13' Golf 2.5l No ECM Connection crank, no-start
your watermelon
C?ID=377340
2013 Golf No ECM Communication
car cranks but doesn't start. Has been doing it ever since a new sound system was installed. And yes I already unplugged all of it including the wiring and the actual head unit,same result. The shop put in fuses into the engine bay fuse box because apparently it was missing some. My guess is something is blocking a connection to the ECM somewhere here is the full scan.
Friday,23,August,2019,15:05:20:27550
VIN: WVWBB7AJ3DW130103   License Plate:
Mileage: 161110km-100109mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56
VIN: WVWBB7AJ3DW130103   Mileage: 161110km-100109miles
01-Engine -- Status: Cannot be reached 1100
1C-Position Sensing -- Status: Malfunction 0010
Address 01: Engine
   Part No SW: 09G 927 750 LM    HW: 09G 927 750 LM
   Component: AQ 250 6F           2252
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 074B9B8C932B8DDF8B3-8052
                    Fault Status: 00101101
                    Reset counter: 0
                    Mileage: 158823 km
                    Date: 2013.12.03
                    Time: 20:27:29
                    Reset counter: 190
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 00:00:07
                    Reset counter: 185
                    Mileage: 161117 km
                    Reset counter: 185
                    Mileage: 161117 km
18275 - Powertrain Data Bus
            P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
                    Reset counter: 185
                    Mileage: 161117 km
   Revision: 00H31001
   Coding: 114B400C492500FA880C02E4921C0041B70000
   VCID: 7DA7F964CDF7D70FA1F-8028
                    Reset counter: 108
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 00:00:43
                    Count: 2
                    Count: 12
                    Count: 20992
                    Count: 8208
                    Count: 44032
                    Count: 1
                    Count: 255
                    Reset counter: 108
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 00:00:43
                    Count: 2
                    Count: 12
                    Count: 20992
                    Count: 8233
                    Count: 44032
                    Count: 1
                    Count: 255
                    Reset counter: 108
                    Mileage: 160839 km
                    Date: 2013.12.31
                    Time: 00:00:48
                    Count: 2
                    Count: 12
                    Count: 29184
                    Count: 16390
                    Count: 49664
                    Count: 254
                    Reset counter: 108
                    Mileage: 161116 km
                    Date: 2014.01.11
                    Time: 17:44:25
                    Count: 12
                    Count: 20992
                    Count: 8194
                    Count: 44800
                    Count: 1
                    Count: 255
   Part No SW: 7N0 907 426 BG    HW: 7N0 907 426 BG
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010002002
   VCID: 7AADF278DC59E03784D-802E
          U1111 00 [009] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Fault Frequency: 82
                    Reset counter: 108
                    Mileage: 161116 km
                    Date: 2019.08.21
                    Time: 17:44:26
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Bremsensteuergerät - kein Signal/Kommunikation]
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 00:00:06
13701408 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Diagnoseinterface für Datenbus - kein Signal/Kommunikation]
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 00:00:42
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 00:00:42
13701488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Türsteuergerät Fahrerseite - kein Signal/Kommunikation]
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 23:25:39
9481748 - High Pressure Sensor
          B10AE 14 [008] - Open or Short to Ground
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.23
                    Time: 01:07:29
   Part No SW: 1K0 937 084 J    HW: 1K0 937 084 J
   Component: BCM PQ35  B   111 0709
   Revision: AC111709
   Coding: 6F180A1A90272A04008800C11000044448010386424D8960648020200040
   VCID: 35372144B547CF4F29F-8060
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 04021  26  0512
   Coding: 009795
24 Faults Found:
01495 - Bulb for High-Beams; Left (M30)
                    Fault Status: 00101010
                    Fault Frequency: 8
                    Reset counter: 143
                    Mileage: 160746 km
                    Date: 2013.12.30
                    Time: 14:35:59
                    Voltage: 14.05 V
                        Term 50 Off
                    Fault Status: 00101110
                    Reset counter: 146
                    Mileage: 133390 km
                    Date: 2018.03.23
                    Time: 22:20:42
                    Voltage: 14.10 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 159049 km
                    Date: 2013.12.06
                    Time: 11:14:35
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 108
                    Mileage: 161116 km
                    Date: 2014.01.11
                    Time: 17:44:26
                    Voltage: 12.65 V
                        Term 50 Off
                    Fault Status: 01101010
                    Reset counter: 108
                    Mileage: 153141 km
                    Date: 2013.09.24
                    Time: 15:33:29
                    Voltage: 13.90 V
                        Term 50 Off
                    Reset counter: 146
                    Mileage: 153141 km
                    Date: 2013.09.24
                    Time: 17:52:17
                    Voltage: 14.10 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161116 km
                    Date: 2014.01.11
                    Time: 18:03:06
                    Voltage: 12.60 V
                        Term 50 Off
                    Reset counter: 146
                    Mileage: 153141 km
                    Date: 2013.09.24
                    Time: 19:16:14
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161116 km
                    Date: 2014.01.11
                    Time: 18:03:17
                        Term 15 Off
                    Voltage: 12.65 V
                        Term 50 Off
00927 - Terminal 30 (Right)
                    Reset counter: 108
                    Mileage: 160979 km
                    Date: 2014.01.07
                    Time: 00:02:23
                        Term 15 Off
                    Voltage: 12.60 V
                        Term 50 Off
02391 - Terminal 30 Reference
                    Reset counter: 108
                    Mileage: 160979 km
                    Date: 2014.01.07
                    Time: 00:21:11
                        Term 15 Off
                    Voltage: 12.70 V
                        Term 50 Off
                    Reset counter: 147
                    Mileage: 153141 km
                    Date: 2013.09.24
                    Time: 19:53:23
                    Voltage: 13.95 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 148
                    Mileage: 160979 km
                    Date: 2014.01.07
                    Time: 01:26:25
                    Voltage: 12.50 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 00:00:07
                    Voltage: 12.55 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 00:00:43
                    Voltage: 12.55 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 00:02:05
                    Voltage: 12.55 V
                        Term 50 Off
01516 - Terminal 30; Left
                    Fault Status: 00101011
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 21:26:44
                        Term 15 Off
                    Voltage: 12.60 V
                        Term 50 Off
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 108
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 21:45:10
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 23:25:37
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.12
                    Time: 02:14:49
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.12
                    Time: 02:15:06
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.12
                    Time: 02:16:28
                    Voltage: 11.95 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.13
                    Time: 01:07:30
                    Voltage: 12.30 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.13
                    Time: 01:07:31
                    Voltage: 12.35 V
                        Term 50 Off
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R01K09%
   Coding: 00004737
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C21346096ED1E07D61-8068
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00006HUQ00
   Serial number: 3572MSME2B2E5076ZZZ/
   Serial number: 3582MSME48325376ZZZW
   Serial number: 3512QSME5E1C2B35ZZZ1
   Serial number: 3522QSME74572B48ZZZ/
   Serial number: 35527SME2F66272FZZZV
   Serial number: 35627SME3946272FZZZP
12670208 - No Communication with Instrument Cluster
          U0155 00 [008] - -
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 00:00:42
12656896 - No Communication with ABS Brake Control Module
          U0121 00 [008] - -
          [Lost Communication With Vehicle Dynamics Control Module]
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 00:00:06
12666368 - No Communication with Diagnostic Gateway
          U0146 00 [008] - -
          [Lost Communication With Gateway]
                    Reset counter: 148
12674816 - Immobilizer Control Module
          U0167 00 [008] - No Communications
          [Lost Comminication with Immobilizer]
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 00:00:42
   Part No SW: 5K0 953 507 AE    HW: 5K0 953 549
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90440MC5001F4
   Coding: 5880140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 73B3DF5CFB33917FC7B-8026
0516 - Databus
                    Fault Frequency: 9
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.22
                    Time: 02:16:26
332564 - Databus
                    Reset counter: 0
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 00:00:42
332580 - Databus
                    Reset counter: 0
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 00:00:42
332596 - Databus
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 00:00:42
   Part No SW: 5K0 920 973 B    HW: 5K0 920 973 B
   Component: KOMBI         H05 0705
   Coding: 270F01
   VCID: 303910504AA5EA677A9-8064
9453074 - Fuel Level Sensor 1
          B103E 1B [008] - Resistance Too High
                    Reset counter: 148
12604928 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [008] - Performance
          [Datenbus Kombi/Fahrwerk: keine Kommunikation]
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 00:00:42
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Motor: keine Kommunikation]
                    Reset counter: 108
                    Mileage: 161116 km
                    Date: 2019.08.21
                    Time: 17:44:25
12648704 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Getriebe: keine Kommunikation]
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.22
                    Time: 02:16:27
12656896 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Bremse: keine Kommunikation]
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 00:00:06
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 020313F1001346
   Coding: 350000
   VCID: 74B1DC40FEBD9647DE1-8020
                    Reset counter: 108
                    Mileage: 161117 km
                    Date: 2014.01.13
                    Time: 23:25:27
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         002 0002
   Revision: 00002000    Serial number: 1225223RMTXE07
   Coding: 0000002
   VCID: 7EA5FE68CCF1CC17B85-802A
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 00:00:43
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 00:00:43
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.13
                    Time: 01:07:35
   Component: IMMO          H05 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC238ACF950B774D-803E
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 138601 km
                    Date: 2018.06.17
                    Time: 00:05:07
13762816 - Databus
          U1201 00 [008] - No Communications
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 00:00:42
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2117
   Coding: 0001076
   VCID: 313F15544D2FE36F757-8064
00912 - Window Regulator Switch; Front Left (E40)
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   VCID: 372B2B4CA34B3D5F3B3-8062
                    Reset counter: 108
                    Mileage: 161116 km
                    Date: 2014.01.11
                    Time: 17:44:26
                    Voltage: 12.50 V
                        DU
                    Temperature: 47.0°C
                    RPM: 1498 /min
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.13
                    Time: 00:01:37
                    Voltage: 12.13 V
                        DU
                    Temperature: 30.0°C
                    RPM: 1498 /min
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 00:02:02
                    Voltage: 12.38 V
                        DU
                    Temperature: 47.0°C
                    RPM: 1498 /min
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.5 V
                        PD
                    Temperature: 42.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001076
   VCID: 323D1A584829D8770CD-8066
Address 56: Radio        Labels:
   VCID: 55F781C41C07EF4FC9F-FFFE
End----------(Elapsed Time: 01:05, VBatt start/end: 12.5V/12.5V)-----------
Friday,23,August,2019,18:52:04:27550
Dealer/Shop Name: Jared's Shop
Address 01: Engine
   Coding: 0000840
                    Reset counter: 197
                    Mileage: 161117 km
                    Date: 2014.01.10
                    Time: 00:00:07
                    Reset counter: 165
                    Mileage: 161117 km
                    Reset counter: 165
                    Mileage: 161117 km
                    Reset counter: 165
                    Mileage: 161117 km
   Revision: 00H31001
                    Reset counter: 108
                    Mileage: 161117 km
                    Date: 2014.01.10
                    Time: 00:00:43
                    Count: 2
                    Count: 12
                    Count: 20992
                    Count: 8208
                    Count: 44032
                    Count: 1
                    Count: 255
                    Reset counter: 108
                    Mileage: 161117 km
                    Date: 2014.01.10
                    Time: 00:00:43
                    Count: 2
                    Count: 12
                    Count: 20992
                    Count: 8233
                    Count: 44032
                    Count: 1
                    Count: 255
                    Fault Status: 00101100
                    Reset counter: 108
                    Mileage: 161117 km
                    Date: 2014.01.13
                    Time: 00:03:43
                    Count: 2
                    Count: 12
                    Count: 20992
                    Count: 105
                    Count: 44032
                    Count: 255
                    Reset counter: 108
                    Mileage: 160839 km
                    Date: 2013.12.30
                    Time: 00:00:48
                    Count: 2
                    Count: 12
                    Count: 29184
                    Count: 16390
                    Count: 49664
                    Count: 254
                    Reset counter: 108
                    Mileage: 161116 km
                    Date: 2014.01.10
                    Time: 17:44:25
                    Count: 12
                    Count: 20992
                    Count: 8194
                    Count: 44800
                    Count: 1
                    Count: 255
   Revision: 00001018
   Coding: 0010002002
          U1111 00 [009] - -
                    Fault Frequency: 91
                    Reset counter: 108
                    Mileage: 161116 km
                    Date: 2019.08.20
                    Time: 17:44:26
          U1111 00 [008] - -
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.20
                    Time: 00:00:06
          U1111 00 [008] - -
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.20
                    Time: 00:00:42
          U1111 00 [008] - -
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.20
                    Time: 00:00:42
          U1111 00 [008] - -
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.20
                    Time: 23:25:39
                    Fault Frequency: 9
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.22
                    Time: 01:07:29
   Revision: AC111709
   Coding: 009795
25 Faults Found:
                    Fault Frequency: 8
                    Reset counter: 143
                    Mileage: 160746 km
                    Date: 2013.12.29
                    Time: 14:35:59
                    Voltage: 14.05 V
                        Term 50 Off
                    Reset counter: 146
                    Mileage: 133390 km
                    Date: 2018.03.22
                    Time: 22:20:42
                    Voltage: 14.10 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 159049 km
                    Date: 2013.12.05
                    Time: 11:14:35
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 108
                    Mileage: 161116 km
                    Date: 2014.01.10
                    Time: 17:44:26
                    Voltage: 12.65 V
                        Term 50 Off
                    Reset counter: 108
                    Mileage: 153141 km
                    Date: 2013.09.23
                    Time: 15:33:29
                    Voltage: 13.90 V
                        Term 50 Off
                    Reset counter: 146
                    Mileage: 153141 km
                    Date: 2013.09.23
                    Time: 17:52:17
                    Voltage: 14.10 V
                        Term 50 Off
                    Fault Frequency: 14
                    Reset counter: 148
                    Mileage: 161116 km
                    Date: 2014.01.10
                    Time: 18:03:06
                    Voltage: 12.60 V
                        Term 50 Off
                    Reset counter: 146
                    Mileage: 153141 km
                    Date: 2013.09.23
                    Time: 19:16:14
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161116 km
                    Date: 2014.01.10
                    Time: 18:03:17
                        Term 15 Off
                    Voltage: 12.65 V
                        Term 50 Off
                    Fault Frequency: 8
                    Reset counter: 108
                    Mileage: 160979 km
                    Date: 2014.01.06
                    Time: 00:02:23
                        Term 15 Off
                    Voltage: 12.60 V
                        Term 50 Off
                    Reset counter: 108
                    Mileage: 160979 km
                    Date: 2014.01.06
                    Time: 00:21:11
                        Term 15 Off
                    Voltage: 12.70 V
                        Term 50 Off
                    Reset counter: 147
                    Mileage: 153141 km
                    Date: 2013.09.23
                    Time: 19:53:23
                    Voltage: 13.95 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 160979 km
                    Date: 2014.01.06
                    Time: 01:26:25
                    Voltage: 12.50 V
                        Term 50 Off
                    Fault Frequency: 9
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.10
                    Time: 00:00:07
                    Voltage: 12.55 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.10
                    Time: 00:00:43
                    Voltage: 12.55 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.10
                    Time: 00:02:05
                    Voltage: 12.55 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.10
                    Time: 21:26:44
                        Term 15 Off
                    Voltage: 12.60 V
                        Term 50 Off
                    Reset counter: 108
                    Mileage: 161117 km
                    Date: 2014.01.10
                    Time: 21:45:10
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.10
                    Time: 23:25:37
                    Voltage: 12.00 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 02:14:49
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 02:15:06
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.11
                    Time: 02:16:28
                    Voltage: 11.95 V
                        Term 50 Off
                    Fault Frequency: 8
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.12
                    Time: 01:07:30
                    Voltage: 12.30 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.12
                    Time: 01:07:31
                    Voltage: 12.35 V
                        Term 50 Off
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.13
                    Time: 00:00:01
                        Term 15 Off
                    Voltage: 12.55 V
                        Term 50 Off
   Coding: 00004737
          U0155 00 [008] - -
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.20
                    Time: 00:00:42
          U0121 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.20
                    Time: 00:00:06
          U0146 00 [008] - -
                    Reset counter: 148
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.20
                    Time: 00:00:42
   Coding: 5880140000
0516 - Databus
                    Fault Frequency: 9
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 02:16:26
332564 - Databus
                    Reset counter: 0
                    Mileage: 161117 km
                    Date: 2019.08.20
                    Time: 00:00:42
332580 - Databus
                    Reset counter: 0
                    Mileage: 161117 km
                    Date: 2019.08.20
                    Time: 00:00:42
332596 - Databus
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.20
                    Time: 00:00:42
   Coding: 270F01
                    Reset counter: 148
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.20
                    Time: 00:00:42
          U1111 00 [009] - -
                    Reset counter: 108
                    Mileage: 161116 km
                    Date: 2019.08.20
                    Time: 17:44:25
          U1111 00 [008] - -
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.21
                    Time: 02:16:27
          U1111 00 [008] - -
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.20
                    Time: 00:00:06
   Coding: 350000
                    Reset counter: 108
                    Mileage: 161117 km
                    Date: 2014.01.12
                    Time: 23:25:27
                    Fault Status: 00110100
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.13
                    Time: 00:00:10
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.13
                    Time: 01:49:27
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.13
                    Time: 01:49:27
01304 - Radio
                    Reset counter: 108
                    Mileage: 161117 km
                    Date: 2014.01.13
                    Time: 00:01:14
   Coding: 0000002
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.10
                    Time: 00:00:43
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.10
                    Time: 00:00:43
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.13
                    Time: 00:00:14
9456681 - Key
                    Mileage: 138601 km
                    Date: 2018.06.16
                    Time: 00:05:07
13762816 - Databus
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2019.08.20
                    Time: 00:00:42
   Coding: 0001076
   Revision: 00H22000
                    Reset counter: 108
                    Mileage: 161116 km
                    Date: 2014.01.10
                    Time: 17:44:26
                    Voltage: 12.50 V
                        DU
                    Temperature: 47.0°C
                    RPM: 1498 /min
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.13
                    Time: 00:00:09
                    Voltage: 12.38 V
                        DU
                    Temperature: 36.0°C
                    RPM: 1498 /min
                    Reset counter: 148
                    Mileage: 161117 km
                    Date: 2014.01.10
                    Time: 00:02:02
                    Voltage: 12.38 V
                        DU
                    Temperature: 47.0°C
                    RPM: 1498 /min
            000 - - - MIL ON
                        PD
                    Temperature: 42.0°C
                    Count: 2
                    Count: 1
                        SteerAng n.Init
   Coding: 0001076
Address 56: Radio
End----------(Elapsed Time: 00:52, VBatt start/end: 12.2V/12.2V)-----------
Engine is also not reading at all and a lot of other errors most likely caused by the ECM not talking what could it be?:popcorn:
Jef
HQ
Thank you for posting the full Auto-Scan! :thumbs:
For any control module to communicate, you MUST have the following:
Lets start with the barest of bones basics... fuses. You need to verify they are to factory design.
SB6, SB7, SB10, SB13
There are more, but I think those will be the starting point. TAKE PHOTOS of your fuse box before you touch it!!! Then pull those fuses out, one at a time, make sure they are good, no signs of hot spots, melting, ect. Maybe even swap them around with another fuse of the same value. Then make sure things look like the photo. More than once, or twice... or the number of fingers on my hands, people pull fuses out to inspect and then put back in the wrong location making things worse... don't be "that guy". :banghead:
I would also suggest you get the factory wiring diagram for your vehicle from erwin.vw.com. Purchase the cheapest option and then print to PDF the living crap out of EVERYTHING you can get your hands on, that way you have it after the subscription expires.
Report back on your fuses and we'll dig deeper if needed. If you are unsure of anything, just ask and the forum's jackass, Jack, will chime in. :rolleyes: He means well, just some times his medication needs to be adjusted.
your watermelon
C?ID=377340
Thank you! turns out the shop moved a lot of fuses around (almost all of them in a different place). "Re-located" them and boom car started right up:thumbs: You're the man!
Jef
HQ
... that guy.... always causing more problems than solutions.
