VW Transporter error code 01324/Control Module for All-wheel drive
Samson
Sweden
C?ID=229490
Hello All!
I have a VW Transporter 2011 with erro code from the All-wheel drive system. I have sent the control module placed in the rear axle for investigation to UK but no problem found. But I am a little confused and need some advice or tips how to proceed with fault finding. The car is converted into an ambulance, it is driveable but need the all-wheeldrive before the winter is coming.
Hope that you can help me in this issue.
Many thanks in advance.
Kind regard
//Kjell
Wednesday,21,August,2019,14:59:53:01232
VCDS Version: 19.6.1.0 (x64)
VIN: WV2ZZZ7HZBH119905   License Plate: RLT260
Mileage: 227550km-141393mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 15 17 18 19 22 25 56 6E 0B
VIN: WV2ZZZ7HZBH119905   Mileage: 227550km-141393miles
22-AWD -- Status: Cannot be reached 1100
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 022 JE    HW: 03L 907 309 H
   Component: R4 2,0L EDC   H34 9114
   Revision: 22H34---    Serial number: 00000000000000
   Coding: 0125401A232600080000
   Shop #: WSC 40953 222 92152
   ASAM Dataset: EV_ECM20BTD01103L906022JE 002008
   ROD: EV_ECM20BTD01103L906022JD_002.rod
   VCID: 71D19679A0ADCAC766-8024
   Part No SW: 0BT 300 011 K    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H04 1409
   Revision: 00H04V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 365B65658943ADFF73-8062
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0105
   Revision: 00H43001
   Coding: 208764AD11A5049E26AB88716A6316
   Shop #: WSC 02736 790 49152
   VCID: 365B65658143ADFF73-8062
01324 - Control Module for All Wheel Drive (J492)
                    Reset counter: 22
                    Mileage: 227555 km
                    Date: 2014.01.11
                    Time: 16:03:47
                    Count: 17
                    Count: 8202
                    Count: 252
   Part No SW: 7E5 907 047 BF    HW: 7E5 907 047 BF
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   Shop #: WSC 40963 222 88811
   ROD: EV_ClimaT5Basis.rod
   VCID: 74DF9F6DDFBFFFEF8D-8020
   Part No SW: 7H0 937 087 F    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0230
   Serial number: 0396 081110623
   Coding: A0B0793A0E212013002808107D2B8DD40090430F60844000300000000000
   Shop #: WSC 02734 790 00000
   VCID: 37456861864954F768-8062
   Subsystem 1 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3311
   Subsystem 2 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3311
   Subsystem 3 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Serial number: 70000000000000192644
   Coding: E20000
   Part No SW: 7E0 959 655 C    HW: 7E0 959 655 C
   Component: VW10Airbag007 H06 0013
   Revision: --------    Serial number: 003HM000X9KI
   Coding: 000000000000000000000000000000003037
   Shop #: WSC 02734 790 50316
   Serial number: 3495ZRB4059010DAEOIK
   Serial number: 3505ZRB405T0891IF0LO
   Part No SW: 7E0 920 870 CX    HW: 7E0 920 870 CX
   Component: KOMBI         H21 0220
   Coding: 160E00
   VCID: 0131C6B9900DDA4796-8054
12653568 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 22
                    Mileage: 227555 km
                    Date: 2019.08.21
                    Time: 16:03:44
Address 18: Aux. Heat        Labels: None
   Part No: 7E0 815 071 A
   Component: J737__Standheizung  0404
   Revision: 00085000    Serial number: 09019275D00000
   Coding: 0000031
   Shop #: WSC 02757 790 00000
   VCID: 237DAC31E2D12857A4-8076
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 042200
   VCID: 70D7937DA3A7C3CF69-8024
                    Reset counter: 22
                    Mileage: 227555 km
                    Date: 2014.01.11
                    Time: 16:03:46
Address 22: AWD
   Component: IMMO          H21 0220
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AE381158D7B391F27-803E
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 00000000    Serial number: VWZ1Z2L0366647
   Coding: 0100040000
   Shop #: WSC 40391 222 09951
   VCID: 6BED84118A8120175C-803E
                    Reset counter: 22
                    Mileage: 227555 km
                    Date: 2014.01.11
                    Time: 16:04:04
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-L2.clb
   Part No SW: 7E5 919 037 F    HW: 7E5 919 037 F
   Component: Dachdisplay   H16 0175
   Revision: 11100010    Serial number: 193374
   Coding: 000206
   Shop #: WSC 02736 790 00000
   VCID: 345F5F6D973FBFEF4D-8060
Address 0B: Sec. Air Heating        Labels: None
   Part No: 7E0 819 006 D
   Component: J604  Standheizung  0401
   Revision: L100300A    Serial number: 00000000000000
   VCID: 2867BB1D98F7CB0FF1-FFFE
00003 - Control Module
End-------------------------(Elapsed Time: 02:45)--------------------------
langers2k
C?ID=224085
If the AWD module has been checked, you should now check the wiring to it as most modules don't seem to be communicating with it.
You can get the wiring diagrams from erwin and at a guess, I'd start with power, ground and CAN wiring.
Samson
Sweden
C?ID=229490
OK, I will try. Thoough it is an ambulance most of the wiring is hidden and I have difficulty to lift the car high enough. But I can crawl on the ground perhaps...
Thanks for the advice!
Pinpointdiag
Scotland
C?ID=90374
Hi did you remove the haldex controller with vehicle on the ground? If so then checking the feed and earth and the CAN at the 8pin plug should be possible. A load test with a bulb for the feeds and earths. Best way to check the CAN is with a scope. Without that then you would have to access the wiring diagram and circuit test from end to end.Your only going to have to start chasing wires under the vehicle if there’s a missing feed earth or CAN at the plug.
This is normally water damage in the controller.
Who tested it for you in the uk?
