Conn. pin 1	0	 mA
IDE08949-MAS07869	Operating current: light driver-Conn. pin 2	0	 mA
IDE08949-MAS07870	Operating current: light driver-Conn. pin 3	0	 mA
IDE08949-MAS07871	Operating current: light driver-Conn. pin 4	0	 mA
IDE08949-MAS07872	Operating current: light driver-Conn. pin 5	0	 mA
IDE08949-MAS07873	Operating current: light driver-Conn. pin 6	0	 mA
IDE08949-MAS07874	Operating current: light driver-Conn. pin 7	0	 mA
IDE08949-MAS07875	Operating current: light driver-Conn. pin 8	16	 mA
IDE08949-MAS07876	Operating current: light driver-Conn. pin 9	16	 mA
IDE08949-MAS07877	Operating current: light driver-Conn. pin 10	0	 mA
IDE08949-MAS07878	Operating current: light driver-Conn. pin 11	0	 mA
IDE08949-MAS07879	Operating current: light driver-Conn. pin 12	0	 mA
IDE08949-MAS07880	Operating current: light driver-Conn. pin 13	0	 mA
IDE08949-MAS07881	Operating current: light driver-Conn. pin 14	0	 mA
IDE08949-MAS07882	Operating current: light driver-Conn. pin 15	0	 mA
IDE08949-MAS07883	Operating current: light driver-Conn. pin 16	0	 mA
IDE08949-MAS07884	Operating current: light driver-Conn. pin 17	0	 mA
IDE08949-MAS07885	Operating current: light driver-Conn. pin 18	0	 mA
IDE08949-MAS07886	Operating current: light driver-Conn. pin 19	0	 mA
IDE08949-MAS07887	Operating current: light driver-Conn. pin 20	0	 mA
IDE08949-MAS07888	Operating current: light driver-Conn. pin 21	0	 mA
IDE08949-MAS07889	Operating current: light driver-Conn. pin 22	0	 mA
IDE08949-MAS07890	Operating current: light driver-Conn. pin 23	0	 mA
IDE08949-MAS07891	Operating current: light driver-Conn. pin 24	0	 mA
IDE08949-MAS07892	Operating current: light driver-Conn. pin 25	0	 mA
IDE08949-MAS07893	Operating current: light driver-Conn. pin 26	0	 mA
IDE08949-MAS07894	Operating current: light driver-Conn. pin 27	0	 mA
IDE08949-MAS07895	Operating current: light driver-Conn. pin 28	0	 mA
IDE08949-MAS07896	Operating current: light driver-Conn. pin 29	0	 mA
IDE08949-MAS07897	Operating current: light driver-Conn. pin 30	498	 mA
IDE08949-MAS07898	Operating current: light driver-Conn. pin 31	14	 mA
IDE08949-MAS07899	Operating current: light driver-Conn. pin 32	19	 mA
IDE08949-MAS07900	Operating current: light driver-Conn. pin 33	13	 mA
IDE08949-MAS07901	Operating current: light driver-Conn. pin 34	13	 mA
IDE09065-MAS07964	Status: remote start-Engine run time after remote start	0	 s
IDE09065-MAS16464	Status: remote start-Number of RemoteStarts carried out	2
IDE09850-MAS07146	Garage Door Opener Operating Unit-Button 1	Not operated
IDE09850-MAS07147	Garage Door Opener Operating Unit-Button 2	Not operated
IDE09850-MAS07148	Garage Door Opener Operating Unit-Button 3	Not operated
IDE11134-IDE01943	Light sequence HU test result-Turn signal	not installed / not active
IDE11134-IDE02515	Light sequence HU test result-Low beam	not installed / not active
IDE11134-IDE02614	Light sequence HU test result-Reversing light switch	not installed / not active
IDE11134-IDE02743	Light sequence HU test result-High Beam	not installed / not active
IDE11134-IDE03310	Light sequence HU test result-Brake light	not installed / not active
IDE11134-IDE03638	Light sequence HU test result-static AFS light	not installed / not active
IDE11134-IDE05323	Light sequence HU test result-Fog light	not installed / not active
IDE11134-IDE05839	Light sequence HU test result-Parking light	not installed / not active
IDE11134-IDE06470	Light sequence HU test result-Ambience lighting	not installed / not active
IDE11134-IDE06864	Light sequence HU test result-Daytime running lights	not installed / not active
IDE11134-MAS02354	Light sequence HU test result-Headlamp flasher	not installed / not active
IDE11134-MAS03835	Light sequence HU test result-Parking light	not installed / not active
IDE11134-MAS03836	Light sequence HU test result-Rear fog light	not installed / not active
IDE11134-MAS11025	Light sequence HU test result-Status	no restriction
IDE11350-MAS12597	Sunlight photo sensor-Sun intensity left	0	 W/m²
IDE11350-MAS12598	Sunlight photo sensor-Sun intensity right	0	 W/m²
IDE11668-MAS06256	Driver side rear sliding door: central locking signals-Status door lock	not coded/not installed
IDE11668-MAS06431	Driver side rear sliding door: central locking signals-Door contact switch	not coded/not installed
IDE11668-MAS06433	Driver side rear sliding door: central locking signals-Door lock: safe status	not coded/not installed
IDE11669-MAS06256	Passenger side rear sliding door: central locking signals-Status door lock	not coded/not installed
IDE11669-MAS06431	Passenger side rear sliding door: central locking signals-Door contact switch	not coded/not installed
IDE11669-MAS06433	Passenger side rear sliding door: central locking signals-Door lock: safe status	not coded/not installed
IDE11670-MAS06256	Rear wing door: central locking signals-Status door lock	not coded/not installed
IDE11670-MAS06431	Rear wing door: central locking signals-Door contact switch	not coded/not installed
IDE11670-MAS06433	Rear wing door: central locking signals-Door lock: safe status	not coded/not installed
IDE11727-IDE04806	Function of the central console button-Driving profile selection button	LED installed
IDE11727-MAS13125	Function of the central console button-Function of button 1	Start-stop
IDE11727-MAS13129	Function of the central console button-Function of button 2	not coded/not installed
IDE11727-MAS13132	Function of the central console button-Function of button 3	not coded/not installed
IDE11727-MAS13135	Function of the central console button-Function of button 4	Steering wheel heater
IDE11943-MAS01737	Signature light-Diagnosis	not coded/not installed
IDE11943-MAS02248	Signature light-Signal state	not active
IDE11943-MAS03873	Signature light-Duty cycle	0	 %
IDE11943-MAS04351	Signature light-Connector terminal number	0
IDE11943-MAS04352	Signature light-Connector number	Plug A
IDE11999-IDE03853	High values of headlight range adjustment: basic setting-Left front level control system sensor: height value adapted	-100
IDE11999-IDE04143	High values of headlight range adjustment: basic setting-Left rear level control system sensor: height value adapted	-100
IDE12060	Headlight range adjustment counter	00 00 00 00
IDE12212	Cause control module incorrectly coded	Not Present
IDE12940-IDE01268	Lever functions of the steering column electronics-Windshield wiper	not activated
IDE12940-IDE02335	Lever functions of the steering column electronics-Signal light switch position	not activated
IDE12940-IDE02711	Lever functions of the steering column electronics-Rear Window Wiper	not activated
IDE12940-MAS00232	Lever functions of the steering column electronics-MFI button UP	not activated
IDE12940-MAS00233	Lever functions of the steering column electronics-MFI button DOWN	not activated
IDE12940-MAS00234	Lever functions of the steering column electronics-MFI button RESET / OK	not activated
IDE12940-MAS00242	Lever functions of the steering column electronics-Driver assistance systems button	not activated
IDE12940-MAS00243	Lever functions of the steering column electronics-Buttons for driver assistance systems: status	No malfunction detected
IDE12940-MAS01288	Lever functions of the steering column electronics-Signal horn	not activated
IDE12940-MAS02338	Lever functions of the steering column electronics-Windshield wiper: intermittent stage	Stage 1
IDE12940-MAS02339	Lever functions of the steering column electronics-Windshield washer system	not activated
IDE12940-MAS02341	Lever functions of the steering column electronics-Rear window washer system	not activated
IDE12940	Lever functions of the steering column electronics	not activated
IDE14095-MAS17564	Wiper park position heater-Relay actuation	not coded/not installed
IDE14110-MAS17842	Digital Key-NFC control section	Not operated
IDE14110-MAS17843	Digital Key-Bluetooth control section	Not operated
IDE14172-MAS03692	Remote key movement information-Key 1	not inoperative
IDE14172-MAS03693	Remote key movement information-Key 2	not inoperative
IDE14172-MAS03694	Remote key movement information-Key 3	not inoperative
IDE14172-MAS03695	Remote key movement information-Key 4	not inoperative
IDE80251-MAS06439	Head area heater-Crash status	not coded/not installed
IDE80251-MAS06646	Head area heater-Head area heater left: specified level	not coded/not installed
IDE80251-MAS06647	Head area heater-Head area heater right: specified level	not coded/not installed
IDE80251-MAS06648	Head area heater-Continuation at terminal 15 on	not coded/not installed
IDE80251-MAS06649	Head area heater-Left front seat occupation status	not coded/not installed
IDE80251-MAS06650	Head area heater-Right front occupation status	not coded/not installed
MAS00043-IDE00019	Supply voltage: Terminal 30-Voltage terminal 30	12.95	 V
MAS00043-IDE05835	Supply voltage: Terminal 30-Supply voltage for central locking	12.95	 V
MAS00043-IDE05967	Supply voltage: Terminal 30-Voltage terminal 30 left	13	 V
MAS00043-IDE05968	Supply voltage: Terminal 30-Voltage terminal 30 right	12.95	 V
MAS00043-IDE08734	Supply voltage: Terminal 30-Supply voltage for anti-theft alarm system	12.95	 V
MAS00043-IDE08735	Supply voltage: Terminal 30-Supply voltage for seat heater	12.95	 V
MAS00043-MAS00362	Supply voltage: Terminal 30-Battery voltage	5	 V
MAS00043-MAS07472	Supply voltage: Terminal 30-Battery voltage BEM	13	 V
MAS00043-MAS07473	Supply voltage: Terminal 30-Test voltage rear window defogger	0	 V
MAS00043-MAS07474	Supply voltage: Terminal 30-Test voltage windshield defogger	0	 V
MAS00179-MAS04422	Brake Light Switch-Brake light signal via CAN	OFF
MAS00179-MAS07313	Brake Light Switch-Brake light signal via HW	OFF
MAS00464-MAS00106	Standard - ambient data 1-Year	2019
MAS00464-MAS00107	Standard - ambient data 1-Month	8
MAS00464-MAS00108	Standard - ambient data 1-Day	25
MAS00464-MAS00109	Standard - ambient data 1-Hours	16
MAS00464-MAS00110	Standard - ambient data 1-Minutes	0
MAS00464-MAS00111	Standard - ambient data 1-Seconds	44
MAS00464-MAS00468	Standard - ambient data 1-Unlearning counter	179
MAS00464-MAS00711	Standard - ambient data 1-Odometer reading	6388	 km
MAS00829-MAS00244	Access and start authorization-Awakening wire	operated
MAS00829-MAS01763	Access and start authorization-Signal Strength	-67
MAS00829-MAS07866	Access and start authorization-Duration: last awakening wire actua.	5	 ms
MAS01281-MAS01737	Back-up light-Diagnosis	normal
MAS01281-MAS02248	Back-up light-Signal state	not active
MAS01281-MAS03873	Back-up light-Duty cycle	0	 %
MAS01281-MAS04351	Back-up light-Connector terminal number	11
MAS01281-MAS04352	Back-up light-Connector number	Plug C
MAS01431-IDE01442	Vehicle key with remote control-Pressing a button	not activated
MAS01431-IDE01839	Vehicle key with remote control-Battery charge condition	Not available
MAS01431-MAS00077	Vehicle key with remote control-Immobilizer	OK
MAS01431-MAS01551	Vehicle key with remote control-Key number	255
MAS01431-MAS05048	Vehicle key with remote control-Number of transmitters adapted	2
MAS01431-MAS06362	Vehicle key with remote control-Code in detection area	Not available
MAS01490-IDE02744	Energy management-Steering wheel heater	Enabled
MAS01490-IDE04216	Energy management-Mirror heater	Enabled
MAS01490-IDE80251	Energy management-Head area heater	Enabling stage 3
MAS01490-MAS01535	Energy management-Rear window defogger	Enabled
MAS01490-MAS01563	Energy management-Auxiliary Air Heater	Enabling stage 3
MAS01490-MAS01564	Energy management-Windshield defogger	Enabled
MAS01490-MAS01632	Energy management-Status	not active
MAS01490-MAS02390	Energy management-Shutoff	1
MAS01490-MAS05795	Energy management-Rear seat heater	Enabled
MAS01490-MAS05796	Energy management-Emergency shut-down	0
MAS01490-MAS05887	Energy management-Battery cut out relay 2	not enabled
MAS01490-MAS06551	Energy management-Seat ventilation	Enabled
MAS01490-MAS06552	Energy management-Seat heater front	Enabling stage 3
MAS01490-MAS06553	Energy management-Display consumer switch-off	not active
MAS01490-MAS06554	Energy management-Switch-off priority while driving	0
MAS01490-MAS06555	Energy management-Maximum switch-off priority while driving	0
MAS01490-MAS06556	Energy management-Switch-off with voltage drops	0
MAS01490-MAS06557	Energy management-Switch-off priority with vehicle crash	0
MAS01490-MAS06558	Energy management-Current negative charge balance	0	 %
MAS01490-MAS06559	Energy management-Switch-off priority with engine off	0
MAS01490-MAS06560	Energy management-Short distance drive	0
MAS01597-IDE00542	Sunroof-Excessive temperature protection	not active
MAS01597-IDE03114	Sunroof-Comfort function	not active
MAS01597-MAS01979	Sunroof-Adapting	Not adapted
MAS01597-MAS02282	Sunroof-Position	126	 %
MAS01597-MAS02447	Sunroof-Release	not active
MAS01597-MAS03656	Sunroof-Reverse	not active
MAS01597-MAS05563	Sunroof-Norming	not normed
MAS01597-MAS05737	Sunroof-Position	Tilt out posi.
MAS03835-MAS01737	Parking light-Diagnosis	normal
MAS03835-MAS02248	Parking light-Signal state	active
MAS03835-MAS03873	Parking light-Duty cycle	100	 %
MAS03835-MAS04351	Parking light-Connector terminal number	39
MAS03835-MAS04352	Parking light-Connector number	Plug B
MAS03836-MAS01737	Rear fog light-Diagnosis	not coded/not installed
MAS03836-MAS02248	Rear fog light-Signal state	not active
MAS03836-MAS03873	Rear fog light-Duty cycle	0	 %
MAS03836-MAS04351	Rear fog light-Connector terminal number	0
MAS03836-MAS04352	Rear fog light-Connector number	Plug A
MAS07959-IDE00787	Remote start history data-Cause for cancellation	Cancel due to term 15 on
MAS07959-MAS00107	Remote start history data-Month	8
MAS07959-MAS00108	Remote start history data-Day	23
MAS07959-MAS00109	Remote start history data-Hours	15
MAS07959-MAS00110	Remote start history data-Minutes	29
MAS07959-MAS07960	Remote start history data-Stop or cancel cause	No reason for prevention
MAS08228-MAS01632	Light sensor-Status	not coded/not installed
MAS08228-MAS02851	Light sensor-Brightness	22860	 lx
MAS08228-MAS04121	Light sensor-Voltage	25.4	 V
MAS13141	Test voltage	0	 V
ENG116910	Control unit internal measured value (supplier)	00 00 00 0A 1A 00 0D 00 63 00 00 03 5D FF 00 C0 00 00 00 00 00 00 00 00 00 02 00 02 00 04 0A EC 00 00 07 15 00 00 07 15 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 00 02 00 20 00 00 0A 06 0B 00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 02 00 00 00 00 00 00 53 64 08 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 02 00 00 01 00 01 08 81 04 5B 00 00 10 00 04 4C 20 34 00 20 00 00 40 08 00 02 6B 1F 00 00 00 7E 51 6F 00 3B 00 00 00 00 00 00 00 00 00 00 00 00 08 02 00 00 00 00 00 00 00 00 26 00 00 00 00 81 00 00 00 00 00 00
ENG117285-ENG115839	Cycle_Protection_Counter-central_locking_cycle_protection_counter	0
ENG117285-ENG115840	Cycle_Protection_Counter-general_cycle_protection_counter	1
ENG117285-ENG124947	Cycle_Protection_Counter-last_wake_up	Pin C14 Kessy Weckleitung
ENG116908-ENG115779	Ecu_Intern_Meas._Values_2-Betriebsstunden_Abblendlicht_an	0	 H
ENG116908-ENG115778	Ecu_Intern_Meas._Values_2-Hours_of_operation	0	 H
ENG116908-ENG115775	Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper	19
ENG116908-ENG115776	Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper	38
ENG116908-ENG115777	Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper	0
ENG116813-ENG28575	Entwicklermesswerte_CONTI-KurzSchlussZaehler	0
ENG116008-IDE10662	light_swich_module-Light switch (button module)	not coded/not installed
ENG116008-MAS17838	light_swich_module-Exterior lighting: global shutoff	not coded/not installed
ENG116909-ENG107391	LIN activity-LIN 1	active
ENG116909-ENG107392	LIN activity-LIN 2	not coded/not installed
ENG116909-ENG114948	LIN activity-LIN 3	active
ENG116909-ENG114949	LIN activity-LIN 4	active
ENG116909-ENG114950	LIN activity-LIN 5	not coded/not installed
ENG116909-ENG114951	LIN activity-LIN 6	active
ENG116793	Monitor 1	00 00 00 00 00 00 00 00
ENG116802	Monitor 10	00 00 00 00 00 00 00 00
ENG116794	Monitor 2	00 00 00 00 00 00 00 00
ENG116795	Monitor 3	00 00 00 00 00 00 00 00
ENG116796	Monitor 4	00 00 00 00 00 00 00 00
ENG116797	Monitor 5	00 00 00 00 00 00 00 00
ENG116798	Monitor 6	00 00 00 00 00 00 00 00
ENG116799	Monitor 7	00 00 00 00 00 00 00 00
ENG116800	Monitor 8	00 00 00 00 00 00 00 00
ENG116801	Monitor 9	00 00 00 00 00 00 00 00
ENG128380	Parametermonitor_0	82 14 64 64 A0 78 00 00 00 00 00 00 00 00 00 00 50 50 32 32 00 50 50 50 50 3E 3E 62 62 00 00 64 3C 01 21 21 0A 04 00 00 1E 0A 1E 1E 03 07 00 00 06 06 28 00 3C 03 1E 22 00 04 19 05 00 01 01 28 00 02 00 02 1E 64 05 B4 1E 32 00 00 00 00 26 1D 5A 96 02 05 0A 6E 96 05 00 00 00 00 00 00 00 00 0A 1E 3C 42 0F 00 00 00 00 00 00 00 00 00 00 00 64 0A 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5A 19 E1 32 0A 0A 00 00 00 00 00 A0 00 00 00 A0 00 00 00 A0 06 0C 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116806	Parametermonitor_1	00 00 00 00 00 00 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 00 64 64 64 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 00 46 7E 7F 46 46 7E 46 46 46 7F 46 46 46 46 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 64 64 64 64 64 64 64 7E 64 64 64 64 64 64 64 64 01 01 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116807	Parametermonitor_2	0F 05 0A 00 16 00 00 14 28 14 00 14 32 5A 32 0A 1E 12 00 4B 0A 01 1E 5A 0F 3C 3C 05 0A 01 0A 78 00 FA 01 1C 00 0F 00 05 0A 14 03 02 00 19 64 00 64 1E 32 18 18 7D 28 05 28 28 7D 3C 3C 7D 7D 0A 19 3C 7D 2B 00 00 02 00 00 01 28 0A 28 19 0A 23 04 C8 FA 17 16 88 00 1E 05 00 01 C8 32 C8 14 00 5A 03 00 03 03 00 00 04 01 05 32 32 32 64 03 00 00 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00 0F 14 50 78 32 3C 02 58 00 00 0A 6E 05 64 28 00 0A 06 19 0A 0A 28 00 00 00 00 00 00 00 00 00 00 14 14 14 00 32 00 00 00 00 28 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 28 14 14 C8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116808-ENG115827	Parametermonitor_3-parameter_monitor_3_climatic	FF 02 32 00 3C FF 80 05 05 00 00 00 00 00 00 00 80 FF 02 32 3C 00 05 00 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 FF 02 05 00 00 00 00 00 00 00 00 00 00 00 00 02 0A 28 0F 1E 06 32 0A 34 0B 01 64 64 03 0A 05 01 0A 46 00 1E 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116808-ENG115828	Parametermonitor_3-parameter_monitor_3_wiper	0A 00 00 19 19 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 50 46 00 58 8B FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116809	Parametermonitor_4	04 04 14 1E 03 B4 00 0A 05 05 0A 4B 00 32 0A 00 00 1E 32 05 14 00 00 00 00 00 00 00 00 00 00 00 01 02 02 01 0A 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 04 0C 78 04 04 0C 01 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2A 3E 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 00 00 00 00 00 00 00 00 00 00 00 0A FF 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 03 0A 00 00 00 00 00 04 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 32 28 00 00 00 00 00 05 05 3C 04 01 01 01 01 96 01 01 C8 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 3C 14 37 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116810	Parametermonitor_5	0A 00 0C 08 09 0A 05 0A 0A 14 08 0A 03 00 0A 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 04 00 00 1E 0A 05 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 46 00 03 09 01 05 00 00 00 00 00 00 0A 0F 0F 00 00 60 06 16 06 19 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116811	Parametermonitor_6	00 46 32 FA 3C 00 1E 32 05 04 3C 00 08 05 01 00 01 00 00 00 05 0A 50 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116911	Parametermonitor_7	00 0A 00 0A 00 0A FF FF 00 0A 00 0A FF FF FF FF 0F A0 00 32 00 32 00 32 00 32 00 32 00 0A 00 0A 00 32 FF FE 00 0A 00 32 00 32 00 00 00 0A 00 0A 00 00 FF FF 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 0A 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG116812	Parametermonitor_FF	00 00 05 30 30 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG126653-MAS00107	Personalized_Account_Key_History-Month	5
ENG126653-MAS00108	Personalized_Account_Key_History-Day	21
ENG126653-MAS00109	Personalized_Account_Key_History-Hours	20
ENG126653-MAS00110	Personalized_Account_Key_History-Minutes	9
ENG126653-MAS01551	Personalized_Account_Key_History-Key number	1
ENG126653-ENG28771	Personalized_Account_Key_History-Account	1
ENG126652-MAS03692	Personalized_key__Setting-Key 1	1
ENG126652-MAS03693	Personalized_key__Setting-Key 2	1
ENG126652-MAS03694	Personalized_key__Setting-Key 3	0
ENG126652-MAS03695	Personalized_key__Setting-Key 4	0
ENG126652-MAS03696	Personalized_key__Setting-Key 5	0
ENG126652-MAS03697	Personalized_key__Setting-Key 6	0
ENG126652-MAS03698	Personalized_key__Setting-Key 7	0
ENG126654-MAS00107	Personalized_Signals-Month	8
ENG126654-MAS00108	Personalized_Signals-Day	23
ENG126654-MAS00109	Personalized_Signals-Hours	15
ENG126654-MAS00110	Personalized_Signals-Minutes	28
ENG126654-ENG30061	Personalized_Signals-Perso_Aktiv	1
ENG126654-ENG28925	Personalized_Signals-Perso_Bedienstelle	0
ENG126654-ENG28926	Personalized_Signals-Perso_Freigabe_Verstellung	0
ENG126654-ENG28772	Personalized_Signals-Perso_Konto	1
ENG126654-ENG28775	Personalized_Signals-Perso_Status	1
ENG126654-ENG28773	Personalized_Signals-Perso_Steuerung	0
ENG126654-ENG28774	Personalized_Signals-Perso_Steuerungs_parameter	0
ENG116792-ENG115817	Power up history-Funktionsanforderung	19
ENG130589-MAS16304	Remotestart_Monitor-Number of driver takeovers from RemoteStart	33
ENG130589-MAS16305	Remotestart_Monitor-Number of duplicate activations	3
ENG130589-MAS16306	Remotestart_Monitor-Number of incorrect takeovers	0
ENG130589-MAS16307	Remotestart_Monitor-Average running time: group 1	43
ENG130589-MAS16308	Remotestart_Monitor-Average running time: group 2	2
ENG130589-MAS16309	Remotestart_Monitor-Average running time: group 3	4
ENG130589-MAS16333	Remotestart_Monitor-Number of RemoteStarts	51
ENG130589-MAS16334	Remotestart_Monitor-RemoteStart cancellations counter	69
ENG116790-MAS00711	Supply voltage history-Odometer reading	3	 km
ENG116790-ENG115814	Supply voltage history-highest voltage ever measured	14.9	 V
ENG116790-ENG115815	Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung	14.3	 V
ENG116790-ENG115816	Supply voltage history-voltage measurement: intern	12.9	 V
ENG116791	Temperatures	31.5	 °C
ENG127111-ENG127149	Valeo_Entwickler_MWB-Batterie_Spannung_KL_15	0	 V
ENG127111-ENG127148	Valeo_Entwickler_MWB-Batterie_Spannung_KL_30	0	 V
ENG127111-ENG127156	Valeo_Entwickler_MWB-GRA leitung	0
ENG127111-ENG30013	Valeo_Entwickler_MWB-Historienspeicher im Fehlerfall	00 00 00 00 81 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127111-ENG98652	Valeo_Entwickler_MWB-Horn	OFF
ENG127111-ENG30027	Valeo_Entwickler_MWB-Lenkrad Heizung	0
ENG127111-ENG30075	Valeo_Entwickler_MWB-Resetmonitor	0
ENG127111-ENG127158	Valeo_Entwickler_MWB-U12V_SW2	0
ENG127111-ENG30182	Valeo_Entwickler_MWB-WakeUp2	OFF
ENG116907-IDE00020	Zusaetzliche Umgebungsdaten-Terminal 15 status	On
ENG116907-IDE01716	Zusaetzliche Umgebungsdaten-Terminal 50 status	OFF
ENG116907-IDE02515	Zusaetzliche Umgebungsdaten-Low beam	not activated
ENG116907-IDE04639	Zusaetzliche Umgebungsdaten-Last wake-up cause	Kessy Prompt Wire
ENG116907-IDE07956	Zusaetzliche Umgebungsdaten-redundant signal line	infinite
ENG116907-MAS01957	Zusaetzliche Umgebungsdaten-Outside air temperature	31.5	 °C
ENG116907-MAS02462	Zusaetzliche Umgebungsdaten-Automatic high beam assist	not activated
ENG116907-MAS02788	Zusaetzliche Umgebungsdaten-CAN	On
ENG116907-MAS03835	Zusaetzliche Umgebungsdaten-Parking light	not activated
ENG116907-MAS04121	Zusaetzliche Umgebungsdaten-Voltage	12.9	 V
ENG116907-MAS06466	Zusaetzliche Umgebungsdaten-Parking light left	not activated
ENG116907-MAS06467	Zusaetzliche Umgebungsdaten-Parking light right	not activated
ENG116907-MAS14232	Zusaetzliche Umgebungsdaten-Light switch: zero setting	operated
ENG116907-MAS19766	Zusaetzliche Umgebungsdaten-Status of brake lamp switch: discrete	OFF
ENG116907-MAS19768	Zusaetzliche Umgebungsdaten-Brake lamp switch via CAN: status	OFF
Elapsed Time: 01:26
TWs/VW
NW Florida
C?ID=369048
I'm really new at this, but I've tryed about every coding combination I could see and I just can't get the running lights to stay on with the turn signal flasher - I'm sure I've just not been lucky enough to stumble onto the right one yet. I'm still hoping that once I figure that out, I can get them to dim to some degree for contrast in brightness with the turn signal flasher.
The low beam lamps (Leuchte6ABL LC5 and Leuchte7ABL RB1) have a “Lichthupe generell” flasher function assigned to channel 'B", whereas the Parking light functions (or running lights) are assigned to channels "C" and "D" of the High beam lamps (Leuchte8FL LB39and Leuchte9FL RB2).
On the left side of the car only, I experimented with various combinations, including changes in Dimming Direction, Dimmwert and Lichtfunktion (below). But so far, nothing kept the running lights (or Parking lights) on with the flasher activated. I didn't try changing the"Versorgungsbedarf der LCM Module" function assigned to the High beam lamps on channel "A".
Blinken links aktiv (beide Phasen)
Blinken links Hellphase
Blinken links Dunkelphase
Lichthupe bei bereits aktivem Abblendlicht oder bereitsaktivem Dauerfahrlicht
Lichthupe bei nicht aktivem Abblendlicht oder bereitsaktivem Dauerfahrlicht
TW
^^^TWs/TW: Hi: I do like your tenacity-respect!!!
But (and there is always a "but") I fear your plight will be the delicious futility of an impossible task!! ;)
The traditional methodology for older MQB platform vehicles was to allocate a specific Leuchte-set (being the 19 x adaptation channels with the same "Primary Tag" number) to each of the 35 x exterior lamps on the car - which ultimately were connected to 35 x pins on the BCM (so each Leuchte-set actually controlled the voltage/current trace on these pins).
But that was in earlier MQB cars - when men-were-men and when women were ......... well women to be frank (and I'm happy to be Earnest if you don't want me to be Frank)
Then came the advent of Light Control Modules (LCMs) and stuff changed (for the worse- IMO) particularly for the operation of the DRLs - which if you think about it - are very sophisticated lamps because they operate as DRLs, Parking Lights, DRL-wink and Single sided Parking Lights (so the power-supply requirements need to be very flexible). The introduction of LCMs took away the ability of us VCDS wielding amateurs to inflict more innovative lighting effects on these lamps - alas.
So- as I have said - continue your crusade if you want, but I suggest you read Don Quixote before doing so (it's a novel about someone who pursues his ideals in the face of overwhelming odds)
TWs/VW
NW Florida
C?ID=369048
I fear you are correct Sancho.
TW
