2010 A4 2.0T w/multiple issues; ESP/TPMS/Parking Brake Malfunction
valdeisel
C?ID=358332
Hello all, I've been trying to pinpoint the issue affecting my Avant lately. Seems the problem has gotten worse over time. I can clear codes, then drive for a minute or two before my gauge cluster lights up with ESP, TPMS, and then the Parking Brake malfunction. If I shut down the car, restart, and drive over 34mph, the lights turn off only to illuminate while I begin to slow down.
I've run a full scan to show you what is being found. Some info upfront, I am fully aware about my engine code P1297. My turbo does have an issue with the wastegate, seems to still produce sufficient boost at all times. I'm putting that repair off till I figure out what's causing everything to light up everytime my car is driven.
The lean code P2187 is relatively new, that one popped once I completed a carbon cleaning--I 'think' I can figure that one out eventually. More likely my injectors, I've searched for air leaks using the C&C spray method, looked at the PVC diaphragm, MAF, tubing...you get the point.
Anyways, here's my scan...
Wednesday,21,August,2019,11:23:28:06641
Dealer/Shop Name: VALDIESEL
VIN: WAU4FAFL0AA011905   License Plate:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 47 52 53 55 56 5F 62
          6D 72
VIN: WAU4FAFL0AA011905   Mileage: 203270km-126306miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H14 0001
   Revision: E1H14---
   Coding: 010C010A190F0160
   Shop #: WSC 58751 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: 79AFEF500958CDDF8D7-802C
          U1113 00 [047] - -
                    Mileage: 203259 km
                    Date: 2019.08.20
                    Time: 20:54:45
                    Engine speed: 1576.50 /min
                    Normed load value: 4.7 %
                    Vehicle speed: 22 km/h
                    Coolant temperature: 96 °C
                    Intake air temperature: 52 °C
                    Voltage terminal 30: 13.523 V
          U1113 00 [096] - -
                    Mileage: 203262 km
                    Date: 2019.08.21
                    Time: 08:29:10
                    Engine speed: 3557.00 /min
                    Normed load value: 53.3 %
                    Vehicle speed: 50 km/h
                    Coolant temperature: 71 °C
                    Intake air temperature: 31 °C
2999 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
          P1297 00 [101] - -
                    Mileage: 203267 km
                    Date: 2019.08.21
                    Time: 11:08:50
                    Engine speed: 1679.50 /min
                    Normed load value: 6.3 %
                    Vehicle speed: 37 km/h
                    Coolant temperature: 78 °C
                    Intake air temperature: 46 °C
                    Voltage terminal 30: 13.216 V
4105 - Bank 1; System too Lean at Idle
          P2187 00 [237] - -
                    Mileage: 203259 km
                    Date: 2019.08.20
                    Time: 20:55:51
                    Engine speed: 816.50 /min
                    Normed load value: 9.4 %
                    Coolant temperature: 100 °C
                    Intake air temperature: 56 °C
                    Voltage terminal 30: 13.617 V
Readiness: 0000 0001
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 J    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H04 0003
   Revision: --H04---
   Coding: 001012
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 3D273B405DF031FFE1F-8068
2505 - Torque Management Feedback Signal A
          P2637 00 [047] - -
                    Mileage: 203259 km
                    Date: 2019.08.20
                    Time: 20:54:48
                    Engine speed: 818.00 /min
                    Transmission input speed: 677 /min
                    Transmission output speed: 288 /min
                    Engine torque: 24 Nm
                    Transmission fluid temperature: 82 °C
                    Accelerator position: 0.0 %
                    Clutch status: 0
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 AN
   Component: ESP8 quattro  H04 0010
   Coding: 150D18
   Shop #: WSC 06341 128 28888
   VCID: 7AADF05C0CDEC6C784D-802E
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 48
                    Mileage: 203259 km
                    Date: 2019.08.20
                    Time: 20:54:45
                    Hex Value: 0x18C0
                    Hex Value: 0x4006
                    Hex Value: 0x1226
                    Hex Value: 0x46AB
                    Hex Value: 0x00FF
                    Reset counter: 48
                    Mileage: 203259 km
                    Date: 2019.08.20
                    Time: 20:54:46
                    Hex Value: 0x11C0
                    Hex Value: 0x6206
                    Hex Value: 0x1232
                    Hex Value: 0x02AC
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DH    HW: 8K0 907 064 DH
   Component: BCM2 1.1      H02 0321
   Coding: 0D0200
   VCID: 79AFEF5009D8CDDF8D7-802C
   Component: J764 ELV MLB  H36 0042
   Serial number: 0209000034294009
00193 - Rear Right Door Handle Touch Sensor (G418)
                    Fault Status: 01101000
                    Reset counter: 48
                    Mileage: 203256 km
                    Date: 2019.08.20
                    Time: 20:44:43
   Part No SW: 8T1 820 043 AK    HW: 8T1 820 043 AK
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01031120091137
   Coding: 64102000
   Shop #: WSC 22129 444 54812
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000386277
   Coding: 26001011063CAF010000080300003D0D0F1C460800010161000000
   Shop #: WSC 06335 123 12345
   VCID: 3C213644466A38F7D61-8068
   Component: WWS 290509  H06 0070
   Serial number: SWF09050295678
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10486921
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001905092042
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EGD020U80
   Coding: 303836354230303030304A55304C384B3053
   VCID: 42DD48BC240E4E079CD-8016
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Serial number: 5810000R0900002R8J
   Serial number: 6334MSME482124486
   Serial number: 6344MSME482453516
   Serial number: 6352QSME6F2F2424R
   Serial number: 6362QSME0A2E140EN
   Serial number: 63732SME2B2F5026%
   Serial number: 63832SME64294818%
   Revision: --------    Serial number: 90304IEL000AM
   Coding: 000037
   VCID: 3D273B405D7031FFE1F-8068
   Part No SW: 8K0 920 980 M    HW: 8K0 920 980 M
   Component: KOMBIINSTR.   H19 0253
   Revision: 00100000    Serial number: BXM749W59
   Coding: 8B1711000300D705020000
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0101
   Revision: EB700052    Serial number: 5200E0950682C2
   Coding: 00C303
   VCID: 52FD78FCF4EEDE872CD-8006
   Component: J367-BDM  H06 0160
   Serial number: 1907C0CC070509
   Component: MEM-FS        H06 0073
   Revision: AA000000    Serial number: 00001001283601
   Coding: 00581B00000000000000
   VCID: 3B23355843643FCFDFB-806E
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000008915449
   Coding: 011C13204E00410001
   VCID: 45D753A035A0793FB9F-8010
   Revision: 00002001    Serial number: 0117401349
   Coding: 0126063A207A741700B0020000000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000139384
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS133  H06 0041
   Subsystem 4 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J394 PS228  H06 0041
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 46
                    Mileage: 203256 km
                    Date: 2019.08.20
                    Time: 20:50:38
02615 - Fuel Tank Cap; Lock
                    Reset counter: 46
                    Mileage: 203261 km
                    Date: 2019.08.20
                    Time: 21:01:54
   Part No SW: 8T0 035 223 AK    HW: 8T0 035 223 AK
   Component: DSP Prem      H08 0170
   Revision: 00008001    Serial number: 34881004301503
   VCID: 77ABE9683FCCDBAFFB3-8022
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000008888864
   VCID: 44D14EA43E9A4037AE1-8010
   Component: EPB Audi B8   H09 0090
   Revision: 00000003    Serial number: 00000000379855
   VCID: 34311E646E3AF0B71E1-8060
                    Fault Status: 11101101
                    Reset counter: 48
                    Mileage: 203259 km
                    Date: 2019.08.20
                    Time: 20:54:46
                    Voltage: 13.80 V
                    Count: 58
                    Speed: 16.0 km/h
                    Hex Value: 0x02E0
                    Hex Value: 0x0004
                    Hex Value: 0x0101
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06334 000 00000
   VCID: 77ABE96833CCDBAFFB3-8022
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335EL097515111
   Coding: 020000010000000001
   VCID: 1D67DBC0FDB051FFC1F-8048
   Part No SW: 8T1 035 664 A    HW: 8T1 035 664 A
   Component: H-BN-NA       H41 0042
   Revision: --------    Serial number: 490EX097505743
   Coding: 010200010106A1EC41000B0C000000030000
   VCID: 3635246C7846E2A7205-8062
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Serial number: 9356EM091003744
   Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
   Serial number: 00000000296169
   Component: CD-Database  1293
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000101225748
   Coding: 010C13204000210001
   VCID: 42DD48BC248E4E079CD-8016
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H27 0300
   Revision: --------    Serial number: 8K9827851A
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H27 0300
   Serial number: 8K9827852A
   Revision:             Serial number: 0000101225769
End----(Elapsed Time: 02:10, VBatt start/end: 12.0V/11.7V. VIgn 11.9V)-----
Jef
HQ
Thank you for posting an Auto-Scan! :thumbs:
With the the engine at idle and up to temp (+80C), go into the OBDII mode of VCDS. Go to Mode 1. Now pull up long term fuel trim and short term fuel trim. What are the values?
MAF concern (possible)... is there any sort of aftermarket air filter? Or has the car been detailed/cleaned recently? These are things that can contaminate the MAF.
valdeisel
C?ID=358332
This is what I got;
Wednesday,21,August,2019,17:56:40
VCDS Release 19.6.1 (x64):  Generic OBD2
Mode 1:Read Data
06:Short Term Trim - Bank 1     -2.3 %
07:Long Term Trim - Bank 1     14.8 %
0C:Engine RPM     791 /min  790 /min
05:Engine coolant temperature     97 °C  97 °C
In regards to the air filter, I am using an AFE drop in filter--nothing fancy. I have not detailed or sprayed off my engine bay in a long time.
NostraJackAss
Useful life warranty is 15/150K no, isn't that turbo charger a free repair?
Did you JPPSG?
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Sounds like a fuel problem or air leak no, how is it, that it would only post these limited faults and no misfire, is car modified?
Does car need any fuel pumps or injectors, if it did and wasn't FOD than wouldn't it all be a free repair according the comprehensive parts list as certified at CARB and EPA?
Vehicle Identification No.WAU4FAFL0AA011905
Modelaudi a4 av. qu. 2,0
A4
Date of production09.06.2009
Model year2010
Sales type8K556L
Engine CodeCAEB
Transmission CodeLML
Emission standard7GBEmission standard ULEV 2
ECM8K2907115ALQ00033790D389AADXV02.03UB
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=24840&flag=1
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=24839&flag=1
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=22151&flag=1
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=21673&flag=1
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=22224&flag=1
Component: 2.0l R4/4V TF H14 0001 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< UPDATE REQUIRED?
Revision: E1H14---
valdeisel
C?ID=358332
I am out of the extended warranty AoA published a while back, that was a 7yr/70K mile warranty on the turbo. I tried my luck at the dealer and was quickly shot down, if i was still living in Utah, I might have had a chance since I had a solid rapport with the SA.
No, sorry--I didn't JPPSG.
I'm not sure if it's 100% a fuel issue or an air leak, as mentioned, I did look things over and did some basic troubleshooting. The thing here is, would a fuel delivery/air leak issue drive all 3 lights to illuminate?
The car does have a stg 1 APR tune (91 file), it was flashed in 2014 and haven't had any issues till now. The only misfires I can recall were last year when I had a coil pack fail, then this year I had intake manifold runner position fail (huge air leak), and then February when my timing jumped about 4 teeth due to the failed tensioner. All sourced parts were OEM and it was insanely expensive.
NostraJackAss
Did you know that your extended warranty was to 15/150K for the turbo as certified but arguably tuning it voided it?
With past recent history of VW, would you put it past them?
Why not?
valdeisel
C?ID=358332
I wasn't aware that the extended warranty carried that far. Audi B8 owners are still getting rejected/denied service when they are well under that cap, even with bone stock vehicles. I knew that when I chose to flash the ECU with a program, I'd be taking a risk. When I got ahold of my Avant, it already had 83K miles on it--surprised they even performed the stg II oil consumption repair.
Honestly, no, I wouldn't be surprised if they developed some off the wall programming that would be considered abnormal by other auto makers.
I'll see what I can do about that JPPSG, need to figure that one out :confused:
Jef
HQ
Not good. I would say CCV or rear main seal as my first guesses. You might want to see about having the crank case smoke tested... blow smoke down the dipstick tube, and see if smoke comes out of the trans bell housing.
valdeisel
C?ID=358332
CCV? or did you mean PCV?
NostraJackAss
That's not extended warranty, that is as certified WARRANTY, doesn't everyone know that FACT already? :rolleyes:
The horror huh?
And what would cause such a thing to happen, oh no FOR shame all this induced FOD?
https://forums.ross-tech.com/showth...ases-and-vacuum-amp-so-should-you!-Air-leaks!
https://forums.ross-tech.com/showthread.php?2612-TFSI-Oil-leak-Not-a-VCDS-related-question-or-is-it
Hey what's a MANN pro-vent do?
https://oe-products.mann-hummel.com...ummel/kurbelgehauseentlueftung/ProVent_en.pdf
valdeisel
C?ID=358332
Jef, thanks for the suggestions. I'll see about getting a smoke test done. I did visual on top and underneath my engine, saw no evidence of an oil leak at the eng/trans mating point or even previously after looking at the belly pans. Still though, the smoke test should point out a failure of the RMS. If that comes back good, guess I can see how much vacuum there is at the dipstick.
Jack, in my Air Force career as an aircraft maintainer, there is a position in flight safety which carries the nickname 'FOD God'...it fits you. ;)
Pinpointdiag
Scotland
C?ID=90374
Your original question asked why the abs, Tpms, handbrake, lights are coming on. And you will fix the engine fault later, but I would suggest all your other lights are just due to the fuel trim fault and the modules all sharing the fact that there is a fault somewhere.
The crank case ventilation system and how it works at idle would be what I’d look at next. After a smoke test. As trim is as previously noted is high at idle.
What makes you think there is a fault with the actual turbo?
