ABS Hydraulic Unit Replacement - Original Code not working
JeffsJetta
C?ID=377728
My apologies for posting this twice but it seemed like this was the better place to post this. I can't see how to move the original thread or remove it.
My ABS Module was acting up so I took in to the dealership because my VIN fell under the recall. Unfortunately VW refused to replace the module because they were unable to do their software update. They wanted to charge me $2600 to replace the module and do the work.
So I bought a replacement module from a junkyard based off the revised part number VW quoted me.
Before installing the junkyard module I pulled the code off my original module which was: 113B400D492300FF880F02E5921E00413000
After I installed the junkyard module I input this code but it was rejected in VCDS. I'm hoping someone out there can help me with coding this module. It's worth mentioning that the original part# was 1K0 907 379 AD but the new part number is 1K0 907 379 AN. According to VW this is the correct revised part number as the AD was phased out.
Thanks in advance to anyone who is able to help.
Here is my Auto-Scan prior to repair:
 Saturday,17,August,2019,14:31:05:54182
VIN: 3VWHM71K49M015415   License Plate:
Mileage: 270160km-167869mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWHM71K49M015415   Mileage: 270160km-167869miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 Q    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9970
   Revision: G6H01---    Serial number: VWX7Z0H624C13L
   Coding: 0000071
   Shop #: WSC 43600 000 1048576
   VCID: 3C2134666A669D87D61-8068
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Fault Frequency: 69
                    Mileage: 269670 km
                    Time: 03:40:32
                    RPM: 708 /min
                    Load: 26.3 %
                    Temperature: 84.0°C
                    Temperature: 45.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.970 V
               U1017 - 000 -
                    Fault Frequency: 36
                    Mileage: 269496 km
                    Time: 03:45:25
                    RPM: 3168 /min
                    Load: 43.5 %
                    Speed: 16.0 km/h
                    Temperature: 63.0°C
                    Temperature: 41.0°C
                    Voltage: 13.970 V
050197 - Implausible Data Received from ABS Control Module
               U0415 - 000 -  - Intermittent - MIL ON
                    Fault Status: 10100000
                    Fault Frequency: 135
                    Mileage: 269581 km
                    Time: 18:55:09
                    RPM: 2643 /min
                    Load: 67.4 %
                    Speed: 255.0 km/h
                    Temperature: 90.0°C
                    Temperature: 65.0°C
                    Voltage: 13.970 V
001287 - Idle Control System RPM
               P0507 - 000 - Higher than Expected. - Intermittent
                    Mileage: 269681 km
                    Time: 03:57:41
                    RPM: 1443 /min
                    Load: 12.9 %
                    Temperature: 86.0°C
                    Temperature: 60.0°C
                    Voltage: 13.843 V
001281 - Vehicle Speed Sensor
               P0501 - 000 - Implausible Signal - Intermittent
                    Mileage: 270116 km
                    Time: 18:44:29
                    RPM: 2901 /min
                    Load: 52.1 %
                    Temperature: 80.0°C
                    Temperature: 31.0°C
                    Voltage: 14.097 V
               U1017 - 000 -  - Intermittent
                    Mileage: 269992 km
                    Time: 06:02:56
                    RPM: 2772 /min
                    Load: 18.0 %
                    Speed: 107.0 km/h
                    Temperature: 86.0°C
                    Temperature: 60.0°C
                    Voltage: 13.970 V
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 113B400D492300FF880F02E5921E00413000
   Shop #: WSC 00066 000 00000
   VCID: 74B1DC460EB615C7DE1-8020
10 Faults Found:
01130 - ABS Operation
                    Fault Frequency: 35
                    Reset counter: 216
                    Mileage: 269495 km
                    Count: 7
                    Count: 1
                    Count: 12800
                    Count: 125
                    Count: 19
                    Count: 3072
                    Count: 63232
                    Fault Frequency: 30
                    Reset counter: 176
                    Mileage: 270108 km
                    Count: 7
                    Count: 1
                    Count: 4608
                    Count: 89
                    Count: 116
                    Count: 63232
                    Fault Frequency: 155
                    Reset counter: 176
                    Date: 2044.00.00
                    Time: 16:01:40
                    Count: 256
                    Count: 32944
                    Count: 51968
                    Count: 57
                    Count: 128
                    Count: 256
                    Count: 20912
                    Count: 7680
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                    Fault Frequency: 86
                    Reset counter: 176
                    Mileage: 269796 km
                    Count: 7
                    Count: 1
                    Count: 4608
                    Count: 41
                    Count: 63232
                    Fault Status: 00101100
                    Reset counter: 176
                    Mileage: 270162 km
                    Count: 16391
                    Count: 512
                    Count: 56
                    Count: 63232
                    Reset counter: 176
                    Mileage: 270162 km
                    Count: 16391
                    Count: 512
                    Count: 88
                    Count: 63232
                    Reset counter: 176
                    Mileage: 656901 km
                    Date: 2000.08.00
                    Time: 16:16:17
                    Count: 1795
                    Count: 22
                    Count: 45056
                    Count: 72
                    Count: 61184
                    Count: 59649
                    Count: 80
                    Count: 45058
                    Reset counter: 176
                    Mileage: 270162 km
                    Count: 16391
                    Count: 512
                    Count: 40
                    Count: 63232
                    Fault Frequency: 203
                    Reset counter: 176
                    Mileage: 269796 km
                    Count: 7
                    Count: 1
                    Count: 4608
                    Count: 128
                    Count: 63232
16352 - Control Module - Electrical Error
            014 - Defective
                    Fault Status: 01101110
                    Fault Frequency: 239
                    Reset counter: 176
                    Mileage: 270116 km
                    Count: 7
                    Count: 1
                    Count: 4608
                    Count: 233
                    Count: 60928
                    Count: 63232
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CA1F4662AE65D87961-8028
01296 - Sensor for Vent Temperature; Center (G191)
            010 - Open or Short to Plus
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000001005320
   Coding: 14058E234004100007140000001400000008730B5C000120000000000000
   Shop #: WSC 33311 002 1048576
   VCID: 6FBBD32A6B90361F233-803A
   Component: Wischer 150708 021  0501
   Coding: 00038805
   Shop #: WSC 33311
                    Reset counter: 205
                    Mileage: 269495 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.35 V
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Reset counter: 181
                    Mileage: 269495 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.50 V
   Component: 6A AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M0609BP
   Coding: 0013889
   VCID: 6C81C4265A86CD07061-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME29416E6FS
   Subsystem 3 - Serial number: 6342MSME3903684FK
   Subsystem 4 - Serial number: 6351HSME163F46136
   Subsystem 5 - Serial number: 6361HSME16631F29B
   Subsystem 6 - Serial number: 63727SME15693564%
   Subsystem 7 - Serial number: 63827SME160E5C212
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Coding: 0000021
   VCID: 03538F9A5718227FD7B-8056
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0H624C13L
   Coding: 0023203
   Shop #: WSC 05226 444 57447
                    Fault Frequency: 68
                    Reset counter: 216
                    Mileage: 269495 km
                    Time: 06:07:31
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 270508F1001414
   Coding: E9807F070002021002
   VCID: 35372142494C4CCF29F-8060
                    Fault Status: 00110100
                    Fault Frequency: 70
                    Reset counter: 216
                    Mileage: 269495 km
                    Time: 06:07:32
   Component: IMMO            3HL 1222
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000605388703
   Coding: 0001205
                    Fault Frequency: 29
                    Reset counter: 216
                    Mileage: 269618 km
00105 - Signal Central Locking SAVE/LOCK Drivers Side
                    Fault Frequency: 172
                    Reset counter: 216
                    Mileage: 269495 km
01030 - Central Locking Key Switch; Driver Side; Lock
                    Reset counter: 214
                    Mileage: 270060 km
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   VCID: 2A0D023E90F21337B4D-807E
                    Fault Frequency: 62
                    Reset counter: 226
                    Mileage: 270153 km
                    Time: 05:23:24
                    Voltage: 14.00 V
                        DU
                    Temperature: 53.0°C
                    RPM: 1946 /min
                    Speed: 28.0 km/h
                    Speed: 28.0 km/h
                    Fault Status: 00101101
                    Fault Frequency: 197
                    Reset counter: 226
                    Mileage: 270162 km
                    Time: 02:26:17
                    Voltage: 12.50 V
                        DD
                    Temperature: 28.0°C
                    Fault Frequency: 128
                    Reset counter: 226
                    Mileage: 270161 km
                    Time: 06:37:22
                    Voltage: 14.00 V
                        DU
                    Temperature: 49.0°C
                    RPM: 2138 /min
                    Speed: 63.0 km/h
                    Speed: 63.0 km/h
   Coding: 13900F880186281B0904058FB0880F0488DCA0
   VCID: 04518C8652162547EE1-8050
                    Reset counter: 216
                    Mileage: 270153 km
                    Time: 05:24:43
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 00000075288702
   Coding: 0001204
   VCID: 70B9D05676AE29E73A9-8024
01553 - Motor for Central Locking; Passenger Door (V57); Lock
                    Reset counter: 216
                    Mileage: 263190 km
                    Fault Status: 00111000
                    Fault Frequency: 201
                    Reset counter: 216
                    Mileage: 263190 km
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
   Component: Radio DE2       017 0021
   Revision: 00017000    Serial number: VWZ4Z7H6359866
   Coding: 0040402
   VCID: 2019E016E6CED967EA9-8074
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003284488
   Coding: 0001168
   VCID: 76B5E64E14CA07D7E05-8022
                    Reset counter: 216
                    Mileage: 241449 km
   Coding: 0100101
00625 - Vehicle Speed Signal
                    Fault Frequency: 169
                    Reset counter: 216
                    Mileage: 270161 km
                    Time: 06:37:23
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003277375
   Coding: 0001168
   VCID: 77ABEB4A13C07EDFFB3-8022
End----------(Elapsed Time: 01:26, VBatt start/end: 12.4V/12.4V)-----------
Address 08: DTCs cleared
Address 01: DTCs cleared
Address 09: DTCs cleared
Address 46: DTCs cleared
Address 65: DTCs cleared
JeffsJetta
C?ID=377728
Here is an Auto-Scan post repair:
Saturday,17,August,2019,22:50:48:54182
Mileage: 270180km-167882mi   Repair Order:
VIN: 3VWHM71K49M015415   Mileage: 270180km-167882miles
   Coding: 0000071
                    Mileage: 270173 km
                    Time: 04:24:20
                    RPM: 1254 /min
                    Load: 41.2 %
                    Temperature: 80.0°C
                    Temperature: 57.0°C
                    Voltage: 13.970 V
                    Mileage: 270173 km
                    Time: 03:28:55
                    RPM: 2870 /min
                    Load: 35.3 %
                    Speed: 44.0 km/h
                    Temperature: 87.0°C
                    Temperature: 60.0°C
                    Voltage: 13.970 V
                    Mileage: 270173 km
                    Time: 03:29:05
                    RPM: 1375 /min
                    Load: 29.0 %
                    Speed: 255.0 km/h
                    Temperature: 87.0°C
                    Temperature: 60.0°C
                    Voltage: 13.970 V
Readiness: 0000 1100
   Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 000000000000000000000000000000000000
   VCID: 7EA5FE6E30FA4F97B85-802A
                    Fault Status: 01100101
                    Reset counter: 177
                    Mileage: 270185 km
                    Count: 16391
                    Count: 8192
                    Count: 279
                    Count: 45312
                    Count: 11520
                    Reset counter: 177
                    Mileage: 270185 km
                    Count: 16391
                    Count: 8192
                    Count: 295
                    Count: 45312
                    Count: 11520
                    Reset counter: 177
                    Mileage: 270185 km
                    Count: 16391
                    Count: 8192
                    Count: 270
                    Count: 45312
                    Count: 11520
                    Reset counter: 177
                    Mileage: 270185 km
                    Count: 16391
                    Count: 8192
                    Count: 195
                    Count: 45312
                    Count: 11520
   Coding: 00038805
   Shop #: WSC 33311
   Coding: 0013889
   Coding: 0000021
   Coding: 0023203
                    Fault Frequency: 80
                    Reset counter: 217
                    Mileage: 269495 km
                    Time: 06:07:31
                    Fault Frequency: 82
                    Reset counter: 217
                    Mileage: 269495 km
                    Time: 06:07:32
   Coding: 0001205
                    Fault Status: 01111000
                    Fault Frequency: 32
                    Reset counter: 177
                    Mileage: 269618 km
                    Fault Status: 01101000
                    Fault Frequency: 184
                    Reset counter: 177
                    Mileage: 269495 km
                    Reset counter: 214
                    Mileage: 270060 km
   Revision: 00H15000
                    Fault Frequency: 72
                    Reset counter: 227
                    Mileage: 270174 km
                    Time: 04:28:10
                    Voltage: 14.00 V
                        DU
                    Temperature: 43.0°C
                    RPM: 2214 /min
                    Speed: 69.0 km/h
                    Speed: 69.0 km/h
                    Fault Frequency: 200
                    Reset counter: 227
                    Mileage: 270174 km
                    Time: 04:27:46
                    Voltage: 14.00 V
                        DU
                    Temperature: 43.0°C
                    RPM: 2816 /min
                    Speed: 87.0 km/h
                    Speed: 87.0 km/h
                    Fault Frequency: 130
                    Reset counter: 227
                    Mileage: 270174 km
                    Time: 04:27:20
                    Voltage: 14.00 V
                        DU
                    Temperature: 43.0°C
                    RPM: 2317 /min
                    Speed: 53.0 km/h
                    Speed: 53.0 km/h
   Coding: 0001204
                    Reset counter: 217
                    Mileage: 263190 km
                    Reset counter: 177
                    Mileage: 263190 km
   Coding: 0040402
   Coding: 0001168
                    Reset counter: 216
                    Mileage: 241449 km
   Coding: 0100101
                    Reset counter: 217
                    Mileage: 270174 km
                    Time: 04:28:11
   Coding: 0001168
End----------(Elapsed Time: 01:23, VBatt start/end: 12.2V/12.2V)-----------
NostraJackAss
Why would they not change this safety item for free under the recall & did you contact NHTSA & VW corporate advocates to complain?
Please explain & show us documents showing the flash failure and why they rejected replacement?
Vehicle Identification No. 3VWHM71K49M015415
Model Jetta
JEM
Date of production 22.07.2008
Model year 2009
Sales type 1K2ES1
Engine Code CBTA
Transmission Code KPF
Please don't start duplicate threads. If you think you posted in the wrong place, ask to have your thread moved.
I'm not sure why the replacement module isn't taking the original coding. Coding lengths appear to be the same, so I would think it should.
JeffsJetta
C?ID=377728
I have not contacted anyone to complain aside from my complaint at the dealership. They stated that the ABS module was not communicating and that they could not update the software and begin the recall until the module was replaced. They also tried to say that the hydraulic pump was bad. I couldn't find any codes for a bad pump personally. I decided to cut my losses and just replace the whole ABS unit, module and pump myself.
I have no idea why its not accepting the original code. Any thoughts on what I can do from here?
My apologies again for the duplicate post. I'll do what you've asked next time.
JeffsJetta
C?ID=377728
Here's a picture of the printout they gave me at the dealership stating the same: https://ibb.co/4sqxY3L
Oh, I'm not sure how relevant it may be but when it rejected the code it stated something about how it could not accept a subvalue or something like that.
NostraJackAss
On a 10 year old car with 168,000 miles on it?
Are not NHTSA safety campaigns good forever?
Is it this one below and does anything specify a mileage range?
https://www-odi.nhtsa.dot.gov/owner...16075&referenceSearch.urlCode=03P45CS14GQ2DLC
Report Receipt Date: DEC 20, 2016
NHTSA Campaign Number: 16V913000
Component(s): ELECTRONIC STABILITY CONTROL , SERVICE BRAKES, HYDRAULIC
All Products Associated with this Recall expand
Details close
26 Associated Documents expand
Manufacturer: Volkswagen Group of America, Inc.
SUMMARY:
Volkswagen Group of America, Inc. (Volkswagen) is recalling certain model year 2009-2010 Volkswagen Jetta A5 Sedan, 2009 Volkswagen Jetta SportWagen, Eos, GTI, Rabbit and Audi A3 vehicles, and 2010 Volkswagen Golf A6 vehicles. The Antilock Brake System (ABS) control unit may fail during ABS or Electronic Stability Control (ESC) activation, possibly causing a loss of vehicle control.
CONSEQUENCE:
A loss of vehicle control can increase the risk of a crash.
REMEDY:
Volkswagen will notify owners, and dealers will update the ABS control module software to improve the module's self-testing abilities. Any module that fails the new diagnostic test will be replaced. These repairs will be made free of charge. The recall began February 2017. Owners may contact Volkswagen customer service at 1-800-893-5298.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov
The OP's complaint or repair concerns of what has happened or as he allegedly describes certainly doesn't add up with the aforementioned at NHTSA, huh?
IDK OP don't you think you should ask about this being done free from the OEM?
JeffsJetta
C?ID=377728
I'm not sure what the deal is but I went back to see exactly what the error message was when it would kick back the code and now the code is being accepted. I'm going to run the adaptions now.
NostraJackAss
OP:
Don't you think you should be completely compensated & based on what you were quoted at dealer in a certified letter to VWGoA along with a complaint form to NHTSA copied on the documents?
I mean seriously, don't you think you could demand that and that the repair still be done too & to the replaced module, no?
:rolleyes:
JeffsJetta
C?ID=377728
Jack, you ceartainly have a point. I definitely feel like the whole "cannot perform software update therefore we won't replace unit" is just a way for them to get out of replacing alot of these units. From what I understand an improper soldering compound was used in these modules which leads to a bad ground in the module. All the software update is supposed to do is detect this issue earlier than it otherwise would have. If I'm understanding things correclty there is a specific error code that they can get from the module that points to this being the problem. Either way it seems like these modules were poorly made. I just took the path of least resistance and decided to take care of this on my own and spare myself the hassle of trying to squeeze some blood out the rock that is VWofA.
I just finished all the adaptions. New module coded and lights on the dash are all gone, so at the end of the day I'm content. All that's left is to finish bleeding the rear brake lines and possibly bleeding the pump and clutch.
NostraJackAss
Hope you didn't mind me asking such dumb questions and that are usually self evident, you know I'm an asshole right? :rolleyes:
JeffsJetta
C?ID=377728
Hey, it's not skin off my back. Only dumb questions are those that are never asked, so they say.
