LONG CODE HELPER - Cent. Elect, ABS Brakes, Engine,CAN Gateway,Central Conv.
jdreid
California, USA
C?ID=349997
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWRZ71K99M0XXXXX   Mileage:126384 miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 M    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9203
   Revision: G6H02---    Serial number: VWX7Z0HN2431AD
   Coding: 0000075
   Shop #: WSC 00066 000 00000
   VCID: 38292B354E583907329-806C
000819 - Knock Sensor 2 (G66)
               P0333 - 000 - Signal too High - Intermittent
                    Mileage: 200677 km
                    Time: 19:24:25
                    RPM: 1902 /min
                    Load: 67.8 %
                    Speed: 90.0 km/h
                    Temperature: 87.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.097 V
   Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
   Component: AQ 250 6F           1377
   Revision: 00H76000    Serial number:
   Coding: 0000072
   VCID: 7DA7FA2121FADC2FA1F-8028
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 113B400D492A0000880E02E6921E00413000
   Shop #: WSC 36555 002 104857
   VCID: 7EA5FD2D20FCC737B85-802A
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78A9EB350ED8F907F29-802C
   Part No SW: 3C8 937 049 D    HW: 3C8 937 049 D
   Revision: 00H54000    Serial number: 00000001126957
   Coding: 14058E234004100007140000001400000008730B5C000120000000000000
   Shop #: WSC 00066 123 12345
   VCID: 323D191DA824D3570CD-8066
   Component: Wischer 111108 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0474413
   Coding: 0000100
   VCID: 33331C19573EDA5F07B-8066
                    Fault Frequency: 9
                    Reset counter: 57
                    Mileage: 200012 km
                    Time: 23:05:21
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M07MLDJ
   Coding: 0013889
   VCID: 6C81C7654A8045A7061-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME41145001U
   Subsystem 3 - Serial number: 6342MSME3F645540E
   Subsystem 4 - Serial number: 6351HSME184928504
   Subsystem 5 - Serial number: 6361HSME184970478
   Subsystem 6 - Serial number: 63727SME19085068/
   Subsystem 7 - Serial number: 63827SME19084108Z
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Coding: 0010021
   VCID: 03538CD9471EAADFD7B-8056
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0HN2431AD
   Coding: 0023203
   VCID: 3C2137257A601527D61-8068
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 220908F2000138
   Coding: ED807F070003021002
   Shop #: WSC 11111 123 12345
   VCID: 35372201594AC46F29F-8060
   Component: IMMO            3HL 1222
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000766589028
   Coding: 0001205
   VCID: 6FBBD0697B96BEBF233-803A
                    Fault Status: 01101000
                    Reset counter: 110
                    Mileage: 190135 km
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Reset counter: 150
                    Mileage: 190135 km
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A0D017D80F49B97B4D-807E
                    Reset counter: 116
                    Mileage: 200179 km
                    Time: 12:16:37
                    Voltage: 11.75 V
                        DU
                    Temperature: 46.0°C
                    RPM: 1498 /min
00750 - Warning Lamp
                    Fault Status: 00101101
                    Reset counter: 50
                    Mileage: 200179 km
                    Time: 12:16:44
                    Voltage: 11.63 V
                        DU
                    Temperature: 46.0°C
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 04518FC54210ADE7EE1-8050
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 08100814090904
   Coding: 0001204
   VCID: 70B9D31566A8A1473A9-8024
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: MIB2-S-R-CN   036 0317
   Revision: -----001    Serial number: VWZ6Z2R7301947
   Coding: 1600040004000A
   Shop #: WSC 00081 790 00120
   VCID: 46D555CD38AC5FF7B05-8012
7 Faults Found:
00856 - Radio Antenna
                    Fault Status: 00100111
                    Reset counter: 57
                    Mileage: 191377 km
                    Time: 07:30:31
                    Reset counter: 45
                    Mileage: 15 km
                    Date: 2003.14.26
                    Time: 05:20:26
                    Reset counter: 45
                    Mileage: 14 km
                    Date: 2003.14.26
                    Time: 08:20:45
00877 - Treble Speaker Rear Right (R16)
                    Fault Status: 00101011
                    Reset counter: 35
                    Mileage: 2 km
                    Date: 2000.14.00
                    Time: 02:16:09
                    Reset counter: 35
                    Mileage: 2 km
                    Date: 2000.14.00
                    Time: 02:16:09
00875 - Treble Speaker Front Right (R22)
                    Reset counter: 35
                    Mileage: 2 km
                    Date: 2000.14.00
                    Time: 02:16:09
                    Reset counter: 35
                    Mileage: 2 km
                    Date: 2000.14.00
                    Time: 02:16:09
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003626568
   Coding: 0001168
   VCID: 76B5E50D04CC8F77E05-8022
   Coding: 0100101
                    Fault Status: 00110100
                    Reset counter: 150
                    Mileage: 200953 km
                    Time: 15:11:53
01487 - System Function Test
                    Fault Status: 01110101
                    Mileage: 200953 km
                    Time: 15:12:21
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003588487
   Coding: 0001168
   VCID: 77ABE80903C6F67FFB3-8022
End----------(Elapsed Time: 01:45, VBatt start/end: 12.4V/12.4V)-----------
Hello All,
By any chance does anyone know the long code for the following modules (2009 VW JETTA SE/SEL PZEV):
Cent. Elect [09]
ABS Brakes [03]
Engine [01]
CAN Gateway [19]
Central Conv. [46]
I forgot to save my default codes before adjusting various modules.
NostraJackAss
[h=2]LONG CODE HELPER - Cent. Elect, ABS Brakes, Engine,CAN Gateway,Central Conv.[/h]
Hello All,
Cent. Elect [09]
ABS Brakes [03]
Engine [01]
CAN Gateway [19]
Central Conv. [46]
JPPSG NO SOUP!
Go search scans of the net and compare attributes, additionally, without VIN number & in some cases, codes can't be generated unless in EOLE 83 mode to find the short string as displayed of existing attributes as set.
God loves backups........ :rolleyes:
SVM
Sounds like you should be in tweaks or retrofits huh?
You are FOD & INDUCED FOD!
"Give before it hurts!"
jdreid
California, USA
C?ID=349997
JPPSG NO SOUP!
SVM
So you need the full VIN Number to get this information?
