06 Jetta 2.0T - EVAP Fault P0455
Burgas
NC, USA
C?ID=376620
The other day I was driving on the way to get gas and my "Check gas cap" light came on, I thought weird but okay. I filled up and put a few extra clicks on the gas cap and then when I started the car it was fairly hard to start. Shortly there after the MIL P0455 came one, as well as a couple other seemingly related vaults during a VCDS scan. As it were, I just swung by the dealership and bought a new gas cap as the rubber ring on mine was looking cracked and the tether to it has broken some time last year and that had been an annoyance that I know had more reason to take care of. I have since fueled up once more and once again the car was hard to start after the fill up. This all makes me think it's the evap/purge valve, N80. It's never been replaced before, and still has those annoying crimp bands on it. I just want to run it by everyone and see if anyone has other ideas before I just start tossing money at the problem, especially since the usually code for a broken N80 is P0441.
Auto-Scan results:
Wednesday,14,August,2019,21:12:32:26167
VIN: 3VWKJ71K66M6xxxx   License Plate:
Mileage: 342700km-212943mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 56 62 72
VIN: 3VWKJ71K66M6xxxx   Mileage: 342700km-212943miles
   Part No SW: 1K0 907 115 B    HW: 1K0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: --H10---    Serial number: VWZ7Z0E2568520
   Coding: 0403010A18070160
   Shop #: WSC 66565 257 00032
   VCID: 2517F1E459E7655F99F-8070
012555 - Low Pressure Fuel regulation
               P310B - 004 - Fuel Pressure Outside Specification
                    Fault Frequency: 39
                    Mileage: 341260 km
                    Time: 23:06:47
                    RPM: 814 /min
                    Load: 29.4 %
                    Speed: 13.0 km/h
                    Temperature: 94.0°C
                    Temperature: 51.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 13.462 V
               P310B - 008 - Fuel Pressure Outside Specification - Intermittent
                    Mileage: 341760 km
                    Time: 17:10:45
                    RPM: 877 /min
                    Load: 16.9 %
                    Temperature: 101.0°C
                    Temperature: 56.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.716 V
001109 - EVAP System
               P0455 - 001 - Large Leak Detected - MIL ON
                    Fault Status: 11100001
                    Mileage: 341870 km
                    Time: 07:37:58
                    RPM: 2001 /min
                    Load: 21.2 %
                    Speed: 82.0 km/h
                    Temperature: 81.0°C
                    Temperature: 23.0°C
                    Voltage: 13.843 V
004243 - Bank 1; Fuel Measuring System 2
               P1093 - 008 - Malfunction - Intermittent
                    Mileage: 342400 km
                    Time: 21:56:35
                    RPM: 1740 /min
                    Load: 11.4 %
                    Speed: 35.0 km/h
                    Temperature: 95.0°C
                    Temperature: 39.0°C
                    Voltage: 13.589 V
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Revision: 00T12001
   Coding: 0021122
   Shop #: WSC 00066 000 00000
   VCID: 40D94070A685A0778A9-8014
   Part No: 1K0 907 044 BA
   Component: ClimatronicPQ35 066 0606
   VCID: 678BBBECE36BB74F6B3-8032
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000000121550
   Coding: 05058E234004180000140000001400000028770B5C
   Shop #: WSC 09449 444 52571
   VCID: 2B0307DC3F03532F4FB-807E
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 09449
                    Fault Status: 00101100
                    Reset counter: 199
                    Mileage: 341669 km
                    Voltage: 12.30 V
                    Fault Status: 01101100
                    Reset counter: 169
                    Mileage: 341218 km
                    Voltage: 13.65 V
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW: 8E0 035 593 E
   Component: SDAR XM         H03 0080
   Revision: 00000000    Serial number: AUZ4Z7E3031320
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 166
                    Mileage: 28901 km
                    Time: 00:08:59
02788 - Internal Communications Error
                    Fault Frequency: 147
                    Reset counter: 209
                    Mileage: 341218 km
                    Time: 17:28:49
                    Bin. Bits: 00000010
                    Bin. Bits: 00000000
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD038G8Z
   Coding: 0012627
   VCID: 2E050EC80C112607685-807A
   Subsystem 1 - Part No: 1K0 959 339 B
   Component: BF-Gewichtsens. 006 0003
   Subsystem 2 - Serial number: 6332MSME0A4A4F29P
   Subsystem 3 - Serial number: 6342MSME0A3F3811D
   Subsystem 4 - Serial number: 6351HSME075E432BD
   Subsystem 5 - Serial number: 6361HSME0759656EK
   Subsystem 6 - Serial number: 63727SME0A174021S
   Subsystem 7 - Serial number: 63827SME072B1A383
01587 - Igniter 2 for Airbag; Drivers Side (N250)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
   Part No SW: 1K0 953 549 AJ    HW: 1K0 953 549 AJ
   Component: J0527           034 0070
   Coding: 0002021
   VCID: 7AADF29880D93AA784D-802E
   Component: E0221           007 0050
01426 - Controls in Steering Wheel (E221)
   Part No: 1K0 920 972 C
   Component: KOMBIINSTRUMENT 3HL 1212
   Coding: 0023203
   VCID: 2C0104C03A0D5417461-8078
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001056168AD9
   Coding: 3D7F03600F1002
   VCID: 2A0D02D830F94A27B4D-807E
   Part No SW: 1K5 919 965 A    HW: 1K5 919 965 A
   Component: Kompass         005 0003
   Revision: 00005000    Serial number: 1293324T05CJ01
   Coding: 0000003
   VCID: 392F2D94C55FF1BFCD7-806C
   Component: IMMO            3HL 1212
   Shop #: WSC 09215 444 101392
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 B    HW: 3C0 959 760 B
   Component: Sitzverstellung     0701
   Revision: 00003000    Serial number: 00000000000000
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2377
   Coding: 0001269
   VCID: 363526A8F4411EC7205-8062
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 323D1AB8182902E70CD-8066
   Part No SW: 1K0 959 433 AT    HW: 1K0 959 433 AT
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 13900E880106083F2D04050FB0080F0480A540
   VCID: 025D8A78E8097267DCD-8056
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 142
                    Mileage: 341564 km
                    Time: 16:30:20
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 372B2BACF34BE7CF3B3-8062
   Part No SW: 1K0 035 180 C    HW: 1K0 035 180 C
   Component: Radio DE2       011 0014
   Revision: 00011000    Serial number: VWZ4Z7E2036415
   Coding: 0040400
   VCID: 2019E0F046C58077EA9-8074
00877 - Treble Speaker Rear Right (R16)
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2434
   Coding: 0000144
   VCID: 313F15B41D2F39FF757-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
End----------(Elapsed Time: 01:10, VBatt start/end: 12.2V/12.2V)-----------
Burgas
NC, USA
C?ID=376620
Thanks for the suggestions. I'll check the low pressure pump duty cycle this evening, and look into how to check the injectors and what values they should be at.
The G410 sensor is one I've replaced either once or twice, I can't recall what fault it threw back then. When I first got the VCDS cable back in early August I scanned my car (I mostly got it to help diagnose my girlfriend's Jetta), I saw the P310B faults, but everything else was acting normally. The P0441 MIL and hard start issue occurred a week or so later.
Overall the car drives fine, the idle might be more rough than it used to be, but it is not down on power or anything. The fuel filter is getting replaced soon as I realized it has 100k on it and even if it isn't the main issue, it's time for a new one.
Burgas
NC, USA
C?ID=376620
I replaced the N80 valve today, and while I don't think it's the only problem, it was a problem as it was allowing air to pass both ways when I tested it. After installing the new N80 I cleared all faults and went for a drive. At first start up no engine faults existed, which is different from how it had been acting, previously those P310Bs came back immediately.
This morning, with low fuel before the N80 was replaced, and then this evening with a full tank and the N80 replaced I drove around and kept an eye on 106.2, the value for the low pressure fuel pump duty cycle. In the first 5-10 minutes of driving it was pretty chill at 50%, but as I drove more when I would idle it would start climbing, and then would dip and go back as I drove around. Eventually after about half an hour of driving when I would idle the duty cycle would be 91.8%. So that seems suspect. The two P310B faults had come back by the time I got home and a pending ODB-II fault now exists, P0089, which if memory serves is that N290 valve on the HPFP.
Full disclosure, the car is running the Unitronic Stage 2 HPFP map with the Autotech high volume fuel pump kit. I don't think that's playing a part in this, but just wanted to let it be known.
Friday,16,August,2019,21:05:33:26167
VIN: 3VWKJ71K66M6xxxxx   License Plate:
Mileage: 343000km-213130mi   Repair Order:
VIN: 3VWKJ71K66M6xxxx   Mileage: 343000km-213130miles
                    Mileage: 342988 km
                    Time: 20:43:04
                    RPM: 2390 /min
                    Load: 8.6 %
                    Speed: 48.0 km/h
                    Temperature: 93.0°C
                    Temperature: 48.0°C
                    Voltage: 13.589 V
                    Mileage: 342998 km
                    Time: 20:53:19
                    RPM: 3430 /min
                    Load: 8.6 %
                    Speed: 93.0 km/h
                    Temperature: 94.0°C
                    Temperature: 34.0°C
                    Voltage: 13.843 V
Readiness: 0000 0100
   Revision: 00T12001
   Coding: 0021122
   Coding: 00065493
   Shop #: WSC 09449
                    Reset counter: 176
                    Mileage: 342976 km
                    Voltage: 12.65 V
            014 - Defective
                    Reset counter: 166
                    Mileage: 28901 km
                    Time: 00:08:59
                    Reset counter: 216
                    Mileage: 342976 km
                    Time: 20:08:12
                    Bin. Bits: 00000010
                    Bin. Bits: 00000000
   Coding: 0012627
   Coding: 0002021
   Coding: 0023203
   Coding: 0000003
   Coding: 0001269
   Coding: 0001269
   Coding: 0040400
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:11, VBatt start/end: 13.7V/13.8V)-----------
Friday,16,August,2019,21:06:13:26167
Mode 07: Pending emission related fault codes
Address 7E8: 1 Fault Found:
P0089 - Valve for Fuel Metering (N290): Implausible Signal
NostraJackAss
Glad you came clean the car is dirty. :p
Holy boot strapped duty cycles!
Burgas
NC, USA
C?ID=376620
Having filled up the gas tank since replacing the N80 valve I can confirm that was the source of the post fill up hard starting.
No evap related faults or issues have returned either.
The high duty cycle remains a concern, but first I want to replace the fuel filter and see where it's at after I do that.
