Alarm on door handle pull
Octo
Canada
C?ID=262239
Does anyone know if it is possible to trigger the horn or alarm if someone pulls on the door handle while the vehicle is locked? I have a 2019 Tiguan Highline with the KESSY system.
We have had people going vehicle to vehicle in my neighbourhood looking for insecure vehicles. I would like to be able to have the horn honk when the door handle is pulled and the key isn't present, might encourage these people to move along quickly.
Mari
C?ID=150535
... the first reaction you get when you ask for a solution for a "problem" is to post a full autoscan so we know where we are talking about...
siLc
Tallinn, Estonia
C?ID=330192
Such functionality can be usually found in aftermarket alarm systems. On those, getting close to a locked car will trigger a beep.
Octo
Canada
C?ID=262239
Saturday,20,April,2019,14:44:41:48581
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4437.4
VIN: 3VV4B7AX1KM091135   License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 36 39 3C 42 44 47
          4B 52 5F 69 6C 6D A5 BB BC CA D6 D7
VIN: 3VV4B7AX1KM091135   Mileage: 2143km-1331miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Not registered 0001
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DGUA)       Labels: None
   Part No SW: 83A 907 115     HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0003
   Revision: 1DH31000
   Coding: 012A00122476012FB4000000000000000000000000000000
   Shop #: WSC 34970 002 1048576
   ASAM Dataset: EV_ECM20TFS01183A907115 001005
   ROD: EV_ECM20TFS01183A907115.rod
   VCID: 638657006AE87D52A0-8036
   Part No SW: 09G 927 158 DT    HW: 09G 927 158
   Component: AISIN AQ8     206 3549
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00444
   ROD: EV_TCMAQ450031_VW32.rod
   VCID: 085C60ACB38EFE0A95-805C
   Part No SW: 5Q0 614 517 DT    HW: 5Q0 614 517 BP
   Component: ESC           H35 0108
   Revision: 00000000    Serial number: 53528000000549
   Coding: 0BFA6BA450291B6DC5780303A2C849D0D60AD8A3C045927438415058D2AA4A0B00402864121A1C230935351919323200
   Shop #: WSC 01383 790 50316
   ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
   VCID: 06406E94B99AE87AE7-8052
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0495911433
   Coding: 132C2C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   VCID: 43C6B780CA281D5280-8016
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11362556
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NN 907 044 N    HW: 5NN 907 044 N
   Component: AC Automat    H35 4601
   Revision: 20K03000    Serial number: 00000D00291273
   Coding: 00020024200118001105010C1211140E
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   VCID: 57FE73D02EB0A1F2CC-8002
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 82746608
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C86412011901HL
   Shop #: WSC 00066 790 00453
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7BB60F60F258A59288-802E
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 190108  034 0373
   Serial number: 19010521117260
   Component: RLHS  052 0107
   Serial number: SBY18M11D22H10M24S19
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 4 - Part No SW: 5Q1 953 521 R    HW: 5Q1 953 569 B
   Component: Lenks.Modul  H23 0170
   Serial number: 0300120120190C207491
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000137088R19021
   Coding: 0471255911
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CD49CBCE776D22A71-8018
   Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0342
   Coding: 320000CA58FF8728749C810530408700000000000000000000
   ASAM Dataset: EV_ACCMRRCONTIVW376 003015
   ROD: EV_ACCMRRCONTIVW376.rod
   VCID: 42C8B284D532145A8B-8016
196741 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
          [FCTSEN_BLOCKAGE]
                    Reset counter: 93
                    Mileage: 1430 km
                    Date: 2019.04.09
                    Time: 15:12:43
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 16 °C
                    Velocity_vehicle_reference: 6.86 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.81 m/s²
196742 - Sensor for Automatic Distance Control
          [FCTSEN_DEC_BLOCKAGE]
                    Reset counter: 93
                    Mileage: 1430 km
                    Date: 2019.04.09
                    Time: 15:13:04
                    Voltage terminal 15: 14.7 V
                    Control Module temperature: 17 °C
                    Velocity_vehicle_reference: 9.73 m/s
                    Longitudinal_acceleration_vehicle_reference: -1.06 m/s²
196743 - Sensor for Automatic Distance Control
          [FCTSEN_INC_BLOCKAGE]
                    Reset counter: 93
                    Mileage: 1430 km
                    Date: 2019.04.09
                    Time: 15:12:20
                    Voltage terminal 15: 14.6 V
                    Velocity_vehicle_reference: 10.24 m/s
                    Longitudinal_acceleration_vehicle_reference: -2.09 m/s²
   Part No SW: 5Q0 959 655 BM    HW: 5Q0 959 655 BM
   Component: AirbagVW21    005 0403
   Serial number: 003FGM00K0ND
   Coding: 8CCCFC00000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 0C545CBCA7F6922AB1-8058
   Occupant Detection:
   Serial number: IBH00000000000AW1QD%
   Coding: 303352
   Subsystem 2 - Part No SW: -----------    HW: 480 002 411 18
   Serial number: 35700000000C123C553F
   Subsystem 3 - Part No SW: -----------    HW: 480 002 411 18
   Serial number: 35800000000361607635
   Subsystem 4 - Part No SW: -----------    HW: 480 400 609 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001C92C817C0F38D
   Subsystem 5 - Part No SW: -----------    HW: 480 400 609 18
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001142B70FA2914Y
   Subsystem 6 - Part No SW: -----------    HW: 480 401 112 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001C12C8C774F44G
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 112 18
   Component: FrontSensor_P  003 6149
   Serial number: 3560001C12C8C775D72H
   Part No SW: 5NA 920 790 D    HW: 5NA 920 790 D
   Component: KOMBI         508 1701
   Coding: 08A4041AEF8888090288634B50010000A0000000
   Shop #: WSC 00066 790 00247
   ASAM Dataset: EV_DashBoardVDDMQBA0 001026
   ROD: EV_DashBoardVDDMQBA0_VW37.rod
   Serial number: 12011900840552
   Coding: 030500347F085900FB03225A1E0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E903634B12AC03A3F-803A
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
   Component: E221__MFL-TAT  H06 0025
   Serial number: 2971814520001309FG2B
   Coding: 2E0000
   Serial number: 9996826200
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Ruhestrom oberer Grenzwert überschritten]
                    Fault Frequency: 12
                    Reset counter: 127
                    Mileage: 1714 km
                    Date: 2019.04.14
                    Time: 02:59:54
                    Supply voltage: Terminal 30: 12.5 V
                    Terminal 15: OFF
   Component: Haldex4Motion H55 7084
   Serial number: HA1-00012.10.18
   Coding: 0101
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45C2A998C41C2362AE-8010
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 126
                    Mileage: 2110 km
                    Date: 2019.04.19
                    Time: 14:50:46
0035 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [functional limitation due to supply voltage - lower limit exceeded]
                    Reset counter: 104
                    Mileage: 1679 km
                    Date: 2019.04.13
                    Time: 16:24:41
0036 - Terminal 15
          U1405 00 [008] - Implausible signal
          [Clamp 15 implausible signal]
                    Reset counter: 104
                    Mileage: 1679 km
                    Date: 2019.04.13
                    Time: 16:24:41
   Serial number: 18000375300002
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 3326E7409A88ADD210-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RJ239898
   Coding: 0010000000000500018280808080000000008101000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3D32C178ACCC6BA2F6-8068
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
                    Reset counter: 126
                    Mileage: 1928 km
                    Date: 2019.04.17
                    Time: 07:01:50
   Serial number: 0501906308
   Coding: 02012103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0503892677
   Coding: 020121
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42035900604288
   Coding: 003F1B205200048000000000
   VCID: 4FEE8BB01660E93214-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000001559131
   Coding: 011000
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1081
   Coding: 911F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50EC88CC0B5EF6CA0D-8004
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1JMD03PYVV
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E10F63471AA803A7F-807A
   Component: FCM MQB Low   002 0345
   Serial number: 16011900840054
   Coding: 0000000509001D5200210F01090000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 3522D95894FCB3E23E-8060
66680 - Databus
          [LCM_LWR_L_allg_Fehler received error value]
                    Reset counter: 104
                    Mileage: 1679 km
                    Date: 2019.04.13
                    Time: 16:24:42
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46035900301277
   Coding: 003F13205E00048000000000
   VCID: 4ED096B4116AE03A1F-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000001574297
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Coding: 027306020000000051220002001828001F0500E401200405C6
   Shop #: WSC 00066 790 00326
   ROD: EV_MUStd4CDELP_VW26.rod
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  252 8130
   Serial number: VWZ6ZMV3495940
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0442704717
   Coding: 0200000200000000
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG042246
   Coding: 01230601A30F20003000400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   VCID: 393AD568B8E45782DA-806C
   Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0266
   Revision: --------    Serial number: A2-C758-8700-2
   Coding: 0AA8
   VCID: 46C0AE94F91A287AA7-8012
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0610
   Serial number: 02111815P11516
   Coding: 0003070601020201002213548150490084000E20012000
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40CCB88CDB3E064A9D-8014
Address BB: Door Rear Drv
Address BC: Door Rear Pass
Address CA: Sunroof (J245)       Labels:* None
   Coding: 00804073260C
   ROD: EV_SunRoofCONTIAU736_009_VW37.rod
   VCID: 75A21958D47CF3E2FE-8020
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 004C788C9BBEC64ADD-8054
1061 - Supply Voltage for Logic
          C121F 13 [032] - Open Circuit
   Component: LED1R         H07 0008
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----------(Elapsed Time: 02:12, VBatt start/end: 12.4V/12.2V)-----------
