Seat Arosa 1.0 2004
louise1972
C?ID=330585
Hi, my daughters car came up with engine management light today, she said the car seems to be running ok, no loss of power, no different sounds or anything else, she cant say if it is using more fuel (she is constantly out in the car) The codes seem to all be related to sensors, is it worth trying to replace maf etc or can anyone suggest any troubleshooting that i can do to rule out any other causes? only used code reader for basic checks before now. Hopefully posted correct info below. Thanks Louise
Monday,19,August,2019,18:35:53:12359
VIN: VSSZZZ6HZ4R016356   License Plate:
Chassis Type: 6H (6H - Seat Arosa (1997 > 2004))
Scan: 01 02 03 08 15 17 19 25 35 56
VIN: VSSZZZ6HZ4R016356   Mileage: 167660km-104179miles
   Part No: 030 906 032 DJ
   Component: ME7.5.10            4693
   Coding: 00001
   Shop #: WSC 06441
   VCID: 55F77C9E9C1252DFC9F-51CE
   VSSZZZ6HZ4R016356     VWZ1Z0D2673740
17573 - Long Term Fuel Trim Additive Air; Bank 1; Range 1
            P1165 - 35-00 - System too Rich
17560 - Long Term Fuel Trim Additive Air; Bank 1; Range 2
            P1152 - 35-10 - System too Lean - Intermittent
   Part No: 1C0 909 601
   Component: 06 AIRBAG VW51      0008
   Coding: 12342
   Shop #: WSC 06441
   VCID: 5DE764BEE4228A9F81F-4B5C
            32-10 - Resistance Too High - Intermittent
Address 17: Instruments        Labels: 6X0-920-xxx-17.lbl
   Part No: 6H0 920 900
   Component: KOMBIINSTRUMENT RB8 V02
   Coding: 00441
   Shop #: WSC 01005
   VCID: 629D5742DD5CB567BCD-5184
Address 25: Immobilizer        Labels: 6X0-953-257.lbl
   Part No: 6X0 953 257
   Component: IMMO                0008
   Coding: 00001
   VCID: 7DA7043E44E26A9FA1F-4B1E
Address 35: Centr. Locks        Labels: 1C0-962-258-III.lbl
   Part No: 1C0 962 258 AB
   Component: 2S Zentr.Verriegel. 0004
   Coding: 00017
   Shop #: WSC 06441
   VCID: 678B4656367ED04F6B3-4B3C
End----(Elapsed Time: 02:00, VBatt start/end: 12.1V/13.7V. VIgn 0.0V)------
What do you have in MVB 032?
louise1972
C?ID=330585
-3.4 first block then 16.4, although I will do this again after work today now I understand a little more.
louise1972
C?ID=330585
Certainly gives me enough to look at...I will check 032 and 032 again when I get home later..many thank for your response.
louise1972
C?ID=330585
so i checked the readings again : 032 -4.0% 15.6% & 033 -1.6% 1.560v do these readings point in any one direction?
louise1972
C?ID=330585
Will check as much as I can at the weekend...i have managed to get engine diagrams - sensor placements etc so will go through your suggestions..thanks again.
