Mileage check
amer
Pirate
Bosnia
Hi guys, I'm pretty new into this and find it very interesting,
I'm interested is it possible to verify true mileage in VCDS. I'm familiar with EDC 15-16 option. When we ran this option in a MK5 Golf, we got a reading of 8 km. I'm suspecting it was rolled back.
When the DTC are listed the mileage that they appeared they match to mileage on the instrument cluster. ( what i suspect the mileage wasn't just edited in EEPROM chip on back of the cluster...)
What I'm interested in, do different modules in the car also store mileage. If they do, can someone tell me which ones, and under witch channel ?
Thanks!
Some automatic transmissions do. Other than that, I'm not sure.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Which is a known bug, VCDS is looking at the wrong place for some ECMs. So ignore what VCDS says there and either ask somebody who can manually check the dump or use another tool.
This depends highly on the specific model (incl. year) as well as the installed options. In order to give you some better info, start by posting an Auto-Scan.
amer
Pirate
Bosnia
Thank you for your reply, i will check if i have a autosave doc.
What "other," tool is good for mileage check?
Is there a memory dump off all DTC's from begining of car life?
No. Cars do not maintain a log of previously stored DTCs. Once they are cleared, they are gone.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Not entirely true. While the actual fault code memory is cleared, the internal memory is a different story (though that is not accessible with regular diagnostic tools). There are also cases (certain control modules) where you can see references for special DTCs in the measuring values even after the codes have been cleared. So again, it all depends on the circumstances, the specific model & model year as well as the issue you are trying to investigate.
