W12 won't crank
Follymans
C?ID=376127
Goodmorning all!
I'm from the Netherlands so excuse me in advance for my incorrect English and the long intro.
I own a Audi a8 W12 from 2005. About 4 weeks ago i had an issue with the air suspension.
Sometimes when i started the car and drove off, the suspension did not come up but dropped the car to his lowest position. I could hear the compressor but after a while he stopped working. Every time that happend i parked the car, shut it down, locked the doors and unlock the doors and start the car right up and problem solved.
Untill 4 weeks ago. After about 100 meters from home i noticed the suspension again failed and stopped the car in the roadside, shut it off, lock the doors and try to start the car again. This time the starter seems to have problems turning around at normal speed to crank the car as if the battery was week.
I switched the ignition to left and after a second again to the right to try again starting the car. Unfortunately the first start cycling was apparently not don yet. So i suppose i was cranking a car that was already cranking.. After that it did nothing more than clicking from the relays in the right footwell. No crank and no start.
After several tries i gave up and called the roadside assistance. I saw him use the battery terminals (no ground pin) to jump the car but it didnt work at all. Just the clicking and the sound of the fuellpumps. After 5 hours struggling with the lowest car he ever seen we manage to load it on a truck to get the car home.
Now before i have to pull out the complete engine to get the starter :banghead: i wanne make sure its not just a fried module or electrical issue.
Attached the latest scan after replacing and coding a new battery, 2 starter relays, suspension relay and checking all fuse and wiring. I have power from startrelay 2 but i don't now if the starter solenoid is getting that power because you can't get at the wiring on the starter without pulling out the engine :facepalm:
Any input is very welcome!
Zaterdag,17,Augustus,2019,22:07:20:29470
VCDS -- Windows Gebaseerde VAG/VAS Emulator Loopt op Windows 10 x64
VCDS Versie: HZH 18.9.1.0  HEX-V2 CB: 0.4508.4
Data versie: 20190515 DS296.0
www.Randstadcarsolutions.nl
VIN: WAUZZZ4E65N011177   Kenteken:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 11 31 13 15 16 17 19 1E 25 34 36 37
          38 42 46 47 4F 52 53 55 56 61 62 72 76 77
VIN: WAUZZZ4E65N011177   Kilometrage: 272530km
00-Stuurhoek Sensor -- Status: OK 0000
01-Motor -- Status: OK 0000
02-Versnellingsbak -- Status: OK 0000
03-ABS Systeem -- Status: Defect 0010
05-Startbevoegdheid -- Status: OK 0000
06-Stoelverst, R -- Status: OK 0000
07-Bed.Paneel/Displ. -- Status: OK 0000
08-Airco/Verwarming -- Status: Defect 0010
09-Centr.Electr. -- Status: OK 0000
11-Motor II -- Status: OK 0000
31-Motorelektr.Verb. -- Status: OK 0000
13-Afstandsregeling -- Status: Defect 0010
16-Stuurwiel -- Status: OK 0000
17-Instrumenten -- Status: OK 0000
19-CAN-bus Interface -- Status: Defect 0010
1E-Mediaplayer 2 -- Status: OK 0000
25-Wegrijblokkering -- Status: OK 0000
34-Niveauregeling -- Status: OK 0000
36-Stoelverst, L -- Status: OK 0000
37-Navigatie -- Status: OK 0000
38-Dakelektronica -- Status: OK 0000
42-Portierelektr.,LV -- Status: OK 0000
46-Comfortsysteem -- Status: OK 0000
47-Geluidsysteem -- Status: OK 0000
52-Portierelectr.,RV -- Status: OK 0000
53-Handrem -- Status: OK 0000
55-Koplamp Niveau -- Status: OK 0000
61-Accuregeling -- Status: OK 0000
62-Portierelektr.,LA -- Status: OK 0000
72-Portierelektr.,RA -- Status: OK 0000
76-Parkeerhulp -- Status: OK 0000
77-Telefoon -- Status: Kan niet bereikt worden 1100
Adres 01: Motor        Labels: 07C-910-018-BHT1.lbl
   Onderdeel No SW: 4E0 910 018 E    HW: 4E0 906 018
   Component: 6.0L W12/4V     A  ª0060
   Revisie: --------    Serienummer: AUX3Z0DN153704
   Codering: 0011773
   Werkplaats#: WSC 44798 002 1048576
   VCID: 211E11A36DCEDBEFB13-8074
Geen Fout Code Gevonden.
Gereedheid: 0110 1101
Adres 02: Versnellingsbak        Labels: 09E-927-156.lbl
   Onderdeel No SW: 4E0 910 156 T    HW: 09E 927 156 A
   Component: AG6 09E 6,0L4V RdW  0090
   Revisie: --H01---    Serienummer:        0042901
   Codering: 0000001
   Werkplaats#: WSC 02313 785 00200
   VCID: 3332EBEBC732597F53F-8066
Adres 03: ABS Systeem        Labels: 4E0-910-517.lbl
   Onderdeel No SW: 4E0 910 517 E    HW: 4E0 614 517 AM
   Component: ESP 5.7 allrad  H44 0240
   Codering: 0008637
   Werkplaats#: WSC 02313 000 00000
   VCID: 251605B379E637CFCDB-8070
1 Fout Gevonden:
01826 - Sensor stuurhoek (G85) voedingsspanning contact 30
Adres 05: Startbevoegdheid        Labels: 4E0-910-131.lbl
   Onderdeel No SW: 4E0 910 131     HW: 4E0 909 131
   Component:     FBS AUDID3  H04 0140
   Revisie: 01404004    Serienummer: AUX3Z0DN153704
   Codering: 0263168
   Werkplaats#: WSC 02311 785 00200
   VCID: 58E87C477E145A2786D-800C
   Subsysteem 1 - Onderdeel No: XXXXXXXXXXX
Adres 06: Stoelverst, R        Labels: Geen
   Onderdeel No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H08  0060
   Revisie: 00000000    Serienummer: 5DS 008 795-03
   Codering: 4063328
   VCID: 23121BAB77D2C9FFA3F-8076
Adres 07: Bed.Paneel/Displ.        Labels: 4E0-910-7xx-07.clb
   Onderdeel No SW: 4E0 910 732 K    HW: 4E0 035 729
   Component: Interfacebox    H43 3460
   Revisie: 00000000    Serienummer: 343JR047541338
   Codering: 0000001
   Werkplaats#: WSC 12345 123 12345
   VCID: 2A0CF68F10F818B7E09-807E
   Subsysteem 1 - Onderdeel No: 4E0 910 609 C
   Component: Bedienteil MMI  H42 0100
   Subsysteem 2 - Serienummer: 301KV047585294
   Subsysteem 3 - Serienummer: 7405.11.0400000000201B0018ÿ
   Subsysteem 4 - Serienummer: 1B0018ÿ
Adres 08: Airco/Verwarming        Labels: Geen
   Onderdeel No SW: 4E0 910 043 A    HW: 4E0 820 043 A
   Component: KLIMAAUTOMAT    016 0340
   Revisie: 00000029    Serienummer: 00000000056442
   Codering: 0012297
   VCID: 1B62234B4FA2F13F6BF-804E
1 Fout Gevonden:
01206 - Signaal voor tijdsduur contact uit
            014 - defect
Adres 09: Centr.Electr.        Labels: 4E0-910-279.clb
   Onderdeel No SW: 4E0 910 279 L    HW: 4E1 955 113 B
   Component: ILM Fahrer      H12 0210
   Codering: 0133121
   VCID: 313EE1E33D2E6B6F213-8064
   Subsysteem 1 - Onderdeel No: 4E1 910 113 B
   Component: Wischer WWS D3  H50 0400
   Codering: 00000037
   Subsysteem 2 - Onderdeel No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0040
   Codering: 00141886
Adres 11: Motor II        Labels: 07C-910-018-BHT2.lbl
   Codering: 0011773
Adres 13: Afstandsregeling        Labels: Geen
   Onderdeel No SW: 4E0 910 561 F    HW: 4E0 907 561 F
   Component: ABSTANDSREGELUNGH03 0020
   Codering: 0041168
1 Fout Gevonden:
01316 - Remmenregelapparaat
            013 - Storinggeheugen afvragen - MIL AAN
             Bevries Frame:
                    Fout Status: 11111101
                    Fout Prioriteit: 5
                    Fout Frekwentie: 2
                    Reset teller: 30
                    Kilometrage: 10392 km
                    Tijd Indicatie: 0
                    Datum: 2004.04.01
                    Tijd: 05:14:00
             Bevries Frame:
                    Temperatuur: 31.0°C
                    Voltage: 12.54 V
                    Bin. Bits: 00000000
Adres 15: Airbags        Labels: 4E0-910-655-84.lbl
   Onderdeel No SW: 4E0 910 655     HW: 4E0 959 655 G
   Component: Airbag 8.4E+    H10 0940
   Codering: 0430707
   VCID: 63925BAB375289FFE3F-8036
Adres 16: Stuurwiel        Labels: 4E0-910-549.lbl
   Onderdeel No SW: 4E0 910 549     HW: 4E0 953 549
   Component: Lenksäulenmodul H13 0040
   Codering: 0012151
   VCID: 659645B33966F7CF0DB-8030
   Component: Lenkradmodul    H05 0080
Adres 17: Instrumenten        Labels: 4E0-910-xxx-17.lbl
   Onderdeel No SW: 4E0 910 930 K    HW: 4E0 920 930 K
   Component: KOMBIINSTR. VDO H53 0200
   Revisie: D02         Serienummer: AUDID3DN000836
   Codering: 0000104
Adres 19: CAN-bus Interface        Labels:. 4E0-910-468.clb
   Onderdeel No SW: 4E0 910 468     HW: 4E0 907 468 B
   Component: Gateway         H7
   Revisie: 7    Serienummer: 1500404A0106B0
   Codering: FEFEFBDC2B3104
1 Fout Gevonden:
01303 - Zender/ontvanger van telefoon
            004 - Geen Signaal/Communicatie
             Bevries Frame:
                    Fout Status: 01100100
                    Fout Prioriteit: 3
                    Fout Frekwentie: 1
                    Reset teller: 30
                    Kilometrage: 272536 km
                    Tijd Indicatie: 0
                    Datum: 2004.04.01
                    Tijd: 05:23:46
Adres 1E: Mediaplayer 2        Labels: 4E0-910-111.lbl
   Onderdeel No SW: 4E0 910 111 F    HW: 4E0 035 111
   Component: CD-Changer      H43 0470
   Revisie: 00000501    Serienummer: AUZ5ZBC1024295
   Werkplaats#: WSC 00000 000 00000
   VCID: 1C6020574AACF607625-8048
Adres 25: Wegrijblokkering        Labels: 4E0-910-131.lbl
   Codering: 0263168
   XXXXXXXXXXX ELV                 XXXX
Adres 34: Niveauregeling        Labels: 4E0-910-553.clb
   Onderdeel No SW: 4E0 910 553 J    HW: 4E0 907 553 F
   Component: LUFTFDR.-CDC    H06 6310
   Codering: 0015510
   Werkplaats#: WSC 42710 001 1048576
Adres 36: Stoelverst, L        Labels: Geen
   Component: Sitzmemory FS  H08  0060
   Codering: 4063330
Adres 37: Navigatie        Labels: 4E0-910-88x-37.lbl
   Onderdeel No SW: 4E0 910 888 P    HW: 4E0 919 887 C
   Component: MNS ECE         H43 1060
   Revisie: 00000000    Serienummer: 353J-047586256
   Werkplaats#: WSC 00100 211 16775
   VCID: 3B22C3CBEF62913F8BF-806E
Adres 38: Dakelektronica        Labels: 4E0-910-135.lbl
   Onderdeel No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Component: Dachknoten D3   H02 0090
   Serienummer: 00000426000083
   Codering: 0003200
   VCID: 1D662D5351B6FF0F95B-8048
Adres 42: Portierelektr.,LV        Labels: 4E1-910-802-42.lbl
   Onderdeel No SW: 4E1 910 802 B    HW: 4E1 959 801 B
   Component: Türsteuer.FS BRM002 0060
   Codering: 0028461
   VCID: 201814A766C4D2E7BED-8074
Adres 46: Comfortsysteem        Labels:. 4E0-910-289.lbl
   Onderdeel No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H04 0040
   Revisie: 00400004    Serienummer:  W040411090111
   Codering: 0004184
   VCID: 270A0FBB03EA25DFFF7-8072
   Subsysteem 1 - Onderdeel No: 4E0 907 719
   Component: Neigungssensor  H03 0020
Adres 47: Geluidsysteem        Labels: 4E0-910-223.lbl
   Onderdeel No SW: 4E0 910 223 K    HW: 4E0 035 223 A
   Component: DSP-Amp.-High   H13 0440
   Revisie: PROD_01     Serienummer: 00000000007543
   Codering: 0000016
Adres 4F: Centr. Electr. II        Labels: Geen
   Onderdeel No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H09 0040
   Revisie:             Serienummer: 00000000050643
   Codering: 0010101
   VCID: 1E642A5F5CB0E4178C1-804A
Adres 52: Portierelectr.,RV        Labels: 4E1-910-802-52.lbl
   Onderdeel No SW: 4E1 910 802 B    HW: 4E1 959 802 B
   Component: Türsteuer.BF BRM002 0060
   Codering: 0028461
Adres 53: Handrem        Labels: 4E0-910-801.clb
   Onderdeel No SW: 4E0 910 801 A    HW: 4E0 907 801
   Component: EPB  AV1C1010   H01 1010
   Revisie: AV1C1010
   Codering: 0000631
Adres 55: Koplamp Niveau        Labels: 4E0-910-357.lbl
   Onderdeel No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0040
   Revisie: 00000001    Serienummer:
   Codering: 0000003
   VCID: 629C5EAF284880F7E89-8036
Adres 56: Radio        Labels: 4E0-910-541.lbl
   Onderdeel No SW: 4E0 910 541 Q    HW: 4E0 035 541 B
   Component: TUNER EU/US/RDW H41 0620
   Revisie: 00000000    Serienummer: 304KU047604487
   Codering: 0000001
   VCID: 2E04FA9F2C1074973C1-807A
Adres 61: Accuregeling        Labels: 4E0-910-181.lbl
   Onderdeel No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Component: J0644 BEM       H11 0510
   Revisie: 00000000    Serienummer: 00000000014183
   Werkplaats#: WSC 00100 211 06074
   Subsysteem 1 - Onderdeel No: 000 915 105 DL
   Component: von VA0  381214E1CC
   Codering: 303030393135313035444C56413033383132313445314343
   Werkplaats#: WSC 00097 211 95421
Adres 62: Portierelektr.,LA        Labels: 4E0-910-802.lbl
   Onderdeel No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Component: Türsteuer.HL BRM002 0060
   Codering: 0028461
Adres 72: Portierelektr.,RA        Labels: 4E0-910-802.lbl
   Onderdeel No SW: 4E0 910 802 A    HW: 4E0 959 802 C
   Component: Türsteuer.HR BRM002 0060
   Codering: 0028461
Adres 76: Parkeerhulp        Labels: 4E0-910-283.lbl
   Onderdeel No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Component: Parkhilfe 8-Kan H12 0020
   Revisie: --.--.--    Serienummer: 08720428600554
   Codering: 0001108
Adres 77: Telefoon
Einde-------(Verstreken Tijd: 02:11, VBatt start/eind: 12.6V/12.6V)--------
Dinsdag,13,Augustus,2019,20:16:38:29470
Kilometrage: 272530km   Reparatie Order:
01-Motor -- Status: Defect 0010
09-Centr.Electr. -- Status: Defect 0010
42-Portierelektr.,LV -- Status: Defect 0010
52-Portierelectr.,RV -- Status: Defect 0010
62-Portierelektr.,LA -- Status: Defect 0010
   Codering: 0011773
1 Fout Gevonden:
19510 - Startmotor draait niet
            P3054 - 001 - Mechanisch geblokkeerd of elektrische storing
   Codering: 0000001
   Codering: 0008637
1 Fout Gevonden:
   Codering: 0263168
   Codering: 4063328
   Codering: 0000001
   Codering: 0012297
1 Fout Gevonden:
            014 - defect
   Codering: 0133121
   Codering: 00000037
   Codering: 00141886
2 Fouten Gevonden:
01317 - Regelapparaat met display in dashboard (J285)
            004 - Geen Signaal/Communicatie - Intermitterend
             Bevries Frame:
                    Fout Status: 00100100
                    Fout Prioriteit: 2
                    Fout Frekwentie: 1
                    Reset teller: 70
                    Tijd Indicatie: 0
                    Datum: 2019.08.10
                    Tijd: 16:28:38
01800 - Lichtschakelaar (E1)
            008 - Onaannem. signaal - Intermitterend
             Bevries Frame:
                    Fout Status: 00101000
                    Fout Prioriteit: 2
                    Fout Frekwentie: 2
                    Reset teller: 70
                    Tijd Indicatie: 0
   Codering: 0011773
   Codering: 0041168
1 Fout Gevonden:
             Bevries Frame:
                    Fout Prioriteit: 5
                    Fout Frekwentie: 3
                    Reset teller: 30
                    Tijd Indicatie: 0
                    Datum: 2019.08.07
                    Tijd: 20:42:00
             Bevries Frame:
                    Temperatuur: 41.0°C
                    Voltage: 12.16 V
                    Bin. Bits: 00100000
   Codering: 0430707
   Codering: 0012151
   Codering: 0000104
1 Fout Gevonden:
             Bevries Frame:
                    Fout Prioriteit: 3
                    Fout Frekwentie: 1
                    Reset teller: 30
                    Tijd Indicatie: 0
                    Datum: 2004.03.28
                    Tijd: 03:35:08
   Codering: 0263168
   Codering: 0015510
   Codering: 4063330
   Codering: 0003200
   Codering: 0028461
1 Fout Gevonden:
00532 - Voedingsspanning
            011 - Onderbreking - Intermitterend
             Bevries Frame:
                    Fout Status: 00101011
                    Fout Prioriteit: 3
                    Fout Frekwentie: 0
                    Reset teller: 70
                    Kilometrage: 272528 km
                    Tijd Indicatie: 0
                    Datum: 2004.03.26
                    Tijd: 00:00:42
   Codering: 0004184
   Codering: 0000016
   Codering: 0010101
   Codering: 0028461
1 Fout Gevonden:
             Bevries Frame:
                    Fout Prioriteit: 3
                    Fout Frekwentie: 0
                    Reset teller: 70
                    Tijd Indicatie: 0
                    Datum: 2004.03.26
                    Tijd: 01:01:22
   Revisie: AV1C1010
   Codering: 0000631
   Codering: 0000003
   Codering: 0000001
   Codering: 0028461
1 Fout Gevonden:
             Bevries Frame:
                    Fout Prioriteit: 3
                    Fout Frekwentie: 0
                    Reset teller: 70
                    Tijd Indicatie: 0
                    Datum: 2004.03.26
                    Tijd: 00:00:42
   Codering: 0028461
   Codering: 0001108
Adres 77: Telefoon
Einde-------(Verstreken Tijd: 02:03, VBatt start/eind: 12.2V/12.1V)--------
Zaterdag,17,Augustus,2019,22:07:49:29470
   Codering: 0011773
   Codering: 0000001
   Codering: 0008637
1 Fout Gevonden:
   Codering: 0263168
   Codering: 4063328
   Codering: 0000001
   Codering: 0012297
1 Fout Gevonden:
            014 - defect
   Codering: 0133121
   Codering: 00000037
   Codering: 00141886
   Codering: 0011773
   Codering: 0041168
1 Fout Gevonden:
             Bevries Frame:
                    Fout Prioriteit: 5
                    Fout Frekwentie: 2
                    Reset teller: 30
                    Tijd Indicatie: 0
                    Datum: 2004.04.01
                    Tijd: 05:14:00
             Bevries Frame:
                    Temperatuur: 31.0°C
                    Voltage: 12.54 V
                    Bin. Bits: 00000000
   Codering: 0430707
   Codering: 0012151
   Codering: 0000104
1 Fout Gevonden:
             Bevries Frame:
                    Fout Prioriteit: 3
                    Fout Frekwentie: 1
                    Reset teller: 30
                    Tijd Indicatie: 0
                    Datum: 2004.04.01
                    Tijd: 05:23:46
   Codering: 0263168
   Codering: 0015510
   Codering: 4063330
   Codering: 0003200
   Codering: 0028461
   Codering: 0004184
   Codering: 0000016
   Codering: 0010101
   Codering: 0028461
   Revisie: AV1C1010
   Codering: 0000631
   Codering: 0000003
   Codering: 0000001
   Codering: 0028461
   Codering: 0028461
   Codering: 0001108
Adres 77: Telefoon
                Adres 03: ABS Systeem  (4E0 910 517 E)
22:09:13
  -2.5°   Steering Angle Sensor (G85)
  12.56 V   Supply Voltage (Terminal 30)
  Stuurho. 1   Steering Angle Sensor (G85)
  Motor 1   Transmission
  Versn.-bak 1   Engine
  Instr.-pan. 1   Instrument Cluster
  Afstand 1   Adaptive Cruise Control (ACC)
  Gateway 1   CAN-Gateway
  Parkeerrem 1   Electric Parking Brake (EPB)
  N/A   Level Control System
22:09:15
  12.64 V   Supply Voltage (Terminal 30)
  Versn.-bak 1   Engine
Zaterdag,17,Augustus,2019,22:12:54:29470
                Adres 19: CAN-bus Interface  (4E0 910 468 )
22:12:52
  Actieve   Wake-Up Line
      CAN-Comfort Static
      CAN-Infotainment Static
      CAN-Powertrain Static
         1   Ring Break Diagnostic Wire
      CAN-Gateway Status
  2-kabel   CAN-Comfort Status
  El.cont.sl 1   Access/Start Authorization (J518)
      Driver (J589) Identification
  Telefoon 0   Telephone Electronics (R36)
  12.50 V   Voltage Terminal 30
  12.60 V   Voltage Terminal 15
South Molton, UK
Thanks for the Auto-Scan, but can I ask that you download the latest English version (19.6.1 today) from the Ross-Tech website and install that in parallel with your Dutch version and post an Auto-Scan from that here?
Most of us aren't very proficient in Dutch (my Dad worked for Philips NV for 40 years and even I'm not!), and the newer version may offer some improved diagnostics.
Follymans
C?ID=376127
Hereby the newest scan with the english and newest version. The funny thing is, i dont have a fault code regarding the starter.
Thursday,22,August,2019,20:37:19:29470
VIN: WAUZZZ4E65N011177   License Plate:
VIN: WAUZZZ4E65N011177   Mileage: 272530km-169342miles
38-Roof Electronics -- Status: OK 0000
Address 01: Engine        Labels: 07C-910-018-BHT1.lbl
   Part No SW: 4E0 910 018 E    HW: 4E0 906 018
   Revision: --------    Serial number: AUX3Z0DN153704
   Coding: 0011773
   Shop #: WSC 44798 002 1048576
   VCID: 211E11A36DCEDBEFE57-8074
Readiness: 0110 1101
Address 02: Auto Trans        Labels: 09E-927-156.lbl
   Part No SW: 4E0 910 156 T    HW: 09E 927 156 A
   Revision: --H01---    Serial number:        0042901
   Coding: 0000001
   Shop #: WSC 02313 785 00200
   VCID: 3332EBEBC732597F07B-8066
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 E    HW: 4E0 614 517 AM
   Coding: 0008637
   Shop #: WSC 02313 000 00000
   VCID: 251605B379E637CF99F-8070
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131
   Revision: 01404004    Serial number: AUX3Z0DN153704
   Coding: 0263168
   Shop #: WSC 02311 785 00200
   VCID: 58E87C477E145A27D29-800C
Address 06: Seat Mem. Pass        Labels: None
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 4063328
   VCID: 23121BAB77D2C9FFF7B-8076
Address 07: Control Head        Labels: 4E0-910-7xx-07.clb
   Part No SW: 4E0 910 732 K    HW: 4E0 035 729
   Revision: 00000000    Serial number: 343JR047541338
   Coding: 0000001
   VCID: 2A0CF68F10F818B7B4D-807E
   Subsystem 1 - Part No: 4E0 910 609 C
   Subsystem 2 - Serial number: 301KV047585294
   Subsystem 3 - Serial number: 7405.11.0400000000201B0018ÿ
   Subsystem 4 - Serial number: 1B0018ÿ
   Part No SW: 4E0 910 043 A    HW: 4E0 820 043 A
   Revision: 00000029    Serial number: 00000000056442
   Coding: 0012297
   VCID: 1B62234B4FA2F13F3FB-804E
            014 - Defective
Address 09: Cent. Elect.        Labels: 4E0-910-279.clb
   Part No SW: 4E0 910 279 L    HW: 4E0 907 279 L
   Coding: 0133121
   VCID: 313EE1E33D2E6B6F757-8064
   Subsystem 1 - Part No: 4E1 910 113 B
   Coding: 00000037
   Shop #: WSC 02313
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Coding: 00141886
   Shop #: WSC 02313
Address 11: Engine II        Labels: 07C-910-018-BHT2.lbl
   Coding: 0011773
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 4E0 910 561 F    HW: 4E0 907 561 F
   Coding: 0041168
                    Fault Status: 11111101
                    Reset counter: 30
                    Mileage: 10392 km
                    Date: 2004.04.06
                    Time: 03:45:00
                    Temperature: 35.0°C
                    Voltage: 11.90 V
                    Bin. Bits: 00000000
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655     HW: 4E0 959 655 G
   Coding: 0430707
   VCID: 63925BAB375289FFB7B-8036
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549
   Coding: 0012151
   VCID: 659645B33966F7CF59F-8030
   Part No SW: 4E0 910 930 K    HW: 4E0 920 930 K
   Revision: D02         Serial number: AUDID3DN000836
   Coding: 0000104
Address 19: CAN Gateway        Labels:. 4E0-910-468.clb
   Part No SW: 4E0 910 468     HW: 4E0 907 468 B
   Revision: 7    Serial number: 1500404A0106B0
   Coding: FEFEFBDC2B3104
                    Reset counter: 30
                    Mileage: 272536 km
                    Date: 2004.04.06
                    Time: 03:57:49
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111
   Revision: 00000501    Serial number: AUZ5ZBC1024295
   VCID: 1C6020574AACF607361-8048
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0263168
Address 34: Level Control        Labels: 4E0-910-553.clb
   Part No SW: 4E0 910 553 J    HW: 4E0 907 553 F
   Coding: 0015510
   Shop #: WSC 42710 001 1048576
   Coding: 4063330
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 C
   Revision: 00000000    Serial number: 353J-047586256
   Shop #: WSC 00100 211 16775
   VCID: 3B22C3CBEF62913FDFB-806E
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135 A
   Serial number: 00000426000083
   Coding: 0003200
   VCID: 1D662D5351B6FF0FC1F-8048
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 801 B
   Coding: 0028461
   VCID: 201814A766C4D2E7EA9-8074
Address 46: Central Conv.        Labels:. 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Revision: 00400004    Serial number:  W040411090111
   Coding: 0004184
   VCID: 270A0FBB03EA25DFAB3-8072
   Subsystem 1 - Part No: 4E0 907 719
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 K    HW: 4E0 035 223 A
   Revision: PROD_01     Serial number: 00000000007543
   Coding: 0000016
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Revision:             Serial number: 00000000050643
   Coding: 0010101
   VCID: 1E642A5F5CB0E417D85-804A
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802 B    HW: 4E1 959 802 B
   Coding: 0028461
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 A    HW: 4E0 907 801
   Revision: AV1C1010
   Coding: 0000631
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Coding: 0000003
   VCID: 629C5EAF284880F7BCD-8036
   Part No SW: 4E0 910 541 Q    HW: 4E0 035 541 B
   Revision: 00000000    Serial number: 304KU047604487
   Coding: 0000001
   VCID: 2E04FA9F2C107497685-807A
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 C    HW: 4E0 915 181 C
   Revision: 00000000    Serial number: 00000000014183
   Shop #: WSC 00100 211 06074
   Subsystem 1 - Part No: 000 915 105 DL
   Coding: 303030393135313035444C56413033383132313445314343
   Shop #: WSC 00097 211 95421
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 801 C
   Coding: 0028461
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802 A    HW: 4E0 959 802 C
   Coding: 0028461
Address 76: Park Assist        Labels: 4E0-910-283.lbl
   Part No SW: 4E0 910 283 A    HW: 4E0 919 283 B
   Revision: --.--.--    Serial number: 08720428600554
   Coding: 0001108
Address 77: Telephone
End----------(Elapsed Time: 01:59, VBatt start/end: 12.0V/12.0V)-----------
Controller Software Versions:
ECU 1 = Engine        0060
ECU 2 = Auto Trans        0090
ECU 3 = ABS Brakes        0240
ECU 4 = Acc/Start Auth.        014
Sub ECU 4 > 1 = Acc/Start Auth.        XXX
ECU 5 = Seat Mem. Pass        0060
ECU 6 = Control Head        3460
Sub ECU 6 > 1 = Control Head        2010
ECU 7 = Auto HVAC        0340
ECU 8 = Cent. Elect.        0210
Sub ECU 8 > 1 = Cent. Elect.        0400
Sub ECU 8 > 2 = Cent. Elect.        0040
ECU 9 = Engine II        0060
ECU 10 = Auto Dist. Reg        0020
ECU 11 = Airbags        0940
ECU 12 = Steering wheel        0040
Sub ECU 12 > 1 = Steering wheel        5008
ECU 13 = Instruments        Labels:
ECU 14 = CAN Gateway        H7
ECU 15 = Media Player 2        0470
ECU 16 = Immobilizer        0140
Sub ECU 16 > 1 = Immobilizer        XXX
ECU 17 = Level Control        6310
ECU 18 = Seat Mem. Drvr        0060
ECU 19 = Navigation        1060
ECU 20 = Roof Electronics        00
ECU 21 = Door Elect, Driver
ECU 22 = Central Conv.        0040
Sub ECU 22 > 1 = Central Conv.        3002
ECU 23 = Sound System        0440
ECU 24 = Centr. Electr. II        0
ECU 25 = Door Elect, Pass.        0
ECU 26 = Parking Brake        1010
ECU 27 = Headlight Range        004
ECU 28 = Radio        0620
ECU 29 = Battery Regul.        0510
Sub ECU 29 > 1 = Battery Regul.
ECU 30 = Door, Rear Left        006
ECU 31 = Door, Rear Right        00
ECU 32 = Park Assist        0020
ECU 33 =
Bruce
Near Philadelphia, PA, USA
Not wanting to give bad news, I suspect that the starter is locked into the starter gear. That is, the starter is unable to turn because the gears are locked together and are jammed. I see nothing in the scan that would indicate a control failure.
When you turn the key, do the lights dim real bad? That is, is the current draw on the stalled starter motor so high, it drops the system voltage? I think the answer is obviously yes owing to the clicking starter relay.
Don't know if you can see the starter - but if you can get to it, you might try a bang with a tool on the starter case.. see if the gear will let loose. Else, I think you have to do what you said you do not wish to do - pull whatever is necessary to get to the starter. If my guess is correct, you may find it difficult to pull the starter once you get to it.
Follymans
C?ID=376127
Thank you for the short replay. No problem , i was already prepared for bad news. Just wanted to make sure i did not missed something and try getting the starter for nothing.
When i turn the key there is no dimming of the lights at all, just some clicks and pumpnoises. From underneith i can see the startercase and tried tapping it before but that also did'nt work.
Tommorow i will start getting the starter pulled. I share my possible successes or failures here for future similar cases.
Bruce
Let's not be hasty... have you checked the relays? Have you checked that the circuit to be sure that the starter motor is getting full voltage and that the leads to the starter can carry the high starting current? No dimming of the lights means no current draw. Could it be an open winding or failed brushes? Sure. But owing to how difficult it is to pull, I would sure exhaust all other possibilities first.
So from your report, I think my premise of a stuck rotor is wrong. Now I do not think the starter is getting the current it needs to start turning. I would consult wiring diagrams and all connections, making certain that both the power lead and the ground connection to the engine are proper. If the 12 volt is not making it to the starter, then there is a control circuit problem. If it is making it to the starter and the starter is pulling no current, then something happened to the starter.
Test your logic by load testing the wires through a headlight or some other load that will pull several amps. Do not trust just voltage readings. You need to know the circuit can push amps at 12 volts. If it cannot, you have control circuit problem. If it is, then again it points to the starter.
