Measuring Blocks at Polo AW 2018 (Brazil)
Pedro Mamprim
Brazil
C?ID=374818
I have a Polo AW 2018 (Brazil) and I'm entering the Engine part and the Measuring Blocks option is disabled for me.
What can I do to get inside this session?
Thank you.
 Sunday,18,August,2019,12:05:35:00092
VIN: 9BWAL5BZ1JP065524   License Plate:
Mileage: 13154km-8173mi   Repair Order:
Chassis Type: BZ-VW27 (2QW)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: 9BWAL5BZ1JP065524   Mileage: 13154km-8173miles
Address 01: Engine (0001-CNXC)       Labels: None
   Part No SW: 04E 906 032 AS    HW: 04E 907 425 F
   Component: R4 1.6l MPIH04 5245
   Revision: --H04---
   Coding: 01110016020400000000
   Shop #: WSC 01530 935 00200
   ASAM Dataset: EV_ECM16MPI02104E906032AS 002002
   ROD: EV_ECM16MPI02104E906032AS_002.rod
   VCID: 71BFD582F1291F4F357-8024
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 2Q0 614 517 S    HW: 2Q0 614 517 L
   Component: ESC_base      H13 0222
   Serial number: 86400234180113
   Coding: 31044B6717478CB2D201E81814DE126A49444926224A242444542254452848569222926444522424222A442AA22924400494240220
   ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
   ROD: EV_Brake1BOSCHESPMQBA0.rod
   VCID: 3E253EBEF0F7B037F85-806A
   Part No SW: 6EA 820 045     HW: 6EA 820 045
   Component: SG_AC_Manuell H50 0301
   Coding: 012000000800000010000000000000000000000000000000000000000000
   ASAM Dataset: EV_ACManuePrehMQBA0 001011
   ROD: EV_ACManuePrehMQBA0_VW27.rod
   VCID: 6FBBD3FAE71D09BF233-803A
   Part No SW: 2QW 937 089     HW: 2QW 937 089
   Component: BCM A0 Entry  H65 0612
   Serial number: 70117321034801
   ASAM Dataset: EV_BCMA0 104001
   ROD: EV_BCMA0_104.rod
   VCID: 1E65DE3E5037D037D85-804A
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 2Q1 959 881     HW: 2Q1 959 881
   Component: FHSG_DRV  001 0001
   Serial number: 00000000000018908601
   Coding: 130000
   Subsystem 2 - Part No SW: 2Q1 959 882     HW: 2Q1 959 882
   Component: FHSG_PSG  001 0001
   Serial number: 00000000000019263829
   Coding: 090000
   Serial number: 000000000ZY1733326BA
   Subsystem 4 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000018610958
   Coding: 030000
   Subsystem 5 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000018592473
   Coding: 1B0000
   Part No SW: 2QB 959 655     HW: 2QB 959 655
   Component: VW22Airbag    010 0246
   Revision: --------
   Coding: 88C0C00000000000540000CF000000000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 0C41A476F6CB52A7A61-8058
   Subsystem 1 - Part No SW: -----------    HW: 442 1A1 912 17
   Component: SideSensor_Df  2C4 0148
   Serial number: 349B4D19B28A7CC5A349
   Subsystem 2 - Part No SW: -----------    HW: 442 1A1 912 17
   Component: SideSensor_Pf  2C4 0148
   Serial number: 350B4D1AD28A7CC64192
   Subsystem 3 - Part No SW: -----------    HW: 442 131 708 17
   Component: FrontSensor_D  290 118A
   Serial number: 355AG119926DCC3254C1
   Part No SW: 6EA 920 740 A    HW: 6EA 920 740 A
   Component: KOMBI         309 0460
   Coding: 442D02002000000C020830001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001020
   ROD: EV_DashBoardVDDMQBA0_VW27.rod
   VCID: 33331F8ACBB56D5F07B-8066
   Part No SW: 2QW 909 901     HW: 2QW 937 089
   Component: GW MQB A0     H65 0612
   Coding: 0101000020086400F8000008080F00000000000000000000000000000000
   ASAM Dataset: EV_GatewA0 013020
   ROD: EV_GatewA0_VW27.rod
   VCID: 1675C61EB8079877005-8042
   Subsystem 2 - Part No SW: 18D 959 442     HW: 18D 959 442
   Component: E221__MFL-YLG  H01 0120
   Serial number: 000000000A0133111017
   Coding: 200000
Address 44: Steering Assist (J792)       Labels:* None
   Part No SW: 2Q1 909 144 J    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 610 6030
   Serial number: 01HBL0F9DC15GR0
   Coding: 00000001000000000101020101000101000001
   ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
   ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
   VCID: 392F2DA2E9D9970FCD7-806C
   Part No SW: 5G0 035 280 C    HW: 5G0 035 280 C
   Component: MU-G--RW      557 5516
   Serial number: VWZ7Z2U3601014
   Coding: 02721000AA00000000220001010000002F0006140000010003
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_MUGlb4CGen25TPWR 001001
   ROD: EV_MUGlb4CGen25TPWR_VW27.rod
   VCID: 211FE5C26149EFCFE57-8074
End----------(Elapsed Time: 00:37, VBatt start/end: 12.5V/12.3V)-----------
South Molton, UK
Short version: ECU uses UDS protocol, which does not support the old "Measuring Blocks" function. Use Advanced Measuring Values instead.
This question seems to be asked quite often, would it be possible for VCDS to leave the Measuring Blocks button enabled but if clicked with a UDS controller show a message box telling the user that as it's a UDS controller they need to use Advanced Measuring Values instead?
That would save having to keep answering the question on the forum ;)
