LED Headlight Issues
bip78
C?ID=367717
This morning I installed a new/replacement OEM Audi LED full headlight for my C7 RS6.
From what I can see, everything works fine, all the light functions are active as they need to be - HOWEVER I am getting error message come up on my display. I have used VCDS to clear the DTCs and they pop up again afterwards.
Would anyone be able to advise on these errors and if VCDS can rectify?
393989 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Reset counter: 66
Mileage: 94447 km
Date: 2019.08.17
Time: 17:38:58
bip78
C?ID=367717
The fan error is resolved, so no need to worry about that. The previous is the only error.
Saturday,17,August,2019,17:47:57:06608
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 22 28 30 34 36 3B 42 44
          46 47 52 53 55 56 5F 62 65 69 6D 72 BA
VIN: X   Mileage: 94447km-58686miles
Address 01: Engine (------CRDB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 560     HW: 4H0 906 014
   Component: 4.0l V8TFSI / H62 0012
   Revision: NCH62---
   Coding: 122A00326536030A0800
   Shop #: WSC 33788 001 1048576
   ASAM Dataset: EV_ECM40TFS0114G0906560 001013
   ROD: EV_ECM40TFS0114G0906560.rod
   VCID: 6597B0E185E05B2F59F-8030
Readiness: 1110 1101
   Part No SW: 4G0 927 158 BD    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIRdW H16 1006
   Revision: --H16---
   VCID: 71BFD4B14128878F357-8024
   Part No SW: 4G0 907 379 P    HW: 4G0 907 379 P
   Component: ESP PREMIUM   H09 0100
   Coding: 62B7DB0146EDDB80EB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004036
   VCID: 3E253F8D40F628F7F85-806A
   Part No SW: 4H0 907 064 EN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0521
   Coding: 01B93046000000000000
   VCID: 79AFEC9119D8CFCF8D7-802C
   Serial number: 0214000018443002
   Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
   Component: KLIMA 4 ZONEN H14 0093
   Serial number: 03031400040247
   Coding: 682200B809
   ASAM Dataset: EV_AirCondiComfoUDS 004003
   ROD: EV_AirCondiComfoUDS_004.rod
   VCID: 6A8DC3DD6CFE745774D-803E
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001524549
   Coding: 090F2011097C9FE02F8100C7A0001800CF9DE70A2F080201800108546F00
   VCID: 6FBBD2C9579C917F233-803A
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 140214  H37 0080
   Serial number:         140222014234
   Coding: 0045F7
   Serial number: 22323029
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
   Component: E1 - LDS  H07 0044
   Serial number: 20 02 2014  00001245
   Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000025021400010395
   Coding: 110000
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000017021400010091
   Coding: 110000
   Subsystem 6 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA107528000006093776
   Coding: 020300
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: D6688617000000000001
03528 - Fan for Left Headlight
                    Fault Status: 01101100
                    Reset counter: 66
                    Mileage: 94447 km
                    Date: 2019.08.17
                    Time: 17:42:00
   Part No SW: 4H0 919 475 AC    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0091
   Revision: 11001001    Serial number: 61031405300682
   Coding: 89C30F
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 73B3DEB93B34B59FC7B-8026
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00H1L1Z
   Coding: 3032343631334E303537554A305234473053
   VCID: 363527AD68C6E0B7205-8062
   Serial number: 3575HRB404V2DE2S4PNA
   Serial number: 3585HRB405L2DJEQ88H+
   Serial number: 3515JRB400I50TIS79DU
   Serial number: 3525JRB400G50U80NP2D
   Serial number: 3554VRB400M50T8GM0O1
   Serial number: 3564VRB400M50T8GLOMN
   Revision: --------    Serial number: 90372NBR000AW
   Coding: 000035
   VCID: 372B2AA96F4C19BF3B3-8062
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 06 02 2014  D0399850
   Part No SW: 4G0 920 981 Q    HW: 4G0 920 981 Q
   Component: TBenGb    Nv  H58 0621
   Revision: 29460235    Serial number: 658010314596009
   Coding: 33AF110B9B412600010400
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 392F2C9159D80FCFCD7-806C
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001297166
   Coding: 00ED074800
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72BDDBBD442EBC97CCD-8026
   Serial number: 5240922603
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 131215000000000000BE
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 04028264747464545425363E00
   VCID: 7CA1F58516EAFAE7961-8028
   Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H16 0200
   Serial number: 002102140001899
   VCID: 2809F9D5B2728647A29-807C
   Part No SW: 4G0 919 158 N    HW: 4G0 919 158 N
   Component: KLIMA FOND    H08 0093
   Serial number: 05031400040322
   Coding: 22
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   VCID: 3A2D339D5CDE04D7C4D-806E
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000055306
   Coding: 01010101000000000001000102
   VCID: 6491ADE58E5A22274E1-8030
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008001
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E050FCD9096D877685-807A
   Revision: AA000000    Serial number: 00000092653407
   Coding: 0078130000006001000001010101102030303232203232
   VCID: 77ABEAA92FCCD9BFFB3-8022
   Component: SARA 6D red   H03 0056
   Revision: --------    Serial number: EJ1BPA7E00WKXE
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 372B2AA96FCC19BF3B3-8062
   Component: TSG FA        H03 0507
   Coding: 011F16005E21620002080002
   VCID: 47CB5A691FAC693F4B3-8012
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0023336351
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1BBD84AEFC970CD-8066
   Revision: 00002001    Serial number: 0329024856
   Coding: 013B0620A0B9389483300984200113470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J245 PS20.008  H02 0007
   Serial number:     WOO2696686H
   Coding: 901E00
   Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
   Serial number: 0000000AP00006355335
   Subsystem 5 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J394 PS20.008  H02 0007
   Serial number:     WOO26932589
   Coding: 801E00
   Revision: CJ007001    Serial number: 00000000078625
   Coding: 030000
   VCID: 1D67D801EDB053EFC1F-8048
   Component: TSG BF        H03 0507
   VCID: 46D5576D18A67037B05-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H03 0015
   Revision: --------    Serial number: 00000000984999
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D0708C19D90A36F51F-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140307-0002-120
   Coding: 11226F601000A300
   ROD: EV_HeadlRegulBasic.rod
393989 - Headlight
                    Reset counter: 66
                    Mileage: 94447 km
                    Date: 2019.08.17
                    Time: 17:42:26
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109BW0E7872402
   Coding: 010103010000000001
   VCID: 2809F9D5B2F28647A29-807C
   Part No SW: 4G0 035 666 J    HW: 4G0 035 666 H
   Component: H-BN-EU       H52 0798
   Revision: --------    Serial number: 189C/0E7575230
   Coding: 070101010303F1FD4780AF3E00000003E00001020000000000
   VCID: 2F3B12C9971CD17F633-807A
   Subsystem 1 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD003XRSX
   Subsystem 3 - Part No SW: 4G2 919 612 Q    HW: 4G2 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NC4000E2
   Component: CD-Database  5571
   Component: TSG HL        H03 0507
   Coding: 010F14004021620002080002
   VCID: 49CF5C5109B89F4F5D7-801C
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273     HW: 4H0 907 273
   Component: RDKBERU25     H09 0700
   Serial number: 10000000007172
   ASAM Dataset: EV_RDKBERU25 003014
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 6889B9D572F24647629-803C
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Anhaenger     H11 0100
   Revision: 5G001001    Serial number: 00000328844824
   Coding: 0109080000000000
   VCID: 71BFD4B141A8878F357-8024
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 059401173
   Coding: 097205C011
   ROD: EV_HDSGAu571.rod
   VCID: 353720A175C0EBAF29F-8060
   Component: TSG HR        H03 0507
   Part No SW: 4H0 907 145 B    HW: 4H0 907 145
   Component: AEM - LEAR    H07 0008
   Revision: 00001001    Serial number: 97812003331401
   ROD: EV_AEMLearAU64X_AU57.rod
End----(Elapsed Time: 02:35, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
bip78
C?ID=367717
Hi Uwe,
My front headlight was hit by a big ass stone and cracked the outer lens. With condensation building up I didn’t want that worry, so bought a replacement headlight.
As these are the high end lights the above mentioned seems to be relevant to halogens/Xenons not the LEDs.
OK, since you're Verified now, moving this to Car Repair Support.
Those LEDs still move up and down, but not side-to-side. So although they were sold as "high end" at the time, from a functional standpoint, they really aren't. Also, I did check the data for your specific headlight range module, EV_HeadlRegulBasic before posting advice. ;)
bip78
C?ID=367717
Ok thanks Uwe. What would you suggest to rectify this problem? Have I missed something ?
NostraJackAss
OP
You could install the correct headlights to comport with a repair as certified, no?
What's this do?
1221A6601002A400
12216F601002A400
bip78
C?ID=367717
OP
What's this do?
1221A6601002A400
12216F601002A400
Sorry Jack I dont understand. The correct headlights are installed - therefore its a case of updating so the headlight are reading from the same source file. As per previous posts, it would seem the replacement headlight is missing its file(s) and wont read frm the other headlights module to solve the issue.
I would assume a fresh file is needed for both?
United States
I began to draft the following in reply to your e-mail before realizing this was in forum already:
Replacement headlights often require swapping several components into the new headlight. Based on this DTC in address 09:
.. I suspect that fan is still inside the old headlight and it needs to be transferred over to the new.
Next, it looks like you need to run the 2-step Basic Settings on this page:
http://wiki.ross-tech.com/wiki/index.php/Audi_A6_(4G/4H)_Headlight_Regulation_Basic
Regards,
Although it is a different Wiki page, that's the same 2-step process Uwe linked so I believe your concern was already addressed. Likewise, it sounds like you already swapped the missing fan.
bip78
C?ID=367717
Thank you all, fully understood and now resolved. I was reading it as a none-LED fix but in fact it works a treat! thank you Uwe, Dana & Andy. Sorry for being a slowbie :D
bip78
C?ID=367717
Case closed - thank you gents. :thumbs:
bip78
C?ID=367717
Brilliant! Never seen that before - and tbh, they are bright!
