Caddy 2K 2018 engine coding calculate
AurimasFr
Lithuania
C?ID=360401
some one know, ho to calculate engine coding in caddy 2018 year? Ho to calculate abs i found, but information about engine no.
I need recode from RHD to LHD.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Start posting an Auto-Scan from the vehicle in question.
AurimasFr
Lithuania
C?ID=360401
Monday,19,August,2019,17:13:25:06635
VIN: WV2ZZZ2KZJX088724   License Plate: CADDY
Mileage: 950km-590mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 18 19 25 42 44 46 4C 52 61
VIN: WV2ZZZ2KZJX088724   Mileage: 950km-590miles
Address 01: Engine (J623-DFSD)       Labels: None
   Part No SW: 04L 906 016 MJ    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 4092
   Revision: 8AH20---
   Coding: 011D0012042415090000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TDI01104L906016MJ 001001
   ROD: EV_ECM20TDI01104L906016GR_004.rod
   VCID: 7DA7FB2CED70F05FA1F-8028
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [039] - -
                    Mileage: 959 km
                    Engine speed: 0.00 /min
                    Coolant temperature: 34 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 14.220 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Drivetrain coordinator: brake function status-Bits 0-7: 32
                    Acceleration: 0.000 m/s²
   Part No SW: 02E 300 066 M    HW: 02E 927 770 AT
   Component: GSG DSG AG6     541 5201
   Revision: 06454104    Serial number: 00001712090499
   Shop #: WSC 35110 377 00147
   VCID: 2313ED5427D466AFF7B-8076
   Revision: 00000000    Serial number: 60048000001086
   Coding: 1079409B936AA486087C0278C986259378F100
   VCID: 3FDB4124A7FC224FF33-806A
8252 - Databus
          U1122 00 [137] - Implausible Message
          [ACAN: SY1_Lenker signal coding missmatch]
                    Reset counter: 204
                    Mileage: 959 km
                    Date: 2019.08.19
                    Time: 02:07:43
   Part No SW: 1K8 907 044 AE    HW: 1K8 907 044 AE
   Component: Climatronic   H05 0304
   Revision: 00001K03
   Coding: 001000C003
   ROD: EV_ClimaAutoBasis_VW32.rod
   VCID: 72BDD810A42EBF27CCD-8026
7 Faults Found:
9471765 - Temperature Sensor for Left Vent
          B1087 15 [009] - Open or Short to Plus
                    Reset counter: 204
                    Mileage: 959 km
                    Date: 2019.08.19
                    Time: 02:07:34
9472021 - Temperature Sensor for Right Vent
          B1088 15 [009] - Open or Short to Plus
                    Reset counter: 204
                    Mileage: 959 km
                    Date: 2019.08.19
                    Time: 02:07:34
9481748 - High Pressure Sensor
          B10AE 14 [009] - Open or Short to Ground
                    Reset counter: 204
                    Mileage: 959 km
                    Date: 2019.08.19
                    Time: 02:07:34
9480469 - Control Circuit for A/C Compressor
          B10A9 15 [009] - Open or Short to Plus
                    Reset counter: 204
                    Mileage: 959 km
                    Date: 2019.08.19
                    Time: 02:07:36
9496597 - Sunlight Photo Sensor
          B10E8 15 [009] - Open or Short to Plus
                    Reset counter: 204
                    Mileage: 959 km
                    Date: 2019.08.19
                    Time: 02:07:34
9496613 - Sunlight Photo Sensor
                    Reset counter: 204
                    Mileage: 959 km
                    Date: 2019.08.19
                    Time: 02:07:34
9478421 - Diagnostic Line for Front Air Blower
          B10A1 15 [008] - Open or Short to Plus
                    Reset counter: 244
                    Mileage: 959 km
                    Date: 2019.08.19
                    Time: 02:07:38
   Part No SW: 5K0 937 086 AA    HW: 5K0 937 086 AA
   Component: BCM PQ35 M+   122 0186
   Revision: BD122001
   Coding: 491A0A3E8825E12D00080083940009CC03D5000842CD8320E48487040041
   VCID: 73B3DD14DBB4B62FC7B-8026
   Subsystem 1 - Part No: 7N0 951 172
   Subsystem 2 - Part No: 1K0 951 605 F
   Part No SW: 1K8 919 465 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0480
   Revision: --------    Serial number: 39261805103033
   Coding: 0000050011
   ASAM Dataset: EV_EPHVA14VW364GP00 001007
   ROD: EV_EPHVA14VW364GP00_VW36.rod
   VCID: 372B29048FCC1A0F3B3-8062
   Part No SW: 7N0 907 572 C    HW: 7N0 907 572
   Serial number: 3012170438A191
   Coding: 00009000FE0339
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 3635240088C6E307205-8062
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 204
                    Mileage: 958 km
                    Date: 2019.08.19
                    Time: 13:43:28
                    Control Module temperature: 37 °C
                    Voltage terminal 15: 13.3 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 204
                    Mileage: 958 km
                    Date: 2019.08.19
                    Time: 13:43:28
1037 - Databus
          [FAULT_CIS_QDCACC_FAIL]
                    Reset counter: 204
                    Mileage: 958 km
                    Date: 2019.08.19
                    Time: 13:43:28
   Part No SW: 2K5 959 655 C    HW: 2K5 959 655 C
   Component: VW10Airbag00K H08 0018
   Revision: --------    Serial number: 003V2004E86P
   Coding: 00000000000000000000000000000000304B
   Shop #: WSC 35110 790 50316
   VCID: 3C213628B6EA3957D61-8068
   Serial number: 3497ARB400A59AHCKJ8D
   Serial number: 3507ARB400259AHDABAP
   Serial number: 3517ARB4059535RI9PKM
   Serial number: 3527ARB405J535RIQ9IW
   Part No SW: 5K0 953 521 FG    HW: 5K0 953 569 BC
   Revision: FF010042    Serial number: 20180104300417
   Coding: 1882460008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 76B5E400C846A307E05-8022
   Subsystem 1 - Part No SW: 2K0 959 442     HW: 2K0 959 442   Labels: 3C8-959-537.CLB
   Serial number: 0021820173200980BA1B
   Coding: 280000
   Part No SW: 2K5 920 866 C    HW: 2K5 920 866 C
   Component: KOMBI         H04 1107
   Coding: 1102011200
   VCID: 34311E089EBAF1171E1-8060
13654544 - Databus
          [Steuergerät für Telefon keine Kommunikation]
                    Reset counter: 204
                    Mileage: 958 km
                    Date: 2019.08.19
                    Time: 13:43:28
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 E
   Component: Standheizer     044 4941
   Revision: 00044000    Serial number: 09028239000000
   Coding: 0031032
   Shop #: WSC 35110 377 00182
   VCID: 372B2904834C1A0F3B3-8062
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 030118F1001674
   Coding: 357421
   VCID: 7BA3F534F3E4FE6F9FB-802E
   Component: IMMO          H04 1107
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC0708CFE77E774D-803E
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2144
   Coding: 0133168
   Shop #: WSC 11111 111 45799
   VCID: 71BFD71CADA8843F357-8024
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   Shop #: WSC 00046 000 00000
   VCID: 392F2F3CB5580C7FCD7-806C
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0132144
   VCID: 72BDD810A8AEBF27CCD-8026
   Component: Batt.regelung H56 1682
   Coding: 030F7873
   VCID: 71BFD71CA1A8843F357-8024
   Subsystem 1 - Part No SW: 2K0 915 181     HW: 2K0 915 181
   Serial number: 75885800001801080C6D
End----------(Elapsed Time: 01:07, VBatt start/end: 14.3V/14.3V)-----------
NZDubNurd
New Zealand
C?ID=230482
I would get the 03 ABS operating correctly, before bothering with the engine coding.
dnoermann
C?ID=358118
Your ABS Coding is right for LHD.
Normly you need to change in Engine Coding Byte 6 Bit 0 from 1 to 0. for change RHD to LHD
Byte 6 ==> 0x24 but in your Scan this is already the case
No clue
Sebastian
Magdeburg, Germany
HN0-nnnnnn
The coding table should display properly with the next VCDS data version/update, however as written by others, you should address the issues in #03 first. That said, feel free to enlighten us what exactly happened to this car in the first place. That may help you getting some directions as to an actual fix...
Spacewalker
Poland
C?ID=159607
code ABS at first might reject it as VIN is RHD , and steering rack too
Anyway - in GW you also have RHD coding ,
AurimasFr
Lithuania
C?ID=360401
Hi
thank you for help. I have miss code gateway. Faults from 01 and 03 gone. 01 is 04L not 03L, vcds dont have soufflers for this engine. How to know or byte 6 bit 0 is for rhd coding? Becouse, before GW coding, I code 01 byte 5 bit 5 and fault disapear from 01. Maybe here is rhd coding. When I recode GW, I recode 01 back and dont have faults. But still, i need recode 01 from rhd to lhd. Question is or byte 6 bit 0 is for rhd coding or byte 5 bit 5.
Thanks for your time
