A6 C7 HBA retrofit
Juan
Spain
C?ID=351946
I would appreciate your help, because I cannot Initialize unite 20
I am afraid some hidden code is hiding the possibility of updating the modules .
No hardware has been changed
First, I copy last Log where failure appears
Second, I copy the very initial log of the car
Thanks a lot for your help!!
VIN: WAUZZZ4G2GN060932   License Plate:
Mileage: 83340km-51785mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 3B 42 44 46 52 53 5F
          62 72 85 8B 8E 8F 90
VIN: WAUZZZ4G2GN060932   Mileage: 83340km-51785miles
17-Instruments -- Status: Not registered 0101
20-High Beam Assist. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CYPA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 4G5 907 115 B    HW: 8T2 907 115
   Revision: --H13---
   Coding: 0A2500322466010B2002
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TFS0204G5907115B 001003
   ROD: EV_ECM20TFS0204G5907115B.rod
   VCID: 290E0B21597F715FBD7-807C
   Part No SW: 4G0 927 166 P    HW: 0B5 927 156 K
   Component: 0B5 20TFSIRdW H03 0001
   Revision: --H03---
   Coding: 100001
   ASAM Dataset: EV_TCMDL501021 001021
   ROD: EV_TCMDL501021.rod
   VCID: 3A2CC46DACD9CAC7C4D-806E
   Part No SW: 4G0 907 379 S    HW: 4G0 907 379 S
   Component: ESP9 Premium  H01 0530
   Coding: 11A69E49886579929B00
   ROD: EV_ESP9BOSCHAU57X_004_AU57.rod
   VCID: 41DEB381C10F991F857-8014
   Part No SW: 4H0 907 064 GN    HW: 4H0 907 064 GN
   Component: BCM2 2.0      H37 0572
   Coding: 01A8700E000000000000
   VCID: 7BA20169E3E333CF9FB-802E
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 4G0 820 043 BH    HW: 4G0 820 043 BH
   Component: KLIMA 2 ZONEN H14 0112
   Serial number: 21071500110058
   Coding: 64011008A50000
   ASAM Dataset: EV_AirCondiBasisUDS 003009
   ROD: EV_AirCondiBasisUDS_003.rod
   VCID: 6694401D88E19E27505-8032
   Part No SW: 4H0 907 063 DF    HW: 4H0 907 063 AF
   Component: BCM1 2.0      H20 0311
   Revision: 13020001    Serial number: 00001070385502
   Coding: 2600001500F471E28181408060001D0CCF9CC30826090201000004206101150200400008010000
   Shop #: WSC 31416 572 00329
   VCID: 6FBA2539A79B5F6F233-803A
   Component: WWS57X 150704  H37 0080
   Serial number:         150712021524
   Coding: 0045F7
   Serial number: 24098434
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 AL    HW: 4G0 941 531 AL
   Component: E1 - LDS  H07 0044
   Serial number: 16 07 2015  00000207
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: AEA84AB7000000000001
03395 - Control Module for High Beam Assistant
                    Reset counter: 106
                    Mileage: 83210 km
                    Date: 2019.08.15
                    Time: 10:30:20
Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
   Part No SW: 4G0 919 475 G    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0070
   Revision: --------    Serial number: 56231520200518
   Coding: 980B14
   ASAM Dataset: EV_EPHVA2CAU64X0000 001011
   ROD: EV_EPHVA2CAU64X0000.rod
   VCID: 3536D75185C725BF29F-8060
   Part No SW: 4G0 907 561 B    HW: 4G0 907 561
   Component: ACC3          H21 0053
   Coding: 7C04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002014
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1005U6C$
   Coding: 30333130313630323532554A304C34473053
   VCID: 3B22C169A3E3F3CFDFB-806E
   Serial number: 3575HRB404R3CGVGAPDL
   Serial number: 3585HRB404P3CGVG7OVY
   Serial number: 3515JRB405R3GICEE06I
   Serial number: 3525JRB405L3G5J43GMI
   Serial number: 3554VRB405B3G5J24OV
   Serial number: 3564VRB40593G5J2P0VY
   Revision: --------    Serial number: 90372OGP00022
   Coding: 00003C
   VCID: 372ADD599F4BD7AF3B3-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 09 06 2015  C0022386
   Part No SW: 4G8 920 934 F    HW: 4G8 920 934 F
   Component: TBenRdwAcc    H10 0104
   Revision: 06001087    Serial number: 658240715596019
   Coding: 138608000F450008050000
   ASAM Dataset: EV_RBD4K 004055
   ROD: EV_RBD4K_AU57.rod
   VCID: 3430EA558EBD3CB71E1-8060
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000001933616
   Coding: C0CD072918
   ASAM Dataset: EV_GatewPkoUDS 001028
   Serial number: 9616267303
   Voltage stabilizer:
   Serial number: 15051500000000000055
5701 - High Beam Assistant Control Module
          U1070 00 [009] - No Communication
                    Reset counter: 106
                    Mileage: 83210 km
                    Date: 2019.08.15
                    Time: 10:30:57
                    Voltage terminal 30: 14.3 V
                    Voltage terminal 15: 14.3 V
                    Control Module temperature: 24 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
0021 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät falsch codiert (CAN)]
                    Fault Frequency: 18
                    Reset counter: 110
                    Mileage: 83012 km
                    Date: 2019.08.14
                    Time: 10:13:39
                    Voltage terminal 30: 14.2 V
                    Voltage terminal 15: 14.2 V
                    Control Module temperature: 27 °C
                    Engine running: On
                   IN ZAS_Te_X: On
                    Datenfeld: 0
Address 20: High Beam Assist.
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H04 0056
   Revision: --------    Serial number: EJ1BPA8209WC3H
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3634D05D98C12EA7205-8062
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0507
   Coding: 011C17015C00628002080003
   VCID: 45D6A791D5A7B53FB9F-8010
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0006006213
   Coding: 101100010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   VCID: 392EDB61A9DFC1DFCD7-806C
   Revision: 00002001    Serial number: 0375319625
   Coding: 0100063800B90080833008040C010E470000000000000000000000000000
   Component: TSG BF        H03 0507
   Coding: 011C17015E04628002080002
   Shop #: WSC 31416 000 00000
   VCID: 46D4A09DE8A1BE27B05-8012
00380 - Special Vehicle Control Module (J608)
                    Fault Frequency: 47
                    Reset counter: 110
                    Mileage: 83012 km
                    Date: 2019.08.14
                    Time: 10:13:36
  Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H04 0015
   Revision: --------    Serial number: 00000001544296
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D06FF316D976D7F51F-8078
   Part No SW: 4G1 035 043 R    HW: 4G1 035 043
   Component: MU-H-N-EU     042 0335
   Serial number: A591G0F7539704
   Coding: 01750101FF0A000013110001000A00002F0006E5F17001009F
   Subsystem 1 - Part No SW: V03 959 801 PR    HW: -----------
   Component: ECE 2018  --- 0166
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0006
   Serial number: AUZ8Z9FY802A8J
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Serial number: 90349OGN00088
   Compact Disc Database:
   Component: Gracenote  --- 1010
   Component: TSG HL        H03 0507
   Coding: 010815004000628002080002
   VCID: 49CEABA1F9BF515F5D7-801C
   Component: TSG HR        H03 0507
   Component: DPC-SG        H27 0081
   Coding: 6A040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C00F235568D6477461-8078
   Part No SW: 4G0 907 541 B    HW: 4G0 907 541
   Coding: 7C04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002012
   VCID: 270A0D194F6B472FAB3-8072
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0092
   Serial number: 005000622207157
   Coding: 0480A9181111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 00660600031F0376000308014248D2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313EE34171AF099F757-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 323CEC4D74A932870CD-8066
End----------(Elapsed Time: 01:42, VBatt start/end: 13.3V/13.3V)-----------
Sunday,15,November,2015,10:52:07:33490
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: WAUZZZ4G2GN060932   License Plate: 5050
Chassis Type: 4G (4G8)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 3B 42 44 46 52 53 5F 62
          72 85 8B 8E 8F 90
Address 01: Engine (J623-CYPA)       Labels: None
   Revision: --H13---
   ROD: N/A
   VCID: 295F8BFF487BF056EC3-807C
No ASAM data for: "EV_ECM20TFS0204G5907115B" (AU57)
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Revision: --H03---
   Coding: 100001
   VCID: 3A7D44B3BDDD4BCE959-806F
Address 03: ABS Brakes (J104)       Labels: 4G0-907-379.clb
   ROD: N/A
   VCID: 418F335FD00B1816D43-8014
No ASAM data for: "EV_ESP9BOSCHAU57X" (AU57)
   VCID: 7BF381B7FA67B2C6CEF-802E
   ROD: EV_AirCondiBasisUDS.rod
   VCID: 66C5C0C399E51F2E011-8033
Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
   Coding: 2600001400349FE28181408000001D0C0F9CC30826090201000004206101150200400008010000
   VCID: 6FEBA5E7BE1FDE66727-803A
   Coding: 0045F7
   Coding: 02006D
Address 10: Park/Steer Assist (J791)       Labels: None
   Coding: 980B14
   ROD: EV_EPHVA2CAU57X0000.rod
   VCID: 3567578F94C3A4B678B-8060
Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
   Coding: 7C04010202
   ROD: EV_AdaptCruisContrAU57X.rod
Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
   ROD: EV_AirbaAU10BPAAU64X_AU57.rod
   VCID: 3B7341B7B2E772C68EF-806E
   Crash sensor for front airbag; passenger side:
Address 16: Steering wheel (J527)       Labels: None
   Coding: 00003C
   VCID: 377B5D8786CF56A66A7-8062
Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
   ROD: EV_RBD4K.rod
   VCID: 34616A8B9FB9BDBE4F5-8061
   Coding: C0CD072918
   ROD: EV_GatewPkoUDS.rod
   Voltage stabilizer:
   ROD: EV_SARA2_AU57.rod
   VCID: 3665508389C5AFAE711-8063
   VCID: 4587274FCC233436E8B-8010
Address 44: Steering Assist (J500)       Labels: None
   ROD: EV_RCEPS.rod
   VCID: 397F5BBFB8DB40D69C3-806C
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Coding: 011C17015E00628002080002
   VCID: 46852043F1253F2EE11-8013
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 2D577FEF7C93EC7600B-8078
   Part No SW: 4G1 035 043 E    HW: 4G1 035 043
   ROD: EV_MUHig6C3Gen2HBAS.rod
   VCID: 204996DB3B41311EBBD-8075
   Engine Control Module 2:
   Subsystem 1 - Part No SW: V03 959 801 F    HW: -----------
   Component: ECE 2015/2016  --- 0122
   Seat Adjustment Driver Side:
   Sound System:
   Door Electronics Rear Left:
   VCID: 499F2B7FE03BD0560C3-801C
Address 85: On Board Cam. (J852)       Labels: None
   Coding: 6A040000
   VCID: 2C5172EB4789E57E175-8079
Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
   Coding: 7C04010202
   ROD: EV_AdaptCruisContr2AU57X.rod
   VCID: 275B8DC75E6FC626FA7-8072
Address 8E: Image Processing (J851)       Labels: None
   Component: BV-SG         H33 0090
   ROD: EV_BC7.rod
   ROD: EV_RGS_L.rod
   VCID: 316F639F60AB8896243-8064
   ROD: EV_RGS_R.rod
   VCID: 326D6C9365ADB38E5D9-8067
End   -
OP is verified. Moving to Retrofits.
I'll note that the second scan above (the "initial" scan) is from a clone, but I will let that slide since he has come clean with a properly registered HEX-V2.
Since HBA "Cannot Be Reached" I suspect a wiring problem.
Juan
Spain
C?ID=351946
No cable problem
I don’t expect any problems with cables because the car has ACC and this system shares cabling from the front mirror sensor and image processor (and ACC performances are ok)
is there any other HBA dedicated cable I should check?:banghead:
Thanks a lot:o
South Molton, UK
AFAIK the ACC doesn't make use of the 20 camera module, only the front radar?
I would check fuses and wiring to the 20 module using the WD relevant to your car.
torrebasetez
Spain
C?ID=354490
Can you say what connections you have made and what coding?
Juan
Spain
C?ID=351946
I haven’t changed any cable, nor pins in connector. Hardware remains as first day!
the only change has been in configuration (by means of legal vcds interface) and you can see it from my initial message
Is there any dedicated fuse for this hba function? because I am checking Audi wiring schemata and I cannot find it
torrebasetez
Spain
C?ID=354490
hba is in the rearview mirror. It is not the camera of the acc or lane assist.
MasterTommy
Amsterdam
C?ID=295586
Are you sure youre not looking at a photosensor for a mirror with dimming function?
Also, anything that is not needed (wires, control modules, brackets, etc) for how the car came out of the factory is never fitted to your car and will have to be retrofit.
Juan
Spain
C?ID=351946
Ok, HBA ifunction is in rear mirror electronics, but my car has that rear mirror electronics suitable for HBA, and those units do not report any power supply fault (they are properly connected to main supply), CONCLUSION: there is no wiring problem and unit 20 has to be availabe for VCDS.
Address 8E: Image Processing (J851) Part No SW: 4H0 907 107 H HW: 4H0 907 107------------------------------------
Address 85: On Board Cam. (J852) Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Address 3B: Sensor Elect. (J849) Part No SW: 4G0 907 637 K HW: 4G0 907 637 F
I am lost.. I know there is a wrong step in my rationale, Please tell me what`s wrong
MasterTommy
Amsterdam
C?ID=295586
Is the mirror part number also fitted to cars with HBA, or is there a different part number for that?
Edit: the first two are lane-departure modules and the last is related to the airbags. Again, have you checked the ETKA to see if cars with the HBA option have a different mirror fitted?
torrebasetez
Spain
C?ID=354490
can you put car front photo?
Juan
Spain
C?ID=351946
torrebasetez
Spain
C?ID=354490
you don't have a rearview mirror for hba
torrebasetez
Spain
C?ID=354490
you need a new rearview mirror for hba as a photo that I put before
torrebasetez
Spain
C?ID=354490
I did retrofit hba and bought kit in k electronic ...
Rizzio
Trondheim, Norway
C?ID=369124
Just so im shure HBA is the high beam assist?
Confirm that you have tha front faceing camera in the rear view mirror asembley.
And that pin 8 and 3 in the 8 pin plug have wires.
If no: get the hardware (camera and wire)
If yes: Changes made are at your own risk
try to log in to unit 09.
Byte 5 Bit 6 set to 1
Byte 20 Bit 3 set to 1
Byte 27 Bit 7 set to 1 (only for cars without adaptive lights/without afs)
If you have alwr: 55
Byte 5 bit 6 set to 1
Juan
Spain
C?ID=351946
ok. I will check the kind of rear mirror and it’s connecting wires, and I will also keep you informed, but I cannot make any advance in this task until next Wednesday
