Transporter T 5.1 BCM swap issues
Timmy
C?ID=345523
Hi guys,
hoping someone can help as I've been searching for hours to see if I could resolve this for myself first, to no avail, I have a 2013 T5 and I'm adding a Golk mk7 MFSW with standard button and cruise on the stalks, however before I sort all of that I'm having issues with the BCM swap, I've bought an 090 version but when it's installed I have no power windows and no indicators, when testing I can get the system to turn on the indicators but not the windows.
I'm not 100% that the BCM was actually out of a T5 previously but I'm hoping that it isn't goosed :(
Any help would be appreciated.
Thanks, Tim.
Here is my original 086 BCM Scan
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 56 0B
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GH    HW: 03L 907 309 M
   Component: R4 2,0L EDC   H45 5576
   Revision: 26H45---    Serial number: 00000000000000
   Coding: 01194012230400080000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GH 003003
   ROD: EV_ECM20TDI01103L906019FM_003.rod
   VCID: 77ABE8B21F41696FFB3-8022
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A60A9924A29174A96110
   Shop #: WSC 02736 790 49152
   VCID: 3A2D31866C53B407C4D-806E
   Part No SW: 7E5 907 047 BN    HW: 7E5 907 047 BN
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 7CA1F79E26674A37961-8028
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Fault Frequency: 12
                    Reset counter: 112
   Part No SW: 7H0 937 086 K    HW: 7H0 937 086
   Component: BCM T5GPM++4  H32 0407
   Revision: BM032001    Serial number: 0532 109130782
   Coding: E0A0393A0A212011002008102C2B8C540010430F60060000320000000000
   Shop #: WSC 02736 790 00000
   VCID: 3B23348263698D0FDFB-806E
   Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00H9LRT
   Shop #: WSC 02734 790 50316
   VCID: 353722BA45CD5B7F29F-8060
          B1000 1B [136] - Resistance Too High
   Part No SW: 7E0 920 960 G    HW: 7E0 920 960 G
   Component: KOMBI         H06 0605
   Coding: 460201
   VCID: 2D070ADAAD9D13BF51F-8078
12664832 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
                    Reset counter: 112
   Part No SW: 6N0 909 901     HW: 7H0 937 086
   Component: GW-K-CAN TP20 H32 0407
   Revision: BM032001
   Coding: 042300
   VCID: 70B9D3AE7AAF3E573A9-8024
   Component: IMMO          H06 0605
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8DC1C65CF3C48774D-803E
and here is the 090 BCM
Scan: 01 03 04 08 09 15 17 19 25 44 56 77 0B
VIN: WV1ZZZ7HZDH124033   Mileage: 177940km-110566miles
44-Steering Assist -- Status: Cannot be reached 1100
   Revision: 00H43001
   Revision: 00001010
   Coding: 0000000002
          U1111 00 [009] - -
                    Fault Frequency: 12
                    Reset counter: 2
   Part No SW: 7H0 937 090 D    HW: 7H0 937 090
   Component: BCM PQ25 Max4 H74 0726
   Revision: B9074001    Serial number: 0661 234140059
   Coding: E0A0393A0A212011002808102C2B8C510010430F60060000320000000000
   Shop #: WSC 05205 002 104857
   VCID: 2F3B10D2A71161AF633-807A
01326 - Control Module for Multi-Function Steering Wheel (J453)
                    Reset counter: 2
01516 - Terminal 30; Left
                    Reset counter: 2
00927 - Terminal 30 (Right)
                    Reset counter: 2
   Coding: 460201
          U1111 00 [009] - -
                    Reset counter: 2
13638912 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Lenkhilfe: keine Kommunikation]
                    Reset counter: 2
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H74 0726
   Revision: B9074001
   Coding: 702300
                    Reset counter: 2
                    Reset counter: 2
                    Reset counter: 2
Address 44: Steering Assist
Address 56: Radio
Address 77: Telephone
racofuy
New Zealand
C?ID=197081
I've done this on my van. Fitted a Passat CC mfsw. Details are a little vague but I do remember running a lin bus wire for the steering wheel button illumination and swapping the bcm T5's are Polo 6R based electronics wise but I'm pretty sure I used a highline T5 bcm as I installed cornering lights at the same time.
Unfortunately I'm not near my van till the weekend so can't confirm till then what part number I used
racofuy
New Zealand
C?ID=197081
Come to think of it an 087 bcm is highline and will support those functions
Timmy
C?ID=345523
Thanks racofuy, I've not got to the wiring bit yet but have all the instructions for it, it's the fact that the indicators and windows aren't working after putting the 090 BCM in, I'm doing it in steps so as not to bring too many potential issues in in one go.
dnoermann
C?ID=358118
If you change the BCM you need to copy old Values in Coding and Installation-List of CAN Gateway (19), too.
From your scan i see that coding there was not copied from old to new.
Installation List is not visibly in Autoscan, but from the Erros it looks like it is configured wrong, too.
Before:
Revision: BM032001
Coding: 042300
Now
Revision: B9074001
Coding: 702300
Timmy
C?ID=345523
Thank you dnoermann, I'll take a look at this as well, it would also appear that I need to add two wires to the instrument cluster for the canbus and extra power as I have got a 'max' BCM.
Learnt a hell of a lot over the past few days :thumbs:
