AUDI A6 (C7) intermittent (and very persistent) problem with ABS electronics
vladomkd
Macedonia
C?ID=332408
hello everyone,
this is my first post here and i just want to congratulate you on a great and very informative forum you are running, one that i have been following for a while. unfortunately my first post is about a problem that i have with my car that has been going on for a while, and i have been unsuccessful in resolving it.
what basically happens with the car is that from time to time the entire DIS cluster will light up with errors from most modules/ECUs (parking brake, adaptive suspension, engine, headlights, braking guard etc...). most of the systems go in limp mode when this happens. the errors rarely disappear on their own, sometimes after i turn off and start the car again, but most often after i turn off the car and disconnect and reconnect the cable to the ABS ECU. these errors can happen often (several times a day) or very rare (i have gone 6 months without errors on one occasion), and i'm unable to find a pattern here. also, it's not a rule, but often the errors will start to appear when driving on a rough road or driving over a road hole/bump.
i have had it scanned on million occasions and as you can see from the autoscan below, most modules point towards lost communication with the ABS. on several occasions, the ABS was not even reachable when scanning with VCDS/ODIS.
curiously, disconnecting and reconnecting the cable to the ABS ECU ALWAYS resolves the problem, albeit temporarily.
at a certain point i was sure the ABS connector was faulty, so i rebuilt it with new contacts. this did not solve the problem, but what changed after rebuilding the connector is that when errors appeared they lasted very briefly and disappeared by themselves. this made me even more certain it's the connector, however this time i was sure the contacts are inappropriate (by design), considering their minimal contact area. so i decided to bypass the ABS connector using female spade connectors on the ECU side (which are very tight and i'm certain don't come loose during driving. in fact the ABS connector now can't be removed without first detaching the ECU from the ABS pump - it's that tight). to be able to disconnect the ABS in emergency, i have split the cable downstream into 3 smaller connectors (one for the power cables, and two for the 21 data connections). this worked for several months, but few days ago coming back from holiday the same errors reappeared with a vengeance. i can now start doubting the 3 new connectors i introduced downstream, but i think at this point this is becoming pointless and it's not the connectors at all?!?!
i have also opened the ABS ECU, and checked (physically and with multimeter) each and every connection that can be checked - no connections are broken and they all show minimal resistance. bare in mind, there are also a lot of microscopic connections in the ECU, covered in silicone. i don't think anyone can check these, certainly not me at home with a multimeter. however, my subjective opinion is that the ECU is well built, and the fault is not in any broken connections. besides, disconnecting and reconnecting the ABS cable will not mend broken connections in the ECU each and every time.
i have also checked the CAN wiring directly on the ABS connector, CAN high gives 2.7V, CAN low 2.3V and 60 ohms resistance between the two, exactly as per spec.
reading a lot of stuff on different forums i have come across some thoughts/suggestions that such problems can be caused by rusted/loose negative connections to the chassis, however i have no idea where these cables are bolted to the chassis and where to check for rust?
also, somebody suggested that the problem is within the ABS electronics, i.e. some of the chips there becomes stuck (like a memory overflow or some loop in software routines). disconnecting the power to the ECU clears the memory and the module starts functioning normally. this sounds logical, but as i mentioned before, sometimes errors resolve without even turning off the car. furthermore, somebody has also pointed that a faulty ABS sensor can feed junk data to the ABS ECU, leading to the above condition. as far as i can understand these sensors are analogue, giving voltage values to the ECU and there is no real "data" there? but is it possible that some other sensor (like lane keeping camera, or ACC radars) can really feed junk data that can block the ECU?
anyways, here are two autoscans from the last two times this has happened, maybe someone can see and understand something in them that i don't...
the car is euro spec AUDI A6 C7 (my 2011) 3.0 TDI 245HP quattro with 7-speed DCT.
sorry for the lengthy post, but i tried to sum up everything from the past year.
Tuesday,20,August,2019,14:36:07:30584
VIN: WAUZZZ4G0BN016789   License Plate:
Mileage: 144670km-89893mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
          44 46 47 52 53 55 56 5F 62 6C 6D 72 85 88 89 8B 8E 8F 90
VIN: WAUZZZ4G0BN016789   Mileage: 144670km-89893miles
3B-Sensor Elect. -- Status: Malfunction 0010
85-On Board Cam. -- Status: Malfunction 0010
8F-Pretens. Frt Left -- Status: Malfunction 0010
90-Pretens. Frt Right -- Status: Malfunction 0010
Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0007
   Revision: 53H37---
   Coding: 0A254012046601020000
   Shop #: WSC 28918 001 1048576
   ASAM Dataset: EV_ECM30TDI0114G0907401F 001007
   ROD: EV_ECM30TDI0114G0907401F.rod
   VCID: 26150B6138607AB7905-8072
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [040] - -
                    Fault Frequency: 20
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:23
                    Engine speed: 2239.50 /min
                    Normed load value: 43.1 %
                    Vehicle speed: 92 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 14.080 V
                    ACC target acceleration: 0.000 m/s²
                    ACC control module received status-Bits 0-7: 0
                    Active brake system error status-Bits 0-7: 33
                    Status of ACC/CCS acceleration interface-Bits 0-7: 0
                    Acceleration: 1.114 m/s²
                    Engine status: COENG_RUNNING
4660 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [040] - -
          [Software Incompatibility with Anti-Lockplease read DTC]
                    Fault Frequency: 21
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:23
                    Engine speed: 2222.50 /min
                    Normed load value: 65.5 %
                    Vehicle speed: 90 km/h
                    Voltage terminal 30: 14.040 V
                    Acceleration: 0.991 m/s²
7136 - No Communication with ABS Brake Control Module
          U0121 00 [032] - -
          [Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
                    Fault Frequency: 15
                    Mileage: 144670 km
                    Date: 2019.08.20
                    Time: 14:01:21
                    Engine speed: 1184.00 /min
                    Vehicle speed: 255 km/h
                    Coolant temperature: 84 °C
                    Intake air temperature: 40 °C
                    Voltage terminal 30: 13.900 V
                    Cruise Control System (CCS): status-Bits 0-7: 209
                    selected gear-Bits 0-7: 4
4713 - No Communication with ABS Brake Control Module
          U0121 00 [168] - -
                    Mileage: 144640 km
                    Date: 2019.08.20
                    Time: 13:40:00
                    Engine speed: 1653.50 /min
                    Normed load value: 56.5 %
                    Coolant temperature: 85 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 13.660 V
                    Cruise Control System (CCS): status-Bits 0-7: 17
                    selected gear-Bits 0-7: 5
Readiness: 1 1 0 0 0
   Part No SW: 4G2 927 156 H    HW: 0B5 927 156 K
   Component: 0B5 30 TDIRdW H03 0002
   Revision: --H03---    Serial number: 0000000467
   Shop #: WSC 04940 001 00001
   ASAM Dataset: EV_TCMDL501021 A03005
   ROD: EV_TCMDL501021_A03.rod
   VCID: 3333E235FBB21F1F07B-8066
18148 - No Communication with ABS Brake Control Module
          U0121 00 [040] - -
                    Fault Frequency: 20
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
                    Engine speed: 1541 /min
                    Transmission input speed: 1541 /min
                    Transmission output speed: 511 /min
                    Engine torque: -48 Nm
                    Transmission fluid temperature: 89 °C
                    Accelerator position: 0.0 %
                    Clutch status: Kupplung 1 kann Moment übertragen
                    Voltage terminal 30: 14.300 V
                    Voltage_5V_CAN_pressuresensors-Param to DOP: 4.923 V
   Part No SW: 4G0 907 379 B    HW: 4G0 907 379 B
   Component: ESP PREMIUM   H09 0190
   Coding: 27A6C700E465E300DB00
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 003013
   ROD: EV_ESPPremiAU57X_003.rod
   VCID: 3039ED390AA424077A9-8064
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Ldm_ApbFailureState]
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:35:11
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 2F
                    Bit Info 3: 20
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 06
                    Uz: A5
0519 - FlexRay Databus
          U1031 00 [008] - No Synchronization
          [NET09_SyncLost_FlxrA]
                    Fault Frequency: 8
                    Reset counter: 134
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:22
                    VzRef: 58
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 6E
                    Uz: B8
   Part No SW: 4H0 907 064 AP    HW: 4H0 907 064 AP
   Component: BCM2 2.0      H24 0217
   Coding: 01A83000000000000000
   VCID: 77AB1625AFCA333FFB3-8022
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000034114014
                    Fault Status: 00101101
                    Fault Frequency: 19
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
   Part No SW: 4G8 959 760 B    HW: 4G8 959 760 B
   Component: MEM-BFS       H04 0153
   Revision: AA000000    Serial number: 00001002306755
   Coding: 0018320000006201000001010101112030303333283333
   VCID: 392FD01DD95EE54FCD7-806C
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H11 0056
   Serial number: 17021100040422
   Coding: 360100B824
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_AirCondiComfoUDS 002029
   VCID: 270B06653F6A63BFAB3-8072
0247 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Motorsteuergerät: Fehlerspeicher auslesen]
                    Reset counter: 134
                    Mileage: 144571 km
                    Date: 2019.08.20
                    Time: 09:45:47
                    Outside air temperature: 29.0 °C
                    Engine speed: 1987 /min
                    Vehicle speed: 87.00 km/h
0330 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Bremsensteuergerät: kein Signal/keine Kommunikation]
                    Fault Frequency: 16
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
                    Voltage terminal 30: 14.32 V
                    Outside air temperature: 28.5 °C
                    Engine speed: 1740 /min
0369 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Spurhalteassistent: kein Signal / Kommunikation]
                    Fault Frequency: 26
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
                    Voltage terminal 30: 14.34 V
                    Engine speed: 1648 /min
   Part No SW: 4H0 907 063 N    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0092
   Revision: 20012002    Serial number: 00000000961257
   Coding: 0200201150B48FE2C981008380001908CF9CC3082E080101000008402100
   VCID: 3333E235FB321F1F07B-8066
   Component: WWS57X 110213  H32 0051
   Serial number:         110214102924
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11300730
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 28 02 2011  00000056
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 5C080495000000000001
                    Fault Frequency: 14
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:00
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:00
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 F    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0200
   Revision: AA001001
   VCID: 231312754BD28F9FF7B-8076
02283 - Video Connection to Output [End Unit]
                    Fault Status: 00101011
                    Fault Frequency: 23
                    Reset counter: 131
   Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0030
   Revision: 11001001    Serial number: 55901105301116
   Coding: 302B05
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 372BD625EFCAF33F3B3-8062
12656912 - Databus
          [Bremsensteuergerät - ESP_01 - kein Signal/keine Kommunikation]
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
   Part No SW: 4G0 907 561     HW: 4G0 907 561
   Component: ACC3          H15 0160
   Coding: 3E04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 001003
   ROD: EV_AdaptCruisContrAU57X_001.rod
   VCID: 678B4665FFEAA3BF6B3-8032
10 Faults Found:
23552 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_Linie_07]
                    Reset counter: 134
                    Mileage: 144668 km
                    Date: 2019.08.20
                    Time: 13:55:11
                    Control Module temperature: 39 °C
                    Voltage terminal 15: 14.015 V
                    Velocity_vehicle_reference: 32.59 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.38 m/s²
23808 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_Linie_08]
                    Reset counter: 134
                    Mileage: 144668 km
                    Date: 2019.08.20
                    Time: 13:55:11
24064 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_Linie_Master]
                    Reset counter: 134
                    Mileage: 144652 km
                    Date: 2019.08.20
                    Time: 13:46:22
                    Voltage terminal 15: 14.003 V
                    Velocity_vehicle_reference: 31.88 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.02 m/s²
25856 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_BVObjekt_07]
                    Reset counter: 134
                    Mileage: 144670 km
                    Date: 2019.08.20
                    Time: 14:01:18
                    Control Module temperature: 47 °C
                    Voltage terminal 15: 14.082 V
                    Velocity_vehicle_reference: 23.44 m/s
                    Longitudinal_acceleration_vehicle_reference: -3.42 m/s²
26880 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_BVOBMaster]
                    Reset counter: 134
                    Mileage: 144670 km
                    Date: 2019.08.20
                    Time: 14:01:18
27136 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_BVS_STATUS]
                    Reset counter: 134
                    Mileage: 144670 km
                    Date: 2019.08.20
                    Time: 14:01:18
77056 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_BV_TIME]
                    Fault Frequency: 16
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
                    Voltage terminal 15: 14.320 V
                    Velocity_vehicle_reference: 20.66 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.62 m/s²
105984 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_EPB_FAIL]
                    Reset counter: 134
                    Mileage: 144670 km
                    Date: 2019.08.20
                    Time: 14:02:28
                    Control Module temperature: 46 °C
                    Voltage terminal 15: 12.617 V
140288 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_ECD_FAIL]
                    Reset counter: 134
                    Mileage: 144670 km
                    Date: 2019.08.20
                    Time: 14:02:34
                    Voltage terminal 15: 12.563 V
145152 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_SWA_FAIL]
                    Reset counter: 134
                    Mileage: 144670 km
                    Date: 2019.08.20
                    Time: 14:02:28
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H40 0040
   Revision: --------    Serial number: 003JG001PWX0
   Coding: 30323436313330303335554A304C34473053
   VCID: 3635DB21E8C00A37205-8062
   Serial number: 3575HRB404T0ATOCBP08
   Serial number: 3585HRB404T07OTS504
   Serial number: 3515JRB406109GGSBG6C
   Serial number: 3525JRB406909GGSAPL1
   Serial number: 3554VRB40516PGAKJ92V
   Serial number: 3564VRB404T6PGAKIPB/
7 Faults Found:
1048832 - Databus
          [CAN: 0x100 ESP_01 Timeout]
                    Fault Frequency: 15
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
1049088 - Databus
          [CAN: 0x101 ESP_02 Timeout]
                    Fault Frequency: 15
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
1049093 - Databus
          [CAN: 0x101 ESP_02 error value ESP_Querbeschleunigung]
                    Fault Frequency: 8
                    Reset counter: 134
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:23
1049094 - Databus
          [CAN: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
                    Fault Frequency: 8
                    Reset counter: 134
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:23
1049095 - Databus
          [CAN: 0x101 ESP_02 error value ESP_Gierrate]
                    Fault Frequency: 8
                    Reset counter: 134
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:23
1049344 - Databus
          [CAN: 0x103 ESP_03 Timeout]
                    Fault Frequency: 15
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
1049866 - Databus
          [CAN: 0x39C Gateway_05 Old value from ESP_07]
                    Fault Frequency: 9
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:54
   Component: Lenks.Modul   H03 0003
   Revision: --------    Serial number: 90372KBP0020B
   Coding: 0000FC
   VCID: 372BD625EF4AF33F3B3-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Component: E221 - MFL  H08 0009
   Serial number: 05 05 2012  C0063401
                    Fault Frequency: 19
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
   Part No SW: 4G8 920 930 T    HW: 4G8 920 930 T
   Component: TDieRdwAcc    H34 0309
   Revision: 19100073    Serial number: 658180211593030
   Coding: 138E09005F050008000000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU57.rod
   VCID: 3E25C301C0F0C277F85-806A
16776968 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ESP_02 keine Kommunikation]
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
16776969 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [LDW_02_FR keine Kommunikation]
                    Fault Frequency: 21
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
16776973 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [RDK_01 keine Kommunikation]
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
16776980 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [VZE_01 keine Kommunikation]
                    Fault Frequency: 21
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
   Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000104008
   Coding: 00CD077D00
   ROD: EV_GatewUDS_AU57.rod
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650619708
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 11045001033011200410
6653 - Image processing control module
          U1079 00 [008] - No communication
                    Fault Frequency: 19
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
                    Voltage terminal 30: 14.4 V
                    Voltage terminal 15: 14.4 V
                    System status: Terminal 15 on
                    IN ESP_standstill flag: no standstill detected
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
4352 - ABS Control Module on FlexRay Data Bus
          U10BD 00 [008] - No Communication
          [Lost Communication With Vehicle Dynamics Control Module]
                    Fault Frequency: 22
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
                    Voltage terminal 30: 14.3 V
                    Voltage terminal 15: 14.3 V
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Part No SW: 4G0 919 158 D    HW: 4G0 919 158 D
   Component: KLIMA FOND    H07 0056
   Serial number: 19021100040082
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
0136 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 17
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
                    Voltage terminal 30: 14.41 V
   Part No SW: 4G0 907 553 B    HW: 4G0 907 553
   Component: LUFE-DAEMPFER H17 0778
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2A0DFF512C785ED7B4D-807E
0008 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 13
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
0009 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 13
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
0006 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 11
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
0007 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 9
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
0648 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Reset counter: 134
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:23
   Component: MEM-FS        H04 0153
   Revision: AA000000    Serial number: 00001002306757
   Coding: 0018330000016201000001010101112030303333203333
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4200DZ160
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D07F44D1D9649EF51F-8078
3801346 - Function Restricted due to Missing Message(s)
          U1111 00 [044] - -
          [Internal Monitoring (MSG)]
                    Fault Frequency: 22
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
                    DCU Temperature: 46 °C
                    Voltage Clamp 15: 14.7 V
                    Voltage Clamp 30: 14.4 V
                    Ignition Cycle Count: 50068
                    WAUZZZ4G0BN016789
   Part No SW: 4G0 907 566 C    HW: 4G0 907 566
   Component: J769  SWA MasterH01 0020
   Revision: 00H01000    Serial number: 6PZ 010 287-01
   Coding: 0000101
   VCID: 2F3BEE451B1A3BFF633-807A
   Subsystem 1 - Part No: 4G0 907 568 C
   Component: J770  SWA Slave H01 0020
   Subsystem 2 - Serial number: 6PZ 010 287-21
   Subsystem 3 - Serial number: 5F01.03.1100H010003CD21904ÿ
   Subsystem 4 - Serial number: D21904ÿ
                    Reset counter: 134
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:23
                    Fault Frequency: 21
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
   Part No SW: 4G8 959 793 B    HW: 4G8 959 793
   Component: TSG FA        H04 0210
   Coding: 011F06205E00628202080003
   Shop #: WSC 02312 785 00200
   VCID: 3FDBBE05C77ACB7FF33-806A
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:57
   Part No SW: 4G0 909 144 L    HW: 4G0 909 144 F
   Component: RCEPS         H32 0010
   Revision: 00001000    Serial number: 0024040880
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323DE73104A816170CD-8066
3158273 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Ausfall Botschaft "PDU_ESP_01"]
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
                    Write only channel
3158336 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Ausfall Botschaft "PDU_HCA_01"]
                    Fault Frequency: 19
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
                    Write only channel
   Revision: 00002001    Serial number: 0144584148
   Coding: 0100062000B93480832008040C0100000000000000000000000000000000
                    Fault Frequency: 19
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
   Part No SW: 4G0 035 223 A    HW: 4G0 035 223 A
   Component: BOSE G3 C7    H07 0070
   Revision: CJ007000    Serial number: 00000000023919
   VCID: 1B632A9573A2B75F3FB-804E
                    Reset counter: 134
                    Mileage: 144581 km
                    Date: 2019.08.20
                    Time: 09:52:37
                    Bin. Bits: 00001000
   Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
   Component: TSG BF        H04 0210
   Coding: 011F06205E00628202080002
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:57
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000046518
   ROD: EV_ParkiBrake_VW51.rod
328448 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_ESP_01_MESSAGE_TIMEOUT]
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
                    Internal Fault ID: 89
                    Vehicle speed: 74 km/h
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: Dynamic
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
328704 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_ESP_02_MESSAGE_TIMEOUT]
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
                    Internal Fault ID: 90
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
328960 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_ESP_03_MESSAGE_TIMEOUT]
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
                    Internal Fault ID: 91
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
329216 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FC_ESP_05_MESSAGE_TIMEOUT]
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
                    Internal Fault ID: 92
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
459264 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_ESP_LAENGSBESCHL_ERROR_VALUE]
                    Fault Frequency: 8
                    Reset counter: 134
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:23
                    Internal Fault ID: 138
                    Vehicle speed: 510 km/h
                    Yellow warning lamp: OFF
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Internal Parking Brake state: Emergency running mode
463616 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
                    Fault Frequency: 8
                    Reset counter: 134
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:23
                    Internal Fault ID: 185
                    Vehicle speed: 88 km/h
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0011
   Serial number: 110210-0004-037
   Coding: 11216F33F91AEB00
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
H02 0006
   Coding: 1D0000
H02 0006
   Coding: 1D0000
0001 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Timeout CAN-Message ESP_02  (0x101)]
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
0061 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
          [Fehlerhafter DLC der CAN-Messages Kamera_Status  (0x318)]
                    Fault Frequency: 16
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:54
337156 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Timeout CAN-Message ESP_03  (0x103)]
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
   Part No SW: 4G0 035 053 J    HW: 4G0 035 053
   Component: Radio U Basic H52 0133
   Revision: AB001007    Serial number: 050BO0B7544019
   Coding: 010003010000000001
   VCID: 25170C6D45E671AF99F-8070
                    Reset counter: 134
                    Mileage: 144668 km
                    Date: 2019.08.20
                    Time: 13:55:24
                    Bin. Bits: 00000000 00000100
   Part No SW: 4G0 035 670 Q    HW: 4G0 035 670
   Component: H-BNT-EU      H46 1034
   Revision: --------    Serial number: 428J80B7514996
   Coding: 050100000003F9EF7D308B3E00000003080001000000000000
   Shop #: WSC 28274 134 100328
   VCID: 313FE83D012E2D0F757-8064
   Subsystem 1 - Part No: 8R0 060 884 GA
   Component: EUR 2019  2802
   Subsystem 2 - Part No SW: 4G1 919 610 C    HW: 4G1 919 612 L
   Component: E380 BDT C7  H08 0204
   Serial number: 90349KBP0006D
   Subsystem 3 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
                    Reset counter: 134
                    Mileage: 144668 km
                    Date: 2019.08.20
                    Time: 13:55:24
                    Bin. Bits: 00000000 10000000
                    Bin. Bits: 00000010 00000000
                    Bin. Bits: 00000000 00000010
                    Bin. Bits: 00000000 00000000
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 94
                    Mileage: 144670 km
                    Date: 2019.08.20
                    Time: 14:03:17
                    Voltage: 13.40 V
                    Fault Frequency: 18
                    Reset counter: 134
                    Mileage: 144670 km
                    Date: 2019.08.20
                    Time: 14:01:54
                    Bin. Bits: 00000000 01100000
   Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
   Component: TSG HL        H03 0210
   Coding: 010F04204000628202080002
   VCID: 42DDB7F1B488A6979CD-8016
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0050
   Revision: --H04---    Serial number: 525 PA8J12F0CG
   Coding: 1020004
   VCID: 25170C6D49E671AF99F-8070
                    Fault Frequency: 17
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
                        Reverse OFF
                    Count: 3
   Part No SW: 4G5 959 107     HW: 4G5 959 107
   Component: HDSG-Modul    H01 0036
   Revision: 13001001    Serial number: 046100202
   Coding: 111104C000
   ASAM Dataset: EV_HDSGAu571 001001
   ROD: EV_HDSGAu571.rod
   VCID: 6FBB2E45D71A7BFF233-803A
0044 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:56
   Component: TSG HR        H03 0210
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Coding: EE060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 65974C6D05E6B1AF59F-8030
0703 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [ESP_timeout]
                    Fault Frequency: 23
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
                    Outside air temperature: -36.0 °C
                    Voltage terminal 15: 14.1 V
                    Control Module temperature: 41.0 °C
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00456842018901
   Coding: 662FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F3BEE45179A3BFF633-807A
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00456842126601
   Coding: 262FF2
   Part No SW: 4G0 907 541     HW: 4G0 907 541
   Coding: 3E04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
   ROD: EV_AdaptCruisContr2AU57X_001.rod
10 Faults Found:
27904 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_ESP_02]
                    Fault Frequency: 19
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
                    Voltage terminal 15: 14.332 V
                    Velocity_vehicle_reference: 20.48 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.70 m/s²
28160 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_ESP_03]
                    Fault Frequency: 19
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
28416 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_ESP_05]
                    Reset counter: 134
                    Mileage: 144670 km
                    Date: 2019.08.20
                    Time: 14:01:19
                    Control Module temperature: 48 °C
                    Voltage terminal 15: 14.126 V
                    Velocity_vehicle_reference: 22.88 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.57 m/s²
28672 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_ESP_07]
                    Reset counter: 134
                    Mileage: 144670 km
                    Date: 2019.08.20
                    Time: 14:01:21
                    Voltage terminal 15: 14.143 V
                    Velocity_vehicle_reference: 18.71 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.14 m/s²
28928 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_ESP_08]
                    Fault Frequency: 25
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
                    Voltage terminal 15: 14.255 V
                    Velocity_vehicle_reference: 20.52 m/s
                    Longitudinal_acceleration_vehicle_reference: -1.18 m/s²
94976 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_QDCPSS_FAIL]
                    Reset counter: 134
                    Mileage: 144668 km
                    Date: 2019.08.20
                    Time: 13:57:05
                    Control Module temperature: 41 °C
                    Voltage terminal 15: 13.697 V
                    Velocity_vehicle_reference: 1.68 m/s
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_VDC_FAIL]
                    Reset counter: 134
                    Mileage: 144668 km
                    Date: 2019.08.20
                    Time: 13:57:05
          U1113 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 134
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:23
                    Voltage terminal 15: 14.287 V
                    Velocity_vehicle_reference: 25.18 m/s
                    Longitudinal_acceleration_vehicle_reference: 1.65 m/s²
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 144670 km
                    Date: 2019.08.20
                    Time: 14:02:34
                    Voltage terminal 15: 12.619 V
                    Velocity_vehicle_reference: -0.00 m/s
144896 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_US_FAIL]
                    Fault Frequency: 18
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
                    Voltage terminal 15: 14.337 V
                    Velocity_vehicle_reference: 20.39 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.25 m/s²
   Part No SW: 4G0 907 107 B    HW: 4H0 907 107
   Component: BV-SG         H28 0034
   Serial number: 000040182202117
   Coding: 04C0BB181111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 25170C6D456671AF99F-8070
7 Faults Found:
0028 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [ESP_ESP_01_Signal_Error]
                    Fault Frequency: 8
                    Reset counter: 134
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:24
                    Outside air temperature: 28.0 °C
                    Voltage terminal 15: 14.2 V
                    Control Module temperature: 42.0 °C
0063 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [SWA_Signal_error]
                    Fault Frequency: 8
                    Reset counter: 134
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:24
0121 - FlexRay Databus
          [Halt-Fehler_/_Kompletter_Syncverlust]
                    Fault Priority: 9
                    Fault Frequency: 50
                    Reset counter: 134
                    Mileage: 144550 km
                    Date: 2019.08.20
                    Time: 09:32:22
0173 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [APS_Signal_Error_Master]
                    Reset counter: 134
                    Mileage: 144637 km
                    Date: 2019.08.20
                    Time: 13:37:50
                    Outside air temperature: 35.5 °C
                    Voltage terminal 15: 12.0 V
                    Control Module temperature: 0.0 °C
0091 - Function Limitation due to Missing Video Data
          C1108 00 [008] - -
          [DPC_SystemError]
                    Fault Frequency: 15
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
0179 - Development Code 4
          B2F04 00 [008] - -
          [MGT_task_stuck_bTask_HCA]
                    Fault Priority: 9
                    Fault Frequency: 13
                    Reset counter: 134
                    Mileage: 144570 km
                    Date: 2019.08.20
                    Time: 09:45:07
                    Control Module temperature: 44.0 °C
0185 - Development Code 4
          B2F04 00 [008] - -
          [MGT_task_stuck_eTask_RSF]
                    Fault Priority: 9
                    Fault Frequency: 11
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:52
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
12583684 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
12583686 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
12583687 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70B92D39CA2464073A9-8024
          U1111 00 [008] - -
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
          U1111 00 [008] - -
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
          U1111 00 [008] - -
                    Fault Frequency: 20
                    Reset counter: 134
                    Mileage: 144554 km
                    Date: 2019.08.20
                    Time: 09:34:53
End----------(Elapsed Time: 02:36, VBatt start/end: 13.5V/14.0V)-----------
Wednesday,21,August,2019,12:30:35:30584
Mileage: 144820km-89986mi   Repair Order:
VIN: WAUZZZ4G0BN016789   Mileage: 144820km-89986miles
   Revision: 53H37---
          U1113 00 [032] - -
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:35
                    Engine speed: 2031.50 /min
                    Normed load value: 59.6 %
                    Coolant temperature: 88 °C
                    Intake air temperature: 52 °C
                    Voltage terminal 30: 13.740 V
                    Active brake system error status-Bits 0-7: 1
                    Acceleration: -0.137 m/s²
          U1017 00 [032] - -
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
                    Engine speed: 1214.50 /min
                    Normed load value: 0.4 %
                    Acceleration: -0.106 m/s²
          U0121 00 [032] - -
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
                    Engine speed: 1236.50 /min
                    Normed load value: 0.8 %
                    Voltage terminal 30: 13.760 V
                    selected gear-Bits 0-7: 2
          U0121 00 [032] - -
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    Engine speed: 1273.00 /min
          U0121 00 [032] - -
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    Engine speed: 1272 /min
                    Transmission input speed: 1272 /min
                    Transmission output speed: 239 /min
                    Engine torque: -56 Nm
                    Transmission fluid temperature: 92 °C
                    Clutch status: Beide Kupplungen können Moment übertragen
                    Voltage terminal 30: 13.700 V
                    Voltage_5V_CAN_pressuresensors-Param to DOP: 4.924 V
          U1113 00 [008] - -
                    Fault Frequency: 19
                    Reset counter: 134
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 02
                    Bit Info 3: 00
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 06
                    Uz: A2
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    VzRef: 1F
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 24
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: 6E
                    Uz: B4
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
   Coding: 360100B824
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 144819 km
                    Date: 2019.08.20
                    Time: 16:06:39
                    Outside air temperature: 37.0 °C
                    Engine speed: 1879 /min
                    Vehicle speed: 38.00 km/h
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    Voltage terminal 30: 13.91 V
                    Engine speed: 1371 /min
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    Voltage terminal 30: 13.93 V
                    Engine speed: 1282 /min
   Coding: 0045F7
   Coding: 02512B
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:00
   Revision: AA001001
                    Reset counter: 134
   Coding: 302B05
12656912 - Databus
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
   Coding: 3E04010202
10 Faults Found:
22528 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_Linie_03]
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
                    Voltage terminal 15: 13.964 V
                    Velocity_vehicle_reference: 8.81 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.41 m/s²
22784 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_Linie_04]
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
23040 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_Linie_05]
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
23296 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [FAULT_CIM_TIMEOUT_Linie_06]
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 144820 km
                    Date: 2019.08.20
                    Time: 19:56:51
                    Control Module temperature: 38 °C
                    Voltage terminal 15: 11.711 V
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 144820 km
                    Date: 2019.08.20
                    Time: 19:56:51
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 144820 km
                    Date: 2019.08.20
                    Time: 19:56:51
1048832 - Databus
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
1049088 - Databus
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
1049093 - Databus
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
1049094 - Databus
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
1049095 - Databus
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
1049344 - Databus
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
   Coding: 0000FC
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
   Coding: 00CD077D00
   Voltage stabilizer:
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    Voltage terminal 30: 13.9 V
                    Voltage terminal 15: 14.0 V
                    Control Module temperature: 59 °C
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
                    Voltage terminal 30: 14.0 V
                    Engine running: On
                    IN ZAS_Te_X: On
                    Datenfeld: 0
   Coding: 00
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    Voltage terminal 30: 14.04 V
   Coding: 008002
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
          U1112 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:34
          U1111 00 [040] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    DCU Temperature: 58 °C
                    Voltage Clamp 15: 14.4 V
                    Voltage Clamp 30: 14.0 V
                    Ignition Cycle Count: 50098
                    WAUZZZ4G0BN016789
   Coding: 0000101
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    Reset counter: 134
                    Date: 2011.01.01
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
                    Write only channel
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
                    Write only channel
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    Vehicle speed: 32 km/h
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
H02 0006
   Coding: 1D0000
H02 0006
   Coding: 1D0000
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
          U1112 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1300E1PE
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 612 L
   Subsystem 4 - Part No: 8R0 060 961 A
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:42
                    Reset counter: 134
                    Mileage: 144670 km
                    Date: 2019.08.20
                    Time: 14:37:02
                    Voltage: 13.90 V
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:35
   Coding: 1020004
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                        Reverse OFF
                    Count: 3
   Coding: 111104C000
   Coding: EE060000
          U1111 00 [008] - -
          [ESP_timeout]
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
                    Outside air temperature: -31.5 °C
                    Voltage terminal 15: 13.7 V
                    Control Module temperature: 46.0 °C
   Coding: 662FF2
   Coding: 262FF2
   Coding: 3E04010202
10 Faults Found:
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
                    Voltage terminal 15: 14.004 V
                    Velocity_vehicle_reference: 8.72 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.45 m/s²
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:35
                    Voltage terminal 15: 13.999 V
                    Velocity_vehicle_reference: 7.51 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.39 m/s²
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:35
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:34
                    Voltage terminal 15: 14.002 V
                    Velocity_vehicle_reference: 8.20 m/s
                    Longitudinal_acceleration_vehicle_reference: -3.24 m/s²
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 144820 km
                    Date: 2019.08.20
                    Time: 19:56:51
                    Control Module temperature: 37 °C
                    Voltage terminal 15: 11.793 V
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 144820 km
                    Date: 2019.08.20
                    Time: 19:56:51
          U1113 00 [008] - -
          [FAULT_CIS_US_FAIL]
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
                    Voltage terminal 15: 14.007 V
                    Velocity_vehicle_reference: 8.70 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.21 m/s²
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:33
   ROD: EV_BC7.rod
          U1113 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:36
                    Voltage terminal 15: 13.9 V
                    Control Module temperature: 54.0 °C
          U1113 00 [008] - -
          [SWA_Signal_error]
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:36
                    Fault Priority: 9
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
   ROD: EV_RGS_L.rod
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
   ROD: EV_RGS_R.rod
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
          U1111 00 [008] - -
                    Reset counter: 134
                    Mileage: 144818 km
                    Date: 2019.08.20
                    Time: 16:05:32
End----(Elapsed Time: 02:38, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
Geosan1638
Romania
C?ID=272555
we seem to have the same problem. Can you please check your auto trans connector and see if you had coolant ingress?
vladomkd
Macedonia
C?ID=332408
does your car lose communication with the ABS or the AutoTrans ECU?
Geosan1638
Romania
C?ID=272555
just the ABS.
vladomkd
Macedonia
C?ID=332408
did you manage to solve the problem by cleaning the trans connector? cause this is really weird problem, and it happens from time to time, so you can never be sure you fixed it...
vladomkd
Macedonia
C?ID=332408
i have looked through your autoscan, you have a newer ABS module (4G0 907 379 F), whereas mine is revision B. it seems unlikely that the exact same problem will happen for different HW/SW revisions...
morski
Cheshire UK
C?ID=90186
try connecting the flexray cable (2 core) directly to the sensor electronics (3B) under the centre console at the rear. Seems to a communication error that i can think of. Failing that replace the abs ecu
vladomkd
Macedonia
C?ID=332408
i'm sorry could you elaborate... isn't the ABS unit directly connected to the sensor electronics already?
morski
Cheshire UK
C?ID=90186
Yes it is but seeing as you have a comms error on the flexray i would see what happens if its connected to it directly
vladomkd
Macedonia
C?ID=332408
Should this connection run in parallel to the existing one? Also, what about all the specs coming with flexray (termination, wiring in twisted pair etc...)?
morski
Cheshire UK
C?ID=90186
Disconnect the original flexray that comes form the abs module and connect it directly to the j533 diagnostic interface under the back seat. Some modules run the flexray to the sensor unit 3B and some to the j533. so as you have acc your flexray runs from abs unit to J851 (image processor unit) to J533. If you have the wring diagrams you will know what im referring to
Use a twisted pair for now ie from a cat 5 cable as its only a temporary connection.
vladomkd
Macedonia
C?ID=332408
i have used this weekend to dig under the carpet and take a look at the image processing ECU. the visual inspection did not reveal anything suspicious (i know this is not a scientific approach) and i still haven't got into running a flexray bypass.
i'm more and more considering replacing the ABS ECU, since after everything that i have checked and modified it seems less and less likely that it is wiring problem. i have two dilemmas here... first of all it is very likely that the new ABS ECU will be a different version (mine is 4G0907379B, as far as i can tell from ETKA newer compatible ones are G and J). will these new versions require the same code as my current one (or a different one considering the different HW revision) and will i be able to code the new ECU myself using VCDS or ODIS?
also, can please somebody check if there is some sort of service bulletin for this unit? i can't seem to find this info publicly available... as far as i can tell this revision (B) was dropped from use very early in the production run (car is 03.2011, version J is in use since 01.2012) and i find this strange, it is likely they have located some issue with revision B.
thank you
marvin1980
C?ID=171833
Hi everybody.
I had similar problems. Having communication problems and ABS module going offline/stuck when reaching 15km/h. Changed the ABS module but after a week or so the problems came back. For me, it turned out to be a bad grounding problem. There are 2 brown negative wires coming out of the abs connector. They bolt to the frame below the ABS unit.
I have unbolted them sprayed some contact spray and bolt them Back. This fixed the problem. When first testing with the multimeter I just measured 0 ohms to ground and thought no problems there. But later on, when still measuring and moving the cable around I saw spikes reaching 175 ohms. So opened up the grounding point, sprayed it and that fixed my error.
Maybe this will help someone.
Best regards,
Marvin
