First time posting. Blough Automotive is a VW specifice used car dealership and repair facility. We buy auction cars and rebuild them for re sale along with general service of VW jettas, tiguans, ect. Below is an auto scan of a repairable vehicle that has lost its abs coding. Please ignore other codes as the vehicle is in the middle of rebuild. We would like to solve the coding issue with the abs module prior to investing in further repair. Any help would be greatly appreciated. I have seen on other threads where people have been able to come up with long coding numbers to try. If possible I would like to know where and how they are able to come up with the code so I may write my own in the future.
Tuesday,13,August,2019,08:56:37:20258
VCDS Version: 19.6.1.0
VIN: 3VW4T7AJ6GM246967 License Plate:
Mileage: 23300km-14477mi Repair Order: 318
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 25 2B 3C 42 44 46 47 4F 52
55 5F 62 72 75
VIN: 3VW4T7AJ6GM246967 Mileage: 23300km-14477miles
Address 01: Engine (J623-CPPA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 071 AT HW: 06K 907 425 C
Component: R4 2.0l TFS H13 2346
Revision: --H13---
Coding: 001D0012242400171000
Shop #: WSC 00066 000 00018
ASAM Dataset: EV_ECM20TFS02006K906071AT 001003
ROD: EV_ECM20TFS02006K906071AT.rod
VCID: 7DFA0D63ECBE4CA7F2-8028
16837 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 00 [175] - Signal too High
Mileage: 23303 km
Date: 2019.07.18
Time: 02:35:00
Engine speed: 0.00 /min
Coolant temperature: 46 °C
Intake air temperature: 22 °C
Voltage terminal 30: 11.738 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 97 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
FAC_TPS_1_SAE: 17.968750 %
FUP_H_SAE: 15390.0 kPa
17791 - Coolant Pump Control Circuit
P2600 00 [047] - Open
Mileage: 23303 km
Date: 2019.07.18
Time: 02:35:02
T_AST_SAE: 0 s
MAP_MES_SAE: 97 kPa
FUP_H_SAE: 15400.0 kPa
15252 - Relay for Secondary Air Injection Pump (J299)
P0418 00 [237] - Malfunction
Mileage: 23303 km
Date: 2019.07.18
Time: 00:34:16
Engine speed: 1725.50 /min
Normed load value: 14.5 %
Coolant temperature: 16 °C
Intake air temperature: 18 °C
Voltage terminal 30: 11.406 V
Engine: operating status: IS
STATE_LS_SAE[1]: OL_CDN
T_AST_SAE: 0 s
MAP_MES_SAE: 39 kPa
FAC_TPS_1_SAE: 14.843750 %
FUP_H_SAE: 7820.0 kPa
18876 - Cruise Control Switch (E45)
P0568 00 [047] - Implausible Signal
Fault Frequency: 25
Mileage: 23303 km
Date: 2019.07.18
Time: 02:35:00
ACC variants (coding): CCS
CCS Switch: CCS operating unit
Cruise control switch actuation-Main switch: not activated
Cruise control switch actuation-Setting: not activated
Cruise control switch actuation-Activation: not activated
Cruise control switch actuation-Accelerate: not activated
Cruise control switch actuation-Decelerate: not activated
Cruise control switch actuation-Cancel: not activated
Cruise control switch actuation-Main switch hardware: not activated
Cruise control switch actuation-Limit button: not activated
Cruise control switch actuation-Main switch CAN: not activated
Cruise control switch actuation-Large increment: not activated
Cruise control switch actuation-Control component verified: No
ACC variants: ACC
26384 - Databus
U1123 00 [109] - Received Error Message
Mileage: 23303 km
Date: 2019.07.18
Time: 01:40:36
Engine speed: 1147.75 /min
Normed load value: 25.9 %
Vehicle speed: 15 km/h
Coolant temperature: 76 °C
Voltage terminal 30: 13.691 V
Engine: operating status: PL
STATE_LS_SAE[1]: CL
T_AST_SAE: 4001 s
MAP_MES_SAE: 60 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.904 V
FAC_TPS_1_SAE: 14.062500 %
FUP_H_SAE: 17020.0 kPa
19854 - Steering Column Control Module
U0212 00 [047] - No Communications
Mileage: 23303 km
Date: 2019.07.18
Time: 02:35:00
ECU_STATE: ENG_STOP
Engine oil temperature: 28.0 °C
Time since engine start: 0.0 s
T_ES: 17 min
STATE_ERR_ABC_PRED: 5
Readiness: 1010 0101
Part No SW: 02E 300 063 P HW: 02E 927 770 AL
Component: GSG DSG AG6 531 4907
Revision: 06253104 Serial number: 00001507051438
Shop #: WSC 02069 000 90108
VCID: 234E1B1BE29ADA57A4-8076
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527)
Mileage: 23303 km
Date: 2019.08.13
Time: 00:05:24
28907 - No Communications with Cruise Control (Front) Distance Sensor
U0235 - 000 - - Intermittent
Mileage: 23303 km
Date: 2019.08.13
Time: 05:50:14
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
Shop #: WSC 00066 000 00000
VCID: 75EA1543DC8E14E7BA-8020
10 Faults Found:
03842 - RPM Sensor Rear Right: Incorrect Signal
Reset counter: 7
Mileage: 23303 km
Date: 2019.08.13
Time: 00:06:32
Count: 7
Count: 12
Count: 20480
Count: 87
Count: 42752
Count: 256
03841 - RPM Sensor Rear Left: Incorrect Signal
Reset counter: 7
Mileage: 23303 km
Date: 2019.08.13
Time: 00:06:32
Count: 7
Count: 12
Count: 20480
Count: 71
Count: 42752
Count: 256
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Reset counter: 222
Mileage: 917761 km
Date: 2055.08.00
Time: 16:05:15
Count: 256
Count: 54494
Count: 256
Count: 38
Count: 212
Count: 256
Count: 12766
Count: 256
Reset counter: 222
Mileage: 23303 km
Date: 2019.08.13
Time: 02:15:33
Count: 16386
Count: 12800
Count: 54
Count: 49926
Count: 59904
Count: 768
Count: 3072
Reset counter: 222
Mileage: 526602 km
Date: 2001.00.00
Time: 16:08:13
Count: 1283
Count: 307
Count: 56832
Count: 128
Count: 257
Count: 9985
Count: 270
Count: 56833
Fault Status: 01100101
Reset counter: 222
Count: 16386
Count: 12
Count: 212
Count: 45056
Count: 256
Reset counter: 222
Count: 16386
Count: 12
Count: 279
Count: 45056
Count: 256
Reset counter: 222
Count: 16386
Count: 12
Count: 295
Count: 45056
Count: 256
Reset counter: 222
Count: 16386
Count: 12
Count: 270
Count: 45056
Count: 256
Reset counter: 222
Mileage: 23303 km
Date: 2019.08.13
Time: 00:06:21
Count: 2
Count: 12
Count: 20480
Count: 297
Count: 44032
Count: 256
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0374283187
Coding: 030C0C
Shop #: WSC 00066 000 00295
VCID: 3776DF4B8E02A6F768-8062
65813 - Supply voltage
Reset counter: 7
Part No SW: 1K8 907 044 AR HW: 1K8 907 044 AR
Component: Climatronic H05 0304
Revision: 00001K02
Coding: 0050019002
Shop #: WSC 00066 000 00319
VCID: 7F06F76BE6B25EB7E0-802A
B10AB F0 [009] - Too Low
Reset counter: 221
Mileage: 23303 km
Date: 2019.08.13
Time: 00:03:35
Part No SW: 5K0 937 087 AJ HW: 5K0 937 087 AJ
Component: BCM PQ35 H+ 122 0183
Revision: BL122001
Coding: EF200A1A902F06D40188008124000D4C0174000845A08DB2E4842000A040
VCID: 7DFA0D63E4BE4CA7F2-8028
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 250615 05 54 0403
Coding: 02300A
7 Faults Found:
Reset counter: 7
Mileage: 23303 km
Date: 2019.08.13
Time: 00:07:01
Voltage: 11.45 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 222
Mileage: 23303 km
Date: 2019.08.13
Time: 00:00:01
Voltage: 11.95 V
Reset counter: 222
Mileage: 23303 km
Date: 2019.08.13
Time: 00:00:01
Voltage: 11.95 V
Reset counter: 222
Mileage: 23303 km
Date: 2019.08.13
Time: 00:00:01
Voltage: 11.95 V
Reset counter: 222
Mileage: 23303 km
Date: 2019.08.13
Time: 00:00:01
Voltage: 11.95 V
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
Reset counter: 221
Mileage: 23303 km
Date: 2019.08.13
Time: 00:03:39
Voltage: 11.85 V
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Reset counter: 221
Mileage: 23303 km
Date: 2019.08.13
Time: 00:03:39
Voltage: 11.85 V
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0479
Revision: -------- Serial number: 39311520205556
Coding: 0071155011
ASAM Dataset: EV_EPHVA18VW364GP00 001006
ROD: EV_EPHVA18VW364GP00_VW32.rod
VCID: 3668D24F89085FFF73-8062
1113107 - Front Parking Aid Sensor(s)
B10FC 13 [008] - Open Circuit
Reset counter: 222
Mileage: 23303 km
Date: 2019.08.13
Time: 00:16:48
U1400 00 [008] - -
Reset counter: 7
Mileage: 23303 km
Date: 2019.08.13
Time: 00:27:33
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 561 959 655 HW: 561 959 655
Component: AirbagVW11 001 0207
Serial number: 003RXM00YFRW
Coding: 8CCCF000000000005000001AC20800000065
Shop #: WSC 00066 790 00012
ASAM Dataset: EV_AirbaVW11SMEVW411 001002
ROD: EV_AirbaVW11SMEVW411_VW32.rod
VCID: 63CE5B1B6A1A9A57E4-8036
Component: BF-Gewichtss. H11 0021
Serial number: IBH000000000003DDMDO
Coding: 30314C
Subsystem 2 - Part No SW: ----------- HW: 480 001 806 15
Serial number: 35700000000D1145F41G
Subsystem 3 - Part No SW: ----------- HW: 480 001 806 15
Serial number: 3580000000022145F417
Subsystem 4 - Part No SW: ----------- HW: 480 022 107 15
Component: SideSensor_Dr 000 0148
Serial number: 3510001C31B2C526751Y
Subsystem 5 - Part No SW: ----------- HW: 480 022 107 15
Component: SideSensor_Pr 000 0148
Serial number: 3520001C31B2C52103FZ
Subsystem 6 - Part No SW: ----------- HW: -----------
Component: FrontSensor_D --- ----
Serial number: -------------------$
Subsystem 7 - Part No SW: ----------- HW: -----------
Component: FrontSensor_P --- ----
B1000 1B [137] - Resistance Too High
Mileage: 23303 km
Date: 2019.08.13
Time: 00:03:38
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 23303 km
Date: 2019.08.13
Time: 00:03:40
9444117 - Front Passenger's Front Airbag Crash Sensor
B101B 15 [137] - Open or Short to Plus
Mileage: 23303 km
Date: 2019.08.13
Time: 00:03:40
B10B4 00 [008] - Function Restriction due to Undervoltage
Reset counter: 7
Mileage: 23303 km
Date: 2019.08.13
Time: 00:28:14
Part No SW: 1K5 953 521 CR HW: 5K0 953 569 BF
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20150720200140
Coding: 0012440008
ROD: EV_SMLSNGVOLWSR8C.rod
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 7
Mileage: 23303 km
Date: 2019.08.13
Time: 00:27:33
365080 - Controls in Steering Wheel
U108E 00 [009] - No Communications
Reset counter: 222
Mileage: 23303 km
Date: 2019.08.13
Time: 00:06:13
Part No SW: 5C6 920 985 C HW: 5C6 920 985 C
Component: KOMBI H04 1009
Coding: 271E010000
VCID: 3260EE5F656043DF5F-8066
Part No SW: 7N0 907 530 BC HW: 7N0 907 530 AN
Component: J533 Gateway H56 1663
Revision: H56 Serial number: 28071503000548
Coding: 351032
VCID: 72E02E5FADE003DF9F-8026
Component: IMMO H04 1009
Coding: 000007
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6AD0363F8D30CB1F27-803E
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 15000175260005
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3064E4576B6C71CF29-8064
U1400 00 [008] - -
Reset counter: 7
Mileage: 23303 km
Date: 2019.08.13
Time: 00:27:37
ELV State: 0C
Information Clamps: 77 60
CoCo State: B0 01
WFS State: 67 1A
Vehicle speed: 0.00 km/h
Voltage: 4A
1049345 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [008] - Performance
Reset counter: 7
ELV State: 0A
Information Clamps: 00 00
CoCo State: F0 01
WFS State: 00 1A
Vehicle speed: 655.35 km/h
Voltage: 2F
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0372940763
Coding: 02011102
Shop #: WSC 00066 790 00295
ROD: EV_HREntryHella_VW32.rod
VCID: 3C7CC067B72485AF85-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0373662439
Coding: 020111
U1400 00 [008] - -
Reset counter: 6
Component: TUER-SG FT 002 0515
Revision: 13110009 Serial number: 0009945611
Coding: 0404BD
Shop #: WSC 00066 790 00192
VCID: 5BBE63FB526AA297AC-800E
Slave Driver:
Subsystem 1 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Serial number: 14102587150806035755
Coding: 800000
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 222
131584 - Motor for Rear Window Regulator
B11EE 54 [009] - Missing Calibration / Basic Setting
Reset counter: 222
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 306 3501
Revision: 00H22000
VCID: 3972D9737016B0879E-806C
Fault Status: 00101101
Reset counter: 3
Mileage: 23303 km
Date: 2019.07.18
Time: 02:37:16
Voltage: 11.75 V
DD
Temperature: 18.0°C
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 12.3 V
PD
Temperature: 20.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0065849
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: 28540C3753BC390FF1-807C
9462035 - Front Left Treble Speaker
B1061 13 [008] - Open Circuit
Reset counter: 5
Mileage: 23303 km
Date: 2019.07.18
Time: 00:02:56
9462803 - Front Right Treble Speaker
B1064 13 [008] - Open Circuit
Reset counter: 5
Mileage: 23303 km
Date: 2019.07.18
Time: 00:02:56
U1400 00 [008] - -
Reset counter: 4
Mileage: 23302 km
Date: 2019.07.18
Time: 09:13:56
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1663
Coding: 01030100
VCID: 6FE6272BBED22E3770-803A
Subsystem 1 - Part No SW: 5K0 959 591 A HW: 6R0 959 591 D
Component: J245 PS41.402 H03 0004
Serial number: 0000FST000CGRYH00000
Coding: 180000
Component: TUER-SG BT 002 0515
Revision: 15110009 Serial number: 0009931221
Coding: 0404BC
VCID: 5CBC60E75764A5AFA5-8008
Slave Passenger:
Subsystem 1 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Serial number: 14202586150821045214
Coding: 800000
Reset counter: 222
Reset counter: 222
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H05 0111
Coding: 081200010B000200
Shop #: WSC 01383 790 50316
13679104 - Local Data Bus
U10BA 00 [137] - No Communication
Reset counter: 222
Mileage: 23303 km
Date: 2019.08.13
Time: 00:03:36
Part No SW: 5C0 035 684 HW: 5C0 035 684
Component: MU-S-NS-US H21 0241
Serial number: VWZAZ2R0356515
Coding: 02630102AA00000051220003001808001F0100D400200105C6
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 62C05E1F7500935FEF-8036
Subsystem 1 - Part No SW: 3G0 919 866 B HW: -----------
Component: NAR 2015/16 --- 0220
U1400 00 [008] - -
Reset counter: 7
Mileage: 23303 km
Date: 2019.08.13
Time: 00:27:43
Voltage terminal 30: 8.3 V
1637 - Interface for External Media
U11B8 00 [009] - No Communications
Reset counter: 221
Mileage: 23303 km
Date: 2019.08.13
Time: 00:03:36
Voltage terminal 30: 11.9 V
Interface for external media: status-Status: Open circuit
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0156
Serial number: 000003554140541
Coding: 02630102C24232107F1606000000
ASAM Dataset: EV_OCULow 002009
ROD: EV_OCULow_002.rod
VCID: 142C48C7FF34ADEF2D-8040
U1400 00 [008] - -
Reset counter: 7
Mileage: 23303 km
Date: 2019.08.13
Time: 00:27:15
End-------------------------(Elapsed Time: 04:28)--------------------------
