Request out of range message 09 adaptations
Carlosfandango
C?ID=349939
Hi, new here so apologies if I’ve posted this incorrectly! I have a 2016 MK7 GTi and Recently I’ve noticed that when in auto mode the headlights (when on) will occasionally flick off and back on once super quickly after exiting a dark area, such as overhanging trees, I made the assumption that maybe it was sensing a further dark area at the point were the lights would shut off, therefore turning back on, to combat this I changed the tunnel on/off delay - channel 09 adaptations eng122930-rls_tunel_gateway_recognize ,(I now believe it may just be the on delay anyway) from 5seconds to 10seconds, this didn’t alter the abnormality so I wanted to put it back to 5seconds as when not playing up the lights stay on too long after a tunnel , however the adaptation will not take this time and displays a box stating ‘request out of range’ or such like and goes back to 10seconds, I’m entering the 31347 security code which takes so I don’t think it’s that, between the two adaptation change attempts I was prompted to update the HEX V2 cable so thought that might be something to do with it maybe? Anyway does anyone have any idea where I should start with this? I’m using the phone at the moment to post this so will post and auto scan ASAP, or an ad map later if required, having not done either of those things before though I may or may not need a little guidance, thanks.
Monday,19,August,2019,20:42:30:06823
VIN: WVWZZZAUZGW133319   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZGW133319   Mileage: 64886km-40318miles
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 C    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00122464050B3000
   ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
   ROD: EV_ECM20TFS0205G0906259C.rod
   VCID: 2E04F8B3F096EF07685-807A
   Part No SW: 0D9 300 041 C    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4902
   Revision: 06253104    Serial number: TFK01508131614
   ROD: EV_TCMDQ250021.rod
   VCID: 18683E6B621201B7129-804C
   Revision: 00000000    Serial number: 62545000003255
   Coding: 01FA93A13423296F077A0601C1CCA980C92C94E0608395F718425078C209
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7AAC04E37C5EF3A784D-802E
   Revision: 00021000    Serial number: 0381047832
   Coding: 030C0C
   VCID: 3A2CC4E33CDE33A7C4D-806E
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 00120004200100011005004000101002
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6A8C34A30CFE432774D-803E
   Air quality sensor:
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061526601261
   Coding: 03051A46C20122FB0F244080B11C07281800000000000000000000000000
   Shop #: WSC 12345 102 209715
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094E6B2F29B8E83F9D7-805C
   Component: WWS    150723  042 0551
   Serial number:         150806065600
   Coding: 0E4DFD
   Component: RLHS  037 0059
   Serial number: S5Y15M09D29H13M37S47
   Coding: 90A8DD
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY1521718CE
   Serial number: 00000000000033405858
   Revision: --------    Serial number: 39331526402744
   Coding: 0071051011
   VCID: 43D2B9074B14726F97B-8016
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 10081503271980
   Coding: 001C1300FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    015 0388
   Serial number: 003MLR13DEGY
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F5AF5F7677CD68FB33-802A
   Belt Pretensioner left:
   Serial number: 34169661C15091540122
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169662C14091541230
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 709 15
   Serial number: 3576700000012955F61T
   Subsystem 4 - Part No SW: -----------    HW: 480 001 709 15
   Serial number: 35867000000C1545F61Z
   Subsystem 5 - Part No SW: -----------    HW: 480 401 509 15
   Serial number: 35165029B1D25F70E1AO
   Subsystem 6 - Part No SW: -----------    HW: 480 401 609 15
   Serial number: 3526502B11D25F718089
   Subsystem 7 - Part No SW: -----------    HW: 480 401 609 15
   Serial number: 3556502B11D25F725114
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 20091504220994
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   Part No SW: 5G1 920 956 A    HW: 5G1 920 956 A
   Component: KOMBI         302 6420
   Coding: 27AD01182F80260001816A011400000000000000
   VCID: 2D06FFBFFD90941F51F-8078
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1224
   Revision: --------    Serial number: 0003976655
   Coding: 030100043F085900FB00027E1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 75B617DF55409CDFE9F-8020
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150001808390035377
   Coding: 2DFFFF
   Serial number: 9124577803
   Revision: 00000000    Serial number: 15000210812004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3430EADB1EBAC5D71E1-8060
   Serial number: 060915BI505597
   Coding: 003F1220D001048100001000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   VCID: 392EDBEF39D838BFCD7-806C
   Serial number: 170915BIG19192
   Coding: 003F1020DE01048100801000
   VCID: 42DCBC03540E7B679CD-8016
   Coding: 029E01001F000200
   VCID: 40D8B60B5A0269778A9-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    820 0629
   Coding: 02730001FF00000051111101008808001F0203C601200100CF
   Shop #: WSC 39782 001 104857
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 3038E6CBEAA2F9F77A9-8064
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU304QHJ
   Subsystem 2 - Part No SW: 3G0 919 866 BJ    HW: -----------
   Component: ECE1 2018  --- 0915
6691 - Local Data Bus
          U10BA 00 [008] - No Communication
          [Sub-Bus keine Kommunikation]
                    Reset counter: 17
                    Mileage: 63174 km
                    Date: 2019.07.13
                    Time: 08:38:17
                    Voltage terminal 30: 12.5 V
                    Network diagnosis-Status: not enabled
   Component: SAS-GEN 2     H06 0014
   Serial number: 150902200753
   VCID: 6B8231A703045A2F0FB-803E
End----------(Elapsed Time: 01:55, VBatt start/end: 12.3V/12.3V)-----------
^^^ hmm.......... here's a more "evocative" form of the code-string on the BCM from your auto-scan:
Byte	Hex	Binary
0	03	00000011
1	05	00000101
2	1A	00011010
3	46	01000110
4	C2	11000010
5	01	00000001
6	22	00100010
7	FB	11111011
8	0F	00001111
9	24	00100100
10	40	01000000
11	80	10000000
12	B1	10110001
13	1C	00011100
14	07	00000111
15	28	00101000
16	18	00011000
17	00	00000000
18	00	00000000
19	00	00000000
20	00	00000000
21	00	00000000
22	00	00000000
23	00	00000000
24	00	00000000
25	00	00000000
26	00	00000000
27	00	00000000
28	00	00000000
29	00	00000000
30		00000000
As you can see - the Bit-structure of Byte 6 and Byte 7 (which is where the Light sensor and LDS is defined) is singularly unremarkable. So, in the words of the leader-of-the-free-world (a walking cliche and my role model - not), "nothing to see here""!!
Just a hunch (actually, it's a complete guess), but jyoung8607 (a very astute forum colleague- particularly where American politics is concerned) mentioned on another post that sometimes VCDS requires modules on MQB platform vehicles to be reset when reverting back channel values.
I wonder if this idiosyncrasy is implicated in your dilemma? Worth considering IMO, given that it's an easy try - perhaps?
If not then perhaps posting a BCM admap (as you say) can shed further light onto the problem (pun intended)
EDIT: Ooops - forgot to mention that the 'JYoung" method for resetting control modules is to remove and re-connect the battery lead - yes, it's a tad severe (why can't VCDS software mimic this process "virtually" - do UDS modules have an interrupt vector 0 facility?) but apparently it has worked in some instances.
EDIT 2 : Subsequent rush of blood to the brain-box - have you tried a softer form of module reset: the one in the MENU called "factory reset"?
Carlosfandango
C?ID=349939
Thanks DV52 for your reply, yes I don’t believe there is anything remarkable showing in the coding for the RLS but I felt it was a requirement to post the auto scan, incidentally just prior to trying again to change the setting back to 5 seconds the battery had been unhooked for just over 24 hours as I had removed the steering wheel for a re trim, this appears to have had no effect, on a side note though it seems to have smoothed out the DSG rather like performing basic settings! Is applying the factory reset via VCDS a simple process? Is it performed in individual modules or is it system wide? Other than making a copy of the coding in the RLS are there any other prerequisites before clicking factory reset? Could updating the HEX-V2 in between changes have altered anything? Thanks.
Carlosfandango
C?ID=349939
Does anyone have any thoughts on why I’d be getting the ‘request out of range’ message please?
That message indicates that the control module in the car is refusing the change. As to why a control module is refusing, one would have to know the module's internal logic, and that's something we're not privy to.
TIs applying the factory reset via VCDS a simple process? Is it performed in individual modules or is it system wide? Other than making a copy of the coding in the RLS are there any other prerequisites before clicking factory reset? Could updating the HEX-V2 in between changes have altered anything? Thanks.
Sorry for the confusion -it must be my thick Aussie accent - or the fact that English is my 2nd language!! When I said "the one in the MENU called "factory reset"" - I meant the MENU in the MIB - not any reset in VCDS (whatever you do, DON'T use "reset all adaptation channels" in Basic Settings in VCDS- that's a definite no no)
You have already made "a copy of the coding in the RLS". On a mk7 Golf, the light sensor is what VCDS calls a SLAVE of the BCM (the sensor uses a LIN wire to talk to the BCM - but yes, that's probably too much information;)) If you look in your autoscan in the section for the hex09 module, you will find the following:
   Coding: 90A8DD
which is a convenient segue into my question - have you changed the coding on this module? I ask because Bits 3-5 of Byte 0 determine the "Light activation threshold". On my earlier model mk7 ( my unit is HW 5Q0 955 547 - not HW 5Q0 955 547 A as in your car), the factory setting for Byte 0 was hex00 - as you can see your value is hex90 (or binary 1001 0000), which suggests that light sensor on your car has +40% earlier threshold.
As for your question about any possible impact from updating to the current Hex series cables - I don't believe that this is the cause of your problem.
Finally, some later version BCMs have a channel called MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung. Mr Google-translate purports this to mean MAS08228-ENG133443-Light sensor-Tunnel switch-on delay and my A3 Audi (which shares the same MQB build platform as the mk7) has the setting 2 - this probably means 2 seconds, I guess. Might be prudent to check this value on your car
Carlosfandango
C?ID=349939
Thanks Don, Yes MAS08228-ENG133443-Light sensor-Tunnel switch-on delay in my car is set to 2, I did change this to 1 and the lights do switch on quicker, it wasn’t what I was looking for so see it back to 2, and yes the car is set to 40% earlier threshold when I look in the long coding helper, however as you know this can be set via the infotainment so I thought that is why it displayed 40% (matching the early infotainment setting), I now see that the value doesn’t change in VCDS when mid or late is selected on the headunit, I’ll check the auto scan I took when I bought the car and see if I changed it at some point (just checked and the coding hasn’t changed from 90A8DD)! However I now believe the ‘tunnel_gateway_recognize’ adaptation I originally asked about is actually the switch off delay, I’d still like to change it back to 5seconds so will have to keep trying, as for the factory reset, I won’t be doing that as I was already under the impression it was a no no,
TBAx
DE
C?ID=287144
Try changing the value in the Engineering Session. I had a very similar problem with a friends car a few weeks ago.
lukkii
Czech Republic
C?ID=337474
I must confrim this issue too! Suddenly missing all RLS channels as non available, on my Passat b8 BCM! Before updating on version 19.6.1., these channels were normaly usuable. Already sent on ross-tech suport as debug. Some bug here??
Carlosfandango
C?ID=349939
Ok, so I’ve been able to change it back to 5 seconds, I had to use the S12345 security access code, I’ve no idea why I didn’t try it previously!? Didn’t cross my mind as I’d used 31347 previously I guess, so there we go, it was simple in the end, thanks for your replies and thoughts guys ��.
