Steering inoperative - Red steering wheel
Colleen DeMenna
C?ID=373470
Greetings
I have a 2007 Rabbit (golf) with a power steering rack issue. The dash shows the “Red steering wheel” indicator. Actually turning of the steering is next to impossible. My initial VCDS scan is enclosed below.
I replaced the rack with a junkyard part, however now the dash light is a “Yellow steering wheel” indicator.
Scan results from OEM Part and Junkyard part below. It appears they are not similar HW and SW versions… I am wondering if I might be able to replace the electronic components off the OEM rack onto the junkyard rack. Is it possible that doing so would allow for normal operation? I am grateful to the forum users to help me resolve this issue.
https://i.imgur.com/jJEsc2m.jpg
https://i.imgur.com/SVtu2NZ.jpg
--OEM Part--
      Part No: 1K1 909 144 L
      Component: EPS_ZFLS Kl.069 H07 1806
      Shop #: WSC 00000 028 00001
      VCID: 34311CC4123A43D71E1-8060
   00003 - Control Module
               007 - Short to Ground - MIL ON
--Junkyard part--
      Part No: 1K1 909 144 M
      Component: EPS_ZFLS Kl.074 H08 1901
      VCID: 353721C019405ADF29F-8060
   02546 - Steering Limit Stop
                    Mileage: 208640 km
                    Temperature: 32.0°C
                    Voltage: 11.90 V
                    Voltage: 11.70 V
Initial full scan
Wednesday,07,August,2019,15:46:42:04807
VIN: WVWAS71K27W238334   License Plate:
Chassis Type: 1K (1K0)
VIN: WVWAS71K27W238334   Mileage: 208640km-129642miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 R    HW: 07K 906 032 Q
   Component: 2.5l R5/4V      G   9651
   Revision: --H01---    Serial number: VWZ7Z0G7062252
   Coding: 0000001
   Shop #: WSC 01279 785 00200
   VCID: 382928F40E52A7B7329-806C
   Part No: 1K0 907 379 P
   Coding: 0017025
   VCID: 3FDB43E82B7C908FF33-806A
   Part No SW: 1K0 820 047 GF    HW: 1K0 820 047 GF
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   VCID: 6E85CEAC3C962907285-803A
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006871937
   Coding: 108D0F214004150047140000001400000008730B5C0001
   Shop #: WSC 08112 444 54565
   VCID: 6B83C7B80F84DC2F0FB-803E
   Component: Wischer 160307 020  0501
   Coding: 00038805
   Shop #: WSC 08112
   Component: 5L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D08AGAY
   Coding: 0013644
   Shop #: WSC 01269 785 00200
   VCID: 6C81C4A40A8ADB17061-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME1720211C/
   Subsystem 3 - Serial number: 6342MSME17326D004
   Subsystem 4 - Serial number: 6352QSME21304C5FJ
   Subsystem 5 - Serial number: 6362QSME236C2063C
   Subsystem 6 - Serial number: 63727SME0C451430W
   Subsystem 7 - Serial number: 63827SME0C450F4DE
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 636 0070
   Coding: 0000022
   VCID: 76B5E6CC44C611C7E05-8022
   Part No SW: 1K0 920 953 P    HW: 1K0 920 953 P
   Revision: V0003000    Serial number: VWZ7Z0G7062252
   Coding: 0007207
   Shop #: WSC 08207 444 53375
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 180307F1001883
   Coding: 3D0F034007000000
   VCID: 2F3B13A8FB1C600F633-807A
                    Reset counter: 254
                    Mileage: 82090 km
                    Time: 04:27:11
   Component: IMMO            VDD 1610
   Shop #: WSC 06401 444 53999
01176 - Key
   Component: Tuer-SG         005 0983
   Coding: 0001077
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K0 959 433 CM
   Coding: 93C803281B09058F880A048050CC
   Shop #: WSC 00000 785 00200
   VCID: 7DA7F9E061F0429FA1F-8028
   Coding: 0001076
   VCID: 392F2DF03558BEBFCD7-806C
00936 - Electric Window Switch in Front Passenger Door (E107).
Address 56: Radio
End----(Elapsed Time: 00:52, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Since the original problem was electrical in nature, why would you want to swap electrical components now?
Is 1K1-909-144-M a suitable replacement for 1K1-909-144-L?
We need a FOD check in this aisle, please.
Gone But Not Forgotten
Indeed checking.........
Vehicle Identification No.WVWAS71K27W238334
ModelRabbit 2.5
GO
Date of production02.04.2007
Model year2007
Sales type1K15R1
Engine CodeBGQ
Transmission CodeJCT
Better check the harness & fuses, no?
I show M & AJ reused for of from legacy..............
PART NUMBERDESCRIPTIONREMARKMODEL
1K1 423 055 M or MXsteering gearGeneration 3
lhd
1K1 971 111 AJ
3
GO
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PCWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0HAVehicle class differentiation -1K0-
tail pipe0P1Rear side exhaust tailpipe
drive-off assistanceUG0Without hill start assist/hill descent control/comfort driving assist
Emission standard0GTEmission standard SULEV
Trailer hitch1D0without trailer towing
airbag4UMDriver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
Aktivkohlebehälter / Ottopartikelfilter1E7Activated carbon canister (ORVR), for intensified evaporation system, siphoning device for fueling
Aerials8ZMAntenna
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WLJack for external audio source
Equipment levelsA8XUS comfort equipment
Brake type in rear1KEDisc brakes in rear
batteriesJ1LBattery 280 A (60 Ah)
Brake type, front1ZPDisc brakes in front (Geomet D)
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0DAssembly kit, USA corresponding vehicle version (not California), various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ACAnti-lock brake system (ABS)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
brake wear indicator9U1brake wear indicator
Heated washer nozzles9T0Without heated washer nozzles
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
Chrome packageQJ0Without aluminum/chrome work package
General operating permit, alterationsC18Operating permit, alteration
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FAroof without cut out
Suspension system in rear1JARear shock absorption, basic design 1
Suspension system in frontG07Shock absorption in front
Load-through hatch/ski bag3X0without load through system
Insert for the filling up of unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for components0EJInstallation differentiation for transmission MQ 250 -- vehicle components --
Theft protection system7AGElectronic immobilizer with anti-theft alarm system (for USA)
Inserts5MJDecorative inserts
Scuff plates7M5Without impact protection film for door sill
Park distance control7X0Without park distance control
Electric interface for external useUF0Without electric interface
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Without extended pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation8K4Separate daytime running lights NAR
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category rear axle0YCWeight range 3 installation control only, no requirement forecast
Weight category front axleL07Suspension range 07 installation control only, no requirement forecast
Base engineT8K5-cylinder SI engine 2.5 l unit 07K.1
Luggage netting/pocket on backrest(s)4U0Without luggage nets/pockets on backrests
Luggage compartment cover3U1Folding trunk cover
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC0without Garage door opener
Luggage compartment trim5A7Comfort luggage compartment trim with service lid/snap-on cover
Transmission specificationsG0C5-speed manual transmission
Brackets3P0Without bracket for first aid kit and warning triangle
handle for hand brake lever6PAHand brake lever handle in plastic
Rear spoiler5J0Without rear spoiler
Rear window wiper and washer system8M1Rear window wiper washer system with intermittent wipe
Rear seats3NZRear bench seat, not split, split backrest, folding
Heating and air-conditioning system9APClimatic air-conditioning system (semi-automatic)
Headlamps8ESTwin headlamps for driving on the right, with integrated high beam (US design)
Customized installationFC0Without individual installation
Interior light in footwell6T0Without interior light in footwell
Instrument clustersU5CInstrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8GHatchback
Cassette and CD storage unit4W0without cassette / CD tray
coolbox1W2Glove compartment cooling system
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climatic zones0Y2Tropical zones
Compass/road sign displayQR0Without compass
headrest for seat, rear3T2Three rear head restraints
Head restraints5ZFFront head restraints
Fuel tank treatment2LFFuel tank with special material treatment (coextrusion) with changed protective layer
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Fuel systems1A1Fuel system for fuel-injected SI engine, injection system without fuel return
Body measures5C1Body measures for increased safety requirements
Child seat anchors in front3G0Without child seat anchora in front (ISOFIX)
Rear license plate bracket6P2License plate bracket, rear (NAR)
Front license plate bracket6W3License plate bracket front (small, NAR)
Paint preservative/transit coating5K0Without surface protection, with additional transit coating
Paint coatingFB0standard paint coating
Rear cargo area3GAWithout luggage compartment floor
Steering system arrangementL0LLeft-hand drive
Reading lamp8S4Two reading lights front, two rear
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H9Backrest release for front seats with Easy Entry feature
Air duct, front areaVK1Air duct, type 1
Load edge protection2P1Plastic loading edge protection
Lumbar support7P0Without lumbar support in seat backrests
steering wheels1MESteering wheel
Speaker installation8RW10 speakers (passive)
Headlight range control8Q0without beam length regulator
Center armrest6E0Without center armrest in front
Multi-function display/trip computer9Q0Without multi-function display/ trip computer
Engine cooling8Z6Hot country
Engine specificationsD4F5-cylinder SI engine 2.5 l/110 kW (20V) (R-5) base engine is T8K/TQ7
Left vanity mirror4SHLeft vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
Right vanity mirror4THVanity mirror, right, illuminated, with cover and special mirror imprint (NAR), extractable
Navigation device7Q0without navigation system
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WAWithout fog lights
Rear of platform module base4P0Rear floor panel module, type 1
Platform group class7PAPlatform group class 1
Hubcaps1NLTrims for alloy wheels
WheelsCM6Alloy wheels 6.5J x 16
Radios8UFRadio with CD drive (double DIN)
Smoker's/non-smoker's package9JANon smoker version
Tire pressure monitoring system7K0Without tyre pressure monitor
tireH4BAll-season tires 205/55 R16 H (NAR)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G2Spare wheel with full tyre, steel
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
P2SGolf 16-inch alloy wheel package
PMCEmissions concept for California
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q1Gearshift knob/handle in plastic
Special labels/plates0SSLabels in English and French
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Front seat, left3TBStandard seat in front, left
Front seat, right3SBStandard seat in front, right
Nameplates for sales nameQD0Without lettering for sales name
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US label
Center rear seat belts3C83-point seat belt, center rear with US label
seat coversN4CSeat trim covers in fabric
Seat adjustment3L1Manual height adjustment for left front seat
seat heater4A0without seat heater
Safety head restraint system3K0w/o safety head restraint system
Side lights7R4Side marker lamps and turn signal repeaters (turn signals with white lens)
Horns8Y1Two-tone horn
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B1Protective side molding
Sunroof roller blind for rear/side windows3Y0without roller blind
Supertone system and tone sequence control9J0Without supertone system and tone sequence control
power outlet7B212 volt socket in luggage compartment
Bumper2JBStandard bumpers
Rear stabilizer0BDRear stabilizer
Front stabilizer bar0ADFront stabilizer bar
Drawers under front seatsQN0Without drawers under front seats
Heavy-duty/sports version2UAStandard design
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Nameplate set0NVNameplate set "2.5"
Special alarm systems9A0Without taxi alarm system
Door storage compartments in front3YRDoor pockets with insert mats
Mass damper for steering wheels1Q0steering wheel without balance weight
Door and lid locking system4K0Central locking w/ radio remote control and interior controls
Type approval countries/countries with special requirementsB38Legal requirements California
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Door and side trim panels4AFDoor and side trim panel in foam film and woven fabric
doors0A12 doors
TV reception/digital radio receptionQV0without TV/digital radio reception
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EBwithout identification plate
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W0Without car phone preparation/ installation
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG0without service interval extension
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TAwithout floor mats
Additional body panels, side6EAWithout additional side body covers (stone guard)
Additional child seat anchors3B7Child seat anchors as per Canadian requirements a. ISOFIX child seat system
Auxiliary heating system9M0Without auxiliary heater/parking heater
siLc
Tallinn, Estonia
C?ID=330192
If the new rack is already in, why not carry out the well-known basic setting for it? It's likely the rack would work then. Ideally, also upload the correct characteristic curve to the rack beforehand.
Colleen DeMenna
C?ID=373470
Thank you for replies and general wisdom.
Does FOD mean foreign object damage?
I replaced the harness when swapping out the rack. The fuses test good.
What is the right direction. Do I find a re-builder who can repair my rack? Can the junkyard rack be flashed to work correctly?
I was not completely certain that there is an electrical issue. the steering is surely bound up.
Colleen DeMenna
C?ID=373470
Silc can you further explain the process.
Different hardware & power class no?
Installing the correct part is always advised no? ............. FOD
Colleen DeMenna
C?ID=373470
Just wanted to conclude this thread, that the junk yard rack, once installed, once the Steering Angle Sensor was reset, the dash lamp went out and performs properly.
The only note I would add is the the Steering Angle Sensor reset has to be done on the ground. Whereas it would not calibrate up on the lift...
Thank you all for sharing your wisdom and time.
