Coding for LED Bulb Out dash warning light 2013 Golf 2.5L
Val
Canada
C?ID=303782
Greetings!
Changed some of the lights in the back of my 2013 Golf 2.5L with LED and of course I received the amber 'Bulb Out' light on dashboard.
I have the VagCom cable registered for the car but I wanna be sure I do the right coding on Bit 18 and not do some irreversible damage to the coding.
Found this on youtube but not sure if applies to my car:
https://www.youtube.com/watch?v=-J91O3ClPCY
I will gladly use some wisdom and knowledegeable advise from any of you. Thanks.
South Molton, UK
Gonna need you to post a VCDS Auto-Scan of your Golf to suggest needed changes, which might be adaptation not coding.
Val
Canada
C?ID=303782
Saturday,17,August,2019,11:15:08:64309
VIN: WVWDA7AJ1DW101XXX   License Plate:
Chassis Type: AJ-VW36 (7N0)
VIN: WVWDA7AJ1DW101307   Mileage: 71440km-44390miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 DH    HW: 07K 907 309 B
   Component: 2,5l R5/4V      G01 3848
   Revision: T4H06---    Serial number:
   Coding: 0000075
   VCID: 77A8E2B9B3C2F7EFFB3-8022
   Part No SW: 09G 927 750 LM    HW: 09G 927 750 LM
   Component: AQ 250 6F           2252
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 07489279C322876F8B3-8052
   Revision: 00H31001
   Coding: 114B400C492200FB880E02E492200041310000
   VCID: 7DA4F0919DFEDDBFA1F-8028
   Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
   Component: AC Manuell    H20 0505
   Revision: 00001018
   Coding: 0010004002
   VCID: 7BA0FE89836AD38F9FB-802E
   Part No SW: 1K0 937 084 J    HW: 1K0 937 084 J
   Component: BCM PQ35  B   111 0709
   Revision: AC111709
   Coding: 6F180A1A94232EC4008000C15000044448010386524D8D60648020200040
   VCID: 353428B1E54EC5FF29F-8060
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 19091  26  0512
   Coding: 009795
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 205
                    Mileage: 71447 km
                    Date: 2014.01.07
                    Time: 23:03:38
                    Voltage: 14.05 V
                        Term 50 Off
00984 - Left Tail Light (M4)
                    Reset counter: 205
                    Mileage: 71447 km
                    Date: 2014.01.07
                    Time: 23:03:39
                    Voltage: 14.10 V
                        Term 50 Off
00985 - Right Tail Light (M2)
                    Reset counter: 205
                    Mileage: 71447 km
                    Date: 2014.01.07
                    Time: 23:03:39
                    Voltage: 14.10 V
                        Term 50 Off
                    Reset counter: 205
                    Mileage: 71447 km
                    Date: 2014.01.07
                    Time: 23:03:39
                    Voltage: 14.10 V
                        Term 50 Off
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R00U2RS
   Coding: 00004734
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C223D95C6E414B7D61-8068
   Serial number: 3572MSME2F062372ZZZU
   Serial number: 3582MSME54586072ZZZV
   Serial number: 3512QSME543E2071ZZZR
   Serial number: 3522QSME762D192BZZZ0
   Serial number: 35527SME24694A2EZZZR
   Serial number: 35627SME5D264C2EZZZZ
   Part No SW: 5K0 953 507 AE    HW: 5K0 953 549
   Revision: --------    Serial number:  90440LIM000WI
   Coding: 5880140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 73B0D6A9AB3A9BCFC7B-8026
   Part No SW: 5K0 920 863     HW: 5K0 920 863
   Component: KOMBI         H05 0705
   Coding: 370F00
   VCID: 6C82CDD5F6044437061-8038
   Part No SW: 7N0 907 530 AB    HW: 7N0 907 530 AB
   Component: J533  Gateway H47 1633
   Revision:   H47       Serial number: 150912F1000407
   Coding: 350002
   VCID: 70BAD9A5DAACA0D73A9-8024
                    Reset counter: 205
                    Mileage: 71447 km
                    Date: 2014.01.07
                    Time: 23:02:05
   Component: IMMO          H05 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8ECBCDFCF05A0774D-803E
   Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
   Component: Tuer-SG         009 2119
   Coding: 0001204
   VCID: 313C1CA11D26E9DF757-8064
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   VCID: 372822B9F34237EF3B3-8062
   Part No SW: 5K0 959 702 B    HW: 5K0 959 702 B
   Coding: 0001204
   VCID: 323E13AD1820D2C70CD-8066
Address 56: Radio
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 353428B1E94EC5FF29F-8060
   Coding: 0001168
   VCID: 36362FBDF448CEE7205-8062
End----(Elapsed Time: 00:52, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
Hah! Byte 18 is not masked with 00:
   Revision: AC111709
   Coding: 6F180A1A94232EC4008000C1500004444801[B][COLOR="#0000FF"]03[/COLOR][/B]86524D8D60648020200040
Val
Canada
C?ID=303782
Forget my ignorance, Uwe, what would that means and what do I need to do?
Danke!
Danke!
It means it's relatively safe to change byte 18 because you know what it needs to be changed back to if your changes don't work out. However, I am by no means an expert on byte 18 values, so I'm not going to suggest any values to try.
Val
Canada
C?ID=303782
Thanks again.
In the youtube video I attached on my first post, the guy changed the Binary and just clicked on Byte 18 and the new value just loaded without input.
Is that one way of doing it and another way is just inputting the Byte 18 value?
Ain't no way I can find out the right value for my car unless I found someone with the same car who has successfully done it? Or going to a dealer with it and have them re-code it?
Val
Canada
C?ID=303782
Thanks again.
I think I know why he did it like that. This was the old way of changing Byte 18 and I believe is no longer there in the new version of VCDS. I've seen some posts saying that there are combinations from 00 to 15, is that the case?
Val
Canada
C?ID=303782
So I looked under the options I have under Byte 18 and I took a screen shot for it but unfortunately I can't post it here. Mine looks like it is 03 set for Golf (5K1/VW360) NAR, is there a setting for LEDs in one of the other models like GTI or should I just use 02 Golf (5k1/VW360) RoW? Seems like the logical choice... Is it safe to go back to original setting if not clearing the Bulb Burn out dash light? Thanks
