Upgrade of a midline 5K0-953-569-C SWCM to a highline module - which one to use?
owdi
C?ID=147985
Hi all, have a 2011 Tiguan (manual gearbox) it needs an upgrade of the SWCM to allow retrofit of a Multi Function Steering Wheel. Using the Ross-Tech list I see that 5K0-953-569-C is a Midline controller, supporting MFD, ACC, but not MFSW. I know I need a highline SWCM however on the Ross-Tech table for the column "Steering Angle Sensor" 5K0-953-569-C shows as "TBD" so I don't know if I should be choosing one that has a "Yes" or a "No" from the Steering Angle sensor column. Anyone upgraded this specific SWCM successfully and which SWCM did you use to replace it? Apologies in advance, I don't have access to a VCDS scan of this vehicle as it's in a different city to me.
golfi_vend
Tartu, Estonia
C?ID=195131
Depends on the steering rack. UK being RHD should have at this year ZF3 steering rack with integrated steering angle sensor.
Can't give better answer without seing actual scan.
owdi
C?ID=147985
Thanks golfi_vend. I did get some information from the owner, but not from a VCDS scan, from another diagnostic tool -
44 Steering Assistance
Part number: 5N0-909-144P
EPS_ZFLS K1.203
3501
ECU Coding:0000000
Serve station code:54412
03 Brake Electronics
Part number: 5N0-614-109-Q
J104 C4 450 V253
0006
Ecu Coding:0031020
Serve station code:01324
16 Steering 5K0953421BJ
Hardware version:014
Software version:0140
Serial number:201104183001
FAZTT idenfitication:ATW-00120.04.11P3TC0337
Revision:FF010040
Theft Prot.UDS/CAN/ISO15765/LIN 2.0:00.00.01/12.07.00/01.02/12/00.0e.01
Hardware part number:5K0953569C
Workshop System Name:J527
Code:30 30 30 30 30 30 30 30
South Molton, UK
A full unedited VCDS Auto-Scan would be much more help...
Petar001
Croatia
C?ID=361578
doing same thing on Tiguan,
i have 5K0-953-569-J that is midline and says TBD for Angle sensor but i confirm that it has Sensor and sent to Dana all info so mow is changed ;)
i bought Highline modul 5K0-953-569-AH same thing regarding Angle sensor info says TBD but this one 100% doesn't have Angle sensor.
so you are in same situation as me.
to be sure if you have sensor or not you must see coding of SWCM it is Byte0, bit 0
golfi_vend
Tartu, Estonia
C?ID=195131
Well 5N racks are APA, and these, at least LHD don't have angle sensor integrated, only external fitted inside of SWCM.
owdi
C?ID=147985
So your original sensor is a "J" which has a "Yes" in the steering angle sensor column, but you are swapping to an "AH" which has a "No" in the steering angle sensor column?
owdi
C?ID=147985
So in my case with having a rack "5N0-909-144P" we assume the rack has no sensor and the sensor is integrated in the SWCM, so the original SWCM "5K0-953-569-C" we can assume does have a sensor and so must it's replacement?
Petar001
Croatia
C?ID=361578
that is not possible, not working
before today
"J" regarding angle was - TBD: We do not have information on the configuration at the present time.
so as
"AH" was same description on Wiki page for angle
so i bought to Upgrade to MFSW but i learned hard way that "AH" doesn't have Angle sensor.
Hi guys,
The following changes were made after Petar001 sent his feedback:
http://wiki.ross-tech.com/wiki/inde..._Control_Module_Versions&diff=8722&oldid=8503
I ran searches of our local scans as well and verified his testing matched factory configured scans so the 5K0-953-569-J and 5K0-953-569-AH info should be accurate at this time on the current page.
Generally speaking using the current day direct replacement for the factory installed 16 module is best. The problem is, if the 16 module isn't faulty and you are retrofitting 1) you need to verify that the direct replacement supports the retrofit and 2) need to determine if the cost of new is worthwhile (when compared to getting a used unit with older part number).
In owdi's case it would be significantly easier based on a factory condition VCDS Auto-Scan from this vehicle however all of our scans with HW#5K0 953 569 C are from Golf based cars (1Z/3T/5L/1P) with manual transmissions and ZF3 steering racks so the internal G85 coding is NOT active.
Based on this info 5K0-953-569-C doesn't look like a module that would have been factory installed in a 5N Tiguan with APA rack.​
I'll edit the TBAs related to 5K0-953-569-C on the Wiki page based on the MT and ZF3 info above but it would be ideal if you could post the scans and and any error messages when attempting to add Steering Angle Sensor (G85) connected to Steering Wheel Control Module (J527) using VCDS.
owdi
C?ID=147985
Thanks Dana / Petar001 / Golfi_vend for your inputs. I'll try to get a full VCDS scan of the Tiguan eventually and will update this post with it.
m87a
Bosnia and Herzegovina
C?ID=156900
Control Module Variant G85 MFD CCS MFSW AT
5K0-953-569 Midline No Yes Yes No Yes
5K0-953-569-A Highline No Yes No Yes Yes
5K0-953-569-B Highline No TBD Yes Yes Yes
5K0-953-569-C Midline No Yes Yes No No
5K0-953-569-D Highline No TBD No Yes Yes
5K0-953-569-E Highline No Yes Yes Yes Yes
5K0-953-569-F Midline Yes Yes Yes No Yes
5K0-953-569-G Highline Yes Yes No Yes Yes
5K0-953-569-H Highline Yes Yes Yes Yes Yes
5K0-953-569-J Midline Yes Yes Yes No No
5K0-953-569-K Highline Yes TBD No Yes No
5K0-953-569-L Highline Yes Yes Yes Yes Yes
5K0-953-569-R Highline Yes Yes Yes No Yes
5K0-953-569-S Highline Yes Yes No Yes Yes
5K0-953-569-T*see note Highline Yes Yes Yes Yes Yes
5K0-953-569-AA Midline Yes Yes Yes No Yes
5K0-953-569-AB Highline Yes Yes Yes Yes No
5K0-953-569-AC Midline No Yes Yes No Yes
5K0-953-569-AD Highline No Yes No Yes Yes
5K0-953-569-AE Highline No Yes Yes Yes Yes
5K0-953-569-AF Midline No Yes Yes No No
5K0-953-569-AG Highline No Yes No Yes No
5K0-953-569-AH Highline No Yes Yes Yes Yes
5K0-953-569-AJ Midline Yes Yes Yes No Yes
5K0-953-569-AK Highline Yes Yes Yes Yes Yes
5K0-953-569-AL Highline Yes Yes Yes* Yes Yes
5K0-953-569-AM Midline Yes Yes Yes No No
5K0-953-569-AN Highline Yes Yes No Yes No
5K0-953-569-AP Highline Yes Yes Yes Yes No
5K0-953-569-AR Highline Yes Yes No Yes Yes
5K0-953-569-AS Highline Yes Yes Yes Yes Yes
5K0-953-569-BA Highline Yes Yes Yes Yes Yes
5K0-953-569-BB Midline Yes Yes Yes No No
5K0-953-569-BC Highline No Yes No Yes Yes
5K0-953-569-BD Highline No Yes Yes Yes Yes
5K0-953-569-BE Midline No Yes Yes No Yes
5K0-953-569-BF Highline No Yes Yes Yes No
5K0-953-569-BG Highline No Yes Yes Yes No
5K0-953-569-AK may support 8T2 - Cruise control system (CCS) electronic with 2ZH Leather multi-function steering wheel controls. That should be cruise control via MFSW buttons but feel free to post in our forum if needed.
**Even if module does support CCS, older ECU doesn't support communication with this module and CCS doesn't work even if retrofitted and coded, so no go.
Hi Muhamed,
Thanks for the contributions over in the Eos thread. I updated 5K0-953-569-E but I missed this when doing so.
I'll take a look at the scans we have from 5K0-953-569-AK but if you happen to have a scan, or car-specific failed retrofit feedback, don't hesitate to post it here.
m87a
C?ID=156900
NP Dana, I have cross check all of the data from wiki and updated it in post above...
I don't have a scan, but I have failed a retrofit with brand new steering wheel from polo and AK module which does support GRA MFSW but, in the end we gave up and decided it's not worth it to play with ECU just to be able to activate cruise control from mfsw
5K0 953 549 R, S, T, AA, AB, AQ, AR, AS, AT, BA only these models support PQ46 ESCL and won't cause DTC: 02823 - Requirements for Locking the Steering Column Lock not met.
Sorry for hijacking thread...
Thanks. I came up with conflicting info on 5K0-953-569-AK. Most were vehicles with MK6 (LIN 2.0) MFSW steering wheels without CCS. One 2016 (7N235Y) Sharan had 8T2 CCS .. but I don't have permission to post that scan. The short of it was:
Address 01: Engine (J623-CUVC)       Labels: None
   Part No SW: 04L 906 016 BL    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 1735
   Coding: 011D001A042411082000
   Part No SW: 02E 300 063 B    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4902
   Part No SW: 5N0 614 109 CD    HW: 5N0 614 109 CD
   Component: ESC-EBC460iV1 H10 0012
   Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
   Component: BCM PQ35 M    122 0183
   Part No SW: 5K0 953 501 CP    HW: 5K0 953 569 AK
   Coding: 1982440008
   Subsystem 1 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Component: E221__MFL-TAT  H04 0019
   Coding: 280000
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.324 1401
A handful were retrofits or wrong new parts including a crash repaired 2015 GLI with Mk7 type wheel and inoperative CCS functions (likely due to wring parts) so I'm conflicted on that one.
I'll go through your list and make some edits to that page in the meanwhile.
No worries about hijacking the thread. We can always split this off to another thread but I'm subscribed to this one already and the e-mail reminders help me stay on top of new contributions.
I edited the Part Number 5K0-953-569 section of that page again. Feedback/corrections welcome. I figured the easiest way to note PQ46 ESCL was with a new column.
The ones I left alone are:
*5K0-953-569-AK
No* with a note is prob best so we don't encourage anyone to buy and install it. We can always revisit that part number later.​
* 5K0-953-569-AQ
and
* 5K0-953-569-AT
I don't have scans from either of those part numbers and they weren't in the Wiki list. I can check the parts catalog, forums, etc ... and update as needed.​
AQ and AT added as of 2/19/2020
m87a
C?ID=156900
Ok no problem, glad to help, yes I agree about AK, no issues there.
Control Module Variant G85 MFD CCS MFSW AT PQ45 ESCL
5K0-953-569-AQ TBD Yes Yes No No Yes Yes
5K0-953-569-AT TBD Yes Yes No No No Yes
I have been informed by TinyQ that this is his data and that it's copied and that it's incorrect, I'm waiting for his confirmation and permission.
All the credits to TinyQ
