Mk7 golf trunk / remote issues
shanefuture
Dublin, Ireland
C?ID=117562
Hi guys , I’m wondering can anyone help us.
We’ve just bought 2015 vw golf mk7 R.
The previous owner has done some coding / changes to the car and isn’t sure what he did exactly or where to start?
He changed the operation of how the boot lid works so for example ( car has kessy)
If I walk up to car and hit open on the remote the boot remains locked and won’t open, if I then hit lock on the remote i can walk up and the boot will open.
Also on the first start in the morning if I walk up to the car and hit the boot open button on the key fob the boot releases but actually sets off the factory alarm.
It’s a very confusing issue I’ve gone through the menus on the infotainment and nothing changed this operation.
I would be ever so grateful if anyone could shed some light on this issue.
I will include in a full vehicle scan below.
[Back]
Wednesday,21,August,2019,12:50:51:11308
VCDS Version: 19.6.1.0 (x64)
VIN: WVWZZZAUZFW239900   License Plate: 2015 golf R
Mileage: 69224km-43013mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 20 22 2B 42 44 47 52
          55 5F A9
VIN: WVWZZZAUZFW239900   Mileage: 69224km-43013miles
VIN: WVWZZZAUZFW239900   License Plate: 151DDAVE
          55 5F A9
A9-Struct. Borne Sound -- Status: Not registered 0001
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 E    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 091D00322466050B3004
   ASAM Dataset: EV_ECM20TFS0205G0906259E 001005
   ROD: EV_ECM20TFS0205G0906259E.rod
   VCID: 3065E5826B0F7FCF29-8064
15072 - Engine Start Blocked by Immobilizer
          P1570 00 [104] - -
                    Mileage: 69089 km
                    Date: 2019.08.19
                    Time: 19:40:55
                    Engine speed: 1320.50 /min
                    Normed load value: 5.9 %
                    Coolant temperature: 91 °C
                    Intake air temperature: 58 °C
                    Voltage terminal 30: 12.089 V
                    FRF_IMMO_SNAPSHOT_BYTE1: 25
                    FRF_IMMO_SNAPSHOT_BYTE2: 127
                    FRF_IMMO_SNAPSHOT_BYTE3: 140
                    FRF_IMMO_SNAPSHOT_BYTE4: 27
                    FRF_IMMO_SNAPSHOT_BYTE5: 16
                    FRF_IMMO_SNAPSHOT_BYTE6: 0
                    Engine: operating status: IS
Readiness: 0010 0001
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4522
   Revision: 03253104    Serial number: TFK01501121573
   ROD: EV_TCMDQ250021.rod
   VCID: 1F47163E0691F0B780-804A
   Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
   Component: ESC           H42 0711
   Revision: 00000000    Serial number: 60165000001724
   Coding: 01FA93A1542329750780070041C36980C92A94E0E08296F7184250F8C208
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 4993A866E8952E070E-801C
   Revision: 00021000    Serial number: 0357554449
   Coding: 030C0C
   VCID: 3A71C7AABD73B59F97-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00120014200100011005000000101000
   VCID: 6AD137EA8D53C51F27-803E
   Air quality sensor:
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011501900387
   Coding: 03111B46C64122F30BA44080B10407281800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 000575429B2F2F4F99-8054
   Component: WWS    150103  042 0551
   Serial number:         150108205225
   Component: RLHS  037 0059
   Serial number: S4Y15M01D21H22M40S18
   Coding: 00A8DD
   Serial number: 000000000ZY1500704XA
   Serial number: 00000000000031523620
   Sun Roof:
   Component: J245 PS73.403  H02 0003
   Serial number: 0000FST0002MHGL00000
   Coding: 181801
          B1263 01 [008] - Electrical Failure
                    Fault Frequency: 45
                    Reset counter: 89
                    Mileage: 69089 km
                    Date: 2019.08.19
                    Time: 19:31:03
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391501405271
   Coding: 0071151011
   VCID: 3D7BCCB6AC5D82A7B2-8068
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 17121403271532
   Coding: 001C1300FE0739
   VCID: 3875DDA2837FA78F61-806C
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H16 0115
   Serial number: 20121441350052
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 76E9139AC9EB11FFB3-8022
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R0F6YFZ
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4183B046D0A5E647D6-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 601 15
   Serial number: 35767000000D8AF09210
   Subsystem 2 - Part No SW: -----------    HW: 480 001 501 15
   Serial number: 3586700000027D29B21X
   Subsystem 3 - Part No SW: -----------    HW: 480 401 401 15
   Serial number: 35165029B1901DA44356
   Subsystem 4 - Part No SW: -----------    HW: 480 401 401 15
   Serial number: 3526502A9196FF40912I
   Subsystem 5 - Part No SW: -----------    HW: 480 401 501 15
   Serial number: 3556502C319121A483E8
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 15011504401108
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 7BFF02AEF2C94C97CC-802E
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
   Part No SW: 5G1 920 758     HW: 5G1 920 758
   Component: KOMBI         304 4310
   Coding: 27AD08183F80040800887E011400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   VCID: 6CDD31F287A7DB2F55-8038
9456128 - Engine Control Module (ECM) not authorized
          B104A 00 [009] - -
                    Fault Frequency: 17
                    Mileage: 69089 km
                    Date: 2019.08.19
                    Time: 19:40:54
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0002965523
   Coding: 030100042F085900EF00027A9C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72E12F8AA5830DDF9F-8026
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0038
   Serial number: 36150000025040075025
   Coding: 2DFFFF
   Serial number: 5565015503
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
                    Fault Frequency: 62
                    Reset counter: 49
                    Mileage: 69084 km
                    Date: 2019.08.19
                    Time: 19:16:12
                    Supply voltage: Terminal 30: 11.9 V
                    Terminal 15: On
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511 D
   Component: FLA           H05 0002
   Revision: AA001001
   Coding: 02028864727264565625393E01
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: 2B5FF2EE42291C171C-807E
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00017.11.14
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   VCID: 4689A35AF98BC17FE3-8012
   Revision: 00000000    Serial number: 15000010357001
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346DE9929F1743EF4D-8060
   Serial number: 150115BA612242
   Coding: 003F1220D001040000001000
   VCID: 4281BF4AD5A3FD5FCF-8016
   Serial number: 00000000000005016677
   Coding: 0D0000
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 87
                    Mileage: 69167 km
                    Date: 2019.08.20
                    Time: 14:16:40
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 8103
   VCID: 3777DE9E8E61A8F768-8062
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC40244W%
   Coding: 120000008AAA8A0000
   ASAM Dataset: EV_AMPMst11CALPI 001007
   ROD: EV_AMPMst11CALPI.rod
   VCID: 63CF5ACE6A799457E4-8036
   Serial number: 120115BAC07127
   Coding: 003F1020DE01040000801000
   Serial number: 00000000000004937392
   Coding: 150000
   Coding: 02A602000B010200
   VCID: 4085B542DBAFEF4FD9-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 043 E    HW: 5G0 035 043 D
   Component: MU-H-N-EU     H44 0376
   Serial number: A309A0F7521764
   Coding: 027300010000000011110002000800001F0207F60100010057
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 204515C23BEFCF4FB9-8074
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9PU300AUZ
   Subsystem 2 - Part No SW: V03 959 801 DG    HW: -----------
   Component: ECE 2016/2017  --- 0153
   Compact Disc Database:
   Component: Gracenote  --- 1010
   Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 141121201809
   VCID: 2D5BFCF67C3D122702-8078
End-------------------------(Elapsed Time: 05:56)--------------------------
^^^^ hmm............. has the ECU on this car been tuned - Immobilizer problem?
shanefuture
Dublin, Ireland
C?ID=117562
Yes the car has a system called Autowatch ghost it’s a immobiliser so if car is attempted to start with out entering the code you’ll get a message in cluster saying “immobiliser active “ which logs a fault also.
Problem with boot was there before ghost was installed.
shanefuture
Dublin, Ireland
C?ID=117562
Anyone any suggestions I could even try .. completely lost at this stage .. please
shane: scratching my head - not much hair there to scratch!!!
The inclusion of Autowatch seems suspicious to me - but I must accept your assurance that the fault preceded the immobilizer issue. The fuel flap error could be implicated in the way the alarm is responding - how does this DTC manifest in the way the flap operates (or. doesn't operate)?
But the most intriguing aspect of your post must Shirley be the changed behavior of the boot lid at "first start in the morning". This might indicate (and I emphasize "might") that the way that the offending module(s) wakes-up after sleeping (a very apt description for "morning start") is a consideration. Again wild conjecture - but perhaps leave the car unattended for a long period of time during the day- does the morning-start dynamic repeat?
Finally - here's my cut-down version of the WD for the rear-lid-lock-unit on a mk7
The pin-out descriptors for the connections on the BCM are as follows
  • Socket A/pin 9 Rear lid central locking motor -V53-
  • Socket A/pin 53 Terminal 31
  • Socket A/pin 52 Rear lid contact switch for anti-theft alarm-F123-
Just to eliminate the possibility of a wiring/connector problem -perhaps grab a multimeter and confirm the correct operation of the pins on the boot-lid pug. Particularly pin #1 (from BCM pin A/52)- if this pin doesn't change state when the siren sounds, then arming the anti-theft unit isn't happening from this point
shanefuture
Dublin, Ireland
C?ID=117562
Hi Don , thanks for your reply and time!
The Autowatch system was fitted a few days after we took delivery of the car and the boot was acting funny From when we first went to look at car. (So immobiliser issue is 100% Autowatch related!)
Funny you mention the fuel flap.
I was back at it last night going through the adaptions in the hope something might stick out to me on a boot/ load area setting but nothing did but the fuel flap actuator is now quite noisy on opening as if the motor is giving up on the Job.
The reason I say first thing in the morning it’s just to be fully sure the car has gone to sleep.
These symptoms would be the same after a hour or so left sitting.
I’m not great at reading the scans do you see something with the fuel flap and what would that indicate or suggest to you ?
Thanks again and very much appreciate your help
shane:
So - here's the thing - the DC actuator that drives the fuel flap (regardless of its form) has a characteristic whereby as the load on the device increases, the electrical current in circuit will increase and the speed will then tend to decrease. For a healthy actuator circuit, the designed load and therefore the designed current will be set so as not to trip the threshold for the monitoring system. But observations like increased noise and high heat in actuator devices often signifies increased load - which tends to confirm the DTC in BCM.
The other interesting aspect of the DTC is the "fault frequency" which suggests that the error has happened on 45 x occasions since first detected. So this is not an intermittent problem - it's a confirmed "aged error". Which all suggests that it's probably time to either repair or replace the device (I think).
shanefuture
Dublin, Ireland
C?ID=117562
Hey Don,
just to confirm we are talking about the faults in the petrol flap now?
should i just replace this regardless or do you think it may also be causing the bootlid issue.
ive a video recorded a video of the boot fault which shows the "issue" probably better than i explain.
i don't think i can post a video here , id love to be able to show you whats happening.
again appreciate your help.
shanefuture
Dublin, Ireland
C?ID=117562
and also to say the "noisy" actuator on the fuel flap I've only noticed that noise in the last few days.
the flap itself locks/unlocks without issue so far.
shane: yes - as I understand, you have 2 x separate problems: the fuel tank actuator (which I suspect is a physical issue) and separately the hatch locking issue (incidentally, thanks for the video- nice accent!) which I suspect/guess might be a wiring, or coding issue given that the lock actually works albeit incorrectly. I'm not sure how the anti-theft issue is related to either of these 2 x problems - I'm actually not sure about much here- alas!!
Again with the hope that the information might help - can you post-up an adaptation channel map (in .CSV format) of the BCM ?
PS: as to your statement that you only recently noticed the noise in the fuel flap actuator - the DTC suggests that there have been repeated failures over a period of time. Clearly the cause of the flap failure has become worse - with the noise appearing recently. As I suggested - perhaps it's now time to address a developing and worsening problem.
shanefuture
Dublin, Ireland
C?ID=117562
I probably should have added subtitles !! Haha..
The person we bought the car off told me he was “messing with settings” and since then the boot was like this . I do tend to believe him but he hasn’t a breeze as to where or what modules he was in sadly!
I’m quite new to the vcds I will absolutely doing anything you think may help but I’m not sure how to do that ?
Could you explain please.
(Were on completely different time zones here 😉) hence delay with replies.
shanefuture
Dublin, Ireland
C?ID=117562
Just had a quick search I think I can do that.
What module do you want me to do it on ? Central electrics ?
I know you said BCM is that just a full map
Of all modules ?
Sorry for the silly questions just trying to get it exactly as you need.
I ordered the fuel flap actuator today should be in vw for Tuesday under €40.
shane : An adaptation channel map just for the BCM (which is also called "Central Electrics" and it's also the module that lives at address "09") is OK.
This is the control module that is identified as "J519" in my WD above - so it's the thing that tells the boot-lid motor what to do (and it also monitors the state of the 2 x switches in my WD).
I will compare the specific adaptation channel settings in your BCM with those of similar modules on other cars that I have in my MQB database. Of course anything is possible, but using the well proven principle of Occam's -razor, I'm hoping that the more obvious place to look for solutions is the correct place to look.
Anyhow- it may not succeed, but let's give it a good try!;)
shanefuture
Dublin, Ireland
C?ID=117562
;SW:5Q0-937-084-AJ   HW:5Q0-937-084-AJ ---  Cent. Elect.
;Component:BCM MQBAB H   H18 0137	Coding:03111B46C64122F30BA44080B10407281800000000000000000000000000
;EV_BCMCONTI	013000	EV_BCMBOSCH_013.rod
;Friday	30	August	2019	10:01:05:11308
;VCDS Version: Release 19.6.1 (x64)  Data version: 20190529 DS308.0
;VCID: 000575429B2F2F4F99-8054
IDE00001-ENG99061-Production mode-Access control	not active	3
IDE00001-ENG115730-Production mode-Exterior lighting	not active	3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren	not active	3
IDE00001-ENG112304-Production mode-Heckwischer	not active	3
IDE00001-ENG98647-Production mode-Interior lighting	not active	3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active	3
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active	3
IDE00002-Transport mode	active	1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	not active	12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	10	12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active	12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	active	12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active	12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	not active	12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	Deactivating	12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	not active	12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	2000 ms	12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	320 ms	12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	0 ms	12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	0 ms	12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	320 ms	12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz	active	12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	not active	12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung	not active	12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant	0	12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active	12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	not active	12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	not active	12
IDE01550-Service position	170.49 °	2
IDE02152-Characteristics in production mode	2000 ms	4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate	4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	active	4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	not active	4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active	4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	active	4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	short	4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	active	4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active	4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active	4
IDE02332-Deactivate production mode	0	3
IDE02488-DWA Interior monitoring	100 %	1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active	8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active	8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken	not active	8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active	8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s	8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s	8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s	8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s	8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active	8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active	8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	50 %	8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	50 %	8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	50 %	8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	Enabled	8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed	8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed	8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-63.75 °	14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.00 %/s	14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	double sided	14
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.00 km/h	14
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.00 °C	14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.00 °C	14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °	14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.00 °C	14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	180 °	14
IDE03638-ENG116676-static AFS light-Upper speed threshold	40.00 km/h	14
IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119	14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger	separte	8
IDE04923-ENG115774-Turn signal control-Komfortblinken	active	8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen	3	8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker	MFG	8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen	not enabled	8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung	not active	8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung	Always active	8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor	0.10	8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert	10.00 %	8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350 km/h	14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	350 km/h	14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung	14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active	14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig	14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren	14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	0 km/h	14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	One-sided	14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	active	14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus	active	14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht	active	14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active	14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren	in Betrieb lassen	14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min	14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Low beam	8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	manual	8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	Driver door	8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	46400 lx	8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	12 lx	8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	Enabled	8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	10 seconds	8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP	10 seconds	8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	active	8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP	active	8
IDE04927-IDE01446-Window heater-Running time of heated front window	240 s	8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.00 °C	8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.00 °C	8
IDE04927-ENG126845-Window heater-FSH Automatik	active	8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	600 s	8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active	8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	not active	8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active	4
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated	4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	driver door contact thatcham	4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active	4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme	4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active	4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung	4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	not active	8
IDE05142-ENG116621-Access control-automatisches Entriegeln	active	8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	not active	8
IDE05142-ENG116706-Access control-Autounlock NAR	not active	8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB	not active	8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	active	8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active	8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	active	8
IDE05142-ENG115722-Access control-Electrical rear lid	not active	8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active	8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein	not active	8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active	8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	not active	8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active	8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active	8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung	not active	8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active	8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable	8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active	8
IDE05142-ENG115755-Access control-Notschließfunktion	active	8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active	8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active	8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung	Always	8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden	Always	8
IDE05142-ENG115758-Access control-Valet Parking	not active	8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe	not active	8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT	not active	8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer	not active	8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active	8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	active	8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Globale Entriegelung	8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	not active	8
IDE05144-Read parameter address	00 00 00	3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0	34	560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1	3E	560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10	37	560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11	41	560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12	00	560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13	00	560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14	00	560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15	00	560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16	00	560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17	00	560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18	08	560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19	18	560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2	48	560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20	10	560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21	20	560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22	29	560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23	00	560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24	00	560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25	28	560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26	1C	560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27	1A	560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28	0B	560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29	1B	560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3	4C	560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30	00	560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31	00	560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32	00	560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33	00	560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34	00	560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4	3A	560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5	44	560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6	36	560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7	40	560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8	35	560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9	3F	560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0	maximize	560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1	maximize	560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10	maximize	560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11	maximize	560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12	maximize	560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13	maximize	560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14	maximize	560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15	maximize	560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16	maximize	560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17	maximize	560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18	maximize	560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19	maximize	560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2	maximize	560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20	maximize	560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21	maximize	560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22	maximize	560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23	maximize	560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24	maximize	560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25	maximize	560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26	maximize	560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27	maximize	560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28	maximize	560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29	maximize	560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3	maximize	560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30	maximize	560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31	maximize	560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32	maximize	560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33	maximize	560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34	maximize	560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4	maximize	560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5	maximize	560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6	maximize	560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7	maximize	560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8	maximize	560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9	maximize	560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0	maximize	560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1	maximize	560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10	maximize	560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11	maximize	560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12	maximize	560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13	maximize	560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14	maximize	560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15	maximize	560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16	maximize	560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17	maximize	560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18	maximize	560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19	maximize	560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2	maximize	560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20	maximize	560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21	maximize	560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22	maximize	560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23	minimize	560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24	minimize	560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25	maximize	560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26	maximize	560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27	maximize	560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28	maximize	560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29	maximize	560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3	maximize	560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30	maximize	560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31	maximize	560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32	maximize	560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33	maximize	560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34	maximize	560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4	maximize	560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5	maximize	560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6	maximize	560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7	maximize	560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8	maximize	560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9	maximize	560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0	maximize	560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1	maximize	560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10	maximize	560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11	maximize	560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12	maximize	560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13	maximize	560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14	maximize	560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15	maximize	560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16	maximize	560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17	maximize	560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18	maximize	560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19	maximize	560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2	maximize	560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20	maximize	560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21	maximize	560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22	maximize	560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23	maximize	560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24	maximize	560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25	maximize	560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26	maximize	560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27	maximize	560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28	maximize	560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29	maximize	560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3	maximize	560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30	maximize	560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31	maximize	560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32	maximize	560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33	maximize	560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34	maximize	560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4	maximize	560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5	maximize	560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6	maximize	560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7	maximize	560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8	maximize	560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9	maximize	560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0	127	560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1	127	560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10	127	560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11	127	560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12	0	560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13	0	560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14	0	560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15	0	560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16	100	560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17	100	560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18	100	560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19	100	560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2	100	560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20	100	560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21	100	560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22	100	560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23	100	560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24	100	560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25	127	560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26	100	560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27	10	560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28	86	560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29	86	560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3	100	560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30	89	560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31	0	560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32	0	560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33	0	560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34	0	560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4	127	560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5	127	560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6	127	560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7	127	560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8	127	560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9	127	560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0	0	560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1	0	560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10	0	560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11	0	560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12	0	560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13	0	560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14	0	560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15	0	560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16	0	560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17	0	560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18	0	560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19	0	560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2	26	560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20	10	560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21	10	560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22	0	560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23	10	560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24	10	560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25	0	560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26	0	560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27	0	560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28	0	560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29	0	560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3	26	560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30	0	560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31	0	560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32	0	560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33	0	560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34	0	560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4	127	560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5	127	560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6	0	560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7	0	560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8	0	560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9	0	560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0	0	560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1	0	560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10	0	560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11	0	560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12	0	560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13	0	560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14	0	560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15	0	560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16	0	560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17	0	560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18	0	560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19	0	560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2	0	560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20	0	560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21	0	560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22	0	560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23	0	560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24	0	560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25	0	560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26	0	560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27	0	560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28	0	560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29	0	560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3	0	560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30	0	560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31	0	560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32	0	560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33	0	560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34	0	560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4	0	560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5	0	560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6	0	560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7	0	560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8	0	560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9	0	560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0	0	560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1	0	560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10	0	560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11	0	560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12	0	560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13	0	560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14	0	560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15	0	560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16	0	560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17	0	560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18	0	560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19	0	560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2	0	560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20	0	560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21	0	560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22	0	560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23	0	560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24	0	560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25	0	560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26	0	560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27	0	560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28	0	560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29	0	560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3	0	560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30	0	560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31	0	560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32	0	560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33	0	560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34	0	560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4	0	560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5	0	560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6	0	560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7	0	560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8	0	560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9	0	560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0	14	560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1	15	560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10	1E	560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11	1F	560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12	00	560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13	00	560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14	00	560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15	00	560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16	41	560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17	42	560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18	16	560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19	18	560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2	4A	560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20	39	560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21	3A	560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22	2C	560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23	00	560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24	00	560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25	30	560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26	2F	560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27	2A	560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28	31	560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29	32	560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3	4C	560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30	02	560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31	00	560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32	00	560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33	00	560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34	00	560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4	49	560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5	4B	560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6	1A	560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7	1B	560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8	26	560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9	27	560
IDE05145-ENG115873-Light configuration-Lasttyp 0	33 - LED-Modul Blinkleuchten	560
IDE05145-ENG115892-Light configuration-Lasttyp 1	33 - LED-Modul Blinkleuchten	560
IDE05145-ENG116062-Light configuration-Lasttyp 10	2 - Shutter: Diagnosesensierung für 'LED low'	560
IDE05145-ENG116081-Light configuration-Lasttyp 11	2 - Shutter: Diagnosesensierung für 'LED low'	560
IDE05145-ENG116100-Light configuration-Lasttyp 12	not active	560
IDE05145-ENG116119-Light configuration-Lasttyp 13	not active	560
IDE05145-ENG116138-Light configuration-Lasttyp 14	not active	560
IDE05145-ENG116157-Light configuration-Lasttyp 15	not active	560
IDE05145-ENG116176-Light configuration-Lasttyp 16	37 - allgemeine LED bis 12W	560
IDE05145-ENG116195-Light configuration-Lasttyp 17	37 - allgemeine LED bis 12W	560
IDE05145-ENG116214-Light configuration-Lasttyp 18	38 - LED Blinkleuchten	560
IDE05145-ENG116233-Light configuration-Lasttyp 19	38 - LED Blinkleuchten	560
IDE05145-ENG115910-Light configuration-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal	560
IDE05145-ENG116252-Light configuration-Lasttyp 20	34 - LED Bremsleuchten	560
IDE05145-ENG116271-Light configuration-Lasttyp 21	34 - LED Bremsleuchten	560
IDE05145-ENG116290-Light configuration-Lasttyp 22	42 - LED dritte Bremsleuchte	560
IDE05145-ENG116309-Light configuration-Lasttyp 23	34 - LED Bremsleuchten	560
IDE05145-ENG116328-Light configuration-Lasttyp 24	34 - LED Bremsleuchten	560
IDE05145-ENG116347-Light configuration-Lasttyp 25	43 - allgemeine LED	560
IDE05145-ENG116366-Light configuration-Lasttyp 26	1 - LED Tagfahrlichtmodul Versorgung	560
IDE05145-ENG116385-Light configuration-Lasttyp 27	32 - allgemeine LED bis 12W	560
IDE05145-ENG116404-Light configuration-Lasttyp 28	9 - allgemeine Glühlampe 27W: auch H15	560
IDE05145-ENG116423-Light configuration-Lasttyp 29	9 - allgemeine Glühlampe 27W: auch H15	560
IDE05145-ENG115929-Light configuration-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal	560
IDE05145-ENG116442-Light configuration-Lasttyp 30	36 - LED Kleinleistung	560
IDE05145-ENG116461-Light configuration-Lasttyp 31	not active	560
IDE05145-ENG116480-Light configuration-Lasttyp 32	not active	560
IDE05145-ENG116499-Light configuration-Lasttyp 33	not active	560
IDE05145-ENG116518-Light configuration-Lasttyp 34	not active	560
IDE05145-ENG115948-Light configuration-Lasttyp 4	6 - LED Lichtmodul	560
IDE05145-ENG115967-Light configuration-Lasttyp 5	6 - LED Lichtmodul	560
IDE05145-ENG115986-Light configuration-Lasttyp 6	3 - Xenon Abblendlicht	560
IDE05145-ENG116005-Light configuration-Lasttyp 7	3 - Xenon Abblendlicht	560
IDE05145-ENG116024-Light configuration-Lasttyp 8	36 - LED Kleinleistung	560
IDE05145-ENG116043-Light configuration-Lasttyp 9	36 - LED Kleinleistung	560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0	Always	560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1	Always	560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10	Always	560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11	Always	560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12	Always	560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13	Always	560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14	Always	560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15	Always	560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16	only_if_closed	560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17	only_if_closed	560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18	Always	560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19	Always	560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2	Always	560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20	Always	560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21	Always	560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22	Always	560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23	Always	560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24	Always	560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25	Always	560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26	only_if_closed	560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27	only_if_closed	560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28	only_if_closed	560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29	only_if_closed	560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3	Always	560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30	Always	560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31	Always	560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32	Always	560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33	Always	560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34	Always	560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4	Always	560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5	Always	560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6	Always	560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7	Always	560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8	Always	560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9	Always	560
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17	0	560
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13	0	560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0	2	560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1	4	560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10	13	560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11	14	560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12	0	560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13	0	560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14	0	560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15	0	560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16	3	560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17	5	560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18	2	560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19	4	560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2	20	560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20	24	560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21	24	560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22	24	560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23	24	560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24	24	560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25	8	560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26	28	560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27	8	560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28	25	560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29	25	560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3	20	560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30	43	560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31	0	560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32	0	560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33	0	560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34	0	560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4	20	560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5	20	560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6	11	560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7	12	560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8	8	560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9	8	560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0	0	560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1	0	560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10	15	560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11	15	560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12	0	560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13	0	560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14	0	560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15	0	560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16	0	560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18	0	560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19	0	560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2	0	560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20	0	560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21	0	560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22	0	560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23	0	560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24	0	560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25	0	560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26	0	560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27	0	560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28	0	560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29	0	560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3	0	560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30	0	560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31	0	560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32	0	560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33	0	560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34	0	560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4	0	560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5	0	560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6	15	560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7	15	560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8	9	560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9	10	560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0	0	560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1	0	560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10	0	560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11	0	560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12	0	560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14	0	560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15	0	560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16	0	560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17	0	560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18	0	560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19	0	560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2	8	560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20	8	560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21	8	560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22	0	560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23	8	560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24	8	560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25	0	560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26	0	560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27	0	560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28	0	560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29	0	560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3	8	560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30	0	560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31	0	560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32	0	560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33	0	560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34	0	560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4	8	560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5	8	560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6	0	560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7	0	560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8	0	560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9	0	560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0	0	560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1	0	560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10	0	560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11	0	560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12	0	560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13	0	560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14	0	560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15	0	560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16	0	560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17	0	560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18	0	560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19	0	560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2	9	560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20	9	560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21	10	560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22	0	560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23	9	560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24	10	560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25	0	560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26	0	560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27	0	560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28	0	560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29	0	560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3	10	560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30	0	560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31	0	560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32	0	560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33	0	560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34	0	560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4	9	560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5	10	560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6	0	560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7	0	560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8	0	560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9	0	560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0	0	560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1	0	560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10	0	560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11	0	560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12	0	560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13	0	560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14	0	560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15	0	560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16	0	560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17	0	560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18	0	560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19	0	560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2	0	560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20	0	560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21	0	560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22	0	560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23	6	560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24	7	560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25	0	560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26	0	560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27	0	560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28	0	560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29	0	560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3	0	560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30	0	560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31	0	560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32	0	560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33	0	560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34	0	560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4	0	560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5	0	560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6	0	560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7	0	560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8	0	560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9	0	560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0	0	560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1	0	560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10	0	560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11	0	560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12	0	560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13	0	560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14	0	560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15	0	560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16	0	560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17	0	560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18	0	560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19	0	560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2	0	560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20	0	560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21	0	560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22	0	560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23	0	560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24	0	560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25	0	560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26	0	560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27	0	560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28	0	560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29	0	560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30	0	560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31	0	560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32	0	560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33	0	560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34	0	560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4	0	560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6	0	560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7	0	560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8	0	560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9	0	560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3	0	560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5	0	560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0	0	560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1	0	560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10	0	560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11	0	560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12	0	560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13	0	560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14	0	560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15	0	560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16	0	560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17	0	560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18	0	560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19	0	560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2	0	560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20	0	560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21	0	560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22	0	560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23	0	560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24	0	560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25	0	560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26	0	560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27	0	560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28	0	560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29	0	560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3	0	560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30	0	560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31	0	560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32	0	560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33	0	560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34	0	560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4	0	560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5	0	560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6	0	560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7	0	560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8	0	560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9	0	560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0	0	560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1	0	560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10	0	560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11	0	560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12	0	560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13	0	560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14	0	560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15	0	560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16	0	560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17	0	560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18	0	560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19	0	560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2	0	560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20	0	560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21	0	560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22	0	560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23	0	560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24	0	560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25	0	560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26	0	560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27	0	560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28	0	560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29	0	560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3	0	560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30	0	560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31	0	560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32	0	560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33	0	560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34	0	560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4	0	560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5	0	560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6	0	560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7	0	560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8	0	560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9	0	560
IDE05145-ENG154438-Light configuration-Reserved 0	0	560
IDE05145-ENG99841-Light configuration-Reserved 1	0	560
IDE05145-ENG154357-Light configuration-Reserved 10	0	560
IDE05145-ENG154352-Light configuration-Reserved 11	0	560
IDE05145-ENG154182-Light configuration-Reserved 12	0	560
IDE05145-ENG154265-Light configuration-Reserved 13	0	560
IDE05145-ENG154334-Light configuration-Reserved 14	0	560
IDE05145-ENG154340-Light configuration-Reserved 15	0	560
IDE05145-ENG154204-Light configuration-Reserved 16	0	560
IDE05145-ENG154344-Light configuration-Reserved 17	0	560
IDE05145-ENG154195-Light configuration-Reserved 18	0	560
IDE05145-ENG154190-Light configuration-Reserved 19	0	560
IDE05145-ENG99862-Light configuration-Reserved 2	0	560
IDE05145-ENG154300-Light configuration-Reserved 20	0	560
IDE05145-ENG154439-Light configuration-Reserved 21	0	560
IDE05145-ENG154440-Light configuration-Reserved 22	0	560
IDE05145-ENG154441-Light configuration-Reserved 23	0	560
IDE05145-ENG154442-Light configuration-Reserved 24	0	560
IDE05145-ENG154443-Light configuration-Reserved 25	0	560
IDE05145-ENG154444-Light configuration-Reserved 26	0	560
IDE05145-ENG154445-Light configuration-Reserved 27	0	560
IDE05145-ENG154446-Light configuration-Reserved 28	0	560
IDE05145-ENG154447-Light configuration-Reserved 29	0	560
IDE05145-ENG101107-Light configuration-Reserved 3	00	560
IDE05145-ENG154448-Light configuration-Reserved 30	0	560
IDE05145-ENG154449-Light configuration-Reserved 31	0	560
IDE05145-ENG154450-Light configuration-Reserved 32	0	560
IDE05145-ENG154451-Light configuration-Reserved 33	0	560
IDE05145-ENG154452-Light configuration-Reserved 34	0	560
IDE05145-ENG154267-Light configuration-Reserved 4	0	560
IDE05145-ENG154291-Light configuration-Reserved 5	0	560
IDE05145-ENG154239-Light configuration-Reserved 6	0	560
IDE05145-ENG154308-Light configuration-Reserved 7	0	560
IDE05145-ENG154184-Light configuration-Reserved 8	0	560
IDE05145-ENG154255-Light configuration-Reserved 9	0	560
IDE05822-DWA Vehicle inclination sensor	100 %	1
IDE05823-DWA Interior monitoring parameter set	01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 23 29 66	172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s	24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C	24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	22.50 °C	24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	21.50 °C	24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	22.50 °C	24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	21.50 °C	24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	36.00 °C	24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	35.00 °C	24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	36.00 °C	24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	35.00 °C	24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	53.50 °C	24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	52.50 °C	24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	53.50 °C	24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	52.50 °C	24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active	8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active	8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	not active	8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	not active	8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active	8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	100 %	8
IDE06425-Roller test bench mode: functional	not active	1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	Daytime running lights	4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active	4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	not active	4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	active	4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active	4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active	4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	active	4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active	4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active	4
IDE07356-Position during interval mode	31.49 °	2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit	12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min	12
IDE08542-IDE02021-Access control 2-Comfort closing	active	8
IDE08542-IDE02022-Access control 2-Comfort opening	active	8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active	8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	active	8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s	8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active	8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen	active	8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	active	8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	active	8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	active	8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by look command via remote control key	8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	not active	8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	active	8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung	not active	8
IDE08542-ENG115670-Access control 2-Komfortbedienung global	active	8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active	8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	active	8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	adjustable	8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	not active	8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung	active	8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung	active	8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf	not active	8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel	active	8
IDE08542-ENG125656-Access control 2-Regenschliessen_art	once	8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus	not active	8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock	not active	8
IDE08542-ENG154261-Access control 2-Reserved_4	not active	8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	active	8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	active	8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	not active	8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	tilting	8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	not active	8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	not active	8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung	active	8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt	active	8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron	active	8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal	not active	8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar	not active	8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	2000 ms	8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active	8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach	not active	8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis	8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	active	8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms	8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal	8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active	8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present	8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present	8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	active	8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte	not active	8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	active	2
IDE08787-ENG101416-Auxiliary functions-Reserved_1	not active	2
IDE08787-ENG99458-Auxiliary functions-Reserved_2	not active	2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	active	2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active	2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active	2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active	4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing	not active	4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active	4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active	4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken	not active	4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active	4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active	4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing	not active	4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active	4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active	4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active	4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing	not active	4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active	4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active	4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active	4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active	4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active	4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active	4
IDE09595-ENG115658-Characteristic curve-x0	0 lx	18
IDE09595-ENG101574-Characteristic curve-X1	2000 lx	18
IDE09595-ENG99557-Characteristic curve-X2	4000 lx	18
IDE09595-ENG102140-Characteristic curve-X3	6000 lx	18
IDE09595-ENG102936-Characteristic curve-X4	8000 lx	18
IDE09595-ENG103548-Characteristic curve-X5	10200 lx	18
IDE09595-ENG148955-Characteristic curve-y1_0	0	18
IDE09595-ENG148956-Characteristic curve-y1_1	40	18
IDE09595-ENG148957-Characteristic curve-y1_2	90	18
IDE09595-ENG148958-Characteristic curve-y1_3	140	18
IDE09595-ENG148959-Characteristic curve-y1_4	190	18
IDE09595-ENG148960-Characteristic curve-y1_5	245	18
IDE09595-ENG148961-Characteristic curve-y2_0	0	18
IDE09595-ENG148962-Characteristic curve-y2_1	60	18
IDE09595-ENG148963-Characteristic curve-y2_2	110	18
IDE09595-ENG148964-Characteristic curve-y2_3	160	18
IDE09595-ENG148965-Characteristic curve-y2_4	210	18
IDE09595-ENG148966-Characteristic curve-y2_5	255	18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s	20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	2	20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	3	20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	1	20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1	225	20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2	225	20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3	225	20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active	20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active	20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80 %	20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	2	20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80 %	20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active	20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active	20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active	20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active	20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active	20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active	20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	not active	20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1	225	20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2	225	20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3	225	20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	not active	20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active	20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	not active	20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	not active	20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active	20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active	20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen	not active	20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active	20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active	20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active	20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active	20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active	20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1	225	20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2	225	20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3	225	20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	active	20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active	20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed	2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	installed	2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed	2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active	2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active	2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed	2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed	2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed	2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed	2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed	2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active	2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed	2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed	2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung	3000 ms	10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit	1000 ms	10
IDE09733-ENG147405-LED bar setting values-Lockout time	0 s	10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige	0 s	10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz	25	10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor	0	10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS	393210 lx	10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS	393210 lx	10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30 %	12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25 %	12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30 %	12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25 %	12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58 %	12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53 %	12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58 %	12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53 %	12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85 %	12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80 %	12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85 %	12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80 %	12
IDE10298-Alternating park position 1	7.49 °	2
IDE10299-Alternating park position 2	29.49 °	2
MAS05055-lower turn position	31.49 °	2
MAS05056-upper turn position	170.49 °	2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck	active	8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb	not active	8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG	not active	8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global	active	8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen	active	8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen	active	8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen	not active	8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach	not active	8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung	active	8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy	active	8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder	active	8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung	active	8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy	active	8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder	active	8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein	not active	8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1.00	30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1.00	30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1.00	30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1.00	30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1.00	30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1.00	30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1.00	30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1.00	30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1.00	30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1.00	30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1.00	30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1.00	30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1.00	30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1.00	30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1.00	30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door	30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door	30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door	30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door	30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door	30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door	30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door	30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door	30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door	30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door	30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door	30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door	30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door	30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door	30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door	30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed	30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed	30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed	30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed	30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed	30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed	30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed	30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed	30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed	30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed	30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed	30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed	30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed	30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed	30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed	30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0	60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0	60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0	60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0	60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0	60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0	60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0	60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0	60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0	60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0	60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0	60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0	60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0	60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0	60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0	60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0	60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0	60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0	60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0	60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0	60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0	60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0	60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0	60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0	60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0	60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0	60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0	60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0	60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0	60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0	60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0	60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0	60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0	60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0	60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0	60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0	60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0	60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0	60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0	60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0	60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed	60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed	60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed	60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed	60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed	60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed	60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed	60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed	60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed	60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed	60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed	60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed	60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed	60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed	60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed	60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed	60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed	60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed	60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed	60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed	60
ENG126647-ENG98399-debug_light_function-Activation	0	11
ENG126647-ENG101417-debug_light_function-Adresse	0	11
ENG126647-ENG126820-debug_light_function-Bitmask	0	11
ENG126647-ENG126821-debug_light_function-Divisor	0	11
ENG126647-ENG98827-debug_light_function-Offset	0	11
ENG126647-ENG126822-debug_light_function-Polaritaet	0	11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe	0	11
ENG99457-ENG117394-Head area heater-blower_speed	1	2
ENG99457-ENG98971-Head area heater-Temperature	-2	2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms	22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms	22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms	22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms	22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms	22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms	22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms	22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms	22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms	22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms	22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms	22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.00 %	22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	72.00 %	22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.00 %	22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	48.00 %	22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3
shanefuture
Dublin, Ireland
C?ID=117562
I’m not sure if I’ve done that right ?
I have it on a email if you would like I can email you it on the .csv format which looks like a table / easier to read.
Again appreciate your help.
It's good enugh. I've added CODE tags for you.
shanefuture
Dublin, Ireland
C?ID=117562
Thank you and apologies with the mix up earlier on my first post i appreciate any and all help. Thanks.
I think I’m fixed !!!!!!
I got fixed about 20 years ago, but the first few days afterward weren't very pleasant. :eek:
Maybe you should elaborate. ;)
