Audi A6 C7.5 ldw/vze retrofit
Rizzio
Trondheim, Norway
C?ID=369124
Hi, i have been trying to fix this problem for the last 8 months.
For starters, my car does not have the front window camera or the imageprocessor from the factory
No ACC or matrix led lights.
I have retrofitted the new front windscreen with the camera (85)
I have modified the flexray cables so the go trought the imageproc (8E) (abs and all other stuff working)
I have changed the sensor electronic (3B) from index H to K
I suspect there is some codeing issues in the gateway that do not like the imageproc (8E)
Any ideas?
Sunday,25,August,2019,14:02:38:62878
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZ4G5FN064973   License Plate:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 36 3B 42 44 46 52 53 5F 62
          69 6C 6D 72 82 85 8E 8F 90 AC
VIN: WAUZZZ4G5FN064973   Mileage: 96264km-59815miles
17-Instruments -- Status: Malfunction 0110
82-Heads Up Display -- Status: Malfunction 0010
85-On Board Cam. -- Status: Malfunction 0010
8E-Image Processing -- Status: Cannot be reached 0100
Address 01: Engine (J623-CRTE)       Labels: Redir Fail!
   Part No SW: 4G2 907 311 C    HW: 4G2 907 401
   Component: 3.0TDI EDC17  H33 0007
   Revision: 92H33---
   Coding: 12254012053601030000
   Shop #: WSC 28389 002 1048576
   ASAM Dataset: EV_ECM30TDI0114G2907311C 001007
   ROD: EV_ECM30TDI0114G2907311C.rod
   VCID: 2502E37C24149867CA-8070
   Part No SW: 4G0 927 166 A    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0009
   Revision: --H03---
   Coding: 100001
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 2B16154442F0AE171C-807E
   Part No SW: 4G0 907 379 Q    HW: 4G0 907 379 Q
   Component: ESP9 Premium  H01 0420
   Coding: 17A69E41E8657982BB00
   ASAM Dataset: EV_ESP9BOSCHAU57X 003019
   ROD: EV_ESP9BOSCHAU57X_003.rod
   VCID: 3FCE5114A68822B7A0-806A
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 01A9700E000000000000
   VCID: 7AB8E000F52AC79FD7-802E
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 30011500041629
   Coding: 360211B8210000
   VCID: 6386BD646AA02657E4-8036
0276 - Engine Off Timer Performance
          P150A 00 [008] - -
                    Reset counter: 91
                    Mileage: 96264 km
                    Date: 2019.08.24
                    Time: 14:55:09
                    Voltage terminal 30: 11.93 V
                    Terminal 15 status: Terminal 15 on
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: 00001002845902
   Coding: 2600001500349FE08181408380001D0CCF9CE60826090201000008206101150200400024030000
   VCID: 71AAC72CA85C84C766-8024
   Component: WWS57X 150124  H37 0080
   Serial number:         150130081946
   Coding: 0045F7
   Serial number: 23704895
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
   Component: E1 - LDS  H07 0044
   Serial number: 28 02 2014  00001000
   Serial number: DBD80197000000000001
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P10033D6B
   Coding: 30333130313730323736554A304C34473053
   VCID: 3B362504B2903E978C-806E
   Serial number: 3575HRB405P33HNGA0R-
   Serial number: 3585HRB405D33RVK81T5
   Serial number: 3515JRB4016533VUN1QW
   Serial number: 3525JRB4006534EADOSB
   Serial number: 3554VRB400S52RDAI1CY
   Serial number: 3564VRB401052RDAO269
   Part No SW: 4H0 953 568 K    HW: 4H0 953 568 K
   Component: Lenks.Modul   H06 0005
   Revision: C0068538    Serial number: 90862OB500081
   Coding: 000015
   VCID: 3B362504BA903E978C-806E
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Serial number: 17 12 2014  E0064336
   Part No SW: 4G8 920 933 Q    HW: 4G8 920 933 Q
   Component: TDieRdw       H07 0043
   Revision: 03001036    Serial number: 658050215596016
   Coding: 03AF12000B410008020000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 3E302C10A1822BBFAB-806A
16776969 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [LDW_02_FR keine Kommunikation]
                    Reset counter: 91
                    Mileage: 96264 km
                    Date: 2019.08.25
                    Time: 13:57:29
16776980 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [VZE_01 keine Kommunikation]
                    Reset counter: 91
                    Mileage: 96264 km
                    Date: 2019.08.25
                    Time: 13:57:29
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Revision: --------    Serial number: 00000001719911
   Coding: C0CD078118
   VCID: 75A2F33CD434A8E7BA-8020
   Serial number: 3565135603
   Voltage stabilizer:
   Serial number: 14112700000000000490
6653 - Image processing control module
          U1079 00 [009] - No communication
                    Reset counter: 51
                    Mileage: 96264 km
                    Date: 2019.08.25
                    Time: 13:50:19
                    Voltage terminal 30: 13.7 V
                    Voltage terminal 15: 13.7 V
                    Control Module temperature: 24 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0112
   Serial number: 04021500040558
   Coding: 20
   Revision: AA000000    Serial number: 00000134103691
   Coding: 0058130000006001000001010101102030303232203232
   VCID: 77BEF934C638DAF7A8-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA820BD7D5
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3620343089B2E3FF73-8062
   Component: TSG FA        H03 0507
   Coding: 011F17014E00628002080002
   VCID: 47DE49F4F6586A7718-8012
   Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
   Component: RCEPS         H41 0011
   Revision: 00001000    Serial number: 0008397702
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009010
   ROD: EV_RCEPS_009.rod
   VCID: 33260D249AC0F6D754-8066
   Revision: 00002001    Serial number: 0359813205
   Coding: 0100063820B930008320090028010F470000000000000000000000000000
   Component: TSG BF        H03 0507
   VCID: 46C044F0F152737FE3-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001356261
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D121B5C7CE4A02702-8078
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 044 D    HW: 4G1 035 044
   Component: MU-H-LN-EU    041 0389
   Serial number: A589B0F7507774
   Coding: 01750201FF0A000013110001000A00132F0006E5F1700100DF
   VCID: 200CF2683B367D4FB9-8074
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0007
   Serial number: AUZ8Z9FY8013QG
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349OB2000V5
   Compact Disc Database:
   Component: Gracenote2  --- 1012
6733 - Control Head Module; Rear Right
          U12B0 00 [009] - No Communication
          [Smart display carrier 1: no signal/communication]
                    Reset counter: 51
                    Mileage: 96264 km
                    Date: 2019.08.24
                    Time: 16:01:49
                    Voltage terminal 30: 12.1 V
7193 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 51
                    Mileage: 96264 km
                    Date: 2019.08.24
                    Time: 16:01:52
                    BAP-BAP_Function_ID: 02
7201 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 51
                    Mileage: 96264 km
                    Date: 2019.08.24
                    Time: 16:01:55
   Component: TSG HL        H03 0507
   Coding: 010F15004000628002080002
   VCID: 49DA4FCCE04C9C070E-801C
Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
   Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 7B001001    Serial number: 0359195306
   Coding: 0100000202000000
Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
   Part No SW: 4S0 980 556 A    HW: 5Q0 980 556 B
   Component: RVC Compact   H12 0201
   Coding: 0275000103002007000040
   Shop #: WSC 17873 123 50804
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
   ROD: EV_CamSysRVRVCPANAAU57X_002_AU57.rod
   VCID: 393A3F0CB8AC0C879E-806C
10489856 - No Basic Setting
          B2010 00 [009] - -
                    Reset counter: 51
                    Mileage: 96264 km
                    Date: 2019.08.25
                    Time: 13:49:43
                    passive
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0150
   Revision: 14005001    Serial number: 022501421
   Coding: 093205C011
   ROD: EV_HDSGAu571.rod
   Component: TSG HR        H03 0507
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
   Component: HeadUpDisplay H07 0304
   Coding: AF0000
   ASAM Dataset: EV_HUDContiC7 001025
   ROD: EV_HUDContiC7.rod
   VCID: 3522333C94B4E8E77A-8060
16776965 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 51
                    Mileage: 96264 km
                    Date: 2019.08.24
                    Time: 16:25:28
16776970 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [VZE_01_ keine Kommunikation]
                    Reset counter: 51
                    Mileage: 96264 km
                    Date: 2019.08.24
                    Time: 16:25:28
   Component: DPC-SG        H27 0081
   Coding: 72040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C14165847FEA92F15-8078
0703 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ESP_timeout]
                    Reset counter: 91
                    Mileage: 96264 km
                    Date: 2019.08.24
                    Time: 16:52:18
                    Outside air temperature: -41.5 °C
                    Voltage terminal 15: 11.6 V
                    Control Module temperature: 50.0 °C
0722 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [LWS_Timeout]
                    Reset counter: 91
                    Mileage: 96264 km
                    Date: 2019.08.24
                    Time: 16:52:18
0728 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [SARA_timeout]
                    Reset counter: 91
                    Mileage: 96264 km
                    Date: 2019.08.24
                    Time: 16:52:18
0733 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [BCM2_Timeout]
                    Reset counter: 91
                    Mileage: 96264 km
                    Date: 2019.08.24
                    Time: 16:52:18
0715 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Gateway_timeout]
                    Reset counter: 91
                    Mileage: 96264 km
                    Date: 2019.08.24
                    Time: 16:52:18
0701 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Motor_timeout]
                    Reset counter: 91
                    Mileage: 96264 km
                    Date: 2019.08.24
                    Time: 16:52:18
Address 8E: Image Processing
   Coding: 00060000031F030000030801424CDA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 312A072C60DCC4C726-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 3228082065DAFFDF5F-8066
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 150090361
   ROD: EV_RDCMA00100_008.rod
End----------(Elapsed Time: 01:49, VBatt start/end: 12.4V/12.4V)-----------
Regards Rizzio
Juan
Spain
C?ID=351946
Dear Rizzio, as you know I have some similar problem (you have participated in my post “Audi A6 C7 HBA Retrofit”) and, I am afraid, at the end of the day, we both will end in some “new manufacturers configuration software firewall”. The purpose: keeping their profits, the alibi: Peoples’ safety.
But as far as I know, there is no independent entity for cars’ manufactures software verification and validation.
For this reason I want to keep this forum where independent opinions can appear , some of them “insane”, but if they can avoid future “cheating configuration for roller mode Diesel engines testing” I will like to participate
Best regards
Juan
Rizzio
Trondheim, Norway
C?ID=369124
I’ve been working on this problem all day. And if someone have any ideas where this failes, give me som pointers.
I have checked all wires (not ones, twice , but checked 4 times)
Pinout is as follows. From gateway pin 7 to 8E pin 3, gateway pin23 to 8E pin 4.
8E pin 9 to Abs pin 11, 8E pin 10 to abs pin 23.
Do we agree on this being correct?
Pin 1 from 8E goes to the fusebox, and pin 2 goes to earth at the bottom of the right A pillar
So if the car is pickey on the power, where should the wires go?
And is my gateway coded the right way?
Any ideas for adaptations or coding?
downtime
Finland
C?ID=280813
From what pin exactly from fusebox you’re taking the power?
Because most likely the imageprocessor is not getting power and that causes the cannot be reached issue.
darkchina811
ITALY
C?ID=333184
also, on other vehicles the lane assist camera HAS to be powered by a switched fuse (Terminal 15), so check your WD.
Rizzio
Trondheim, Norway
C?ID=369124
Found the fault. Wire snap in the kufatec wireloom. Fixing the wires now, new update when im done rewiring.
The imageproc up and running.
But i now have a new problem.
Outside operating area.
Coding for the 8E does not include my mib2 high version. i have Rcm, 3G+ and no navi
Could this be fixed with vcds or Vag can Pro?
XPepino
Czech Republic
C?ID=91614
I can post my car A6 Avant 3.0 TDI 2015+, if it help
But it have also Acc, Side Assist.
Hope it help:
   Component: 3.0TDI EDC17  H34 0003
   Revision: 92H34---
   Coding: 12254012046601030000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM30TDI0114G2907311C 001003
   VCID: 2502051A24D1A66286-8070
   Component: 0B5 30 TDIRdW H03 0008
   Revision: --H03---
   Coding: 100001
   VCID: 2B16F3224235901250-807E
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 17A6DE49E8657B929B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41CAB18AD0B96A429A-8014
   Part No SW: 4H0 907 064 GP    HW: 4H0 907 064 GP
   Component: BCM2 2.0      H37 0572
   Coding: 05A96F0E000000000000
   VCID: 7DB20D7AE4C1CEA2BE-8028
   Part No SW: 4G8 959 760 C    HW: 4G8 959 760 C
   Component: MEM-BFS       H04 0154
   Revision: AA000000    Serial number: 00000016109954
   Coding: C018320085006201010001010101112030303333283333
   Shop #: WSC 02311 785 00200
   VCID: 3A38C666B56F399ADB-806E
   Serial number: 19101500040623
   Coding: 368211BE250000
   VCID: 63865B026A651852A8-8036
Address 09: Cent. Elect. (J519)       Labels:. User\4H0-907-063-V2.clb
   Part No SW: 4H0 907 063 DG    HW: 4H0 907 063 AG
   Revision: 14020001    Serial number: 00001172356502
   Coding: 0105001440349FE2C9014084A0001800CF9CC7082E08020180000894E101170200400009090000
   VCID: 70AC244EA393B3CA25-8024
   Component: WWS57X 150827  H38 0080
   Serial number:         150920100926
   Coding: 0045F7
   Serial number: 20788606
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Serial number: 22 10 2015  00000323
   Component: EVLS-SG  H08 0300
   Serial number: WA121418000014967796
   Coding: 020300
   Serial number: 1B1840D7000000000001
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 H    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0080
   Revision: --------    Serial number: 56261528901101
   Coding: B82B16
   ASAM Dataset: EV_EPHVA2CAU64X0000 001014
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 3620D2568977DDFA3F-8062
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0053
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   VCID: 291A092A48C98202A2-807C
   Revision: --------    Serial number: 003P1006XR7G
   Coding: 30333130313730323539554A304C34473053
   VCID: 3B36C362B2550092C0-806E
   Serial number: 3575HRB40553LHKE2PM+
   Serial number: 3585HRB405J3LHKEC1K/
   Serial number: 3515JRB405P3JK6278SQ
   Serial number: 3525JRB405R3K164HG9C
   Serial number: 3554VRB4008553H0D15I
   Serial number: 3564VRB4006553H4CPRN
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372OJQ00077
   Coding: 0004FD
   VCID: 383CDC6E8B632B8A2D-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Component: E221 - MFL  H08 0009
   Serial number: 29 06 2011  11148824
Address 17: Instruments (J285)       Labels:. 4H0-920-xxx-17.clb-SRI1
   Part No SW: 4G8 920 934 H    HW: 4G8 920 934 H
   Component: TDieRdwAcc    H11 0104
   Revision: 07001088    Serial number: 658131015596041
   Coding: 038612001F550008080000
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K.rod
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000002019450
   Coding: C0CD078118
   ASAM Dataset: EV_GatewPkoUDS 001028
   Serial number: 4304577903
   Voltage stabilizer:
   Serial number: 15072900000000000376
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 X299
   Serial number: 17051300040785
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   VCID: 373EDF528E7D24F224-8062
   Coding: 008002
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2F2EE732762DEC327C-807A
   Component: MEM-FS        H04 0154
   Revision: AA000000    Serial number: 00000016110514
   Coding: C0183B0085016201010001010101112030303333203333
   Revision: --------    Serial number: EJ1BPA820ADWCS
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H07 0060
   Serial number: 0383839204
   Coding: 040311
   VCID: 393AD96AB8693282D2-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H07 0060
   Serial number: 0384004426
   Coding: 040311
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0511
   Coding: 011F17015E00628002080013
   VCID: 45C2A59ACC914662A6-8010
   Component: RCevo         H53 0202
   Revision: 00000002    Serial number: 0000308997
   Coding: 101101010001
   ASAM Dataset: EV_RCEPS 106007
   ROD: EV_RCEPS_106.rod
   VCID: 3A38C666BD6F399ADB-806E
   Revision: 00002001    Serial number: 0382776124
   Coding: 01000E3820B93081C32009840C030F4F0000000000000000000000000000
   Subsystem 1 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00016043045
   Subsystem 2 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
   Serial number: 93656352
   Component: TSG BF        H03 0511
   Coding: 011F17015E00628002080002
   VCID: 46C0A296F1974D7AAF-8012
   Revision: --------    Serial number: 00000001621928
   VCID: 2D12FD3A7C219E224E-8078
   Coding: 04FA02202A170200
   VCID: 3424E85E9F0BCFEA01-8060
   Coding: E01F00
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
   Part No SW: 4G1 035 044 H    HW: 4G1 035 044
   Component: MU-H-LN-EU    042 0924
   Serial number: A589J0F7540746
   Coding: 01750201FF0A000013110001000A00102F0006E5F17001009F
   Shop #: WSC 41834 002 1048576
   VCID: 2404181E2FEB5F6A91-8070
   Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
   Component: ECE 2018  --- 0166
   Serial number: AUZ8Z9FY8037VG
   Serial number: 90349OJD0000G
   Component: TSG HL        H03 0511
   VCID: 49DAA9AAE089A20242-801C
   Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
   Component: TopView       H08 0361
   Revision: 11001001    Serial number: 82330JG0121226
   Coding: 0213000001010000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
   ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 280501070
   Coding: 093205C030
   Component: TSG HR        H03 0511
   Coding: FA160000
   VCID: 2C14F03E473B972A59-8078
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00002607222501
   Coding: 766FF0
   Shop #: WSC 06745 128 28888
   ROD: EV_IVBDriveSideFrnt.rod
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00002607253001
   Coding: 366FF0
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7E04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 271E0F125EDDB472B4-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0090
   Serial number: 005000622610157
   Coding: 04C0BB181111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Component: RGS-VL        H14 0080
   Coding: 0066E608031F0376070308014240C2010000
   ROD: EV_RGS_L.rod
   VCID: 312AE14A6019FAC26A-8064
   Component: RGS-VR        H14 0080
   ROD: EV_RGS_R.rod
   VCID: 3228EE46651FC1DA13-8066
   Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0013
   Revision: 00000000    Serial number: 152741199
XPepino
Czech Republic
C?ID=91614
Do you also have Image unit for Facelifted Car ?
4H0907107H ? Or you used from prefacelift car ?
So you have also MIB 2 (if i understand, it is not clear)
If yes, i can download from my car adaptation channels
Rizzio
Trondheim, Norway
C?ID=369124
I have facelift H image proc, and yes, i do have the mib2 high mmi
I’m going to attack this problem again on sunday.
And yes, adaptations would help
Mike_Jones
C?ID=18137
Hi There - can you repost now the 8E is visible - I have done this retrofit but I had the camera already and used the same image proc as you. Are VZE and Lane Assist not working? If you look at my post (updated yesterday on Lane assist you will see the issues I had.
nirvananils
C?ID=289109
There's no Dataset on 8E for use with TSR. Sou youll have to do it to delete fault Outside operating Area
Rizzio
Trondheim, Norway
C?ID=369124
Today i passed the first milestone. I’ve got the trafficsign recognition to work.
Still a bit missing regarding lane assist, so this will be figured out soon.
Should i write a guide on how to retrofit this from scratch?
Meaning with a car that does not come equiped with camera og imageprocesor from the factory
Bruce
Near Philadelphia, PA, USA
I'm certain many would like to see such a guide.
WuMutien
Atlanta, GA USA
C?ID=245683
I would greatly value such a guide!
