Read mileage
skoukiadakis
Greece
C?ID=262443
My current car , Polo Gti 6R 2011 ,which bought used , seems that do not support ECU mileage reading!
So I would like ask if there is another way to check the mileage , like ABS module , AUTO TRANS module , ENGINE module!
Thank you!
VIN: WVWZZZ6RZBY199045
Scan: 01 02 03 08 09 10 15 17 19 25 44 55
08-Auto HVAC -- Status: OK 16000
09-Cent. Elect. -- Status: OK 16000
19-CAN Gateway -- Status: OK 16000
Address 01: Engine  (CAVE  J623)        Labels: 03C-907-309-V1.clb
        Part No SW: 03C 906 027 AR      HW: 03C 906 027 AR
        Component: 1.4l R4 TSI   H15 9971
        Revision: L2H15---
        Coding: 00250012002400000000
        Shop #: WSC 00017 666 02801
        ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
        ROD: EV_ECM14TSI01103C906027AR.rod
        VCID: 71A546C70477922CD57C7F-8024
No fault codes found.
Address 02: Auto Trans  Labels: 0AM-927-769.clb
        Part No SW: 0AM 300 050 K       HW: 0AM927769D
        Component: GSG DSG AG7     403  9032
        Revision: 00040034      Serial Number: TFK01012130269
        Shop #: WSC 22643 000 1048576
        VCID: 312586C7C4F74B2C95FCBF-513C
Address 03: ABS Brakes  (J104)  Labels: 6R0-907-37x-ESP82.clb
        Part No SW: 6R0 907 379 AK      HW: 6R0 907 379 AF
        Revision: --------
        Coding: 210248E3417602BB842512E682D640411700
        Shop #: WSC 00788 648 00255
        VCID: 8751881F9AF3209CEB5871-80D2
Address 08: Auto HVAC  (J255)   Labels: 6R0-907-044.clb
        Part No SW: 6R0 907 044 N       HW: 6R0 907 044 N
        Component: Climatronic   H12 0812
        Revision: V0000000
        Shop #: WSC 00000 000
        VCID: 3E3FADFB05A92554187E0C-806B
Address 09: Cent. Elect.  (J519)        Labels: 7H0-937-08x-09.clb
        Part No SW: 7H0 937 089 D       HW: 7H0 937 089
        Component: BCM T5GP Li4  H47 0230
        Revision: BS047001
        Coding: 3DB029BF48F324009B280EB17CEB0FD05AC0670F60053041200000000000
        Shop #: WSC 124697 483 00190
        VCID: 3731B8DF2A93141CDB38C1-8062
        Subsystem 1 -   Part No SW: 1K0-955-559-AH      Labels: 1K0-955-559-AG.clb
        Component: RLS 140111 0554  0403
        Coding: 06302D
        Subsystem 2 -   Part No SW: 6R0-959-801-AB      Labels: 6R0-959-801.clb
        Component: J386__TSG_FT 007 1621
        Coding: 08BC30
        Subsystem 3 -   Part No SW: 6R0-959-802-AD      Labels: 6R0-959-802.clb
        Component: J387__TSG_BT 007 1621
        Coding: 08BC30
        Subsystem 4 -   Part No SW: 1K8-951-171-A
        Component: DWA-Sensor 00001 0103
        Subsystem 5 -   Part No SW: 1K8-951-605-B
        Component: LIN BACKUP HOH11 9005
        Subsystem 6 -   Part No SW: 6R0-959-591-A
        Component: J245 PS72.015H05 0006
        Coding: 081001
        Subsystem 7 -   Part No SW: 1K8-951-171-A
        Subsystem 8 -   Part No SW: 5K0-959-542
        Component: E221__MFL-TASH06 0010
        Coding: 830000
Address 10: Park/Steer Assist  (J446)   Labels: 6R0-919-475.clb
        Part No SW: 6R0 919 475 B       HW: 7E0 919 475
        Component: PARKHILFE 4K  H10 0012
        Revision: --------
        Coding: 108104
        ASAM Dataset: EV_VW250ParkiAssis2 S01008
        ROD: EV_VW250ParkiAssis2.rod
        VCID: 3D3DAAF708AF264C017403-8068
Address 15: Airbags  (J234)     Labels: 5K0-959-655.clb
        Part No SW: 6R0 959 655 M       HW: 6R0 959 655 M
        Component: VW10Airbag012 H09 0020
        Revision: --------
        Coding: 003132
        ROD: EV_AirbaVW10BPAVW250.rod
        VCID: 4CDBF73343159FC486EAE6-8019
        Subsystem 1 -   Serial Number: 3575HRB406509RECAH8F
        Subsystem 2 -   Serial Number: 3585HRB406109REC297
        Subsystem 3 -   Serial Number: 3515RRB405709GGUGHB
Address 17: Instruments  (J285) Labels: 5K0-920-xxx-17.clb
        Part No SW: 6R0 920 870 HW: 6R0 920 870
        Component: KOMBI         H20 0320
        Coding: 140E00
        ROD: EV_Kombi_UDS_VDD_RM09_A04_VW25.rod
        VCID: F2A7C9CB81712934AC66C8-80A7
Address 19: CAN Gateway  (J533) Labels: 6N0-909-901-19.lbl
        Part No SW: 6N0 909 901 HW: 7H0 937 089
        Component: GW-K-CAN TP20 0230
        Coding: 002000
        VCID: F0A3C3C38F7D03245A72F2-80A5
Address 25: Immobilizer  (J334) Labels: 5K0-920-xxx-25.clb
        Component: IMMO          H20 0320
        ROD: EV_Immo_UDS_VDD_RM09.rod
        VCID: EA97D1ABA9A1E1F41436B0-80BF
Address 44: Steering Assist     Labels: 6Q0-423-156.clb
        Part No SW: 6R0 423 156 B
        Coding: 11241
        Shop #: WSC 00788 000
        VCID: 2F2180BFD2C348DC83C8A9-807A
Address 55: Xenon Range  (J431) Labels: 6R0-907-357.clb
        Part No SW: 6R0 907 357 HW: 6R0 907 357
        Component: LWR-ECU       H02 0070
        Revision: --------
        Coding: 0110000001000000
        ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
        ROD: EV_HeadlRegulVWLWRPt_VW25.rod
        VCID: F7B1F8DFEA134C1C9BB801-80A2
End--(Elapsed Time: 02:03, VBatt start/end: 12.4/12.4 Vign: 0.0)-
What do you have in MVB 028 of 02-Auto Trans?
I can't really tell what you're looking at with VCDS-Mobile. Do it with VCDS please.
OK, what is the reading of the car's odometer in the instrument cluster?
skoukiadakis
Greece
C?ID=262443
It is 71566
Well, two out of three match within the expected precision for such things. The 655350 in the last field should certainly be ignored; that's clearly a 16-bit value of all 1s. I am not sure where the 99050 comes from though.
skoukiadakis
Greece
C?ID=262443
Is there anywhere else I can check the mileage?
Any other module?
Any other module?
Not that I am aware of, but you could make measuring value maps of all modules with VCDS and look for other "km" values.
skoukiadakis
Greece
C?ID=262443
I am going to try this!
Thank you!
mylhan
France
C?ID=361415
hi look in dsg , exemple canal 109 dsg 6 golf6 seat leon etc... you have dsg 7
