Audi A5 2008 B8 Brake switch issues.
Ej2_sir
Derby UK
C?ID=373261
Hi. First post here so hopefully its all done correct!
New to VAGs and VCDS but bought a 2007 Audi A5 3.0tdi quattro and VCDS. Scanned and have a fault of
4366 - Brake Switch (F)
P0703 00 [044] - Electrical Malfunction
and also
I have tried to reset these but they constantly return. I then replaced the switch with a aftermarket part. The faults remained after reset. I then replaced the switch with an OE one. Fault still remains (followed Elsawin proceedure eg do not move pedal, click in locating tabs and then rotate purple locking tabs clockwise). I checked the bulbs and all brake lights are working correctly.
Today I got the ESP light on and the errors appear to have moved into the ABS section. Attached full scan if anyone can assist!
Thursday,15,August,2019,16:47:27:35605
VIN: WAUZZZ8T88A005904   License Plate:
Mileage: 152760km-94920mi   Repair Order: esp fault
Chassis Type: 8T-AU48 (8T0)
Scan: 01 03 05 06 07 08 09 0E 0F 10 15 16 17 19 1E 36 37 42 46 47
          52 53 55 56 57 77
VIN: WAUZZZ8T88A005904   Mileage: 152760km-94920miles
0F-Digital Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAPA)       Labels:| 059-907-401-V1.clb
   Part No SW: 8K0 907 401     HW: 8K0 907 401
   Component: 3.0TDI EDC17  H01 0008
   Revision: --H01---
   Coding: 01140023180F0118
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_ECM30LTDIA5 A01009
   ROD: EV_ECM30LTDIA5_A01.rod
   VCID: 6889B88AA2FB6A17629-803C
4698 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [036] - -
                    Mileage: 152710 km
                    Date: 2019.08.15
                    Time: 15:36:30
                    Engine speed: 792.50 /min
                    Normed load value: 52.2 %
                    Vehicle speed: 10 km/h
                    Coolant temperature: 54 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 14.040 V
                    Engine speed: 795.5 /min
                    Vehicle speed: 23.69 km/h
                    CCS target speed: 0.00 km/h
                    CCS status-Bits 0-7: 11001101
                    Cr Ctl st Shut Offirev-Bits 0-7: 00000000
                    Cr Ctl st Shut Offrev-Bits 0-7: 00000000
                    Cr Ctl st Shut Offrev-Bits 0-7: 00010000
                    Cr Ctl st Shut Offrev-Bits 0-7: 10000000
                    Cr Ctl st Shut Offrev-Bits 0-7: 00001101
                    Cr C st Key 0-Bits 0-7: 00000000
4699 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [036] - -
                    Mileage: 152710 km
                    Date: 2019.08.15
                    Time: 15:36:30
                    Engine speed: 792.00 /min
                    Normed load value: 51.8 %
                    Voltage terminal 30: 13.940 V
                    Engine speed: 793.5 /min
                    Vehicle speed: 23.89 km/h
                    Mileage: 152434 km
                    Date: 2019.08.13
                    Time: 15:19:50
                    Engine speed: 1358.50 /min
                    Normed load value: 85.5 %
                    Vehicle speed: 51 km/h
                    Coolant temperature: 50 °C
                    Intake air temperature: 24 °C
                    Ambient air pressure: 1410 mbar
                    Voltage terminal 30: 13.960 V
                    Engine speed: 1749.5 /min
                    Vehicle speed: 38.31 km/h
                    Vehicle voltage terminal 30: 13680 mV
                    Accelerator position: 0.00 %
                    Limiting torque: 395.2 Nm
                    Co Eng st: COENG_RUNNING
7900 - Right Engine Mount Solenoid Valve (N145)
          P1577 00 [040] - Open Circuit
                    Fault Frequency: 18
                    Mileage: 152416 km
                    Date: 2019.08.12
                    Time: 17:26:55
                    Engine speed: 679.00 /min
                    Normed load value: 25.9 %
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 14.160 V
                    Unlearning counter according OBD: 35
                    Engine speed: 679.0 /min
                    Vehicle speed: 0.00 km/h
                    Engine mounting valve: right: activation: 0.00 %
                    Engine mounting valve: left: activation: 0.00 %
                    Gearbox mounting valve 1: activation: 0.00 %
                    Gearbox mounting valve 2: activation: 0.00 %
                    Vehicle voltage terminal 30: 14160 mV
   Part No SW: 8K0 907 379 J    HW: 8K0 907 379 J
   Component: ESP8 quattro  H03 0190
   Coding: 1B0500
   VCID: 40D9402AEA8B72578A9-8014
                    Reset counter: 134
                    Mileage: 152709 km
                    Date: 2019.08.15
                    Time: 11:15:43
                    Hex Value: 0x15C0
                    Hex Value: 0x4006
                    Hex Value: 0x1F07
                    Hex Value: 0x90B7
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 289 C    HW: 8K0 907 289 C
   Component: BCM2.01       H37 0253
   Coding: 031000
   VCID: 392F2DCE8951239FCD7-806C
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H33 0049
   Serial number: 0107000081248001
   Subsystem 2 - Part No SW: 8K0 905 852 A    HW: 8K0 905 852 A
   Component: ELVAUDIB8  H34 0039
   Serial number: 0207000000074012
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760     HW: 8T0 959 760
   Component: MEM-BFS       H08 0027
   Revision: AA000000    Serial number: 00001001007975
   Coding: 08217025002444441000
   VCID: 55F7817E0509E7FFC9F-8000
Address 07: Control Head        Labels: 8T0-035-7xx-07-H.clb
   Part No SW: 8T0 035 730     HW: 4E0 035 729 A
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 331EG077508140
   Coding: 0025002
   Shop #: WSC 00000 000 08192
   VCID: 6E85CE928C9FB427285-803A
   Subsystem 1 - Part No: 8T0 919 609
   Component: E0380 BedienteilH07 0100
   Subsystem 2 - Serial number: 00000000008170
   Subsystem 3 - Serial number: 0108.06.070000000100010006ÿ
   Subsystem 4 - Serial number: 010006ÿ
   Part No SW: 8T2 820 043 H    HW: 8T2 820 043 H
   Component: KLIMA 3 ZONEN H04 0093
   Revision: D1000000    Serial number: 0114.06.070011
   Coding: 36060000
   VCID: 372B2BF6BF4535EF3B3-8062
                    Fault Status: 00101101
                    Fault Frequency: 12
                    Reset counter: 133
                    Mileage: 152416 km
                    Date: 2019.08.12
                    Time: 17:45:38
   Part No SW: 8K0 907 063 D    HW: 8K0 907 279 D
   Component: BCM1 1.0      H19 0253
   Revision: 05019001    Serial number: 00000000024939
   Coding: 260050910014AF211709000300005D5D409D03C800010141000000
   Shop #: WSC 00546 210 91529
   VCID: 303910EA5A2BE2D77A9-8064
   Subsystem 1 - Part No SW: 8T2 955 119 B    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 140607  H11 0040
   Serial number: SWFBIE 0000190
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8T0 955 559     HW: 4E0 955 559 B
   Component: RLS  H12 0001
   Serial number: 10007807
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000001106070660
                    Fault Status: 00101110
                    Fault Frequency: 12
                    Reset counter: 133
                    Mileage: 152416 km
                    Date: 2019.08.12
                    Time: 17:45:00
03207 - Charisma Switch Module
                    Reset counter: 86
                    Mileage: 152416 km
                    Date: 2019.08.12
                    Time: 17:26:00
   Part No SW: 8T2 035 110 C    HW: 8T2 035 110 A
   Component: MP3-Changer     H42 0390
   Revision: 00042001    Serial number: AUZ5ZBG4511183
   VCID: 2B0307867F0D810F4FB-807E
Address 0F: Digital Radio
   Part No SW: 8K0 919 475     HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0003
   Revision: 11001001    Serial number: 46130716301923
   Coding: 100001
   Shop #: WSC 06325 123 12345
   VCID: 76B5E6F2F8CF8CE7E05-8022
   Part No SW: 8K0 959 655     HW: 8K0 959 655
   Component: AirbagVW-AU10 H21 0334
   Serial number: 0038GD082S80
   Coding: 30323232333030303030554A305238543053
   ASAM Dataset: EV_AirbaECUVWAUDI010 A02001
   VCID: 7AADF2C2CC57E88784D-802E
   Serial number: 6334LSME1A251070+
   Serial number: 6344LSME1A3027321
   Serial number: 6352QSME2F5330117
   Serial number: 6362QSME2F5C3303L
   Serial number: 63734SME2E0C3111Z
   Serial number: 63834SME2C62780FB
   Part No SW: 8K0 953 568 B    HW: 8K0 953 568 B
   Component: Lenks.Modul   H09 0011
   Revision: --------    Serial number: 90304GF70000Z
   Coding: 000016
Address 17: Instruments (J285)       Labels: None
   Part No SW: 8T0 920 980 M    HW: 8T0 920 980 M
   Component: KOMBIINSTR.   H20 0136
   Revision: 00300000    Serial number: 6C1205M67
   Coding: 2F05010002002600010000
   VCID: 45D7513EF5A9577FB9F-8010
   Part No SW: 8T0 907 468 F    HW: 8T0 907 468 F
   Component: GW-BEM 4CAN-M H07 0084
   Revision: EB002032    Serial number: 3200E076088034
   Coding: 000003
   Shop #: WSC 00762 210 57650
   VCID: 44D14C3AFE936E77AE1-8010
   Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
   Component: J367-BDM  H06 0150
   Serial number: 1700178A100507
02230 - Digital Radio (DAB) (R147)
                    Reset counter: 86
                    Mileage: 152416 km
                    Date: 2019.08.12
                    Time: 17:27:51
Address 1E: Media Player 2 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785 B
   Component: SG ext.Player H15 0850
   Revision: 00000000
   VCID: 2B030786730D810F4FB-807E
   Component: MEM-FS        H08 0027
   Revision: AA000000    Serial number: 00001001004049
   Coding: 08217125002444441000
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
   Component: MNS ECE         H49 1060
   Revision: 00000000    Serial number: 333FT077511984
   VCID: 3B2337C68F6D118FDFB-806E
   Part No SW: 8K0 959 793 A    HW: 8K0 959 793 A
   Component: TSG FA        H08 0149
   Revision:             Serial number: 0VQP
   Coding: 0110022240012201
   VCID: 3E253ED2907F04A7F85-806A
   Revision: 00002001    Serial number: 0104871599
   Coding: 011B068200390440002000
   Component: DWA-Sensor  H02 0030
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 86
                    Mileage: 152416 km
                    Date: 2019.08.12
                    Time: 17:30:20
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 86
                    Mileage: 152416 km
                    Date: 2019.08.12
                    Time: 17:35:32
                    Fault Frequency: 129
                    Reset counter: 134
                    Mileage: 152417 km
                    Date: 2019.08.12
                    Time: 17:46:35
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASM.clb
   Part No SW: 8T0 035 223 P    HW: 8T0 035 223 A
   Component: DSP STD       H07 0250
   Revision: 22S00000
   Coding: 010101
   VCID: 3B2337C6836D118FDFB-806E
   Part No SW: 8K0 959 792 A    HW: 8K0 959 792 A
   Component: TSG BF        H08 0149
   Revision:             Serial number: 0HSP
   Coding: 011002224C012201
   VCID: 3D2739DE9D791FBFE1F-8068
   Part No SW: 8K0 907 801 C    HW: 8K0 907 801 C
   Component: EPB Audi B8   H03 0030
   Revision: 00000003    Serial number: 00000000009369
   VCID: 2F3B13964715FD2F633-807A
   Part No: 8K0 907 357
   Coding: 0000002
   VCID: 72BDDAE298A790C7CCD-8026
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0630
   Revision: 00000000    Serial number: 336FS077510297
   Coding: 0000001
   VCID: 313F15EE5D21EBDF757-8064
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 E    HW: 4E0 919 148
   Component: R0078 TVhybridT     0470
   Revision: R0H06000    Serial number: 76300800482201
   Coding: 0000203
   VCID: 2517F1BE19E9B77F99F-8070
Address 77: Telephone        Labels: 4F1-910-336.lbl
   Part No SW: 4F1 910 336 D    HW: 4F1 862 335
   Component: BTA             H09 1120
   Revision: 00H09000    Serial number: 00000007535628
   Coding: 0010021
End----------(Elapsed Time: 01:51, VBatt start/end: 14.3V/14.4V)-----------
Waxing pedantic: This is a 2008 model, not 2007. In fact, I don't think a 2007 model A5 exists. I'll fix the thread title.
Have you verified all the wiring related to the brake switch?
Ej2_sir
Derby UK
C?ID=373261
Thanks for the reply. Appologies, the date on the v5 is first reg 15/10/17 and its a 57 plate so just assumed it was an 07.
With regards to diagnosis as far as ive got is to confirm the lights work. I also looked at the control module (engine?) And checked that the ecu signal and switch signal were active on pressing the pedal (they were but iirc the ecu lagged slightly behind the switch?) Could you give a brief indication of what to check across tje 4 pins and ill check and report back.
Really appreciate the help!
South Molton, UK
IIRC the switch has two parts - normally open and normally closed when the pedal isn't pressed. The ECU looks for these two parts to always be "opposites".
NostraJackAss
Vehicle Identification No.WAUZZZ8T88A005904
ModelAudi A5 Coupe
Quattro TDI 3.0
A5CO
Date of production05.07.2007
Model year2008
Sales type8T30H9
Engine CodeCAPA
Transmission CodeKMU
Indeed............ https://www.youtube.com/watch?v=OpbdGnJbneE
OP JPPSG
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
RTFB
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
Did you verify fuses first & ground points + all connections, then switch tracks from end to end isolated with load light & if good change switch, if fault persists chance modules intercepting signal?
