Passat b6 folding mirror retrofit
rhinopower
C?ID=58979
Modules wont accept coding, getting -31 out of range
Modules are gen3 max so should work, but i've never done folding mirrors before
Scan as below
Monday,19,August,2019,22:14:54:34436
VCDS Version: 19.6.1.0
Workshop Code: 755 54764 070000
VIN: WVWZZZ3CZ7P046711   License Plate:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 7D
VIN: WVWZZZ3CZ7P046711   Mileage: 281910km-175170miles
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-018-BKP.clb
   Part No SW: 03G 906 018 CE    HW: 03G 906 018 CE
   Component: R4 2.0l PPD1.5 G    9384
   Revision: --H25---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 66565 257 00032
   VCID: 6ADC7C0D45F96D1F27-803E
005187 - Potentiometer for EGR (G212)
               P1443 - 007 - Signal too Low
                    Fault Status: 01010010
                    Mileage: 281919 km
                    Date: 2014.01.09
                    Time: 22:11:13
                    Torque: 128.0 Nm
                        0.00 %
                    Battery Volts: 1.0 V
                    Mass Air / Rev.: 0.0 mg/str
Readiness: N/A
Address 03: ABS Brakes        Labels:. 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 P    HW: 3C0 614 095 P
   Component: ESP 440 C2     H015 0004
   Revision:  H015       Serial number: 0667854032
   Coding: 0013602
   Shop #: WSC 00191 210 89371
   VCID: 2F6AAD19BE9BC83730-807A
   Part No SW: 7N0 907 426 AM    HW: 7N0 907 426 AM
   Component: AC Manuell    H19 0304
   Revision: 00001016
   Coding: 0000004002
   Shop #: WSC 70885 001 00001
   ROD: EV_ACManueBHBVW36X_VW46.rod
   VCID: 7F0ABD59E67BF8B7E0-802A
   Part No SW: 3C0 937 049 H    HW: 3C0 937 049 H
   Component: Bordnetz-SG     H37 1301
   Revision: 00H37000    Serial number: 00000004320760
   Coding: A0800F0700041A00000A00000F000000000859435C0000
   Shop #: WSC 54764 755 70000
   VCID: 2E54B01DB991C13F3B-807A
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 290607 022  0601
   Coding: 00046997
   Shop #: WSC 54764
   Part No SW: 3C0 909 605 F    HW: 3C0 909 605 F
   Component: 02 AIRBAG VW8   029 2421
   Revision: 08029000    Serial number: 0039USD4JJLH
   Coding: 0012338
   Shop #: WSC 05311 000 00000
   VCID: 295E4301807FA607EE-807C
   Subsystem 1 - Serial number: 6332MSME110F1075
   Subsystem 2 - Serial number: 6342MSME117A722E
   Subsystem 3 - Serial number: 6351HTS6K5Q6U873
   Subsystem 4 - Serial number: 6361HTS6VARQ03B2
01217 - Side Airbag Igniter; Driver Side (N199)
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
Address 16: Steering wheel (J527)       Labels:| User\3C0-953-569.lbl
   Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
   Revision: FF010040    Serial number: 20110927100793
   Coding: 0182250000
   Shop #: WSC 00028 028 00020
   VCID: 72EC646DA529A5DF9F-8026
   Subsystem 1 - Part No SW: 3C8 959 537 B    HW: 3C8 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H4  0021
   Coding: E20000
   Part No SW: 3C0 920 971 R    HW: 3C0 920 971 R
   Component: KOMBI         H05 0110
   Coding: 160F00
   VCID: 3460A2759FBDEBEF4D-8060
Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 E    HW: 3C0 907 951
   Component: J533__Gateway   H10 0080
   Revision:   H10       Serial number: 1200P07C110958
   Coding: F9807F160002021003
   VCID: 23425129E2537C57A4-8076
                    Reset counter: 208
                    Mileage: 281919 km
                    Date: 2014.01.09
                    Time: 22:11:14
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 00545 210 88561
   VCID: 7AFC4C4D3559DD9FD7-802E
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
02823 - Requirements for Locking the Steering Column Lock not met
                    Reset counter: 208
                    Mileage: 281919 km
                    Date: 2014.01.09
                    Time: 22:12:26
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1132
   Revision: 31008001    Serial number: 00000126369120
   Coding: 0000695
   VCID: 3C708A557FED23AF85-8068
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.134 H07 1806
   Shop #: WSC 00028 028 00001
   VCID: 35669F715CC7F2E77A-8060
   Component:    KSG PQ46 ELV 043 0612
   Coding: 18910A0001860E7630041C1D70085FCE107C01
   Component: LIN BACKUP HORN H08 9001
   Subsystem 2 - Part No: 3C0 951 171 A
   Component: Neigungssensor  002 0508
   Subsystem 3 - Part No: 3C0 951 171 A
   Component: Innenraumueberw.002 0508
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1132
   Revision: 31008001    Serial number: 00000027169123
   Coding: 0000694
   VCID: 3D76875164F72AA7B2-8068
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000012
   VCID: 214E5B21F84F6E47B6-8074
Address 56: Radio        Labels: None
   Part No SW: 3TD 035 156     HW: 3TD 035 156
   Component: RadioSK46MID  006 0010
   Coding: 01000424041000
   Shop #: WSC 00078 790 00000
   VCID: 7F0ABD59EE7BF8B7E0-802A
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1113
   Revision: 11005001    Serial number: 00000000426810
   Coding: 0000144
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1113
   Revision: 11005001    Serial number: 00000000524634
   Coding: 0000144
   VCID: 3E74805D69F131BFAB-806A
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D56B711B497BA2702-8078
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End---------------------(Elapsed Time: -2:00, udsna)-----------------------
kamold
Australia
C?ID=241363
Gen3 door controllers in RHD as far as I've been able to tell there is no known eeprom data for folding.
Need to upgrade to gen4s.
rhinopower
C?ID=58979
So gen3 in rhd won’t accept the +4096 regardless?
langers2k
C?ID=224085
The factory fitted RHD gen3 max modules certainly can as I retrofitted folding mirrors to my Octavia.
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2120
   Coding: 0004854
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0005110
They are very different SW/HW versions to your Passat which could explain it.
I think Kamold is suggesting that some LHD versions need the EEPROM data updating to support folding but has never seen a dump for RHD versions.
kamold
Australia
C?ID=241363
Sorry I'm confusing things here....I'm actually talking about comfort folding from the keyfob...:facepalm:
That's a known eeprom change for LHD but unknown for RHD.
Regular folding from the mirror controls is fully supported with Gen3 modules.
rhinopower
C?ID=58979
But that is the issue I am having. Two sets of gen 3 modules won’t accept the coding
langers2k
C?ID=224085
It's two different issues Rhinopower.
- Kamold is talking about direct editing of the door controller EEPROM to add 'comfort folding' on a vehicle which already has working folding mirrors.
- Your talking about the door controllers refusing a coding change to add folding mirror support when retrofitting.
Just to confirm, you're trying 0004791 and 0004790?
I'm not sure what else to suggest as I'm not super familiar with the B6 so others might be able to offer more help. I believe that MAX3 door controllers should be able to support folding mirrors, did you check the pins were present when you added the mirrors?
Kamold, RHD comfort folding certainly can be done. As per this thread I was able to tweak the EEPROM using the information from this page.
rhinopower
C?ID=58979
Yes to confirm i have tried 4791 and 4790. I even tried coding just folding mirrors and nothing else, and still refused by the controllers :(
langers2k
C?ID=224085
rhinopower
C?ID=58979
Coding: 0001463
Coding: 0001462
This coding worked for folding mirrors, so the label file is wrong
I corrected the coding for the puddle lights etc after and mirrors still worked, but the label file saying add 4096 is incorrect
