You could connect it to a Windows 8 tablet.ok..so you can not connect a hex can usb to a tablett?
This might be the only reason I can think of to use this Surface. I will give it a shot and see what I can learn. It's certainly better as a logging device than any of the laptops I have!You could connect it to a Windows 8 tablet.
There are viable Win 8.1 tablet options for cheap, such as an HP Stream 7 for under $100. That's what I'm using VCDS on with micro-CAN dongle. Works quite well though there is a learning curve for not having a real keyboard among other things.You could connect it to a Windows 8 tablet.
I'm not Bruce, but I can answer your question. VCDS will work perfectly on a Windows 10 tablet. I have 2 tablets running Windows 10 and both run VCDS without a problem. The biggest issue is usually in finding a tablet with a full size USB A connector for the cable. An OTG adapter will work but those micro USB connectors in tablets can be damaged fairly easily. I prefer a tablet with a full size USB connector.Hey Bruce I know this is an old thread. I'm wondering if the VCDS "wired" will work on a Windows 10 tablet. I can't find Windows 8 tablets anymore.
Tony
I have seen several that will work well. My personal favorite (because it is cheap) is branded as an RCA Cambio 10.1". It is a quad core Intel Atom with a detachable keyboard and it has a full size USB connector for your cable and that USB connector is on the tablet part (I've seen some nice ones with the USB on the keyboard part). The best part is that I only paid $89.95 for it at WalMart.com. You should be able to find it for under $100 (US).Hi Don thanks for the info. I got a tablet Samsung Android and it will not work with my 10 year old VCDS. I will exchange it tomorrow for a Windows 10
tablet. Is any particular one preferred?
Tony
