AC Woes Please Help
S.O.S
Trinidad and Tobago
LP/IP
Hello my ac is not working and this code is active in the hvac and central control unit
00457 - Control Module for Network (J519)
013 - Check DTC Memory
I have searched all over mostly people who get this code will get it with the temp sensor and or the ac pressure switch sensor as stated in the TSB regrading this fault code but I only get this code nothing else.
I drained the system and changed the control valve solenoid on the compressor inspected the oil in the compressor it was clean vacuumed the system and recharged the system to spec 550g using my scale everything was good until i shut off the vehicle and started back up now the compressor does not turn on.
vehicle is a 2008 jetta with a 2.0fsi non turbo engine and a denso variable displacement compressor thanks.
Please post an Auto-Scan for context.
PS: This does not belong in Forum Support & Feedback. Moving to New User section.
S.O.S
Trinidad and Tobago
LP/IP
It was a dead compressor the code had nothing to do with the activation/deactivation of the compressor also cleared the rest of codes the only code I have now is the brake booster code which is intermittent on a side note the customer said that the last tech added oil on the high side will this cause the compressor to fail as it has to push the oil (pag 46) through the condenser etc? thanks.
Tuesday,13,August,2019,20:16:24:50820
VCDS Version: 19.6.1.0 (x64)
VIN: WVWZZZ1KZ8M154124   License Plate:
Chassis Type: 1K (1K0)
VIN: WVWZZZ1KZ8M154124   Mileage: 144420km-89738miles
46-Central Conv. -- Status: Malfunction 1010
   Part No SW: 06F 906 056 JC    HW: 06F 906 056 FD
   Component: MED9.5.10       G00 0849
   Revision: 6AH03---    Serial number: VWX7Z0H224C0U5
   Coding: 0000075
   Shop #: WSC 00066 000 00000
   VCID: 73EFE4001273ACD794-8026
005241 - Brake Boost Vacuum System
               P1479 - 008 - Mechanical Failure
                    Fault Status: 01101000
                    Temperature: 75.0°C
Readiness: 0110 0100
   Part No: 09G 927 750 FB
   Component: AQ 250 6F           0844
   Coding: 0000072
   VCID: 76E9DD140101B9FFB3-8022
   Part No: 1K0 907 379 P
   Coding: 0017025
   VCID: 3F8778306EBB38B7A0-806A
   Part No SW: 1K0 820 047 HB    HW: 1K0 820 047 HB
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   VCID: 6BDFFC604A4374175C-803E
   Revision: 00H54000    Serial number: 00000000901587
   Coding: 01050E2700041500470A00000F00000000085D035C000100000000000000
   VCID: 71E3EE08686F9EC766-8024
   Component: Wischer 070308 021  0501
   Coding: 00038805
   Shop #: WSC 00066
10 Faults Found:
                    Fault Status: 00101100
                    Fault Frequency: 53
                    Reset counter: 26
                    Mileage: 133757 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.35 V
                    Fault Frequency: 11
                    Reset counter: 34
                    Mileage: 144069 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.65 V
                    Reset counter: 23
                    Mileage: 144057 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 8.95 V
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 250
                    Mileage: 144067 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.00 V
                    Reset counter: 35
                    Mileage: 144426 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.40 V
                    Fault Frequency: 91
                    Reset counter: 23
                    Mileage: 136975 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 8.65 V
00154 - Windshield Wiper Motor;  Passenger Side (V217)
                    Fault Frequency: 237
                    Reset counter: 23
                    Mileage: 136975 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.90 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
                    Reset counter: 23
                    Mileage: 136975 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 9.90 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 23
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.80 V
01598 - Drive Battery Voltage
                    Reset counter: 34
                    Mileage: 136507 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.35 V
   Component: 2M AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1T4AT-
   Coding: 0012877
   VCID: 3D7B023864B72AA7B2-8068
   Subsystem 1 - Serial number: 6332MSME2D156B05E
   Subsystem 2 - Serial number: 6342MSME38257834C
   Subsystem 3 - Serial number: 6351HSME132816570
   Subsystem 4 - Serial number: 6361HSME132869401
            002 - Lower Limit Exceeded - Intermittent - MIL ON
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
            010 - Open or Short to Plus - Intermittent - MIL ON
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           051 0100
   Coding: 0012021
   VCID: 78F5D32C0B15CF8FA1-802C
00576 - Terminal 15
00885 - Ignition Switch (D) Terminal 50
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
   Part No SW: 1K0 920 964 A    HW: 1K0 920 964 A
   Component: KOMBIINSTRUMENT 3HL 1212
   Revision: V0002000    Serial number: VWX7Z0H224C0U5
   Coding: 0016403
   Shop #: WSC 07737 898 62730
   VCID: 2B5F3C608AC3B4171C-807E
                    Reset counter: 35
                    Mileage: 144426 km
                    Time: 13:42:17
   Revision:   H07 01    Serial number: 290108F2001876
   Coding: ED807F060002021003
   VCID: 30652B0CA3E5D7CF29-8064
                    Fault Status: 00110100
                    Reset counter: 34
                    Mileage: 144426 km
                    Time: 13:46:51
   Component: IMMO            3HL 1212
01176 - Key
                    Mileage: 140655 km
                    Time: 00:15:31
   Component: J386  TUER-SG FT    1134
   Revision: 32008001    Serial number: 00000025988111
   Coding: 0000692
   VCID: 3B7F0C207AA324978C-806E
                    Reset counter: 23
                    Mileage: 144057 km
                    Fault Status: 00100101
                    Reset counter: 34
01706 - Switch for Mirror-Adjust (E43)
                    Fault Frequency: 58
                    Reset counter: 30
                    Mileage: 144244 km
                    Reset counter: 35
                    Mileage: 144426 km
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   VCID: 36691D144181F9FF73-8062
   Coding: 99900A0001060C7F2D04850560085F0380FCA0
   VCID: 030FB4C042D39C5784-8056
                    Fault Status: 01101101
                    Reset counter: 250
                    Mileage: 144426 km
                    Time: 13:53:49
   Component: J387  TUER-SG BT    1134
   Revision: 32008001    Serial number: 00000019488122
   Coding: 0000692
   VCID: 3C7D0F3C7FAD23AF85-8068
                    Reset counter: 23
                    Mileage: 144057 km
                    Fault Frequency: 23
                    Reset counter: 34
                    Mileage: 133757 km
00097 - Front Passengers Central Locking (Safe) Motor (V162)
                    Reset counter: 30
                    Fault Status: 00111000
                    Reset counter: 35
                    Mileage: 133773 km
                    Reset counter: 35
                    Mileage: 144426 km
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio ZSW       019 0035
   Revision: 00019000    Serial number: VWZ5Z7H6175703
   Coding: 0040400
   VCID: 2A5139648539AD1FE7-807E
                    Fault Frequency: 181
                    Reset counter: 22
                    Mileage: 136975 km
                    Time: 22:33:01
                    Fault Status: 00111011
                    Reset counter: 24
                    Mileage: 144067 km
                    Time: 00:03:18
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1120
   Revision: 11006001    Serial number: 00000002853556
   Coding: 0000144
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1120
   Revision: 11006001    Serial number: 00000002821316
   Coding: 0000144
   VCID: 3E79053469B131BFAB-806A
00935 - Electric Window Motor; Rear Right (V27)
                    Fault Status: 01100101
                    Reset counter: 250
End-------------------------(Elapsed Time: 01:53)--------------------------
S.O.S
Trinidad and Tobago
LP/IP
Anyone know the dangers of adding oil to the high side on a system that uses a denso 7seu17c compressor?
