No start help please
OnlinePolice
C?ID=244576
Hello. Please help diagnosing a no start.
2011 A4 Quatro 2.0L FL chassis
Did a major engine repair after a chain tensioner failed.
If I spray starting fluid it starts.
using VCDS i was able to turn on HPFP valve, LPFP and all 4 injectors.
Did some scanning on fuel, here's what I have while cranking
Address 01: Engine (8K2 907 115 AD)
14:58:24
IDE00201 High fuel pressure: specified value 5.3250 MPa
IDE00357 Fuel temperature -48.0 °C
IDE00371 Fuel consumption 0.00 l/h
IDE00589 Fuel pressure 80 kPa rel
IDE01893 Fuel pump: specified value 10.001 %
Please help me understand these numbers. I though I understand English untill i ran into this.
NostraJackAss
OnlinePolice
C?ID=244576
Saturday,17,August,2019,12:16:54:35464
VCDS Version: 19.6.1.0 (x64)
VIN: WAUHFAFL8BN042640   License Plate:
Mileage: 195070km-121210mi   Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72 77
VIN: WAUHFAFL8BN042640   Mileage: 195070km-121210miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AD    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H19 0003
   Revision: E1H19---
   Coding: 0104010A180F0160
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_ECM20TFS0118K2907115AD 001006
   ROD: EV_ECM20TFS0118K2907115AD.rod
   VCID: 71E99438A02392C766-8024
4527 - Coolant Fan Control Circuit 1
          P0480 00 [039] - Electrical Malfunction
                    Mileage: 195074 km
                    Date: 2010.04.03
                    Time: 12:47:13
                    Engine speed: 0.00 /min
                    Coolant temperature: 25 C
                    Intake air temperature: 30 C
                    Voltage terminal 30: 12.957 V
Readiness: 1110 0101
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0060
   Coding: 070D18
   Shop #: WSC 02391 823 56573
   VCID: 020BCBF49D85995F8F-8056
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 81
                    Mileage: 195074 km
                    Date: 2010.04.03
                    Time: 12:50:01
                    Hex Value: 0x0000
                    Hex Value: 0x0280
                    Hex Value: 0x0032
                    Hex Value: 0x02A2
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
   Component: BCM2 2.0      H05 0435
   Coding: 0B0100
   Shop #: WSC 02399 823 56573
   VCID: 76E3A724C14DB5FFB3-8022
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0811000006715015
   Serial number: 2310000105926010
   Revision: C1000000    Serial number: 01250120110483
   Coding: 64002000
   VCID: 000FC1FC93898B4F99-8054
                    Fault Status: 01101000
                    Reset counter: 81
                    Mileage: 195074 km
                    Date: 2010.04.03
                    Time: 12:47:12
                    Temperature: 28.0C
                    Reset counter: 81
                    Mileage: 195074 km
                    Date: 2010.04.03
                    Time: 12:47:12
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000000768899
   Coding: 26001091063CAF010000080300003D0D0F1C120802010161000000
   VCID: 3C77750CBFE12FAF85-8068
   Component: WWS 240111  H06 0070
   Serial number: SWF11010245905
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11234911
   Coding: 025028
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001001110134
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                    Fault Status: 01101100
                    Reset counter: 81
                    Mileage: 195074 km
                    Date: 2010.04.03
                    Time: 12:47:00
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                    Reset counter: 81
                    Mileage: 195074 km
                    Date: 2010.04.03
                    Time: 12:47:00
                    Reset counter: 81
                    Mileage: 195074 km
                    Date: 2010.04.03
                    Time: 12:47:00
   Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003GLD0N3Z2U
   Coding: 303837354230303030304A55304C384B3053
   Shop #: WSC 02135 785 00200
   VCID: 458110E8C42B6E67EA-8010
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1100003R69
   Serial number: 6334MSME5B314B67L
   Serial number: 6344MSME5B422B51F
   Serial number: 6352QSME707D01027
   Serial number: 6362QSME4700066EF
9443859 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
                    Mileage: 195074 km
                    Date: 2010.04.03
                    Time: 12:47:12
9444115 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [137] - Open or Short to Plus
                    Mileage: 195074 km
                    Date: 2010.04.03
                    Time: 12:47:12
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372KAP00174
   Coding: 000016
   VCID: 3D717808A4FB26A7B2-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 950 H    HW: 8K0 920 950 H
   Component: KOMBIINSTR.   H20 0258
   Revision: 00200000    Serial number: EIL369T1C
   Coding: 8B1409000300D705020000
   VCID: 34675D2C97B1E7EF4D-8060
00771 - Fuel Level Sensor (G)
                    Fault Status: 00101010
                    Reset counter: 121
                    Mileage: 195074 km
                    Date: 2010.01.25
                    Time: 22:20:05
00438 - Fuel Supply Sensor 2 (G169)
                    Fault Status: 01101010
                    Reset counter: 81
                    Mileage: 195074 km
                    Date: 2010.01.25
                    Time: 22:20:05
   Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0117
   Revision: GB800053    Serial number: 5300G111168082
   Coding: 00C303
   VCID: 0109C4F89883824796-8054
   Component: J367-BDM  H07 0170
   Serial number: 11004371140111
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   VCID: 39796C18B0D31A879E-806C
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1501
   Coding: 011C03204000410001
   VCID: 53A53EB0327FC0D774-FFFE
   Revision: 00002001    Serial number: 0141838300
   Coding: 0106023A00FA444480B0013200000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000354421
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS039  H07 0041
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T0 035 223 AR    HW: 8T0 035 223 AJ
   Component: DSP Prem      H19 0320
   Revision: 00019001    Serial number: 34803000708601
   Coding: 0203010302
   Shop #: WSC 09223 444 84432
   VCID: 7EF3BF04E97DFDBFEB-802A
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1501
   VCID: 52AB3BB40D65C9DF7F-8006
   Revision: 00000003    Serial number: 00000000842883
                    Fault Status: 11101101
                    Reset counter: 81
                    Mileage: 195074 km
                    Date: 2010.04.03
                    Time: 12:47:12
                    Voltage: 13.00 V
                    Count: 80
                    Hex Value: 0x0270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No: 8K5 907 357 B
   Coding: 0000004
   VCID: 39796C1870D31A879E-806C
                    Reset counter: 121
                    Mileage: 195074 km
                    Date: 2010.04.03
                    Time: 12:47:13
                    Reset counter: 121
                    Mileage: 195074 km
                    Date: 2010.04.03
                    Time: 12:47:13
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
   Component: Con3 Sirius   H06 0351
   Revision: 00000008    Serial number: AUZ5Z6J1374836
   Coding: 04030002010185004359070800
   Shop #: WSC 54644 000 1048576
   VCID: 468317E4F12D657FE3-8012
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
                    Reset counter: 81
                    Mileage: 195074 km
                    Date: 2010.04.03
                    Time: 12:47:22
   Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
   Component: TSG HL        H06 1501
   Coding: 010C03204000210001
   VCID: 56A3C7A4218DD5FF93-8002
   Component: TSG HR        H06 1501
   Part No SW: 8T0 862 336 E    HW: 8T0 862 336 E
   Component: FSE_256x BT     H42 0650
   Revision: 00000000    Serial number: 00000005107768
   Coding: 0010370
   Shop #: WSC 02335 785 00200
   VCID: 3D71780864FB26A7B2-8068
End-------------------------(Elapsed Time: 09:39)--------------------------
12:34:37
  IDE00019   Voltage terminal 30 12.910 V
  IDE00021   Engine speed 0 /min
  IDE00190   Charge air pressure specified value 340 hPa
  IDE00201   High fuel pressure: specified value 5.0000 MPa
  IDE00407-ENG57549   Rail pressure regulation: status-Bits 0-7 0
  IDE01930   High pressure regulation: adaptation value -0.1630 MPa
  IDE01931   High pressure pump injection volume control deviation 4.8125 MPa
  IDE01932   High pressure pump injection volume 327.67 mm
No mods to the engine. Stock except for 2 ignition coils.
Just finished rebuilding the head due to bent valves.
Replaced all spark plugs, timing chains, chain guides, and tensioners.
The front of the car is still off so fans, temp sensors etc aren't connected. Hence the errors on the scan.
Parts purchased at genuineaudiparts.com and ecstuning.com
All fuses are checked and none were bad. Although, I dont know if I found all fuse boxes. One in the trunk, one on each side of the dash.
NostraJackAss
Hmmm is there something you are failing to tell us here?
Is this car modified?
Can you explain to us why your car is failing a readiness monitor bit for EGR valve?
Uhm, the car isn't fully back together yet. Are we really going to obsess over readiness bits on a car that won't start?
NostraJackAss
Well sure because It's a serious anomaly to me.
I would like the OP or law enforcement official of the net to default controller clear codes and see if the status of anything changes here.
OP please do this by a mere recode and clearing codes in the engine 0x01 and also in OBD2 mode in 0x33 MODE 4.
Please advise of new scan and if readiness bit changed for EGR and if a pulse wakes up to injectors or N276?
Usually people set stuff to not ready when doing something nefarious, in this case it's just the opposite so to me it matters!
Are we missing power on bus to injectors or N276?
What are ground points status?
OnlinePolice
C?ID=244576
I can assure you that the car isn't modified.
Sorry, what do you mean by EGR? Where do I find it on the scan I provided?
There was a whole bunch of codes right at initial scan. The scan I provided above is after I cleared the initial codes after looking over stuff and plugging the things that were not connected and then cranking the engine a few times. However, will clear it again when I get to it.
Meanwhile, can someone please explain these fuel stats to me?
NostraJackAss
Reset counter: 121
Mileage: 195074 km
Date: 2010.01.25
Time: 22:20:05
Reset counter: 81
Mileage: 195074 km
Date: 2010.01.25
Time: 22:20:05
What is this all about?
