Steering column lock
PeteJ
C?ID=340777
The car is a 2017 RS3 with keyless ignition. I've experienced an issue several times where the car will not start due the the steering column being locked. I've tried to turn the steering wheel while the wheels on the ground with no luck. Oddly, if I lift the front end off the ground and remove pressure off the steering system the car will start. Here is the full autoscan, as you can see lots of messages, the TPMS messages are due to putting on a set of wheels that did not have sensors in them for a few days.
Sunday,18,August,2019,12:04:42:24295
VIN: WUABWGFF9H1900173   License Plate:
Mileage: 43596km-27089mi   Repair Order:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 29 2B 39 3C 42 44 47
          52 55 5F 65 6C BB BC CF D6 D7
VIN: WUABWGFF9H1900173   Mileage: 43596km-27089miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Cannot be reached 0100
Address 01: Engine (------DAZA)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404 G    HW: 07K 907 309 E
   Component: R5 2.5l TFSI  X21 0004
   Revision: 53X21000
   Coding: 0A250032242600053620
   ASAM Dataset: EV_ECM25TFS0118V0907404G 001004
   ROD: EV_ECM25TFS0118V0907404G.rod
   VCID: 3D27C5225DF4409FE1F-8068
10064 - Fuel Pump
          P308D 00 [096] - RPM too Low
                    Mileage: 43320 km
                    Date: 2019.08.15
                    Time: 08:41:58
                    Engine speed: 7098.50 /min
                    Normed load value: 65.9 %
                    Vehicle speed: 200 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 52 °C
                    Voltage terminal 30: 12.540 V
                    Unlearning counter according OBD: 35
                    Fuel pump: specified value: 77.423 %
                    Low fuel pressure: specified value: 500.0 kPa
                    Fuel temperature: 39.8 °C
                    Adaptation of Fuel Pump (FP): -83.4 kPa
                    High fuel pressure: specified value: 24.0000 MPa
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [100] - -
                    Mileage: 43436 km
                    Date: 2019.08.15
                    Time: 14:34:26
                    Engine speed: 6029.00 /min
                    Normed load value: 71.0 %
                    Vehicle speed: 124 km/h
                    Coolant temperature: 98 °C
                    Intake air temperature: 56 °C
                    Voltage terminal 30: 13.000 V
                    Unlearning counter according OBD: 68
                    Engine status: COENG_RUNNING
10594 - Cylinder 4
          P0304 00 [100] - Misfire Detected
                    Mileage: 43436 km
                    Date: 2019.08.15
                    Time: 14:34:26
10595 - Cylinder 5
          P0305 00 [100] - Misfire Detected
                    Mileage: 43436 km
                    Date: 2019.08.15
                    Time: 14:34:26
Readiness: 0010 0001
   Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2112
   Revision: 00H06V07
   VCID: 2E05F26E8092AB07685-807A
   Part No SW: 8V0 614 517 C    HW: 8V0 614 517 C
   Component: ESC           H25 0621
   Revision: 00000000    Serial number: 60457000000243
   Coding: 2EAA6B7DD4990BA989920B6B81946974D62BD091D081963602415084028812
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 070001
   VCID: 392FD13249DC7CBFCD7-806C
9 Faults Found:
8246 - Databus
          [FCAN: Motor_Code_01 message is not received]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:58
8250 - Databus
          [FCAN: Motor_07 message is not received]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:58
8252 - Databus
          [FCAN: Motor_11 message is not received]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
8254 - Databus
          [FCAN: Motor_12 message is not received]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
8256 - Databus
          [FCAN: Motor_14 message is not received]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
8258 - Databus
          [FCAN: Motor_20 message is not received]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
8264 - Databus
          [FCAN: Tsk_06 message is not received]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
8351 - Databus
          [FCAN: Motor_17_alt veraltet bit is set]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:55
8400 - Databus
          [FCAN: AB_Gurt_FA signal is invalid]
                    Reset counter: 168
                    Mileage: 43295 km
                    Date: 2019.08.15
                    Time: 08:27:44
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0434002464
   Coding: 030C0C
   VCID: 3B23CB3A43E04EAFDFB-806E
12716804 - Databus
          [Ausfall Motor_14 - Botschaft -  kein Signal/Kommunikation]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0130
   Revision: 20002000    Serial number: 00000001172916
   Coding: 03000015010000000000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 40D9BCD62A062D778A9-8014
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: EF08869800PAG0MUFU03
459023 - Databus
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
   Part No SW: 5Q0 937 085 BF    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H34 0236
   Serial number: 02001705300865
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EA5022E10729B87B85-802A
   Component: WWS371 170117  043 0585
   Serial number:         170201053603
   Coding: 0A47F7
   Serial number: 62658002
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 22 12 2016  00001718
   Serial number: 00000000000068746455
   Sun Roof:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST001GD2NJ00000
   Coding: 101F00
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 108
                    Mileage: 41721 km
                    Date: 2019.08.02
                    Time: 15:14:32
541973 - Databus
          [Motor_04 Datenbus fehlende Botschaft]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
542229 - Databus
          [Motor_14 Datenbus fehlende Botschaft]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
542485 - Databus
          [Motor_18 Datenbus fehlende Botschaft]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
555541 - Databus
          [Motor_12_alt aktiv]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
559125 - Databus
          [Motor_07 Datenbus fehlende Botschaft]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
   Part No SW: 5QA 919 294 A    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0038
   Serial number: 000308418617056
   Coding: 0470155011
   ASAM Dataset: EV_EPHVA18AU3700000 009031
   VCID: 4ACD9EFE1C3AE72754D-801E
12648465 - Databus
          [Motorsteuergerät - Motor_12 - kein Signal/keine Kommunikation]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
13637426 - Databus
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
12648468 - Databus
          [Motorsteuergerät - Motor_20 - kein Signal/keine Kommunikation]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 G    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0082
   Serial number:       090117040
   ASAM Dataset: EV_AudiMagneRide 002008
   ROD: EV_AudiMagneRide.rod
   VCID: 45D7ADC23524085FB9F-8010
10506241 - Databus
          [Motor_07_Timeout]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:58
                    COM: 0A DF 0A EF 00 01 03 DD 00 00
                    Voltage terminal 30: 12.0 V
                    Terminal 15 status via CAN: Terminal 15 on
                    Engine run: Not available
                    Engine torque: Not available
                    AMR state: 6
                    Damping adjustment indicator lamp: OFF
                    ESP automatic engagement: not activated
                    Fall-back level: 01 B0 20 00
10510337 - Databus
          [Motor_11_Timeout]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
                    COM: 0A EF 0A EF 00 00 F3 BA 00 00
                    Voltage terminal 30: 12.1 V
                    Engine run: 0
                    Engine torque: -4 Nm
                    AMR state: 0
                    Fall-back level: 00 00 00 00
10510339 - Databus
          [init value Moment Ist Sum]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:28:32
                    COM: 0A DF 0A FE 00 01 89 74 00 00
                    Engine run: 0
                    AMR state: 6
                    Fall-back level: 01 B8 20 00
10510343 - Databus
          [init value Raw Soll Moment]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:28:32
                    Engine run: 0
                    AMR state: 6
10514433 - Databus
          [Motor_14_TimeOut]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
                    COM: 0A DF 0A FE 00 00 F5 72 00 00
                    AMR state: 6
                    Fall-back level: 01 30 20 00
10518529 - Databus
          [Motor_Code_01_Timeout]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:58
                    COM: 0A D0 0A EF 00 01 03 8C 00 00
                    AMR state: 6
   Serial number: 003GCR07ENV4
   Coding: 9DCCFCC0008000005000001AC24800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47CBA7CA0F281A4F4B3-8012
   Belt Pretensioner left:
   Serial number: 34230167A28021750057
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34230168A01031740816
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001KJ98X
   Coding: 303337
   Subsystem 4 - Part No SW: -----------    HW: 480 002 602 17
   Serial number: 3570000000040B44E12C
   Subsystem 5 - Part No SW: -----------    HW: 480 002 602 17
   Serial number: 358000000009FA44E12W
   Subsystem 6 - Part No SW: -----------    HW: 480 401 502 17
   Serial number: 351000199247F13265F2
   Subsystem 7 - Part No SW: -----------    HW: 480 401 502 17
   Serial number: 352000199247F136536
   Subsystem 8 - Part No SW: -----------    HW: 480 401 601 17
   Serial number: 3550002C523C4E32E2EG
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 401 601 17
   Serial number: 3560002C323C4E35B245
1053952 - Databus
          [NWD: 0x121 Motor_20 Timeout]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
   Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 02031704401807
   Coding: A018
   VCID: 0D4755E22DD4B01FB1F-8058
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 890     HW: 8V0 920 890
   Component: FBenUSA       H14 0046
   Coding: 086D18D33A88CF050204EE041800001000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 7AAD0E3E0C5AB7A784D-802E
16776971 - Databus
          [Motor_04 communication error can_error_timeout]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
   Component: GW MQB High   515 5286
   Serial number: 28021710522664
   Coding: 03010004340860005B00822CB80B00000001010000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 2F3BEF6A8798A20F633-807A
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20170210175324 22168
   Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
   Serial number: 1384521504
131689 - Rear View Camera System Control Module
          U104C 00 [009] - No communication
          [Timeout Knoten 0x69 / 6C - Steuergerät für Rückfahrkamerasystem]
                    Reset counter: 133
                    Mileage: 41260 km
                    Date: 2019.07.06
                    Time: 12:38:32
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: On
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
          [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:56
                    Terminal 15: On
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7762
   Serial number: HA1-00001.09.16
   Coding: 0601
   VCID: 4DC795E2ED54F01F71F-8018
17506 - Databus
          [Motorsteuergerät - TO -- Mot_07]
                    Fault Priority: 8
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:57
17473 - Databus
          [Motorsteuergerät - TO -- Mot_11]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
16657 - Databus
          [Motorsteuergerät - TO -- Mot_12]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
17474 - Databus
          [Motorsteuergerät - TO -- Mot_14]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
16727 - Databus
          [Motorsteuergerät - TO -- Mot_20]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
17475 - Databus
          [Motorsteuergerät - TO -- Mot_Code]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:57
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H06 0017
   VCID: 42DDB6DE240A3F679CD-8016
0279 - Databus
          [databus - message missing]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
   Revision: 00000000    Serial number: 17000608488008
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E0066EBE81D71E1-8060
12666369 - Databus
          [Timeout Message Motor_14]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: A0 01
                    WFS State: 17 06
                    Vehicle speed: 0.00 km/h
                    Voltage: 68
                    AD-Value H-bridge: 33
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
12666381 - Databus
          [Timeout Message Motor_09]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
                    ELV State: 04
                    CoCo State: A0 01
                    WFS State: 17 06
                    Voltage: 68
                    CAN signals: 00
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
0279 - Databus
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:55
   Part No SW: 3Q0 907 566 D    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0410
   Revision: --------
   Coding: 040002
   ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
1183750 - Databus
          [databus message missing - Motor]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:55
                    Control Module temperature: 38 °C
                    Voltage terminal 30: Measured value not available
                    Terminal 15 status: Measured value not available
                    Voltage terminal 15: 11.70 V
   Serial number: 310117EAV06361
   Coding: 005D1B205C00048000000002
   VCID: 43D3B3DA3B10366F97B-8016
458803 - Databus
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
   Coding: 8106
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2DCE3E4CDA77A7C4D-806E
23040 - Databus
          [MOTOR_20 Botschaft - CAN-Timeout]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:53
                    Motor status: 00
                    Supply voltage: 12.00 V
                    Temperature: 36.0 °C
                    KFC: 5A
                    KFA: 00 00
                    Environmental conditions: 20
                    uioUdNotFilt_xdu16: 12.02 V
                    uAdSensI_SwitchedKl30_xdu16: 12.01 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
22272 - Databus
          [KFC_MOTOR_11 Botschaft - CAN-Timeout]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
                    Motor status: 00
                    KFC: 57
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 12.17 V
                    uAdSensI_SwitchedKl30_xdu16: 12.16 V
22528 - Databus
          [MOTOR_12 Botschaft - CAN-Timeout]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
                    Motor status: 00
                    KFC: 58
                    KFA: 00 00
22784 - Databus
          [MOTOR_14-Botschaft - CAN-Timeout]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
                    Motor status: 03
                    System status: Driving mode
                    KFC: 59
                    KFA: 00 00
19460 - Databus
          [ESP_05 Botschaft - SNA-Check]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
                    Motor status: 03
                    KFC: 4C
                    KFA: 00 04
23296 - Databus
          [MOTOR_CODE_01 Botschaft - CAN-Timeout]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:58
                    Motor status: 03
                    KFC: 5B
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 12.14 V
                    uAdSensI_SwitchedKl30_xdu16: 12.14 V
   Part No SW: 81A 035 466     HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0100
   Revision: 00000001    Serial number: AUZ8ZAGHX00H2MK
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 629D565E84CA5F67BCD-8036
   Serial number: 030217EB326689
   Coding: 005D13205E00048000000002
458803 - Databus
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
Address 55: Headlight Range (J745)       Labels:* None
   Part No SW: 8V0 907 357 A    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0230
   Coding: 0E62021123200400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005014
   VCID: 3E25C22E50F25B87F85-806A
13705475 - Databus
          [Motor_20 Datenbus fehlende Botschaft]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:54
   Part No SW: 8V1 035 880 A    HW: 8V1 035 880
   Component: MU-P-LNS-US   053 0906
   Serial number: A702B0HS002089
   Coding: 017361020000000011220002041A00102F0028E5017001047E
   VCID: 3829D43672D665B7329-806C
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Component: DU High  H49 0014
   Serial number: AUZ8Z9G1Y00Y85
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BK    HW: 8V0 919 614 BK
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL112011700010068
   Compact Disc Database:
   Component: Gracenote2---  --- 3011
          B11CF 53 [009] - Deactivated
                    Reset counter: 89
                    Mileage: 41260 km
                    Date: 2019.07.06
                    Time: 12:43:25
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
5637 - Control Head for Multimedia System; NAV Button
          B1291 F6 [008] - Unknown Error Elaboration
                    Reset counter: 151
                    Mileage: 41260 km
                    Date: 2019.07.06
                    Time: 12:45:55
5656 - Control Head for Multimedia System; RADIO Button
          B1291 FC [008] - Unknown Error Elaboration
                    Reset counter: 134
                    Mileage: 41260 km
                    Date: 2019.07.06
                    Time: 12:45:55
1562 - Microphone 1
          B129B 11 [008] - Short to Ground
                    Reset counter: 168
                    Mileage: 43446 km
                    Date: 2019.08.15
                    Time: 14:38:53
                    Voltage terminal 30: 13.8 V
6708 - Databus
          [Engine: no communication]
                    Reset counter: 167
                    Mileage: 43169 km
                    Date: 2019.08.14
                    Time: 20:27:58
                    Network diagnosis-Status: Enabled
7179 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 89
                    Mileage: 41260 km
                    Date: 2019.07.06
                    Time: 12:38:36
                    BAP-BAP_Function_ID: 02
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 8S0 907 273     HW: 4M0 907 273 B
   Component: RDKHUFAU736   H04 0002
   Serial number: 40000000004695
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 77AB170A3F48AACFFB3-8022
9 Faults Found:
8397058 - Front Left TPMS Sensor
          C1050 31 [008] - No Signal
                    Reset counter: 159
                    Mileage: 41523 km
                    Date: 2019.07.27
                    Time: 17:09:30
                    Expanded ambient data 6-Vehicle speed: 123.65 km/h
                    Expanded ambient data 6-Outside air temperature: 30.00 °C
                    Left front tire pressure sensor: remaining oper. life: 127 m
                    Left front tire pressure sensor: identification-Manufacturer code: numerical value: no text
                    Left front tire pressure sensor: identification-Sensor identification number (sensor ID): 691391293
8397314 - Front Right TPMS Sensor
          C1051 31 [008] - No Signal
                    Reset counter: 159
                    Mileage: 41523 km
                    Date: 2019.07.27
                    Time: 17:09:30
                    Right front tire pressure sensor: remaining oper. life: 127 m
                    Right front tire pressure sensor: identification-Manufacturer code: numerical value: no text
                    Right front tire pressure sensor: identification-Sensor identification number (sensor ID): 691389745
8397570 - Rear Left TPMS Sensor
          C1052 31 [008] - No Signal
                    Reset counter: 159
                    Mileage: 41523 km
                    Date: 2019.07.27
                    Time: 17:09:30
                    Left rear tire pressure sensor: remaining oper. life: 127 m
                    Left rear tire pressure sensor: identification-Manufacturer code: numerical value: no text
                    Left rear tire pressure sensor: identification-Sensor identification number (sensor ID): 692634682
8397826 - Rear Right TPMS Sensor
          C1053 31 [008] - No Signal
                    Reset counter: 159
                    Mileage: 41523 km
                    Date: 2019.07.27
                    Time: 17:09:30
                    Right rear tire pressure sensor: remaining oper. life: 127 m
                    Right rear tire pressure sensor: identification-Manufacturer code: numerical value: no text
                    Right rear tire pressure sensor: identification-Sensor identification number (sensor ID): 691388705
8389633 - Adapatation Not Possible
          C112C 00 [008] - Tire Pressure Sensor(s) Defective or No Signal
                    Reset counter: 159
                    Mileage: 42296 km
                    Date: 2019.08.05
                    Time: 13:39:58
                    Radio interference levels: 28
8400898 - Tires 01: Tire  Pressure Warning
          C111B 00 [009] - Pressure too Low
                    Reset counter: 128
                    Mileage: 43295 km
                    Date: 2019.08.15
                    Time: 08:18:43
                    Expanded ambient data 6-Vehicle speed: 19.14 km/h
                    Expanded ambient data 6-Outside air temperature: 14.50 °C
                    Expanded ambient data 2-Left front tire pressure sensor: nominal pressure: 2.70 bar
                    Expanded ambient data 2-Left front tire pressure sensor: actual pressure: 2.18 bar
                    Expanded ambient data 2-Left front tire pressure sensor: temperature: 27 °C
                    Expanded ambient data 2-Left front tire pressure sensor: identification: 691389745
8400901 - Tires 02: Tire  Pressure Warning
          C111D 00 [009] - Pressure too Low
                    Reset counter: 128
                    Mileage: 43295 km
                    Date: 2019.08.15
                    Time: 08:18:52
                    Expanded ambient data 6-Vehicle speed: 15.75 km/h
                    Expanded ambient data 3-Right front tire pressure sensor: nominal pressure: 2.70 bar
                    Expanded ambient data 3-Right front tire pressure sensor: actual pressure: 2.15 bar
                    Expanded ambient data 3-Right front tire pressure sensor: temperature: 23 °C
                    Expanded ambient data 3-Right front tire pressure sensor: identification: 691391293
8400904 - Tires 03: Tire  Pressure Warning
          C111F 00 [009] - Pressure too Low
                    Reset counter: 128
                    Mileage: 43295 km
                    Date: 2019.08.15
                    Time: 08:23:12
                    Expanded ambient data 6-Vehicle speed: 16.73 km/h
                    Expanded ambient data 4-Left rear tire pressure sensor: nominal pressure: 2.65 bar
                    Expanded ambient data 4-Left rear tire pressure sensor: actual pressure: 2.18 bar
                    Expanded ambient data 4-Left rear tire pressure sensor: temperature: 25 °C
                    Expanded ambient data 4-Left rear tire pressure sensor: identification: 691388705
8400907 - Tires 04: Tire  Pressure Warning
          C1121 00 [009] - Pressure too Low
                    Reset counter: 128
                    Mileage: 43302 km
                    Date: 2019.08.15
                    Time: 08:34:13
                    Expanded ambient data 6-Vehicle speed: 167.94 km/h
                    Expanded ambient data 6-Outside air temperature: 19.50 °C
                    Expanded ambient data 5-Right rear tire pressure sensor: no: 2.65 bar
                    Expanded ambient data 5-Right rear tire pressure sensor: actual pressure: 2.30 bar
                    Expanded ambient data 5-Right rear tire pressure sensor: temperature: 29 °C
                    Expanded ambient data 5-Right rear tire pressure sensor: identification: 692634682
Address 6C: Back-up Cam.
   Serial number: 240117EAN1063C
   Coding: 000C13204000048000000002
   Serial number: 240117EAN10638
   Part No SW: 3Q0 907 590 D    HW: 3Q0 907 590
   Revision: --------
   Coding: 040002
   ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
   VCID: 3635DA0E78C293C7205-8062
   VCID: 176B378A1F084ACF1B3-8042
End----------(Elapsed Time: 02:09, VBatt start/end: 12.0V/11.9V)-----------
Wow, lotta fault codes in that car! Clear all fault codes and let's see what comes back.
PeteJ
C?ID=340777
Unfortunately all those (other than the TPMS) came at once on my last track day. I found the limits of my RS3... I'll clear the codes and see if the steering code comes up again by itself.
dieseldub
Bay Area, CA
C?ID=28764
Whole lotta data bus codes.
Something on the bus crashing communication perhaps? Time to start unplugging modules until the CAN bus is happy again?
Also, the key code might just be a low battery in the fob. KESSY systems are extra sensitive to battery voltage and effectiveness of the transponder key. I think they say once the battery gets below 3.06V the door touch features stop responding more often than not. Get below 3V and it might not detect the key to allow start authorization (which is funny, because the battery is rated at 3V... but if you measure a new battery, they usually are more like 3.3V, so there's that).
