2015 Golf MK7 R BOOT / REMOTE FOB ISSUES
Davers1
Ireland
HC423489 (2nd hand?)
Hi guys , first time posting here so hopefully I'm in the right section.
I've also purchased the vcds kit in the hope i can possibly rectify some coding I'm told was done by the previous owner.
i'll do my best to explain the car itself has keyless entry , I've also gone through all settings on infotainment and nothing fixed it.
so my issue is when i walk up with my key in hand to open boot with keyless entry it stays locked.
so i press the lock button on the remote and presto i can then pull latch and the boot opens.
if i come out first thing in the morning and just hold down the boot open on key fob the boot releases but sets the car alarm off.
i hope I've explained this issue fairly well its basically the boot lock appears to work in reverse.
all functions are working just the wrong way around.
im not sure what to do from here do i need to post a vehicle scan or can any suggest any pointers.
thanks for reading and hopefully i can get some help.
Yes, please do post an Auto-Scan so people can see how this car is equipped and configured.
Davers1
Ireland
Ok Great I’ll try do it in the morning!
Davers1
Ireland
Wednesday,21,August,2019,12:50:51:11308
VCDS Version: 19.6.1.0 (x64)
VIN: WVWZZZAUZFW239900   License Plate: 151DDAVE
Mileage: 69224km-43013mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 20 22 2B 42 44 47 52
          55 5F A9
VIN: WVWZZZAUZFW239900   Mileage: 69224km-43013miles
          55 5F A9
A9-Struct. Borne Sound -- Status: Not registered 0001
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 E    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 091D00322466050B3004
   ASAM Dataset: EV_ECM20TFS0205G0906259E 001005
   ROD: EV_ECM20TFS0205G0906259E.rod
   VCID: 3065E5826B0F7FCF29-8064
15072 - Engine Start Blocked by Immobilizer
          P1570 00 [104] - -
                    Mileage: 69089 km
                    Date: 2019.08.19
                    Time: 19:40:55
                    Engine speed: 1320.50 /min
                    Normed load value: 5.9 %
                    Coolant temperature: 91 °C
                    Intake air temperature: 58 °C
                    Voltage terminal 30: 12.089 V
                    FRF_IMMO_SNAPSHOT_BYTE1: 25
                    FRF_IMMO_SNAPSHOT_BYTE2: 127
                    FRF_IMMO_SNAPSHOT_BYTE3: 140
                    FRF_IMMO_SNAPSHOT_BYTE4: 27
                    FRF_IMMO_SNAPSHOT_BYTE5: 16
                    FRF_IMMO_SNAPSHOT_BYTE6: 0
                    Engine: operating status: IS
Readiness: 0010 0001
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4522
   Revision: 03253104    Serial number: TFK01501121573
   ROD: EV_TCMDQ250021.rod
   VCID: 1F47163E0691F0B780-804A
   Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
   Component: ESC           H42 0711
   Revision: 00000000    Serial number: 60165000001724
   Coding: 01FA93A1542329750780070041C36980C92A94E0E08296F7184250F8C208
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 4993A866E8952E070E-801C
   Revision: 00021000    Serial number: 0357554449
   Coding: 030C0C
   VCID: 3A71C7AABD73B59F97-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00120014200100011005000000101000
   VCID: 6AD137EA8D53C51F27-803E
   Air quality sensor:
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011501900387
   Coding: 03111B46C64122F30BA44080B10407281800000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 000575429B2F2F4F99-8054
   Component: WWS    150103  042 0551
   Serial number:         150108205225
   Component: RLHS  037 0059
   Serial number: S4Y15M01D21H22M40S18
   Coding: 00A8DD
   Serial number: 000000000ZY1500704XA
   Serial number: 00000000000031523620
   Sun Roof:
   Component: J245 PS73.403  H02 0003
   Serial number: 0000FST0002MHGL00000
   Coding: 181801
          B1263 01 [008] - Electrical Failure
                    Fault Frequency: 45
                    Reset counter: 89
                    Mileage: 69089 km
                    Date: 2019.08.19
                    Time: 19:31:03
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391501405271
   Coding: 0071151011
   VCID: 3D7BCCB6AC5D82A7B2-8068
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Serial number: 17121403271532
   Coding: 001C1300FE0739
   VCID: 3875DDA2837FA78F61-806C
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H16 0115
   Serial number: 20121441350052
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 76E9139AC9EB11FFB3-8022
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R0F6YFZ
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4183B046D0A5E647D6-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 601 15
   Serial number: 35767000000D8AF09210
   Subsystem 2 - Part No SW: -----------    HW: 480 001 501 15
   Serial number: 3586700000027D29B21X
   Subsystem 3 - Part No SW: -----------    HW: 480 401 401 15
   Serial number: 35165029B1901DA44356
   Subsystem 4 - Part No SW: -----------    HW: 480 401 401 15
   Serial number: 3526502A9196FF40912I
   Subsystem 5 - Part No SW: -----------    HW: 480 401 501 15
   Serial number: 3556502C319121A483E8
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 15011504401108
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 7BFF02AEF2C94C97CC-802E
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
   Part No SW: 5G1 920 758     HW: 5G1 920 758
   Component: KOMBI         304 4310
   Coding: 27AD08183F80040800887E011400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   VCID: 6CDD31F287A7DB2F55-8038
9456128 - Engine Control Module (ECM) not authorized
          B104A 00 [009] - -
                    Fault Frequency: 17
                    Mileage: 69089 km
                    Date: 2019.08.19
                    Time: 19:40:54
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0002965523
   Coding: 030100042F085900EF00027A9C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72E12F8AA5830DDF9F-8026
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0038
   Serial number: 36150000025040075025
   Coding: 2DFFFF
   Serial number: 5565015503
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
                    Fault Frequency: 62
                    Reset counter: 49
                    Mileage: 69084 km
                    Date: 2019.08.19
                    Time: 19:16:12
                    Supply voltage: Terminal 30: 11.9 V
                    Terminal 15: On
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511 D
   Component: FLA           H05 0002
   Revision: AA001001
   Coding: 02028864727264565625393E01
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: 2B5FF2EE42291C171C-807E
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00017.11.14
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   VCID: 4689A35AF98BC17FE3-8012
   Revision: 00000000    Serial number: 15000010357001
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346DE9929F1743EF4D-8060
   Serial number: 150115BA612242
   Coding: 003F1220D001040000001000
   VCID: 4281BF4AD5A3FD5FCF-8016
   Serial number: 00000000000005016677
   Coding: 0D0000
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 87
                    Mileage: 69167 km
                    Date: 2019.08.20
                    Time: 14:16:40
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 8103
   VCID: 3777DE9E8E61A8F768-8062
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC40244W%
   Coding: 120000008AAA8A0000
   ASAM Dataset: EV_AMPMst11CALPI 001007
   ROD: EV_AMPMst11CALPI.rod
   VCID: 63CF5ACE6A799457E4-8036
   Serial number: 120115BAC07127
   Coding: 003F1020DE01040000801000
   Serial number: 00000000000004937392
   Coding: 150000
   Coding: 02A602000B010200
   VCID: 4085B542DBAFEF4FD9-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 043 E    HW: 5G0 035 043 D
   Component: MU-H-N-EU     H44 0376
   Serial number: A309A0F7521764
   Coding: 027300010000000011110002000800001F0207F60100010057
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 204515C23BEFCF4FB9-8074
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9PU300AUZ
   Subsystem 2 - Part No SW: V03 959 801 DG    HW: -----------
   Component: ECE 2016/2017  --- 0153
   Compact Disc Database:
   Component: Gracenote  --- 1010
   Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 141121201809
   VCID: 2D5BFCF67C3D122702-8078
End-------------------------(Elapsed Time: 05:56)--------------------------
Davers1
Ireland
Just posted the autoscan hopefully that makes some sense to the more knowledgeable folk on here.
Would be very grateful if anyone could help.
Davers1
Ireland
Hi uwe , I’ve done that but no luck with a reply , I’m unable to post in the verified section aswel? Can you help me please 🙏🏻
Less than 12 hours passed between the time you posted your scan and the time you posted this.
Personally, I'm not sure what's up with your car. I don't think it's the remotes themselves, but some kind of configuration problem with your BCM. What changes have you made to it?
I’m unable to post in the verified section aswel? Can you help me please ����
That's because you're not Verified. The system you're using is registered to someone named "Shane", whereas your profile here says your name is "Dave".
Davers1
Ireland
No problem Shane is my boss hopefully he can sort this.
I haven’t done any coding I bought the car with the boot like this , the previous owner did coding but wasn’t sure what he did?
Thanks for your time
