2015 Passat Tdi Se -Airbag Control Module/No Communication
Bigbsk8s
Texas, USA
C?ID=377564
Hello Good people,
My name is Bryan. I am the proud owner of a 2015 Passat tdi se. I am new to VCDS, This ismy first postas well as my first autoscan. I purchased the Hex can cable as a result of my airbag failure dashboard light coming on. Prior to ordering the cable I checked all fuses which all of them looked good, I removed the airbag control module and checked the connector for bent pins/noticeable damage and the module looked ok as well as the connector. With most of the faults reading the airbag control module has no communication I am guessing the ACM went out. Has anyone had these same faults and have any advice as to the best and most cost effective way to fix this? Any advice would be greatly appreciated.
Thursday,22,August,2019,19:42:18:06070
VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
VIN: 1VWBV7A36FC093834   License Plate:
Chassis Type: A3-VW41 (7N0)
          75 77
VIN: 1VWBV7A36FC093834   Mileage: 78100km-48529miles
15-Airbags -- Status: Malfunction 1010
Address 01: Engine (J623-CVCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 016 D    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 9466
   Revision: 8AH20---
   Coding: 011D0012032410080000
   Shop #: WSC 04909 444 00000
   ASAM Dataset: EV_ECM20TDI01104L997016D 004002
   ROD: EV_ECM20TDI01104L997016D.rod
   VCID: 34311C564EBA14C71E1-8060
4710 - No Communications with Airbag Control Module
          U0151 00 [040] - -
                    Mileage: 78015 km
                    Engine speed: 0.00 /min
                    Coolant temperature: 50 °C
                    Intake air temperature: 51 °C
                    Voltage terminal 30: 12.460 V
                    Limitation: accelerator pedal: 140.0 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 2
                    selected gear-Bits 0-7: 0
   Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4518
   Revision: 05653104    Serial number: 00001501270285
   Shop #: WSC 09003 957 00200
   VCID: 2517F112F9E07D4F99F-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -  - Intermittent
                    Fault Frequency: 73
                    Reset counter: 39
                    Mileage: 64385 km
                    Date: 2019.03.23
                    Time: 15:29:17
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: C54BC0F5492B00FDA31303E7921D0042A1100012
   VCID: 04518C965E1A6447EE1-8050
                    Reset counter: 46
                    Mileage: 78015 km
                    Count: 12
                    Count: 16384
                    Count: 8226
                    Count: 44544
                    Count: 65280
                    Count: 1
02214 - Tire Pressure Warning
                    Reset counter: 6
                    Mileage: 78060 km
                    Date: 2019.08.22
                    Time: 08:53:48
                    Count: 16384
                    Count: 32768
                    Count: 8704
                    Count: 16401
                    Count: 49223
                    Count: 65534
                    Count: 65276
                    Count: 768
   Part No SW: 561 907 426 J    HW: 561 907 426 J
   Component: AC Manuell    H02 0404
   Revision: 00001K01
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 221DEA0EE44E8A77FCD-8076
13701600 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Airbagsteuergerät - kein Signal/Kommunikation --> Fehlende Botschaft [ID] von Airbagsteuergerät]
                    Fault Frequency: 12
                    Reset counter: 46
                    Mileage: 78015 km
                    Date: 2019.08.21
                    Time: 19:52:02
   Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
   Component: BCM PQ35 B+   122 0174
   Revision: BH122001
   Coding: EF200E1B902B08D4098800010600044800F1A08640801520648060000C70
   VCID: 73B3DF4A0BB453FFC7B-8026
                    Reset counter: 46
                    Mileage: 78015 km
                    Date: 2019.08.21
                    Time: 19:52:02
                    Voltage: 12.25 V
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD06CKG/
   Coding: 00004D53
   Shop #: WSC 49769 002 1048576
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 72BDDA4E742E5AF7CCD-8026
   Serial number: 6940000Y150001C14K0B
   Coding: 303044
   Serial number: 3572MSME45101D4EZZZZ
   Serial number: 3582MSME40743C4EZZZ%
   Serial number: 3516KSME041B6735ZZZQ
   Serial number: 3526KSME115A6935ZZZU
   Serial number: 3556LSME60336634ZZZP
   Serial number: 3566LSME69086634ZZZ.
9445892 - Seat occupied recognition control module
          B1022 04 [137] - Internal System Fault
                    Mileage: 74506 km
                    Date: 2019.07.17
                    Time: 08:21:37
   Part No SW: 1K5 953 521 BM    HW: 5K0 953 569 AE
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20150219200629
   Coding: 088A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79AFED62295829AF8D7-802C
   Component: E221__MFL-8LP  H07 0023
   Serial number: 00000000000001044553
   Coding: E20000
   Part No SW: 561 920 970 G    HW: 561 920 970 G
   Component: KOMBI         H05 0813
   Coding: 231E01
   VCID: 1E65DEFED036AE97D85-804A
12669184 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Airbag: keine Kommunikation]
                    Reset counter: 46
                    Mileage: 78015 km
                    Date: 2019.08.21
                    Time: 19:52:01
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 08041503000791
   Coding: 461000
   VCID: 005980864A027867CA9-8054
                    Fault Status: 00110100
                    Reset counter: 46
                    Mileage: 78015 km
                    Date: 2019.08.21
                    Time: 19:52:00
Address 1C: Position Sensing
   Component: IMMO          H05 0813
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC22E5CFE923774D-803E
Address 2E: Media Player 3
   Revision: 13110009    Serial number: 0009474590
   Coding: 0404B5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BE397EA83A4FBBFFFB-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630150413190222
   Coding: 800000
68107 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Front CAN AirBag]
                    Reset counter: 46
                    Mileage: 78015 km
                    Date: 2019.08.21
                    Time: 19:52:02
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 215    3501
   Revision: 00H22000
   VCID: 392F2D626558E9AFCD7-806C
   Component: EZE_2         H55 1653
   Coding: 01030108
   VCID: 6FBBD33A679C771F233-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011429501475
   Coding: 181100
   Component: Analoguhr  009 0005
   Revision: 15110009    Serial number: 0009433614
   Coding: 0404B4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CE194F686AAFC87F61-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631150413115755
   Coding: 800000
          U1111 00 [008] - -
          [Front CAN AirBag]
                    Reset counter: 46
                    Mileage: 78015 km
                    Date: 2019.08.21
                    Time: 19:52:01
   Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
   Component: Radio Prem-8  H08 0009
   Revision: -----13S    Serial number: VWZ4Z7R3697276
   Coding: 0100044004000B
   VCID: 2B03072A93044B3F4FB-807E
                    Fault Frequency: 25
                    Reset counter: 184
                    Mileage: 64343 km
                    Date: 2019.03.23
                    Time: 11:38:42
                    Reset counter: 31
                    Date: 2063.15.31
                    Time: 07:30:16
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0156
   Serial number: 000003554140535
   Coding: 02140102C21632007F1606C00000
   ASAM Dataset: EV_OCULow 002009
   ROD: EV_OCULow_002.rod
   VCID: 1471BCD62EFAF4C77E1-8040
0035 - Databus
          [CAN TO Airbag]
                    Fault Frequency: 12
                    Reset counter: 46
                    Mileage: 78015 km
                    Date: 2019.08.21
                    Time: 19:52:06
   Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007666968540
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 323D1A4EB4AE1AF70CD-8066
End----------(Elapsed Time: 01:38, VBatt start/end: 13.2V/13.2V)-----------
DrPeter
16.4905° S, 151.7375° W
We have a Ross-Tech wiki page for the fault code B1022-Seat occupied recognition control module that maybe of some help.
Since the 'Seat Occupied Recognition Control Module (J706)' has an "Internal System Fault" it is most likely that the J706 is faulty.
However I would still check the power, ground and signal connection to the Air Bag controller. There is a three pin connector [T3aj] on the J706, see the Official Factory Wiring Diagrams for more details.
If you do end up replacing the J706 controller, I strongly recommend to use same exact part number or a newer version/part number if available. (Check with your local Volkswagen Parts department)
Use this Ross-Tech wiki page to help with the Basic Settings for the Seat Occupied Recognition Control Module (J706).
Hope this helps,
drpeter
Bigbsk8s
Texas, USA
C?ID=377564
Will do and thank you very much! Should time permit given my hectic work schedule I hope to find the time to look more into this matter on Sunday. I will post status once I do, Thanks again!
