hello everyone,
this is my first post here and i just want to congratulate you on a great and very informative forum you are running, one that i have been following for a while. unfortunately my first post is about a problem that i have with my car that has been going on for a while, and i have been unsuccessful in resolving it.
what basically happens with the car is that from time to time the entire DIS cluster will light up with errors from most modules/ECUs (parking brake, adaptive suspension, engine, headlights, braking guard etc...). most of the systems go in limp mode when this happens. the errors rarely disappear on their own, sometimes after i turn off and start the car again, but most often after i turn off the car and disconnect and reconnect the cable to the ABS ECU. these errors can happen often (several times a day) or very rare (i have gone 6 months without errors on one occasion), and i'm unable to find a pattern here. also, it's not a rule, but often the errors will start to appear when driving on a rough road or driving over a road hole/bump.
i have had it scanned on million occasions and as you can see from the autoscan below, most modules point towards lost communication with the ABS. on several occasions, the ABS was not even reachable when scanning with VCDS/ODIS.
curiously, disconnecting and reconnecting the cable to the ABS ECU ALWAYS resolves the problem, albeit temporarily.
at a certain point i was sure the ABS connector was faulty, so i rebuilt it with new contacts. this did not solve the problem, but what changed after rebuilding the connector is that when errors appeared they lasted very briefly and disappeared by themselves. this made me even more certain it's the connector, however this time i was sure the contacts are inappropriate (by design), considering their minimal contact area. so i decided to bypass the ABS connector using female spade connectors on the ECU side (which are very tight and i'm certain don't come loose during driving. in fact the ABS connector now can't be removed without first detaching the ECU from the ABS pump - it's that tight). to be able to disconnect the ABS in emergency, i have split the cable downstream into 3 smaller connectors (one for the power cables, and two for the 21 data connections). this worked for several months, but few days ago coming back from holiday the same errors reappeared with a vengeance. i can now start doubting the 3 new connectors i introduced downstream, but i think at this point this is becoming pointless and it's not the connectors at all?!?!
i have also opened the ABS ECU, and checked (physically and with multimeter) each and every connection that can be checked - no connections are broken and they all show minimal resistance. bare in mind, there are also a lot of microscopic connections in the ECU, covered in silicone. i don't think anyone can check these, certainly not me at home with a multimeter. however, my subjective opinion is that the ECU is well built, and the fault is not in any broken connections. besides, disconnecting and reconnecting the ABS cable will not mend broken connections in the ECU each and every time.
i have also checked the CAN wiring directly on the ABS connector, CAN high gives 2.7V, CAN low 2.3V and 60 ohms resistance between the two, exactly as per spec.
reading a lot of stuff on different forums i have come across some thoughts/suggestions that such problems can be caused by rusted/loose negative connections to the chassis, however i have no idea where these cables are bolted to the chassis and where to check for rust?
also, somebody suggested that the problem is within the ABS electronics, i.e. some of the chips there becomes stuck (like a memory overflow or some loop in software routines). disconnecting the power to the ECU clears the memory and the module starts functioning normally. this sounds logical, but as i mentioned before, sometimes errors resolve without even turning off the car. furthermore, somebody has also pointed that a faulty ABS sensor can feed junk data to the ABS ECU, leading to the above condition. as far as i can understand these sensors are analogue, giving voltage values to the ECU and there is no real "data" there? but is it possible that some other sensor (like lane keeping camera, or ACC radars) can really feed junk data that can block the ECU?
anyways, here are two autoscans from the last two times this has happened, maybe someone can see and understand something in them that i don't...
the car is euro spec AUDI A6 C7 (my 2011) 3.0 TDI 245HP quattro with 7-speed DCT.
sorry for the lengthy post, but i tried to sum up everything from the past year.
Tuesday,20,August,2019,14:36:07:30584
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4G0BN016789 License Plate:
Mileage: 144670km-89893mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
44 46 47 52 53 55 56 5F 62 6C 6D 72 85 88 89 8B 8E 8F 90
VIN: WAUZZZ4G0BN016789 Mileage: 144670km-89893miles
3B-Sensor Elect. -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CDUC) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0007
Revision: 53H37---
Coding: 0A254012046601020000
Shop #: WSC 28918 001 1048576
ASAM Dataset: EV_ECM30TDI0114G0907401F 001007
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 26150B6138607AB7905-8072
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [040] - -
Fault Frequency: 20
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:23
Engine speed: 2239.50 /min
Normed load value: 43.1 %
Vehicle speed: 92 km/h
Coolant temperature: 87 °C
Intake air temperature: 33 °C
Voltage terminal 30: 14.080 V
ACC target acceleration: 0.000 m/s²
ACC control module received status-Bits 0-7: 0
Active brake system error status-Bits 0-7: 33
Status of ACC/CCS acceleration interface-Bits 0-7: 0
Acceleration: 1.114 m/s²
Engine status: COENG_RUNNING
4660 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [040] - -
[Software Incompatibility with Anti-Lockplease read DTC]
Fault Frequency: 21
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:23
Engine speed: 2222.50 /min
Normed load value: 65.5 %
Vehicle speed: 90 km/h
Voltage terminal 30: 14.040 V
Acceleration: 0.991 m/s²
7136 - No Communication with ABS Brake Control Module
U0121 00 [032] - -
[Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
Fault Frequency: 15
Mileage: 144670 km
Date: 2019.08.20
Time: 14:01:21
Engine speed: 1184.00 /min
Vehicle speed: 255 km/h
Coolant temperature: 84 °C
Intake air temperature: 40 °C
Voltage terminal 30: 13.900 V
Cruise Control System (CCS): status-Bits 0-7: 209
selected gear-Bits 0-7: 4
4713 - No Communication with ABS Brake Control Module
U0121 00 [168] - -
Fault Frequency: 7
Mileage: 144640 km
Date: 2019.08.20
Time: 13:40:00
Engine speed: 1653.50 /min
Normed load value: 56.5 %
Coolant temperature: 85 °C
Intake air temperature: 38 °C
Voltage terminal 30: 13.660 V
Cruise Control System (CCS): status-Bits 0-7: 17
selected gear-Bits 0-7: 5
Readiness: 1 1 0 0 0
Part No SW: 4G2 927 156 H HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H03 0002
Revision: --H03--- Serial number: 0000000467
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501021 A03005
ROD: EV_TCMDL501021_A03.rod
VCID: 3333E235FBB21F1F07B-8066
18148 - No Communication with ABS Brake Control Module
U0121 00 [040] - -
Fault Frequency: 20
Reset counter: 40
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Engine speed: 1541 /min
Transmission input speed: 1541 /min
Transmission output speed: 511 /min
Engine torque: -48 Nm
Transmission fluid temperature: 89 °C
Accelerator position: 0.0 %
Clutch status: Kupplung 1 kann Moment übertragen
Voltage terminal 30: 14.300 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.923 V
Part No SW: 4G0 907 379 B HW: 4G0 907 379 B
Component: ESP PREMIUM H09 0190
Coding: 27A6C700E465E300DB00
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_003.rod
VCID: 3039ED390AA424077A9-8064
0486 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Ldm_ApbFailureState]
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:35:11
VzRef: 00
Bit Info 1: 80
Bit Info 2: 2F
Bit Info 3: 20
Bit Info 4: 1F
F-Path: 02
F-Type: 06
Uz: A5
0519 - FlexRay Databus
U1031 00 [008] - No Synchronization
[NET09_SyncLost_FlxrA]
Fault Frequency: 8
Reset counter: 134
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:22
VzRef: 58
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 26
Bit Info 4: 1F
F-Path: 00
F-Type: 6E
Uz: B8
Part No SW: 4H0 907 064 AP HW: 4H0 907 064 AP
Component: BCM2 2.0 H24 0217
Coding: 01A83000000000000000
VCID: 77AB1625AFCA333FFB3-8022
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000034114014
Fault Status: 00101101
Fault Frequency: 19
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Part No SW: 4G8 959 760 B HW: 4G8 959 760 B
Component: MEM-BFS H04 0153
Revision: AA000000 Serial number: 00001002306755
Coding: 0018320000006201000001010101112030303333283333
VCID: 392FD01DD95EE54FCD7-806C
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H11 0056
Serial number: 17021100040422
Coding: 360100B824
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AirCondiComfoUDS 002029
VCID: 270B06653F6A63BFAB3-8072
0247 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Motorsteuergerät: Fehlerspeicher auslesen]
Fault Frequency: 7
Reset counter: 134
Mileage: 144571 km
Date: 2019.08.20
Time: 09:45:47
Outside air temperature: 29.0 °C
Engine speed: 1987 /min
Vehicle speed: 87.00 km/h
0330 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Bremsensteuergerät: kein Signal/keine Kommunikation]
Fault Frequency: 16
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
Voltage terminal 30: 14.32 V
Outside air temperature: 28.5 °C
Engine speed: 1740 /min
0369 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Spurhalteassistent: kein Signal / Kommunikation]
Fault Frequency: 26
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Voltage terminal 30: 14.34 V
Engine speed: 1648 /min
Part No SW: 4H0 907 063 N HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0092
Revision: 20012002 Serial number: 00000000961257
Coding: 0200201150B48FE2C981008380001908CF9CC3082E080101000008402100
VCID: 3333E235FB321F1F07B-8066
Component: WWS57X 110213 H32 0051
Serial number: 110214102924
Coding: 0045F7
Component: RLS H04 0003
Serial number: 11300730
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 28 02 2011 00000056
Component: AQ_Hum_Sensor H02 0002
Serial number: 5C080495000000000001
01316 - ABS Control Module
Fault Frequency: 14
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:00
Fault Frequency: 6
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:00
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
VCID: 231312754BD28F9FF7B-8076
02283 - Video Connection to Output [End Unit]
Fault Status: 00101011
Fault Frequency: 23
Reset counter: 131
Part No SW: 4H0 919 475 H HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0030
Revision: 11001001 Serial number: 55901105301116
Coding: 302B05
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod
VCID: 372BD625EFCAF33F3B3-8062
12656912 - Databus
[Bremsensteuergerät - ESP_01 - kein Signal/keine Kommunikation]
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
Part No SW: 4G0 907 561 HW: 4G0 907 561
Component: ACC3 H15 0160
Coding: 3E04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 001003
ROD: EV_AdaptCruisContrAU57X_001.rod
VCID: 678B4665FFEAA3BF6B3-8032
10 Faults Found:
23552 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_07]
Reset counter: 134
Mileage: 144668 km
Date: 2019.08.20
Time: 13:55:11
Control Module temperature: 39 °C
Voltage terminal 15: 14.015 V
Velocity_vehicle_reference: 32.59 m/s
Longitudinal_acceleration_vehicle_reference: -0.38 m/s²
23808 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_08]
Reset counter: 134
Mileage: 144668 km
Date: 2019.08.20
Time: 13:55:11
24064 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_Master]
Reset counter: 134
Mileage: 144652 km
Date: 2019.08.20
Time: 13:46:22
Voltage terminal 15: 14.003 V
Velocity_vehicle_reference: 31.88 m/s
Longitudinal_acceleration_vehicle_reference: -0.02 m/s²
25856 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_BVObjekt_07]
Reset counter: 134
Mileage: 144670 km
Date: 2019.08.20
Time: 14:01:18
Control Module temperature: 47 °C
Voltage terminal 15: 14.082 V
Velocity_vehicle_reference: 23.44 m/s
Longitudinal_acceleration_vehicle_reference: -3.42 m/s²
26880 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_BVOBMaster]
Reset counter: 134
Mileage: 144670 km
Date: 2019.08.20
Time: 14:01:18
27136 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_BVS_STATUS]
Reset counter: 134
Mileage: 144670 km
Date: 2019.08.20
Time: 14:01:18
77056 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_BV_TIME]
Fault Frequency: 16
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Control Module temperature: 33 °C
Voltage terminal 15: 14.320 V
Velocity_vehicle_reference: 20.66 m/s
Longitudinal_acceleration_vehicle_reference: -0.62 m/s²
105984 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_EPB_FAIL]
Reset counter: 134
Mileage: 144670 km
Date: 2019.08.20
Time: 14:02:28
Control Module temperature: 46 °C
Voltage terminal 15: 12.617 V
Velocity_vehicle_reference: -0.01 m/s
140288 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_ECD_FAIL]
Reset counter: 134
Mileage: 144670 km
Date: 2019.08.20
Time: 14:02:34
Voltage terminal 15: 12.563 V
145152 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_SWA_FAIL]
Reset counter: 134
Mileage: 144670 km
Date: 2019.08.20
Time: 14:02:28
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG001PWX0
Coding: 30323436313330303335554A304C34473053
VCID: 3635DB21E8C00A37205-8062
Serial number: 3575HRB404T0ATOCBP08
Serial number: 3585HRB404T07OTS504
Serial number: 3515JRB406109GGSBG6C
Serial number: 3525JRB406909GGSAPL1
Serial number: 3554VRB40516PGAKJ92V
Serial number: 3564VRB404T6PGAKIPB/
7 Faults Found:
1048832 - Databus
[CAN: 0x100 ESP_01 Timeout]
Fault Frequency: 15
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
1049088 - Databus
[CAN: 0x101 ESP_02 Timeout]
Fault Frequency: 15
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
1049093 - Databus
[CAN: 0x101 ESP_02 error value ESP_Querbeschleunigung]
Fault Frequency: 8
Reset counter: 134
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:23
1049094 - Databus
[CAN: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
Fault Frequency: 8
Reset counter: 134
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:23
1049095 - Databus
[CAN: 0x101 ESP_02 error value ESP_Gierrate]
Fault Frequency: 8
Reset counter: 134
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:23
1049344 - Databus
[CAN: 0x103 ESP_03 Timeout]
Fault Frequency: 15
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
1049866 - Databus
[CAN: 0x39C Gateway_05 Old value from ESP_07]
Fault Frequency: 9
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:54
Component: Lenks.Modul H03 0003
Revision: -------- Serial number: 90372KBP0020B
Coding: 0000FC
VCID: 372BD625EF4AF33F3B3-8062
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0009
Serial number: 05 05 2012 C0063401
Fault Frequency: 19
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Part No SW: 4G8 920 930 T HW: 4G8 920 930 T
Component: TDieRdwAcc H34 0309
Revision: 19100073 Serial number: 658180211593030
Coding: 138E09005F050008000000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU57.rod
VCID: 3E25C301C0F0C277F85-806A
16776968 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[ESP_02 keine Kommunikation]
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
16776969 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[LDW_02_FR keine Kommunikation]
Fault Frequency: 21
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
16776973 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[RDK_01 keine Kommunikation]
Fault Frequency: 7
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
16776980 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[VZE_01 keine Kommunikation]
Fault Frequency: 21
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000104008
Coding: 00CD077D00
ROD: EV_GatewUDS_AU57.rod
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650619708
Voltage stabilizer:
Serial number: 11045001033011200410
6653 - Image processing control module
U1079 00 [008] - No communication
Fault Frequency: 19
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
Voltage terminal 30: 14.4 V
Voltage terminal 15: 14.4 V
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
4352 - ABS Control Module on FlexRay Data Bus
U10BD 00 [008] - No Communication
[Lost Communication With Vehicle Dynamics Control Module]
Fault Frequency: 22
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
Voltage terminal 30: 14.3 V
Voltage terminal 15: 14.3 V
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
Part No SW: 4G0 919 158 D HW: 4G0 919 158 D
Component: KLIMA FOND H07 0056
Serial number: 19021100040082
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
0136 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 17
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
Voltage terminal 30: 14.41 V
Part No SW: 4G0 907 553 B HW: 4G0 907 553
Component: LUFE-DAEMPFER H17 0778
Coding: 008002
ROD: EV_AirSuspe_VW51.rod
VCID: 2A0DFF512C785ED7B4D-807E
0008 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 13
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
0009 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 13
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
0006 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 11
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
0007 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 9
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
0648 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
Fault Frequency: 10
Reset counter: 134
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:23
Component: MEM-FS H04 0153
Revision: AA000000 Serial number: 00001002306757
Coding: 0018330000016201000001010101112030303333203333
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200DZ160
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D07F44D1D9649EF51F-8078
3801346 - Function Restricted due to Missing Message(s)
U1111 00 [044] - -
[Internal Monitoring (MSG)]
Fault Frequency: 22
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
DCU Temperature: 46 °C
Voltage Clamp 15: 14.7 V
Voltage Clamp 30: 14.4 V
Ignition Cycle Count: 50068
WAUZZZ4G0BN016789
Part No SW: 4G0 907 566 C HW: 4G0 907 566
Component: J769 SWA MasterH01 0020
Revision: 00H01000 Serial number: 6PZ 010 287-01
Coding: 0000101
VCID: 2F3BEE451B1A3BFF633-807A
Subsystem 1 - Part No: 4G0 907 568 C
Component: J770 SWA Slave H01 0020
Subsystem 2 - Serial number: 6PZ 010 287-21
Subsystem 3 - Serial number: 5F01.03.1100H010003CD21904ÿ
Subsystem 4 - Serial number: D21904ÿ
Reset counter: 134
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:23
Fault Frequency: 21
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
Part No SW: 4G8 959 793 B HW: 4G8 959 793
Component: TSG FA H04 0210
Coding: 011F06205E00628202080003
Shop #: WSC 02312 785 00200
VCID: 3FDBBE05C77ACB7FF33-806A
Fault Frequency: 6
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:57
Part No SW: 4G0 909 144 L HW: 4G0 909 144 F
Component: RCEPS H32 0010
Revision: 00001000 Serial number: 0024040880
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323DE73104A816170CD-8066
3158273 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Ausfall Botschaft "PDU_ESP_01"]
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Write only channel
3158336 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Ausfall Botschaft "PDU_HCA_01"]
Fault Frequency: 19
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Write only channel
Revision: 00002001 Serial number: 0144584148
Coding: 0100062000B93480832008040C0100000000000000000000000000000000
Fault Frequency: 19
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Part No SW: 4G0 035 223 A HW: 4G0 035 223 A
Component: BOSE G3 C7 H07 0070
Revision: CJ007000 Serial number: 00000000023919
VCID: 1B632A9573A2B75F3FB-804E
Reset counter: 134
Mileage: 144581 km
Date: 2019.08.20
Time: 09:52:37
Bin. Bits: 00001000
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
Coding: 011F06205E00628202080002
Fault Frequency: 6
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:57
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000046518
ROD: EV_ParkiBrake_VW51.rod
328448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_ESP_01_MESSAGE_TIMEOUT]
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
Internal Fault ID: 89
Vehicle speed: 74 km/h
Network management state: normal
Function light in parking brake button: OFF
Red operating lamp: OFF
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: Dynamic
Status of parking brake button: Not operated
Status ParkingBrake left: Open
Status ParkingBrake right: Open
328704 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_ESP_02_MESSAGE_TIMEOUT]
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
Internal Fault ID: 90
RWU: not active
DSD: not active
HTR: not active
ECD: not active
328960 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_ESP_03_MESSAGE_TIMEOUT]
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
Internal Fault ID: 91
RWU: not active
DSD: not active
HTR: not active
ECD: not active
329216 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FC_ESP_05_MESSAGE_TIMEOUT]
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
Internal Fault ID: 92
RWU: not active
DSD: not active
HTR: not active
ECD: not active
459264 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FC_SIGNAL_ESP_LAENGSBESCHL_ERROR_VALUE]
Fault Frequency: 8
Reset counter: 134
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:23
Internal Fault ID: 138
Vehicle speed: 510 km/h
Yellow warning lamp: OFF
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Internal Parking Brake state: Emergency running mode
463616 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
Fault Frequency: 8
Reset counter: 134
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:23
Internal Fault ID: 185
Vehicle speed: 88 km/h
RWU: not active
DSD: not active
HTR: not active
ECD: not active
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0011
Serial number: 110210-0004-037
Coding: 11216F33F91AEB00
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
H02 0006
Coding: 1D0000
H02 0006
Coding: 1D0000
0001 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Timeout CAN-Message ESP_02 (0x101)]
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
0061 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
[Fehlerhafter DLC der CAN-Messages Kamera_Status (0x318)]
Fault Frequency: 16
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:54
337156 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Timeout CAN-Message ESP_03 (0x103)]
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Part No SW: 4G0 035 053 J HW: 4G0 035 053
Component: Radio U Basic H52 0133
Revision: AB001007 Serial number: 050BO0B7544019
Coding: 010003010000000001
VCID: 25170C6D45E671AF99F-8070
Fault Frequency: 7
Reset counter: 134
Mileage: 144668 km
Date: 2019.08.20
Time: 13:55:24
Bin. Bits: 00000000 00000100
Part No SW: 4G0 035 670 Q HW: 4G0 035 670
Component: H-BNT-EU H46 1034
Revision: -------- Serial number: 428J80B7514996
Coding: 050100000003F9EF7D308B3E00000003080001000000000000
Shop #: WSC 28274 134 100328
VCID: 313FE83D012E2D0F757-8064
Subsystem 1 - Part No: 8R0 060 884 GA
Component: EUR 2019 2802
Subsystem 2 - Part No SW: 4G1 919 610 C HW: 4G1 919 612 L
Component: E380 BDT C7 H08 0204
Serial number: 90349KBP0006D
Subsystem 3 - Part No: 8R0 060 961 A
Component: CD-Database 2712
Reset counter: 134
Mileage: 144668 km
Date: 2019.08.20
Time: 13:55:24
Bin. Bits: 00000000 10000000
Bin. Bits: 00000010 00000000
Bin. Bits: 00000000 00000010
Bin. Bits: 00000000 00000000
02259 - Information Display and Control Head (Front) (J685)
Reset counter: 94
Mileage: 144670 km
Date: 2019.08.20
Time: 14:03:17
Voltage: 13.40 V
Fault Frequency: 18
Reset counter: 134
Mileage: 144670 km
Date: 2019.08.20
Time: 14:01:54
Bin. Bits: 00000000 01100000
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010F04204000628202080002
VCID: 42DDB7F1B488A6979CD-8016
Part No SW: 4G0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0050
Revision: --H04--- Serial number: 525 PA8J12F0CG
Coding: 1020004
VCID: 25170C6D49E671AF99F-8070
Fault Frequency: 17
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
Term 15 On
Reverse OFF
Count: 3
Part No SW: 4G5 959 107 HW: 4G5 959 107
Component: HDSG-Modul H01 0036
Revision: 13001001 Serial number: 046100202
Coding: 111104C000
ASAM Dataset: EV_HDSGAu571 001001
ROD: EV_HDSGAu571.rod
VCID: 6FBB2E45D71A7BFF233-803A
0044 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 6
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:56
Component: TSG HR H03 0210
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Coding: EE060000
ROD: EV_OnBoardCamerDPC.rod
VCID: 65974C6D05E6B1AF59F-8030
0703 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[ESP_timeout]
Fault Frequency: 23
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Outside air temperature: -36.0 °C
Voltage terminal 15: 14.1 V
Control Module temperature: 41.0 °C
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00456842018901
Coding: 662FF2
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F3BEE45179A3BFF633-807A
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00456842126601
Coding: 262FF2
Part No SW: 4G0 907 541 HW: 4G0 907 541
Coding: 3E04010202
ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
ROD: EV_AdaptCruisContr2AU57X_001.rod
10 Faults Found:
27904 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_ESP_02]
Fault Frequency: 19
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Voltage terminal 15: 14.332 V
Velocity_vehicle_reference: 20.48 m/s
Longitudinal_acceleration_vehicle_reference: -0.70 m/s²
28160 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_ESP_03]
Fault Frequency: 19
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
28416 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_ESP_05]
Reset counter: 134
Mileage: 144670 km
Date: 2019.08.20
Time: 14:01:19
Control Module temperature: 48 °C
Voltage terminal 15: 14.126 V
Velocity_vehicle_reference: 22.88 m/s
Longitudinal_acceleration_vehicle_reference: -0.57 m/s²
28672 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_ESP_07]
Reset counter: 134
Mileage: 144670 km
Date: 2019.08.20
Time: 14:01:21
Voltage terminal 15: 14.143 V
Velocity_vehicle_reference: 18.71 m/s
Longitudinal_acceleration_vehicle_reference: -0.14 m/s²
28928 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_ESP_08]
Fault Frequency: 25
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Voltage terminal 15: 14.255 V
Velocity_vehicle_reference: 20.52 m/s
Longitudinal_acceleration_vehicle_reference: -1.18 m/s²
94976 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_QDCPSS_FAIL]
Reset counter: 134
Mileage: 144668 km
Date: 2019.08.20
Time: 13:57:05
Control Module temperature: 41 °C
Voltage terminal 15: 13.697 V
Velocity_vehicle_reference: 1.68 m/s
105472 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_VDC_FAIL]
Reset counter: 134
Mileage: 144668 km
Date: 2019.08.20
Time: 13:57:05
U1113 00 [008] - -
Fault Frequency: 8
Reset counter: 134
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:23
Voltage terminal 15: 14.287 V
Velocity_vehicle_reference: 25.18 m/s
Longitudinal_acceleration_vehicle_reference: 1.65 m/s²
U1113 00 [008] - -
Reset counter: 134
Mileage: 144670 km
Date: 2019.08.20
Time: 14:02:34
Voltage terminal 15: 12.619 V
Velocity_vehicle_reference: -0.00 m/s
144896 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[FAULT_CIS_US_FAIL]
Fault Frequency: 18
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Voltage terminal 15: 14.337 V
Velocity_vehicle_reference: 20.39 m/s
Longitudinal_acceleration_vehicle_reference: -0.25 m/s²
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H28 0034
Serial number: 000040182202117
Coding: 04C0BB181111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 25170C6D456671AF99F-8070
7 Faults Found:
0028 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[ESP_ESP_01_Signal_Error]
Fault Frequency: 8
Reset counter: 134
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:24
Outside air temperature: 28.0 °C
Voltage terminal 15: 14.2 V
Control Module temperature: 42.0 °C
0063 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[SWA_Signal_error]
Fault Frequency: 8
Reset counter: 134
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:24
0121 - FlexRay Databus
[Halt-Fehler_/_Kompletter_Syncverlust]
Fault Priority: 9
Fault Frequency: 50
Reset counter: 134
Mileage: 144550 km
Date: 2019.08.20
Time: 09:32:22
0173 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[APS_Signal_Error_Master]
Reset counter: 134
Mileage: 144637 km
Date: 2019.08.20
Time: 13:37:50
Outside air temperature: 35.5 °C
Voltage terminal 15: 12.0 V
Control Module temperature: 0.0 °C
0091 - Function Limitation due to Missing Video Data
C1108 00 [008] - -
[DPC_SystemError]
Fault Frequency: 15
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
0179 - Development Code 4
B2F04 00 [008] - -
[MGT_task_stuck_bTask_HCA]
Fault Priority: 9
Fault Frequency: 13
Reset counter: 134
Mileage: 144570 km
Date: 2019.08.20
Time: 09:45:07
Control Module temperature: 44.0 °C
0185 - Development Code 4
B2F04 00 [008] - -
[MGT_task_stuck_eTask_RSF]
Fault Priority: 9
Fault Frequency: 11
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:52
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
12583684 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
12583686 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
12583687 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70B92D39CA2464073A9-8024
U1111 00 [008] - -
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
U1111 00 [008] - -
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
U1111 00 [008] - -
Fault Frequency: 20
Reset counter: 134
Mileage: 144554 km
Date: 2019.08.20
Time: 09:34:53
End----------(Elapsed Time: 02:36, VBatt start/end: 13.5V/14.0V)-----------
Wednesday,21,August,2019,12:30:35:30584
Mileage: 144820km-89986mi Repair Order:
VIN: WAUZZZ4G0BN016789 Mileage: 144820km-89986miles
Revision: 53H37---
U1113 00 [032] - -
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:35
Engine speed: 2031.50 /min
Normed load value: 59.6 %
Coolant temperature: 88 °C
Intake air temperature: 52 °C
Voltage terminal 30: 13.740 V
Active brake system error status-Bits 0-7: 1
Acceleration: -0.137 m/s²
U1017 00 [032] - -
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
Engine speed: 1214.50 /min
Normed load value: 0.4 %
Acceleration: -0.106 m/s²
U0121 00 [032] - -
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
Engine speed: 1236.50 /min
Normed load value: 0.8 %
Voltage terminal 30: 13.760 V
selected gear-Bits 0-7: 2
U0121 00 [032] - -
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Engine speed: 1273.00 /min
U0121 00 [032] - -
Reset counter: 40
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Engine speed: 1272 /min
Transmission input speed: 1272 /min
Transmission output speed: 239 /min
Engine torque: -56 Nm
Transmission fluid temperature: 92 °C
Clutch status: Beide Kupplungen können Moment übertragen
Voltage terminal 30: 13.700 V
Voltage_5V_CAN_pressuresensors-Param to DOP: 4.924 V
U1113 00 [008] - -
Fault Frequency: 19
Reset counter: 134
Time: 00:00:00
VzRef: 00
Bit Info 1: 00
Bit Info 2: 02
Bit Info 3: 00
Bit Info 4: 1F
F-Path: 02
F-Type: 06
Uz: A2
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
VzRef: 1F
Bit Info 1: 00
Bit Info 2: 40
Bit Info 3: 24
Bit Info 4: 1F
F-Path: 00
F-Type: 6E
Uz: B4
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
Coding: 360100B824
U1113 00 [008] - -
Reset counter: 134
Mileage: 144819 km
Date: 2019.08.20
Time: 16:06:39
Outside air temperature: 37.0 °C
Engine speed: 1879 /min
Vehicle speed: 38.00 km/h
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Voltage terminal 30: 13.91 V
Engine speed: 1371 /min
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Voltage terminal 30: 13.93 V
Engine speed: 1282 /min
Coding: 0045F7
Coding: 02512B
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:00
Revision: AA001001
Reset counter: 134
Coding: 302B05
12656912 - Databus
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Coding: 3E04010202
10 Faults Found:
22528 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_03]
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
Voltage terminal 15: 13.964 V
Velocity_vehicle_reference: 8.81 m/s
Longitudinal_acceleration_vehicle_reference: -0.41 m/s²
22784 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_04]
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
23040 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_05]
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
23296 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[FAULT_CIM_TIMEOUT_Linie_06]
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
U1113 00 [008] - -
Reset counter: 134
Mileage: 144820 km
Date: 2019.08.20
Time: 19:56:51
Control Module temperature: 38 °C
Voltage terminal 15: 11.711 V
U1113 00 [008] - -
Reset counter: 134
Mileage: 144820 km
Date: 2019.08.20
Time: 19:56:51
U1113 00 [008] - -
Reset counter: 134
Mileage: 144820 km
Date: 2019.08.20
Time: 19:56:51
1048832 - Databus
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
1049088 - Databus
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
1049093 - Databus
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
1049094 - Databus
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
1049095 - Databus
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
1049344 - Databus
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Coding: 0000FC
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Coding: 00CD077D00
Voltage stabilizer:
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Voltage terminal 30: 13.9 V
Voltage terminal 15: 14.0 V
Control Module temperature: 59 °C
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
Voltage terminal 30: 14.0 V
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
Coding: 00
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Voltage terminal 30: 14.04 V
Coding: 008002
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
U1112 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:34
U1111 00 [040] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
DCU Temperature: 58 °C
Voltage Clamp 15: 14.4 V
Voltage Clamp 30: 14.0 V
Ignition Cycle Count: 50098
WAUZZZ4G0BN016789
Coding: 0000101
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Reset counter: 134
Date: 2011.01.01
Time: 00:00:00
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
Write only channel
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
Write only channel
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Vehicle speed: 32 km/h
RWU: not active
DSD: not active
HTR: not active
ECD: not active
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
RWU: not active
DSD: not active
HTR: not active
ECD: not active
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
RWU: not active
DSD: not active
HTR: not active
ECD: not active
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
RWU: not active
DSD: not active
HTR: not active
ECD: not active
U1113 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
RWU: not active
DSD: not active
HTR: not active
ECD: not active
U1113 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
RWU: not active
DSD: not active
HTR: not active
ECD: not active
H02 0006
Coding: 1D0000
H02 0006
Coding: 1D0000
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
U1112 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1300E1PE
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 612 L
Subsystem 4 - Part No: 8R0 060 961 A
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:42
Reset counter: 134
Mileage: 144670 km
Date: 2019.08.20
Time: 14:37:02
Voltage: 13.90 V
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:35
Coding: 1020004
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Term 15 On
Reverse OFF
Count: 3
Coding: 111104C000
Coding: EE060000
U1111 00 [008] - -
[ESP_timeout]
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
Outside air temperature: -31.5 °C
Voltage terminal 15: 13.7 V
Control Module temperature: 46.0 °C
Coding: 662FF2
Coding: 262FF2
Coding: 3E04010202
10 Faults Found:
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
Voltage terminal 15: 14.004 V
Velocity_vehicle_reference: 8.72 m/s
Longitudinal_acceleration_vehicle_reference: -0.45 m/s²
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:35
Voltage terminal 15: 13.999 V
Velocity_vehicle_reference: 7.51 m/s
Longitudinal_acceleration_vehicle_reference: -0.39 m/s²
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:35
U1113 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:34
Voltage terminal 15: 14.002 V
Velocity_vehicle_reference: 8.20 m/s
Longitudinal_acceleration_vehicle_reference: -3.24 m/s²
U1113 00 [008] - -
Reset counter: 134
Mileage: 144820 km
Date: 2019.08.20
Time: 19:56:51
Control Module temperature: 37 °C
Voltage terminal 15: 11.793 V
U1113 00 [008] - -
Reset counter: 134
Mileage: 144820 km
Date: 2019.08.20
Time: 19:56:51
U1113 00 [008] - -
[FAULT_CIS_US_FAIL]
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
Voltage terminal 15: 14.007 V
Velocity_vehicle_reference: 8.70 m/s
Longitudinal_acceleration_vehicle_reference: -0.21 m/s²
U1113 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:33
ROD: EV_BC7.rod
U1113 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:36
Voltage terminal 15: 13.9 V
Control Module temperature: 54.0 °C
U1113 00 [008] - -
[SWA_Signal_error]
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:36
Fault Priority: 9
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
ROD: EV_RGS_L.rod
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
ROD: EV_RGS_R.rod
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
U1111 00 [008] - -
Reset counter: 134
Mileage: 144818 km
Date: 2019.08.20
Time: 16:05:32
End----(Elapsed Time: 02:38, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
